Sharp-Optonica Record Player RP-2626H incl Tonarm and SME Headshell - Repair-Kit Suppliers ?
For this automatic direct drive record player model (sometimes only mentioned "RP-2626" or "RP2626") I don't find both a repair-kit and some repair instructions on the web. Main issue is the fact, that the tonarm don't go to the record after press the "START" knob. Basically the same reason than on several DUAL models - go to the first image under
https://www.dual-board.de/index.php?thread/83881-was-ist-ein-pimpel/
Go also to post #27 under
https://www.diyaudio.com/community/threads/dual-721-question.313998/page-2
and
https://www.diyaudio.com/community/threads/dual-turntable-steuerpimpel-sub.239593/
Maybe one of the member know, which parts are to be replace - thank you very much.
B&W Bass Alignment Filter for my 802 S3s
Hi all,
I know this is the loudspeaker forum but this is directly related to my B&W 802s3 speakers.
I bought a Bass Alignment Filter from a fellow DIYaudio member. He is a very nice guy and I am happy with the parts he sent, the price for them and the promptness of the transaction.
However none of it came with documentation of any sort. I am piecing it together as best I can.
The reason for the post is...
1. Anyone recognize this PCB and have a link to ANY documentation?
2. The signal lead pads (in and out) on the PCB are not marked for positive or negative. Ground is center. The outside pads are one circular and one square. Any guesses as to which is positive?
3. The transformer is labeled as dual primary and dual secondary. With secondary as 0-15vac / 0-15vac. However I am getting 22.5vac off both secondaries. Rechecked the jumpers on the primaries to make sure I didn't series the primaries but it doesn't appear so. The rectified DC side is 29.5vdc. Added an LED for some type of load on the DC side but the output of the secondaries didn't change. Kit type PCB's, anything else I can check?
Any help would be appreciated.
My amps are balanced in so the factory BAF I have from B&W doesn't work in this scenario.
Cyrus two phono stage oscillations
Hi!
I'm trying to get rid of oscillations in the MC part of the phono stage of the Cyrus Two Issue 07 amp, but to no avail. The amp belongs to a friend, he complained about no sound on left channel over phono (MM). It was "overhauled" years ago, but only C43/C44 were changed back then. I found almost all caps were dry and the RIAA opamp (A5) was oscillating.
I changed all electrolytic caps except main filter caps and renewed the regulators. After that, the amp seems to work fine, but now I have oscillations on both MC opamps. I added 100n to the C67/C68 and C72/C71, I tried even to add some capacitance directly to the opamp leads - no change. C3/C4 were not populated on the board, but they are not marked as "deleted" in the part list. Added them, but still no change. Any other steps I could do, before I disable MC section completely?
Thank you!
  • Locked
Crossover frequency
I want to know crossover frequency what should be it ?
This is my subwoofer specs Bass Enhancer, Flat Cap. 5,25 Inch Low frequency (40Hz to 160Hz) driver with Amplifier sub out/Low pass filter connection. Full Range Driver with 15W direct Car Head output. 6.5cm depth required to use in car door pad. Best for home theatre stock driver
Tweeter/satelite speaker is 4 ohms 2.5inch
First build, almost done
I'm almost done my first build, and getting ready to enter the testing phase. I've never built a set of speakers before, so it's been a learning process, that's for sure. Lots of little things I'll do better next time, and lots of small defects that likely only I'll ever see, but so far I'm happy with how they turned out. I don't have a real workshop, so I had to relay on our equivalent of Home Depot to do the cutting, the routing in my buddy's backward, and I finished with most of the assembly and painting in my hallway. But I purposefully wanted a white faced speaker with wood back and sides to match my flooring and my entertainment unit.
Main driver is the Dayton Reference RS180-8 and the tweeter is the SDC26ADC-C0001. The veneer was a white oak. I still have to clean the front face up a bit more and I'll likely put on a light coat of furniture wax. But I couldn't wait to set it up and take a look at least.
Thanks for all the inspiration and help here so far!
1.5v Phase splitter
Hi, I'm trying to take a 1.5v audio signal and split it to 2 outputs, one with the phase inverted at 1.5v and one non inverted at 1.5v
I currently know two ways of doing this, the first is using a opamp chip with two comparators to make the circuit below. I have tested this and it works OK.
Vin is where audio signal comes in. A dual opamp is used as it has the two comparators needed to make this circuit. I used 10k on each resistor and it worked ok, a little background noise
Note that load is taking one inverted input and one non inverted input (from output of each comparator)
The other way which I have not tested is by using a single transistor and a resistor network to split phase, would this work as well as an op amp?
Ever build a Neutrik Minicon cable?
I have a Neutrik 12-pin DC cable but it's too short, so I will need to make one (or pay someone to make one). 12 pins of 22awg, times two.
I am not terrible at soldering but it's sort of a twice a year thing for me, and these pins are little. I couldn't hold a candle to someone like my father, who was godlike at my age.
