Active Volume Control in tube preamp?
I have seen only a few instances of global feedback as the sole method of volume control for a tube amp. Any reason it isn't used more often? What about local feedback?
I know that feedack is used to tune the frequency response in some amp, but care needs to be taken with poles, phase, etc- none of which I could really account for in any of my projects. Anything I did would need to be tuned by ear, which might be OK.
FYI- I have a post about an "ARC" tube preamp if you are interested in where I'm going with this.
Question about 7C tone rotary switches
Looking for an answer to something that has puzzled me for a while about the Marantz 7 preamp stepped tone controls. In particular, the schematic shows the bass rotary to be a twin deck switch and treble rotary to be a single deck. Photos of the treble unit shows it has a phenolic disc at its rear connected via standoffs but the disc is used for terminating the other ends of the RC components only and is not a contacts deck.
Photos of the bass rotary switch shows it to also only have a phenolic termination disc at its rear and I'm not seeing a switch deck. All the photos I've seen show a cutout hole at the rear disc of both treble and bass rotary switches.
I would love to hear from someone who can look at these switches and let me know if I'm just not seeing the second switch deck of the bass tone controls or if the actual switches do not match the schematic?
6n6p for tremolo
Hey guys!
I have a couple of 6n2p (Russian 12ax7?) and I wanted to add a bias shifting tremolo to a mic preamp based on two 6au6 pentodes that I built out of an old Akai tape recorder.
Im a bit frustrated after hours of messing around with it.. Just cant get that tube to oscillate😕
I tried different feedback caps and resistors for the RC stages, and also experimented with the cathode cap and resistor values and still nothing..
I have 320V for a B+.
Would appreciate any help to get that LFO up and running 🙂
Help with Infinity RS6000
Long story short, one of my friends gave me the old Infinity RS6000 speakers from his dad since he already has a pretty nice setup and I'm the one that's always experimenting with things and building/restoring amps. The RS6000s won't go into my main system, but I still want to get them up and running and try to get the best out of them that I can, within reason of course.
First thing on my list would be to refoam the 2x 10"-woofers and the 1x 2" polydome midrange per speaker and of course get the Emit-K's serviced.
After that I'd replace the electrolytics in the crossover and clean the pots of the speaker controls.
Maybe I'll also add new speaker terminals and also a second set for bi-amping them...
Sounds good so far? Would the RS6000's even be worth the effort?
For all of this and maybe more I would greatly appreciate any info/experience about/with the Infinity RS6000 anyone on diyaudio.com has. Especially how hard (or dangerous, considering many Infinity speakers are amp-killers) they are to drive and how low they dip, how they fit into the Infinity speaker-lineup (I guess somewhere in the middle but surely miles away from the IRS and the Kappa line), what you think about them sound-wise, if they are even worth restoring,...
I couldn't find much info on the web about them, but at least they are listed on infinity-classics with their spec-sheet http://www.infinity-classics.de/technik/manuals/RS_6000_technical_sheet.pdf
Power supply for external boxes
You probably all have this problem. You have a phono preamp, a DAC, a small streamer, or even a turntable with an outboard motor, and they're all powered by one of these wall wartz, and all the manufacturers are doing there darnest to use a different voltage, 12, 15, 18, 20...and often even AC.
So I would like to build a sturdy, low noise power supply, with say 4-5 outputs, each individually switchable between voltage. So I can connect all these boxes to 1 power supply, by making a small adapter cable to convert the socket.
Has something like this been attempted or done ? I'm having some trouble finding the correct search tags to narrow down the results.
Thanks, Pete
JFET - Mosfet Amplifier inspired by GoldMund Mimesis3
Inspired by the famous GoldMund Mimesis 3, I was intrigued with a naughty idea..
I changed the topology final stage from source follower to common source. With this change, there is a slightly more gain going on this stage and give a more punchy bass. This is according to my personal opinion based on my experience in building solid state power amplifier for more than 20 years, Nevertheless, if this opinion is wrong, please feel free to criticize me 🙂
Minor improvement in the input stage also made, I added variable resistor (trimmer) on the CCS circuit which is, at least on my personal seen, never found in any commercial amplifier. However, being a DIY who has a lot of curiosity and naughty ideas 🙂, I let DIY to spoil their ideas with a trial and error in order to obtain a specific or special character of sound which is most appropriate to personal taste.
With adjustable CCS, we can play with various idle current of differential pairs of 2SK170 (LSK170), from 0.8mA - 3 mA. What is the difference? It is difficult to explain in words, but I just give you a clue : different character of vocal, mid and bass.
Well in the mean time, please enjoy the schematic 🙂
Best regards form Jakarta, Indonesia
NAD C521BEE cd drawer problem
Hi all. I'm getting problem with the drawer of my NAD C521BEE player. Instead of the normal just one quick press on the "open" button to open the drawer, occasionally I have to keep on pressing the button for maybe 5 or more seconds before the draw comes out. And at times, have to do this the second time to open it. Moreover, the drawer sometimes closes half-way and comes out again, and has to be closed by pressing the "open" button again. I have replaced the rubber belt and also cleaned with electronic cleaner the "open" button. Also, the socket linking the control PCB to the main PCB circuit board has been cleaned the same way. However, problem still cannot be fixed. Grateful for solutions to the problem. Thanks.
Current measurement in choke input supply
Hi there,
question: In a choke input supply, would it make sense to measure the DC current in the 1st choke and assume that this is the average of the total current in the transformer winding?
As far as I understood the theory, the choke current vs. time should consist of a DC component and a (symmetrically) superimposed AC part...
Background: I almost killed my tube amp by operating it during elevated temperatures last summer. We had 40°C and above outside, and in our flat directly below the roof temperatures reached >30°C. While the transformer was chosen with very narrow margin in terms of power requirements and operating temperature, everything went well until this summer. The 10°C increase in ambient temperature pushed the transformer over the edge, a plastic interlayer insulation started melting and turning brown while releasing an unpleasant odor.
As there is not enough room to throw in a larger EI core, I am going to switch to a toroid. But before ordering the expensive made to order piece, I'd really like to confirm the theoretical current consumption to have enough margin this time.
Rundmaus
Velodyne SPL 1000 II distortion
Hello to the group.
I have inherited TWO of these subwoofers that have seen very little use. Unfortunately, they both have severely distorted output. They were driven by a McIntosh MX135 preamp with very long (30 foot) runs of small gauge shielded phono cable thus probably very low input signal strength with a lot of noise. Both failed simultaneously and have exactly the same symptoms. Power on just fine, drivers (subwoofer speakers) are intact, do not rub, and resistance of voice coils are the same. Both were plugged into surge protectors and no known lightning, etc. I have a feeling that the chronic distortion blew something in the sub preamp, but without a schematic to be found anywhere, this amp board is very difficult to troubleshoot. I have a shop complete with all manner of test gear including signal generators, digital Tektronix scope, multimeters, rf voltmeters, etc. I am pretty handy having been a ham for 45 years. One of my hobbies is restoring Collins radio gear. Any suggestions, oh gurus, would be beneficial. If I can fix these things myself, I can avoid about $250 apiece for repairs plus shipping of the amps . I have a feeling that the problem will be identical in both units. Thanks in advance for the assistance.
Rebuilding a 1967 Zenith stereo cabinet. Need some help with Speakers
Hi guys,
I'm working my way through the search results now, but wanted to start a quick thread to see if you could provide some help.
My wife found this cool little cabinet, and we've been interested in building a vinyl hi-fi setup for a while now.
The bad news is that it's mostly stripped, which is kind of good news, because it gives me the freedom to create my own design in a lot of areas.
My plan is to go modern in some areas, like with a U-Turn turntable, but keep some cool vintage touches, like with a Marantz 1030 amplifier.
My question is regarding the speakers. The wiring is stripped, and one of the speakers is trashed, so it looks like I am going to have to rebuild everything. I'd like your input on replacement parts to rebuild the speaker baffles. I can build a new one to fit different components if that's a requirement, i'm fairly handy.
But things like brands, sizes, compatibility and crossovers are currently above my pay grade.
pics:
Cabinet:
Gutted insides and speakers:
b500 bass
hi,
i build a 2 channel b500 from apexaudio but i get small problem. for input i use apexaudio another amplifier input schematic. but there is one thing i see i am losing bass signals in the amplifier or in the input board.
there is schematics. for input it start with 10k resistor and then 100pf capasitor. this can be work like a high filter and cuting my bass signals? and another thing i want to learn. that 2 10k resistors at the -in and + in, if i change them to 1k is it effect to my signal tone? i just want get more volume from amp.
and if some one make b500 amp do i really need a input buffer like that cause b500 have limiter on it. and signal will be coming from mixer. i feeling that input schematic cutting too much signal.
sory for bad english and thank you for al answers.
marantz cd6006 power supply issue
Hi all , i'm a bit stuck with a power supply , i have this marantz cd 6006 player i am trying to fix , there seemed to be an issue with the drive motor but i think it was down to the power supply failing , the main transformer is separate , i get 240v at the main transformer plug but it drops to 0 when i plug it in , i thought the transformer could have been shorted but it seems ok .
When i connect the transformer directly to the mains and it works ok without getting hot .
Here are some photos of the psu , i have checked all the caps on the power board , they seem fine . and the 2 transistors on the black heatsinks , they are ok , The third black heatsink is a voltage regulator (7805A) there is no voltage getting to this though ..
If anyone is familiar with this board and could point me in the right direction i would be very grateful .