My questions are threefold:
1. Can someone who is barely skilled do this or is it simply a bad idea?
2. What's the best way to strip 22awg wire?
3. Any other tips or tricks?
(details here: https://www.neutrik.com/en/product/mscm12)
100VA transformer for a 100W chipamp/LM3886 amp
The transformer is undersized (I've seen recommendation of 1.5x expected output power) but what does "undersize" actually mean?
Is it undersized on high volume only or undersized for any volume level? (I believed if the amp is class A then I would expect to have problems)
Thank you.
eDIT1: or when there's a low frequency tune (lots of bass), it'll be undersized even at low volume?
EDit2: 2x 4A 25VAC (for a transformer rated 100VA) for the secondaries and using unregulated supply. (just a rectifier bridge + some capacitors)
Need help obtaining a part...Pioneer AKX-507 line switch
Greetings all,
It's been while since I been on DIYA...
I've run a couple of Pioneer repair threads over on AK.
I just purchased an 80's Pioneer pre-Elite A-77X (S/G multi voltage model) as a backup to the one I purchased in Europe when I was in the Army in Berlin.
The first thing I noticed was that the voltage line selector switch on the back of the unit was broken
The part number is AKX-507. That part seems to be "unobtainium" here in the States. This place in England apparently has the part but is unwilling to ship to the U.S.
https://fixpart.co.uk/en/product/pioneer-akx-507-selector-switch
Can anybody lend a hand?
Thanks for looking.
S~
Mark Levinson 333 problem
Hello,
I have a broken Mark Levinson 333 that I want to repair for myself. It's working so far, but I have a problem on the Volage Gain board, which is why I can't figure it out at the moment.
The following were defective so far:
Q37,Q39 and the CR55 had passage.
After I replaced the parts, the Q36 gets around 100°C, but in the other functioning channel it only gets around 40°C
I had measured all the transistors so far and didn't find anything unusual. What could that be?
Best ring radiator compression driver?
Has anyone tested what's the difference between e.g. a BMS 4540, Eminence n151m and B&C DE360?
Or how about other small CDs that can play up to 20kHz like the Celestion CDX1-1425 and CDX1-1412?
Which can play the lowest, highest and has the least distortion etc?
My goal is to play at least close to 20kHz flat at up to 125dB/1m, so not that much for a CD and it will go in a constant directivity waveguide.
I have 40-90W per channel and fully parametric DSP to correct the output.
Here are some tests I've found, but they don't use the same waveguides so I don't know how comparable the results are:
n151M test
DE360 test
CDX1-1412 test
Musical Fidelity A220 issue with hum on new output mosfets installed.
Hi All
So a friend accidently blew this amp up due to a short in his speaker cabling, Upon inspection it uses BUZ900P and BUZ905P outputs, this amp had been worked on before because the transistors had been changed before and they did not look original.
Finding a schematic for this amp is near impossible, although i managed to find a shcematic for the A2 which is similar.
Anyway i gave the amp a good going over, all new electrolytics, new emmiters (as one had been taken out). I luckily had some spare buz900ps to test the amp.
Now with the original 900P/905P It worked with no issues, i could adjust the idle current/bias to 60mv (across the emmiters) and above i had it playing for hours. My friend decided he wanted all new outputs as the original ones were a mismatch and had been replaced in the past.
I decided based on research to use Exicon ECX10P20R/10N20R outputs. I used a device to measure them and match them best i could.
To make sure they were fine i did one channel at a time, here is my issue. With one channel running 10P20R/10N20R and the other with BUZ900/905 it worked without issues.
As soon as i replaced all the outputs on both channels to exicons i get a low level hum from the speakers and output if i try and adjust the idle current over 40mv?
The only way to stop the hum is to have it running at say 35-40mv, if i got higher i get an annoying hum from the speakers. At first i thought i had damaged something so checking voltages showed nothing bad.
I replaced the outputs back to the buz900/905s and no issues or hum.
So my question is what is going on? i have a few ideas.
1. Could have an issue with the new mosfets? maybe one or two are faulty
2. They are not matched for the amp and not a good replacement choice?
3. Perhaps the gate voltages are different and the driver transistors need to be updated to match the new outputs?
I could leave it at 40mv but then its not running at class A and i really want to get this running as it should. Any advice or tips would be appreciated.
Croft Vitale transformer identification
I’m hoping someone may be able to correctly identify the pictured transformer.
It’s fitted to a 20 year old Croft Vitale valve preamplifier which is showing short circuit across one of the secondaries and blows the 500ma internal fuse.
The part number shown on the front returns zero in Google search and unfortunately the genius and ever helpful Glenn Croft is no longer with us. The closest in size and value I’m able to find is a vintage RS components 207-144 available on EBay for around £20. Would this be a suitable replacement ?
Any advice gratefully received.
David.
Variables (Subjective).
I know there is very little for the subjective on this forum but I am experiencing a strange phenomenon. I operate a 2.1 desktop system. Over time I have replaced the satellites with increasingly large bookshelf speakers. The intention was to make the 8" sub optional (I live in an apartment. I have neighbours).
Long story short . . . my latest satellites are 2-way with 6.5" woofers. They sounded awful, boxy and shallow . . . until today. Today they came to life. For the first time ever the neighbours banged on the wall when the sub was off.
I can only consider 2 variables. 1: (Me), but my neighbours have acknowledged the change in bass response. 2: Atmospheric conditions, temperatures are 10 centigrade lower than 3 days ago.
Question about a pin at oscilloscope probe connector
Was buying passive probe for an old LeCroy oscilloscope I acquired.
Going through the manuals I narrowed down 2 probe models that seems to be default setup to the oscilloscope model.
One thing I am confused is regarding a tip right next to the BNC connector on the probe. Is this tip auto-retracting and would just slip into probe when connected to channel input, some sort of ground pin? Or is it pin specific to newer models? Or is it designed to just touch the oscilloscope case when probe attached for maybe reference ground or something, but I think that should be done by the cable shield in the BNC cable?
The pin is highlighted in the picture below.
Tried contacting LeCroy but I have to make an account first, and the account has not been processed by their sales after few days.
P3A Comparison table ( long .... )
P3A is my favourite amplifier of this class ... i have designed my own pcb ... did a few things on it ... and this become my favourite amplifier and a standard to listen for almost 3 years now together with a diy nearfield monitors 6.5" visaton +vifa ...
I repair give or take around 200 amplifiers per year so i thought since except scopes loads and generators i also want to listen to the amps i repair i normally hook them up to my system and listen from them a few hours
Since i have a few standards created from my setup while listening most of the time my amplifier from the same tuner ( same radio station ) the same cd player and for reference always the same music for more than three years now. In this post i would like to provide some information about the amplifiers i repair may be start some questions about them and listen to others opinions but as a base i will use my listening expirience from the P3...always regarding sound qualities and never power
P3A construction and set up
dual mono 250W trafo per channel 2x28AC
psu caps 2x10.000 mfd on board
MKT input cap 4.7 mfd bypassed with 100nf mika
350 pf silver mica input filter
LTP matched pair +thermal junction
VBE attached in pos driver
82pf styroflex miller cap for VAS
100 PF multileyer cap on the driver
multiturn
120ma biass
BD139-140 family for drivers +VAS ( philps )
outpouts are MJL1302A 3281A motorola originall ( zeck replacement sets )
i normally listen from a passive shunt relay source selector with Alps blue line 47K so most of my tests do not include crosstalk issues since this configuration is almost unbeatable and since i am in the comercial bussines and most of the amplifiers i repair are comercial Japanese amplifiers there is actually no point to try to compaire the one with the other ....
Questions are about sonics, colourations ,ends , how deep , how clear , how crisp, and goes on and on
Most of the amplifiers i repair include tone controls so still comparsion is not that fair but lets thing of defeat switches where ever they exist...
here is a few things i have to say for my amplifier as made that will be followed of a few scope readings and then i will start posting the things i have seen in the amplifiers i repair ...
I will try to post as many details possible about these amplifiers and feel free to email me i f you have any questions or schematic requests
the P3A as is together with the Visaton/ Vifa near filed monitors become a bit endy ...means that this set has absolutelly no problem to deliver low frequencies or high frequencies....Bass is plenty extending often to very low frequency without any problems without anything excecive , punchy and tight but delicate... midle and soundstage are very very present but extremelly balanced and vocals or strings are very pleasent with the slightest sign of distortion and with a lot of depth .... sound stage is so perfect that can provide the placing of the vocals on stage easilly ... now high is one of the most nice since no matter how many remain crystal clean and extremelly detailed at various types of music ...
i t seems that the particular setup will deliver exactly what the producer had in mind ...negatives are that the all system performance has slight U eq performance meaning that midle is a click lower ...but just a clik...
then again it seems that if you play a terrible production the amplifier will make it even worst ...that i cannot explain if right or wrong ...The impression i have is that the amplifier is way too free with no llimmitations of any kind and under this ...sounds logic
thanks for listening ...here we go ...scope readings
Audio Note kit 1 SE amplifier
Hi guys, we refurbished an amplifier built by Audio Note kit 1 with 300b end tubes and by measuring the primary/secondary voltage ratio resulted for the 4 ohm output a ratio of 25 and for 8 ohm a ratio of 17.5 both corresponding to a Z=2.5K but THD>5% for 6.5w. Replacing the load resistor with 8 Ohm and 16 Ohm respectively yields Z=5K and THD<3% also at 6.5W. Did Audio Note erroneously show that the outputs are on 4-8 ohm, what do you think?
Doubts battery
I have doubts:
here the temperature varies 33-35C
1) I have AA NI-MH 2600mah batteries from Toshiba, I contacted the manufacturer and he said that there is no problem with the battery life if you store 0% or 100% the reduction in battery life only occurs when recharging
2) the original Toshiba charger does not have a percentage display so I charged all AA Ni-MH 2600mah Toshiba batteries to 100% and I stored them at the temperature I mentioned, I would need to recharge them after how many days or months without harming life battery usage?
3) I have Chinese Nokia BP-5L and original Xiaomi BM20 batteries, I charged them all to 3.8v and stored them at this temperature of 33-35C, after 6 months I saw that their charge dropped a little to 3.78v, which Would it be a longer and safer period of time to charge all of them without compromising their useful life?