Dropbox - marantz psu.jpg - Simplify your life
Dropbox - Photo 25-01-2020, 10 10 57 am.jpg - Simplify your life
heres the back of the board
Dropbox - Photo 28-01-2020, 6 49 13 pm.jpg - Simplify your life
  • Locked
China Delays
Do not order anything from China unless you have a month or two to spare. You aren't going to see it anytime soon. I ordered something going on 3 weeks now and it hasn't left China and the T-number from DHL has no record yet.
There are issues with getting the goods to port and also a reduced number of ships for those goods.
Just a heads up, if you are buying anything that has to come from China, you are in for a long wait.
opamp IS, CFP VAS, lateral FET OS
Several moons ago I designed a PCB for one of my experimental amp designs, and at some point braved ordering parts and sending the pcb design off - today the PCB arrived in the post and I've spent a fair few hours putting it together and doing the very first, low power, tests.
The principle is to take advantage of an opamp as both input stage and to close the feedback loop.
The limited voltage output of standard opamps means using a voltage amplification stage to magnify the opamp output somehow, and I've selected a class B CFP stage with gain of about 5, using 4 small-signal transistors.
The output stage is a pair of Exicon lateral MOSFETs, avoiding the issue of thermal compensation for the bias - less complexity with a new design seems a good idea.
R6 and R14 form the feedback network for the top CFP pair, setting the gain, and the bias voltage is amplified along with the signal by the CFP sections. The bias arrangement is a bit rough and ready I think, but emulated OK.
The implementation is nearly all surface mount, on a board 3" by 1.5".
So far I have got the amp basically working, with the minimum of bias needed to prevent instability, about 15mA are taken overall I think. The bias pot I chose was 11-turns which turned out to be a wise choice, but I had to hunt around for a small enough screwdriver to adjust it!
Unloaded it seems to work fine so far (using siggen + 'scope), I need to arrange some form of heatsink before going any further. Its always a relief when a new board basically works without modification.
This design predates my opamp-tripler circuit (see this posting: https://www.diyaudio.com/forums/sol...stacking-voltage-operation-4.html#post5954865)
I will be building that on a PCB that's also just arrived at some point (parts need ordering). It will be interesting to compare the two techniques for leveraging an opamp as integral part of a power amp.
In retrospect I should have use DIP8 for the opamp in this design to allow experimentation with different opamps.
I think the choice of the discrete transistors is fairly non-critical in this arrangement which is a bonus as good audio transistors are getting harder to source. Great opamps at bargain prices are too good a resource to ignore!
[ oh yes, and I know the input network is DC coupled, I think I forgot to fix that ]
Tube Change: Regulator and Rectifier
Hi All
I have a bit of a unique setup and can't find a straight answer for the 300B's I have a preamp that used a 300B for a Rectifier and a 12ax7 & 300B for the regulator portion. I know its basically using a Ferrari engine in a pinto lol
Question, swaping out to lower end 300B's for the rectifier and regulator, will that effect the sound? It came with a pair of factory matched and tested PSVane WE300B replica's. Chaning the 12ax7 to a mullard f91 or others makes a lovely difference in the sound.
Thoughts on swapping out the very expensive 300b's would be nice please
Rockford 2500.1 BD
Good morning Perry,
I dared to open another thread to see if I can finally solve this Rockford or throw it away. The amplifier is in protection, without rectifiers the drive circuit is correct since that verifies it under your instructions and I get a square wave in all the output mosfet, I have rail voltage and the correct voltages in the regulators, as I can do to find out where exactly protection comes from?
FETs switching noise at the output
Hello forum!
I have Jensen 2000.1d D-class amp, which have output switching noise which is present at the output relatively to power source ground:
Blue: VS pin of IR2010S,
(Yellow) (+ terminal).
And at the speaker terminals (between speaker ground and + terminal) I'm getting sine wave ~150khz and 4v rms, (it's without any signal at the input).
Is there any way that this could be normal? Amp is working when signal in, though.
I know that some D-class amps self-oscillating, but thing is that before it wasn't any of that noise or sine wave at the output.
Before that all the problem was with blown some of output fets and one gate diode, I've changed them, but After some time turns out that it was also transformers failure, because all irf3205 PSU fets and couple of output 640n's blew up. I've changed them. And now I see this picture.
Amplifier photos jensen amp — Yandex.Disk)
how do you measure acoustic performance of planar?
Hi, I am not experienced with loudspeaker measurement.
I have done some of my boxed speaker following the guide for REW prepared by the author of Vituix cad.
The measurements i took from the Magnepan are full of peaks and null for relatively close measurements. I used gating, and i think i did it right.
The only measurement that seems to make sense is from 8 feets, non gated.
But I know this includes too much of the room, non-quasi-anecoic.
How do you measure, and what are you looking for in the measurement?
Hi all, any tips?
Recently I've been lucky enough to stumble across some Kef Reference 104ab's, recently restored and painted in a very striking orange! Weird color choice, I know, the picture included can't do justice to them. Lovely orange at night, almost red in ambient daylight. I am currently driving them with a Simaudio Moon Ace, which is a 3500 dollar amp. I'm a high school student with a tight budget in need of a good amplifier, with a per channel minimum output of 20 watts. What would be a good combination for my Kef speakers? (budget max of around 200 to 300 dollars)
Personally I have been looking at the Duson PA75 Amplifier, which is to my specification, but I have a very limited knowledge regarding older amps.