Moving Coil Prepre PSU: Basic Questions, What am i missing?
I won't lie, most of the time when i built DIY audio stuff, i'm blindly following ready made schematics. So i did 20 years ago when building my 2sk170 PrePre and the following RIAA stage. Now, over the years i have gathered crates full of electronic components stuff, often MIL spec parts, which i wanted to use some day to rebuild things that actually work, but have some flaws, maybe only optical, sometimes it was just me modifying into a wrong direction because i didn't have parts at hand, no money or whatsoever.
Now the time has come, the amount of parts in my garage is getting annoying. So i decided to "build it away" and get my final stereo setup done.
One of the DIY devices that has a flaw is the PSU of my phono amp. It humms a little bit. It is basically only LM7824/LM7812 with some filtering caps. So i thought to myself i had to go look into the crates what i have.
What i found is a nice little Collins choke with 2,5H/100R at 0,11A. I thought it could be a good idea to use it with a decent 30V toroid, some 4,7mF caps and two LM317 regulators for creating a dual power supply. The needed voltages are +12V@40mA and +24V@60mA.
I turned on PSU designer to simulate that and... wow... i'm getting 30V @ 1,4mV of ripple only? Can that be correct? I mean plus the additional rejection of the LM317s which should be around 60dB for each stage that should make a very quiet phono PSU in the nanoVolts region right?
Now what i would do is adding a LM317 stage to regulate for 24V for the MM stage (approx 60mA) and behind it another LM317 to regulate for 12V for the MC stage (approx 40mA). Maybe add another RC in front of the second LM 317. Should take off some heat from the reg's shoulders and should reduce ripple even more. Maybe something like 20R with 4,7mF or so.
Ok, so i'm not the smartest guy when it comes to designing circuits (and living with women). So i have some basic questions.
Everyone is building shunt regulated PSUs etc. No doubt they work good, but for me they are hard to understand and build. If i interpret PSU designer correctly, i wouldn't need more than these few parts plus etching a little PCB for regulators etc to get away with it? Does that mean all the effort put in shunts, low noise regs, huge filter caps etc is only for cost reasons because of rather expensive chokes? I mean actually you can get a choke with these values around USD 10 to 20 used or so. Can this be true?
Also another basic question: I would like to build a test setup. Do i have to worry inrush current could destroy the choke? Maybe should i add a current limiting resistor?
Thanks for your help!
I am just too lazy!
OMG I have so much crap in boxes. Projects, projects, dreams and failures and more projects..
somehow never the exact part.. hello Mouser. Goodbye $$.
I cannot live long enough to use or learn how to use it all up!!
oh well. better to join up here and learn and see what others actually accomplish 🙂
43 Years as a Tech. About 35 of those years suxed, lol. Should have stayed in the New England area,
73's AE5ZN
Tubelab SPP - Bias of 12AT7 Phase Splitter?
DYI Audio folks
I have built a point-to-point version of Tubelab's SPP amp and had some difficulty understanding how the bias of the phase splitter section of the 12AT7 works. When first built, using the specified value 75K resistor as R106, the grid voltage on pin 2 was a couple of volts higher than the Cathode voltage on pin 3. For example, 72.2v on pin 2 and 70.6v on pin 3, when B+ is around 280v. I changed R106 to 150K ohms, which nicely turned this difference around. This approach was a suggestion by rknize on the SPP thread in the Vendor's forum. FWIW, I'm using new reissue Mullard 12AT7s
Is there a simple explanation for how this splitter is biased that anyone can offer, or refer me to, that would explain how the tube is biased and why changing the 75K resistor to 150K worked, and whether that's the best resolution of my bias issue? Thanks in advance for any assistance on this.
Simon
Preamp/Power Amp Mashup - Possible?
Hi everyone,
I will start this off by saying I found this forum via a bit of googling but everything y'all are talking about is well above my pay grade. It's like reading a foreign language. That said, this seems like the place to ask, so I figure I'll do so - I am basically trying to see if the modifications/build I am thinking of is even possible - not "affordable," "optimal," or even "sensible," but possible.
I have a 1970s Peavey bass amp. I love the tone I get from Channel A to death. I don't necessarily care about Channel B or the combined two channels. There is a pedal manufacturer who makes a pedal replicating Channel A, and I may buy one at some point in the future. However, these amps are currently a dime a dozen, I think I paid a hundred dollars for mine and less functional ones that have been stripped for parts are even cheaper.
Being a 1970s Peavey, it has a number of drawbacks - it's 2 feet long by 1 foot high by 8 inches deep, it weighs about forty pounds, and even at that size it's 130W RMS. It has 1/4" jacks rather than Speakon outputs, and it has no balanced/XLR output to run to a board or front of house.
Now, the sensible thing to do here is to get a small class D amp that has these features and run it through the effects loop, and indeed I have done this with some success in the past. But I don't like carrying around multiple amps and having to hook things up. I want it to be in one package, and having something totally different than everyone else appeals to me.