Recommendations as to where to start a thread with a question like this would be great!
Happy listening and have a great day!🙄
PCBs, kits, transformers and film caps
Help me with my New Year’s resolution: finish one-project-at-a-time. Instead of buying everything I needed to finish a project, my bad habit of collecting exciting, new parts, passives and PCB’s as they appeared has left me with a cabinet of kits missing critical components. I want to sell the unused hoard to finance the missing pieces.
The prices listed are what I paid, less, or my best guess. All are unused/unsoldered and untested. Since I want to make fewer trips to the post office, a discount for multiple items or reasonable offers for bundles accepted. USPS shipping and hence the continental US strongly preferred; shipping will be calculated per order. I can send/post pictures as needed.
PCBs
1 Diyaudio F4 pcb, $12 for a stereo set
1 Pass Labs B1 stereo PCB, $14
Transformers
1 Antek AS-1212, 100VA, 12V output. $12
5 x Avel Lindberg 40/3010 47/400Hz potted transformers, 115V input, dual 9V@2A output. NOTE: THESE ARE 400Hz TRANSFORMERS. You cannot plug them into a standard 50/60Hz wall supply. Free if you pay shipping.
See pictures at Power transformers, Plitron and other)
Caps (take them all for $50)
1 Hovland MusiCap, 1.0 microFarad, 200V, $3.00
2 Solen MKP-FC, 1.2 microFarad, 400V, $1/ea
2 Kimber KAP, 0.1 microFarad, 600V, $6.00/ea
4 Kimber KAP, 0.022 microFarad, 600V, $6.00/ea
2 MultiCap, 0.10 microFarad, 400V, $12 for a matched pair
4 Rel-Cap, RT series, 0.022 microFarad, 600V, $6 for a matched pair
4 Wima MKP 10, 0.22 microFarad, 630V, $1.00/ea
2 Vishay/Sprague Orange drop, 0.68 microFarad, 100V, $0.75/ea
2 Vishay/Sprague Orange drop, 0.22 microFarad, 100V, $0.75/ea
2 Vishay/Sprague Orange drop, 0.22 microFarad, 200V, $0.75/ea
2 Vishay/Sprague Orange drop, 0.1 microFarad, 600V, $0.75/ea
4 Vishay/Sprague Orange drop, 0.47 microFarad, 200V, $0.75/ea
2 Vishay/Sprague Orange drop, 0.1 microFarad, 400V, $0.75/ea
Other
1 IcePower 50ASX2, 50W Class D stereo amp, non-bridgeable version, with wiring harness, $65
FREE if you order other stuff
2 Raspberry pi rev B 2011.12, $9/ea or free
SOLD
SOLD -- 1 sets Diyaudio F4 pcb
SOLD -- 2 sets Peter Daniels F4 pcb
SOLD -- 1 Modified Linkwitz Crossfeed pcb (stereo, headphone use)
SOLD -- 2 Peter Daniels/Brian GT Mini Aleph pcb
SOLD -- Diyaudio Mezmerize older version), stereo pcb
SOLD -- 1 Zen v9 kit with Peter Daniels Zen v9 pcbs, 2 mono boards, 2 power supply boards, and a matched quad of LU1014D
SOLD -- 2 F5 kits, Peter Daniels stereo board, Mofsets - IRFP240/9240; Jfets - Linear J74/K170; Zeners - ZTX 450/550) from Hannes
SOLD -- 2 Diyaudio BA Gain Stage kits, stereo board, 2 matched pairs 2sj313/2sk2013 from Buzzforb
SOLD -- 1 matched quad Toshiba 2SK369GR, IDSS 8mA (grade B), from Hannes
SOLD -- 8 Vishay/Sprague Orange drop, 0.22 microFarad, 400V
SOLD -- 1 Plitron 077017000 2107 standard transformer, 300VA, dual 115V input, dual 30V secondaries
full range line source - help needed!
hi all,
i am considering a full range line source. i'm wanting something that can be eq'd as low as possible. (or perhaps they can go as low as 20hz w/o eq? i'm a novice at this, i dunno). ported or sealed is fine.
anyway, here are the driver specs; i would be using 15 of them.
• VCdia: 11/16"
• Le: 0.42 mH
• Impedance: 4 ohms
• Re: 3.52 ohms
• Frequency response: 45-18,000 Hz
• Fs: 45 Hz
• SPL: 91.3 dB 1W/1m
• Vas: 1.1 cu. ft.
• Qms: 4.25
• Qes: 0.36
• Qts: 0.34
• Xmax: 2 mm
• Dimensions: Overall diameter: 5-1/16"
i'd most likely wire 5 in series; three sets then paralleled for 6.6 ohms total. so, my question is what's cu-ft of the box (or sonotube) that i need to build?
tia,
doug s.
One Electron BFT-1B power transformer
$160 shipped to USA addresses..great shape...no issues
Specifications
Primary: 100, 110, 120, 220, 230, 240 volts at 50 to 60Hz
Secondary #1: 770 VCT @ 360 mA with a set of taps at 520 VCT, capacitor-input filter load
Secondary #2: 5.0 VCT @ 4 A, resistive load
Secondary #3: 6.3 VCT @ 9.6 A, resistive load
Secondary #4: 6.3 V @ 4 A, resistive loadSize: 3.75" x 4.5" x 6" (95 x 114 x 152 m
https://www.tubesandmore.com/sites/default/files/associated_files/p-tbft-1b.pdf
Transformer testing: Personal Journey
Recently I have asked questions about AC coupled OPT for valve circuits, and well...let's be honest...I got a little frustrated by the seemingly rule-less selection of OPTs by impedance ratio, and then flamed slightly for quoting my transformer impedance as being the same as the impedance ratio...
So to educate myself, and hopefully show myself that I am not as dumb as some of the more simple comments would imply, I am investigating a number of transformers for suitability in my headphone amp circuit.
Now I have stated that I believe my valve circuit likes a reflected load impedance of 15k to shine, and deliver good THD results (<1%) @ 1kHz.
This was based on the calculated Impedance Ratio of a RS 30VA toroid (196-505):
N = 6.7
N^2 = 45
45*330R = about 15k with 330R headphones.
Q1: But what relevance is the Impedance Ratio?
It defines the output voltage, hence power output
Q2: Does measured Impedance Bandwidth stand close to impedance Ratio?
I am testing this
Q3: Which parameter is relevant here? Z ratio or Z BW? Both?
I hope to find out
Mounting ICEpower 500asp in chassis
I am assembling my first stereo ICEpower 500ASP class D amp, and I would like to check if there is a problem in mounting as shown in the picture, without standoffs.
My idea is to add some thermal paste between the amp's heatsing and the chassis base, which is stainless steel so not the best thermal performance, but still better than nothing.
Looking forward to your reply.
Thanks!
Rotel ra-940bx tone switch
Hello,
I have a Rotel ra-940bx whose left channel works intermittently. I noticed that the tone switcher might be the cause of the dysfunction as if I play with it the sound sometimes comes back.
Following the suggestion of an amplifier repairman, I tried to spray some wd-40 lubricant and it worked for a while but now the problem is back.
This amplifier is not particularly valuable, but I am kind of fond of it. I would like to try replacing the switcher, to see if it fixes the problem.
I am in no way an expert and I am a bit clueless on where I can find the parts. I searched a bit on the internet but the shops I found did not have the specific part (I would have been surprised otherwise, to be fair).
I would be grateful if you know any shop that might have these type of things or if you could point me in the right direction for a more successful search.
Thank you
Duccio
Hello everyone, a beginner question.
Hello everyone. I'm an ee student from Turkey. I've a bit of experience in digital electronics. Made some simple analog circuits as well. Electronics have always been my hobby and searching on google about my last project led me here🙂
I'm looking for an amp to drive a 20" 4ohm 150w max cont subwoofer in a car. But i got confused after research. TDA1560 seems like an easy way to drive it but i'm not sure if it will suffice in terms of power. My goal is to drive it around 100w to stay away from limits while getting best sound out of it possible. I understand i need to boost voltage level to achive that power, which led me to boostor on this forum.
What amp circuit do you think would be appropriate for this project to use with boostor? Simpler the better. Also what kind of input filter would i need to protect it from cars noise? And one last thing, do you think it would worth to build this sort of system as compared to simple TDA in terms of better bass response? Thanks for reading🙂
lucky goodwill find... vintage Vitavox DU120
A friend of mine bought some end tables for his new appartment at 5$ each.
inside were these 2 near mint Vitavox DU 120. Made in england and apparently still in production. (We can get some vitavox units here in canada for roughly 6k a peice.)
Was wondering if anybody has any comments/ideas on what I should do with these.
I was thinking of making some sealed old style boxes to go with my 60's turntable and 20watt chip amp and hopefully replacing the cap on the tweeter somehow. (although I haven't looked into if that's possible or not)
But really I don't know. These look amazing and should be treated with respect in my opinion.
Regards.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Horns and Compression Drivers - Screw thread too tight
Greetings.
A while ago I bought some horn flares with 1 3/8 inch screw threads. They were cheap and I thought they might come in handy.
Today I bought some cheap piezo drivers (3 different kinds to play with) planning to screw them into the flares and take some measurements to see if they were any good. Party speakers maybe.
Well, the threads are so tight that I could only screw the first one in about half way. The effort required to UNscrew it was so great the body of the piezo driver broke off in my hand. One driver down and a horn flare with half a tweeter jammed permanently into it. Boo.