So - is it possible to build a single, elegant solution, combining the preamp from Channel A with a lighter, louder, class D power amp (ICEPower or the like)? Can this be done for a price that does not rival that of a used car? Is this just insanely stupid and not at all worth pursuing? Assuming the answer to the last question is "no," who, if anyone does this kind of work? I mean, in theory I could, but given that I don't even know how to read a schematic I'm not sure it's a project I'd like to tackle.
Cheers!
Unregulated rectifier boards connected together
Aim; I want to have more capacitance
Some info
1. Only board1 has a rectifier bridge. This means AC is only going Too this board.
2. board2 (± V and ground pins on the missing rectifier) is connected to the corresponding locations in board1 immediately after the bridged rectifier
3. The boards are on top on each other using hex spacers.
4. This is what the input looks like.
Would it work? I thought of having rectifiers on both boards and then they share the transformer secondaries but I read that's bad idea.
Thanks for the help.
is this a dead transformer on a Technics 1200?
Acquired a Technics 1200 MK2 that won't turn on. I took the platter and plastic cover off to take a look. Right away noticed there was what I assume to be magic juice residue in the well that that the power transformer sits in. No external evidence of liquid spill or anything of the like.
I plugged in to see if I could do some basic testing as far as I might understand. I measured where the power cable leads plug in and got 120V AC, then again the two red wires that run into the transformer case. Again got 120V AC. Then measured the two yellow wires that plug into the mainboard, got 0V AC. Would this indicate a dead transformer?
Just want to be somewhat sure before I go ahead with an order for a replacement transformer assembly, which comes with power cord, power input board, and transformer..
Crossover Conundrum - CX2310 vs. CX3400
Okay, I am about to buy my first ever rack crossover and am torn between two Behringer models, the CX2310 V2 or the CX3400 V2
https://www.behringer.com/product.html?modelCode=P0CCS
https://www.thomann.de/gb/behringer_cx2310_v2.htm
https://www.behringer.com/product.html?modelCode=P0CCT
https://www.thomann.de/ie/behringer_cx3400_super_x_pro_v2.htm
I plan to split it in 2 only, running 2 18" subwoofers and 2 full range 15" + tweeters. Low and high respectively.
I do like the extra features on the 3400 but it does seem a little more complex to set up and "tune" than the 2310.
Which one would you pick.... And why......?
/DATABASS
Adcom 5800 restoration kit – eBay
I was hoping I could get some opinions on this Adcom 5800 restoration kit. Cost is stated at 295.00 (make an offer).
https://www.ebay.com/itm/1656357443...jyrKVaT2T3usOX53luZLTpFOsQ==|tkp:BFBMpJL6v-pi
It does not seem a super far-fetched price for everything that is included, just in my opinion, and of course it would be a timesaver in-regards to having everything in one package instead of researching everything myself, and searching out all of the part numbers, parts, etc.
The one thing that I do question is the kit has 22000uF capacitors instead of the 24000uF is that came stock in the unit. I also inquired if the transistors are hand matched, and the seller stated they were not. I had looked up for a replacement 24000uF capacitor, and I could not find any around that appear that they would work and the seller said that is one of the reasons he dropped the capacitor, micro farad range down to the 22.
I have placed the description from the seller of the kit below in case people rather read it here than searching through the eBay ad itself.
Any opinions, thoughts, etc. on if this kit seems to be worthwhile would be greatly appreciated. Thank you very much for your time.
Description from eBay item:
The scarcity of good, honest techs who can do good and reasonably priced restoration/rebuild of audio equipment inspired me to create this restoration kit. In today's day and age, it is difficult to find a knowledgeable technician who can service your audio gear properly. I have seen many poor quality restorations of equipment that cost way too much for their owners. In 99% of the cases, only a few parts were replaced, instead of a full and proper restoration job.
A proper restoration must replace all electrolytic capacitors on all boards. Do not fall for partial kits that restore just one PCB (power supply, power amp, etc.). This is not a good or proper way to restore your audio equipment. It is the same as with car tires; one should never replace just one tire and keep the other worn-out tires on. A proper rebuild requires a full recap of all PCBs.
On the other hand, if one succeeds in finding a good tech, the wait time is usually 6-12 months for the unit to be serviced, and costs are sky-high. I have been servicing audio equipment for many years and have developed deep respect for all good equipment. Knowing how amazing and warm these units can sound, I decided to put together this kit. It includes very good upgrades and improvements that must be done to the unit. This restoration kit will make a huge difference in the sound quality. All the parts are of high-quality Japanese Nichicon / Rubycon / IC / United Chemi capacitors.
I am extremely particular about the quality of the parts provided in this kit. Knowing how many bogus/fake caps, diodes, resistors, etc. are out there, I source all the parts from reputable wholesalers and buy them in bulk.
Vintage audio equipment has the potential to deliver rich and authentic sound when it is properly restored. Not only can it enhance your listening experience, but it can also evoke memories and bring joy to your life. Let's work together to bring your vintage gear back to its full potential, and make sure you have the music you deserve.
Why am I getting very little sound from this EL84 P-P amp?