So I tried a different driver, very carefully, in another horn. Same deal. So I carefully unscrewed it, applied some vaseline and tried again. Went in easily, about half way, then stopped. Very carefully unscrewed it again, with much effort.
I have now tried half a dozen driver / flare combinations, all the same.
There are no obvious defects in the threads of the drivers or the flares.
Can an experienced soul tell me if this is par for the course (plastic driver thread into plastic horn thread) and if so, what's the trick to getting them in and out.
If this is unusual, perhaps someone might suggest a fix.
Perhaps I just bought dud flares, which is pretty sad because I have dozens of them.
Any advice gratefully received.
Thanks,
blakk
NAD S100 preamp restoring/upgrading
Have a NAD s100 preamp that i like a lot but after 20yrs of use it needs some service.
Have replaced some aging Elna caps (down to half value..) also have some problems with the potentiometer and thinking just replacing it with a new one but hard to source (Alps 20x2 rk27 with motor) I can only find 10, 50 and 100k replacements.
I wonder what would happen if i replaced it with a 10K version? Or a 50K?
Input imp unbal. is 75ohm and balanced 100ohm according to another thread.
Another questions is about the psu and diodes, original it has the IN4003 and i happen to have some BYV26C old stock from Philips(vishay) https://www.vishay.com/docs/86040/byv26.pdf
laying around and what i can see it seems like a good replacement and maybe even some improvements? And something i haven't seen before it's the 2x ceramic caps they've placed before the diodes? Can i replace those with polyester caps i have. Bad feeling seeing ceramics that's all...
Servicemanual: Login - HiFi Engine
Roland JC-120
I have a Roland JC-120 (serial# 728284) that Has a relatively loud 60Hz buzz through the speakers. Also, no audio. None of the fuses are blown. I need the correct repair manual for that version. Also if anyone has any suggestions on what may be wrong, I'd really appreciate it. I'm thinking rectifier diodes or filter caps. The bridge rectifiers in this version are individual diodes as opposed to a single bridge rectifier brick.
Thanks,
Ron
* edit: Bridge rectifier diodes and Filter caps all test okay.
Anyone familiar with NS10 tweeters disassembly?
I wonder if anyone ever disassembled Yamaha NS10 tweeter for dome replacement etc. My dome seems to have come unglued partially on one side. When I run frequency sweep it buzzes at certain frequency but when I push lightly on the dome side edge it goes away.
I've started to open it up, took out the three screws but it wasn't coming apart so I've stopped because I have no idea if the front plate is also glued together, thus me forcing it apart could rip out the coil and who know what else is in there.
Any advice would be appreciated, thanks.
Headphone tube amp components upgrade
Hello folks!
Im doing some experiments on tube circuits. I have this schiit audio valhalla fully tube headphone amp. I would like to know which kind of upgrade or customization i can make on this. Is it possible to get a cleaner sound or refined sound changing, for exemple, the capacitors for better quality ones? Or maybe the transformadores?
I would like to get the best out this circuit, any tips for upgrade?
Thanks!
Electromcompaniet AW100 Component Identification
A few years ago, my AW-100 developed an intermittent crackle in one channel that was annoying enough to be noticed, but infrequent enough to be really difficult to diagnose. I did the dry joint and freezing spray check. No luck.
I sent it to a technician who tried to get the service manual and lo and behold, EC stuck their Serial Numbers onto the amps with a paper sticker which has been lost to antiquity. The technician sent it back to me, and I have not had luck finding a matching schematic so far. I think this is a really early AW-100, based on the lack of PCB markings and the dried flux residue everywhere.
I was told to try replacing all the output stage Electrolytic Caps, which seem like low hanging fruit. But then I saw these mysterious components labelled: "1000 H" and "470 H". Does anyone know what are they, and if so are they worth restuffing?
1 buffer for 2 channels or not
Hello.
I need to buffer 1 signal to 2 channels.
I need help to determine if I can use a single buffer opamp to send the buffered signal to 2 different channels ?
What is the optimal setup for lower noise ?
Thank you.
EDIT: I will not use the lt1018 it just for illustration purpose.
Fmu22u replacement in Skar RP-4500
I have a Skar RP-4500.1 with blown Power section which uses IRF3205PBF and dual series rectifier FMU22U.
The FMU22U's were blown to shreds. I was hoping ether of the attached datasheet would be a suitable replacement. I don't mind the package style because the heatsink will have kapton tape as an insulator.
Phantom Center Speaker w/L-pad & bass blocker
I am looking to add a center speaker to my car audio system. After all I've read I think the Left + Right will be the best way to go for this build. I want to include a L-PAD and a capacitor to lower the volume and to block low frequency because it will be a small 3.5in speaker. How should I wire this??? My thought is that the L-pad would be in line with the positive speaker wire with terminal one grounded to the chassis, terminal 2 from the left positive speaker lead, and terminal 3 to the positive of the speaker. I think the negative of the speaker would go directly to the right negative lead. Does this sound correct? Where do you think the bass blocker should be placed? Before or after the l-pad? Any other suggestions would be greatly appreciated and I would love to start a conversation about different options. Thanks!!
Subwoofer TL in a sphere?
I have a 22" fiberglass sphere that I would like to use as an enclosure for either a sub or a bass driver BUT as a transmission line. I have been trying to imagine the (internal) design problems that would come with this project. Since I have never built a TL but only modified a pre-exisiting one, I am having difficulties with the design of the internal chambers. Most TL cad programs are for boxes (of sorts) with at least 2 parallel walls.
Does anyone have any experience building a TL in a sphere? Any help would be appreciated.
Thanks in advance.
Seas U22REX/P-SL any good in a ported 2way
Hi all,
I'm retrofitting/upgrading/rebuilding some speakers into existing 36L ported cabinets. I have a preference for rigid cones with proper pistonic motion and avoiding crossovers in the 300Hz-3kHz region. Rigid (metal) cones won't allow for this in an 8" woofer and I am limited to 8" woofers by the existing cabinet. I had pretty much concluded the only way to get what i want is to go 3 way, but this does complicate design and crossover significantly. (will be driven by 2 way active crossed amp, so i would have to passively cross the mid/tweeter if i went 3 way)
Then i found the Seas U22REX/P-SL, which professes super duper frequency response all the way to 4kHz, while (presumably) retaining a nice stiff woven cone. problem is is was custom designed by seas to be a lower mid in an open baffle Linkwitz design, very different to what i'm proposing and i'm wondering if it would even be suitable in a ported 2 way.
Does anyone have experience with this driver?
suggestions welcome 🙂
Thoughts on this "ARC" preamp circuit
I bought the following. If there is any interest, I will post my project ideas. I started a lengthy description of my needs and design goals. It seemed a bit much for an introduction. I'll post that tomorrow.
First- most of this project is unnecessary. It is for fun, although I do need the switching capabilities of a preamp without the gain. My amp is a Volksamp Aleph 60, 60-100 watt clone with a sensitivity of 1.25 v to reach full output depending on the speaker load. Everything I have puts out more than 2v. It has a 52k input impedance with the balanced inputs.
Second- I have no issues using a "clone" like this without consent from the manufacturer as there is nothing here that hasn't already come in circuits designed 80 years ago. You shouldn't be able to patent physics (yeah, I'm looking at you, Bose). I'm also not convinced it is actually a clone of anything.
Third- I'm posting because the actual components in the kit look decent and I'm pretty impressed with the quality of the whole thing for the $125 I paid for it.
I'm willing to entertain heavy changes but have no issue with the cathode follower as an output topology. Although that cathode resistance of the 3 parallel resistors seems super low, but more on that later.
Active volume control using feeback?
Thanks.
  • AudioResearch-ARC-Tube-Preamplifier-XLR-RCA-In-Out-12AU-ECC82-6DJ8-ECC88-_57.jpg
Phenolic Resin (Lab Top) Audio Rack Shelves
I once made an audio rack out of salvaged maple butcher block for shelves and small aluminum I-beams vertical posts. Problem is the old maple started to split because of past improper storage.
I need to rebuild the rack with new wood or use a different material.
I was thinking of trying phenolic resin or epoxy resin shelves/tops, the same thing used in lab tables and countertops.
I might be able to source some used from the local university property disposition warehouse that is open to the public on the cheap, but would have to cut it down.
Question is, would this be a good material to use?
Uncutable safely?
Too weak to hold a lag bolt which is how my old rack was held together?
It will not sound good as it will suck too much energy out?
I see that a few high-end racks use it as trimming or some special composite mix of their own that seems to be similar.
I've also read that some high-end loudspeaker makers use it in their enclosures for it's anti-resonance qualities.
I do not see anyone doing exactly what I have in mind, just beating the bush to see what flies out.
Top 5 Materials To Consider For Your Lab Countertops
Are there any HPL (High Pressure Laminate ) audio rack shelves in use?
WTB Thiel SCS tweeter
Hi everyone 🙂
I have a pair of Thiel SCS monitors that I just picked up that need replacement tweeters
The SCS uses a coax driver from Seas (the 17RE series, 170mm , 2 way )
The tweeter uses a 26mm fabric dome, with neo magnet that fits in the voice coil opening- the woofer cone acts as a horn for the tweeter
The tweeters are easy to remove with only a slight push from behind
*See attachment for driver/ tweeter specs
The old tweeters work but have very low output. I do not know if they have been over-driven or if the ferrofluid has become gelled.
* Not a crossover issue
Anyone have a pair of tweeters?
Much thx
SW
Hartke BA900 Bass Amp Combo - Transformer Needed
Hello there,
1st post here for me and hoping someone might be able to help - I have a Hartke BA900 bass combo amp. Great little unit, has done me good service for years since I bought it s/h, but died yesterday - no sign of life.