Greetings friends. I've put together a small power amplifier around a pair of PCBs sold as Dynaco 6V6 Push-Pull Amp:
This is my first Push-Pull build, and a bit of a Shoebox build, as I already had the power transformer. It has a pair of windings for HV and LV, so each channel has its own dedicated power supply:
Login to view embedded media
I got it all hooked up and the voltages looked good, they're written in red in the diagram above. Hooked up a pair of speakers, and got nothing. Well, a tiny, tiny bit of very distorted signal out of the left channel when I open the volume pot all the way. There is a 100k Log pot on the input as a volume control I forgot to draw in there. Is that 10k input resistor too big? Is this thing meant to be fed a much larger input signal from a Preamp or such? I've no experience with the floating paraphrase - is the cathode bypass cap meant to be polarized?
I'm getting no hum or buzz at all, just a tiny bit of signal coming thru. And when I touch the meter probe to pins 1 and 6 on the preamp tubes, I get very clear taps coming thru the speakers. Voltages look right - what am I missing? should I bypass that pot on the frond end and see what I get, then reduce that input resistor to 1k or less?
thanks!
will
For Sale USA-CA: 4 Madisound Open Baffle/Dipole Subwoofer Boxes
4 boxes for open baffle subwoofer. Cut for the Seas L26RO4Y driver (for adding subs to LxMini).
Two painted, two unpainted.
$30 for one, or $100 for all four.
Pickup in Sacramento (or in SF/on the way but that will be in a few weeks
S
For Sale miniDSP 4x10 HD in California. $300
Hi
I have a 4x10 HD in good condition with original boxes and power cable, no remote. Available for local pickup in San Francisco, or Sacramento or anywhere in between.
$300 + Shipping.
Shri
Are there any 3rd-party programs to force Bass-redirection and LFE gain globally on my W11 PC?
I used to use a Creative Sound Blaster X3 connected to a set of Logitech z607 5.1 speakers for my PC, which I converted into an all-in-one entertainment system in my lounge room including using it for TV and a home theater, and the bass redirection passed sound 80hz and lower from all 5 satellite speakers to my sub. I went to my onboard Realtek on my B550 MoBo because it has loudness equalization for gaming which my Sound Blaster X3 does not. The problem is its bass management only works for the front left and front right speakers and not for my center, rear left, and rear right. I hooked up my SB X3 again only to find a Windows update that happened in the meantime has broken bass redirection completely. Is there a program free or paid (as long as it's not a monthly or yearly subscription) that would allow me to have bass redirection from all 5 speakers globally with LFE gain included, so I can disable it in my Gigabyte Realtek audio panel and use said program? An example of my conundrum is the DOS game Exhumed, running through the Raze source port, that supports surround sound. When I open a door in front of me I hear the bass as the sound of grinding stone is heard in front of me, but when the door closes behind me the sound is flat and quiet, even when I set the front speakers to -10dB and the rear speakers to +10dB. My sub is set to +5dB.
Seeking a better understanding of the physics behind selecting ideal T/S parameters for a small TH
To start, if you're aware of other threads/links on this subject please feel free to reference.
Backstory: Since joining this forum years ago and learning hornresp, I've played around with hundreds of combinations of subwoofer designs and speakers in hornresp and it has become one of my favorite ways to burn time. It's not uncommon for me to see a driver, lookup the T/S parameters, plug into hornresp and see if I can make a box with the flattest response curve between 40-100hz.
Example: Eminence Legend BP 102 in a ported box vs TH smoothed with a 2mh inductor in series
When I swap out the Eminence Legend driver with a JBL GT5-10D, everything goes crazy:
There doesn't seem to be much I can do with the TH dimensions in the GT5-10D to flatten it out. Therefore it seems this driver just isn't suitable for a TH unless I'm really doing something wrong here (I do want to know).
If this is not a mistake on my part, I'd really like to understand why this is happening.
I'd also like to hear any opinions on using the Legend BP 102 in a TH. These dimensions seem very reasonable and easy to build, especially if I build a TH with only one turn. I'm not concerned with maximum power (I see it will reach xmax with ~50 watts), just something with good response that is not too big and easy to build.
Settings for the Legend BP 102TH:
Bass reflex:
Settings for JBL GT5-10D TH:
Bass reflex:
Mission Model "750 LE" (Limited Edition - 750LE) vs. "750" - which Differences on Drivers and Crossover Network ?
As I know, the main difference consist on the enclosure resp. cabinet version. But maybe there are additional differences on the electrical parts.
Because on the web I have found only information concerning the "LE" version I also think it is possible that this model "750" was only manufactured and thus only available as an "LE" version.
Thank you for clarify.
P.S.: A friend of me want to replace the drivers for bass-Midrange and dome tweeter because the voice coils don't longer work in the right manner.
Which currently available drivers are close to those from genuine used ?
Thank you for an advice.
Here a review from the "LE" version
https://www.tnt-audio.com/casse/miss750e.html
Mystery DIY Speakers
I've had some diy floor standing speakers hanging around for quite a while, something I had to buy to get something else and have now decided to do something about them.
They have 2X Seas P21REX drivers per speakers and an Audax 25DT tweeter installed between them, the crossover I'm sure isn't correct as it just has a coil and capacitor installed, nothing else!