Had it to bits to find both inline T1.6A fuses blown, so got some new ones. Blew the new ones straight away. Diagnosing the fault seems to point to the (pretty big and possibly torrodial) transformer being the issue - when I disconnect the xformer o/p from the PCB (i.e. just the AC jack, power switch and xformer in the picture) it still blows the fuses so dont think its the amp board.
Disconnecting the orange wire which runs to the xformer input stops the fuses blowing, switch neon stays on but no amp noise or action at all. So I think the winding is probably shorting.
I cant find *any* trace of Hartke online - old post pointed to Korg, who told me helpfully today that its Hal Leonard Pro Audio who support these... HL dont have a service dept to phone, just proaudio@halleonard email - tried them and got a bounce back from their server - duff address :-(
Anyone got any idea where to get a replacement xformer at all? Seems a real shame to scrap the amp for a 10 min swap out job.
Many thanks for any help you can give,
Cheers
David
Which DAC kit to use with nanoDIGI 2x8
Hello people
I am looking for some simple DAC (min 24/96) board/kit which I could use in a chassis with nanoDIGI to use all digital signal DSP. Plenty of them on ebay and other diy electronics shops, but as said..I have no idea what to look for.
I want to bypass the double DA/AD when using a miniDSP 2x4/2x8/4x10 etc.
Just a caution...I have no idea about all the DAC chips, and have no idea what is good or not. i have seen some used a nanoDIGI with 4 x Fiio D03K as a full digital processing. Found it on a Linkwitz Lab site, powering the LX521
I would like to have naked boards, which I can put inside some chassis. Also the reviews on the Fiio are quite contradictory. Some say good, some say bad. If I could match the DACs in other miniDSP boards, that would be enough
Please easy on me 🙂
Thank you all
Matched quads of Toshiba 2SK1530/2SJ201
Unused/unsoldered NNNNPPPP matched quads (8 pieces) of Toshiba 2SK1530/2SJ201 for your Pass amp project(s). Purchased several sets from the F5X group buy back in 2013, but it's not fair for me to continue stockpiling transistors, so I'm selling the sets I don't have plans to use.
Two sets available. $80 plus shipping.
The measurements for the specific devices and sets I'm selling are attached so you can see what sort of matching was involved.
DIY TDA1543 DAC
Hello everyone.
I've been doing some reading and came across the TDA1543 DAC chip. From what I can tell it is the newest NOS chip made.
The chip itself has a S/N ratio of somewhere in the 90's, which by today's standards is not great. As I've been reading, it was mentioned that paralleling a bunch of these chips together will increase the sound quality.
I pondered up a simple schematic of 5 of these paralleled together with some output caps. The schematic is in the attachments section.
Here comes my questions:
1. How many TDA1543's need to be paralleled to sound good? I know "sound good" is a vague term though I've seen these paralleled with up to 60 chips. I would just like to know whats a good sweet-spot before they hit the point of diminishing return.
2. Some of the TDA1543 designs have a "re-clocker" which I am not sure if makes a noticeable sound benefit.
3. If the S/N ratio does increase proportional to the amount of chips added, how can that figure be calculated?
Any help would be greatly appreciated. Thanks everyone
Poor amplifier frequency response.
I am trying to sort out an Electrocompaniet (EC) AW-100 DMB amplifier and wanted to ask for help from the experts on this site.​
The idling current (bias) and the DC adjustments have been made to the manufacturer's recommendations. In use the amplifier lacks treble and is bass heavy. The first image shows the square wave response at 10kHz across a resistive load and the lack of high frequencies. EC will not give me the circuit diagrams to identify where filtering is taking place. However, they did say there was filtering in the input section. The second image is a circuit diagram found on the internet which appears to cover this amplifier.​
I think the only filtering is due to C1 and C14 which at 1000pf seems too large. If this is correct, would I see any significant improvement by reducing it’s value to 47-100pf?​
I would appreciate any comments or further suggestions if this is wrong.​
10 Icepower modules in a single amp enclosure
Hi, we are putting the following ice power modules in a large amp enclosure in 3 separately powered groups... there will be 3 Powercon plugs (1 for each group which will be remotely powered on via Insteon outdoor outlets)
Group 1 will have 3 Icepower 50asx2 BTL amps, and 3 125asx2 bridged amps
Group 2 will have 2 Icepower 125asx2 bridged amps
Group 3 will have 2 Icepower 125asx2 bridged amps
Questions...
1: Do I make a central ground for all the amps to be grounded to, do I make a central ground for each group, or? I am assuming each group would have its own, it I do not know.
2: Fuses...what size should I get, and should they be fast blow or slow?
Suggestions appreciated.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,624
Members
7,880,747
Messages
Filter
Forum Statistics
Threads
405,896
Messages
7,880,747
Members
507,624
Latest member
Neilonpoint