I'm sure some design must have been followed when building them can anyone shine a light on possible crossover designs etc?
Anyone interested in these LM3886 PCBs?
It's been a long time since I posted here and I hope I'm not breaking a rule.
I have some unpopulated boards I made with a friend back in 2008 that I thought maybe some could make use of. I need to actually get a count of how many I have but there's a small quantity. Maybe 10 or 20.
They're setup to biamp a single speaker so there's four LM3886's to drive a woofer and then a single LM3886 to drive a tweeter.
They also have an optional crossover which, I think is a linkwitz-riley style and there's both a 12dB and 24dB. If that's not wanted there's pads for an RCA input jack directly into each amp.
I used a pair of these for many years until I finally gave them to a friend a few years ago. As far as I know, they're still working.
The board only has one modification which is I had to add a capacitor to the single LM3886 circuit, I think in the feedback loop to drop the DC offset as I was using it to directly drive a tweeter. The four LM3886's with the so called "servos" seemed to work beautifully on the two I built.
They were originally intended to be bolted onto the original rear panels of powdered advent speakers, but I also had plans to use them as stand alone amplifiers as well, it just never happened.
Anyone interested?
22R dual emitter resistor help
Hi All,
I’m looking to replace a .22R dual emitter resistor for a dynacord powermate 600 That has gone into protect mode.
1, 5w 0.22ohmn JX2
I’m Having bother finding one.
Is there a substitute I could use please?
I have confirmed 10 faulty components so far on one channel. The other channel is ok.
Thanks in advance
Is the CS43198 a same fake?
Hi! Everybody knows Cirrus Logic DACs CS43131 and CS43198. Once I noticed a discrepancy between the sound of my CS43131 and its measurements. After some research, I came to the conclusion that its brilliant results are fake. I have not any source with CS43198, so it would be interesting if someone checked my findings with it.
Fake 1. 352kHz and 384kHz support
Both chips accept such streams, but few people noticed the fixed setting of digital filters for these modes: 0.263Fs. In other words, frequencies above 92.8/101kHz will not be played at all.
Fake 2. Noise I (THD+N)
The noise floor in wideband measurements, which is also rarely used, has a steep rise above 40 kHz.
On the FFT, the signal harmonic bases are more wide compared to, for example, es9038q2m.
I'm not an expert, just an advanced user. If this is not a consequence of active noise shaping, then at least it looks that way. That is, the real THD+N should be noticeably worse.
Fake 3. Noise II (DR)
According to the standard test, CS43131 shows a DR of at least 130dB(A), similar to good professional chips. It was unclear why I couldn't hear it. The following test was carried out. A 30kHz@0dB signal was mixed into the standard 1kHz@-60dB. 30kHz is far enough from the [20Hz-20000kHz] range so as not to interfere with the measurement too much.
Result DR=129.8dB(A)
The noise floor rose by almost 20dB!
Result DR=110.3dB(A)
This confirms the rumors about variable gain, I suppose.
I very briefly repeated this test on the ES9038Q2M to avoid an error.
Result DR=122.8dB(A)
Result DR=120.9dB(A)
In general, there is no difference of 20dB here.
Logic of Currus
Of course, I can't know it for sure. I believe the dynamic gain is needed for outstanding DR. The noise shaping helps to improve THD+N measurement. And the huge noise hump is reduced by a non-switchable filter. I don't want to blame the CS developers for anything. I just don't think the CS43131 is a high quality HiFi chip.
PS Many thanks to IVX for exellent equipment!
Silver micas various values lot
Hello.
I have theese dipped silver micas, 300v most are 1 % , there is 3 kilos, I would like to sell them as lot.
I have no idea about how many, but it's on the other side of 1000.
Was thinking 300 euro .
33pf 84.5pf 130pf 160pf 174pf 177pf 270pf 280pf 316pf 330pf 354pf 372pf 378pf 470pf 632pf 1120pf
1240pf 2920pf 1480pf 1500pf 4005pf 4008pf 4300pf 4340pf 4540pf 4860pf 4990pf 5500pf.
SSE Power Transformer Advice
George's most recent advice is that the power transformer should be 700VCT (350-0-350). Looking at Hammond's potted offerings I see the 373XP rated at 700VCT @ 127mA:
  • 5V/2A - this would tie me to the 5AR4 rectifier tube @1.9mA heater current but that's not a big deal to me.*
  • 6.3V/4A - this should be sufficient: 2xKT88 =3.2A, 1x12AT7 =0.3A, Total 3.5A Other output tubes (EL34, KT66, etc) would need even less heater current.
Does anyone see a problem or caution with this?
Hammond 373XP
* Edit: Some other rectifier tubes run on 2A heater current but that would be right at the transformer max with no margin.
any Class-D modules that can operate from a 63Vdc rail?
I would like to refurbish four subwoofers. Each was previously were outfitted with a class-AB plate amp, which unfortunately is terrible. I powered the plate amps from a 300VA transformer that has dual 45Vac secondaries, which translates to an unloaded DC secondary of about 63V, and I would like to re-use them (there is one in each subwoofer box). I would like to remove the remaining amp guts, re-build the power supply, retain that large heat sink from the old AB amp and mount the new amp module to it. I have lots of 100V can style caps that I can use to make a beefy linear power supply. I'm just looking for an amp module to work at this rail voltage. I would prefer not to add other DC driver voltages if possible, although I would consider that. The drivers will be 4R nominal 12" subwoofers.
I would like to keep the cost at or below $200 per amp module and am looking for at least 250W@4R. Perhaps there is an older ICEpower or UCD module (e.g. UCD400) that would be good when only used for subwoofer duty?
Other suggestions welcome!
Ferro fluid replacement on 1" dome tweeter
Frist time trying replacing ferro fluid on old 1" soft dome tweeter and seek kind advice from experienced members.
When I google, there are several different ul (microliter) such as 100, 300, 650, 900ul. If I replace 1 inch dome tweeter, do I just need 100 microliter per each 1 inch dome tweeter? It looks like 300 ul is the most popular one from the number of units sold somehow.
And, how much filling the ferro fluid? My guess is that it is not to fill all the way up since voice coil needs to be going in then it will overflow.
Do I fill about half way and it is about right?
Thank you very much in advance and any advice would be hugely appreciated.
Connector Identification Needed
Have a 1970's Quad Sanyo Receiver DC6100K with an early type 12 pin connector on the back -
Does anyone know more about the type of connector and what plug would have been used to marry them together.?!
By the way there is no manual (yet) ....still searching for one...must be one out there somewhere!
Thanks in advance
James Loudspeaker A2.1 amp trouble
I have a James loudspeaker a2.1 amp with a humming noice on the .1 (Subwoofer) output, sounds very much like wind blowing and it comes and goes but never disapear complitly.
I have no idea what kind of amp it is but my gues is chip class ab or class d amp, it has a Switch mode power supply if it makes any differens.
Any suggestion where to start the localisation of the problem.
The sub channel has a phase 0/180 degree button on the front. When I press that button it gives som scratching noice.
My hope was a cold soldering but after trying to resolder the legs to that bitton it stays the same as before.
James loudspeaker does not answere my e-mail or messenger messages. I have no schematics for the amp.
Where to start?
Speaker sound qualities vs speaker parameters
I have built my first speaker about 20 years ago, but I always built a ready plan or used the trial and error methode to build/improve something.
The speakers are quite good what I have now, but I feel, I need to dive deeper if I want to step further. I have started to learn what Thiele/Small parameters are, but don't fully understand yet, how to use them.
For me the following qualities are important in a speaker's sound:
1. Frequency response
2. Dynamics
3. Clean sound
4. Detailed sound stage
5. Good resolution
1: The frequency response is the easiest part since it is possible to correct it by a DSP. Currently I use wideband speakers, thats why I need some DSP correction.
4: The good sound stage comes from good phase response under 2-3kHz, but don't know what is above.
What about the other qualities? Could you please give me some advices, or a good reading/watching material?
Someone mentioned in a thread, that the detailed soundstage and the good resolution is not possible in the same time. What is the reason behind this?
Aleph 3 how is power 4 ohm
In the aleph3's manual is written the peak power on 2 ohm :120 watt.
On stereophile the graphic is that an aleph3 give 32.8 on 8 ohm
55.8 on 4 ohm and 40.. on 2 ohm.
Ok but this is with a sinusoidal signal but what is the power impulsive on 2-4-8 ohm
it's because in the manual is written that the max output is 8 amp and 23 volt.
I can understand (but I know that is not so) the aleph3 give with an impulsive signal
120 watt on 2 ohm
240 watt on 4 ohm
It's impossible I know...
but what is real the power on the aleph3 in this condition?
Someone can help me?
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite
piCorePlayer = piCore Linux + Raspberry Pi + Squeezelite + LMS
piCorePlayer is a dedicated Squeezebox player (like a Duet receiver) for your Raspberry Pi. It is built on a small read-only linux (Tiny Core/piCore) and Triodes excellent Squeezelite player. It is small, very small, only 75Mb.
December 12 2015
Please try the new release (piCorePlayer 1.22).
Ralphy has been a great support and help during the development - so thank you very much.
https://sites.google.com/site/picoreplayer/home/news
Changes:
  • Updated kernel 4.1.12.
  • Updated piCore (even faster booting).
  • Touchscreen support improved (the official raspberry 7" touchscreen).
  • Calibration file included.
  • Jivelite can be installed from webpage.
  • VU-Meters can be changed from webpage.
  • New high quality default VU-Meter made by forum member Kolossos - thank you very much.
  • Backlight on/off (Jivelite settings/screen/screensavers/when stopped/Display off ) then the backlight will be off when not playing, and on when you touch the screen.
  • Ralphy is providing two versions of squeezelite. The basic version which is shipped with pCP allow playback of pcm, (wav/aiff), flac, mp3, ogg and aac. It is only 1 Mb in size. The ffmpeg version is bigger (12 MB) and allows in addition playback of ALAC and WMA via build in ffmpeg. In the Main page you can choose which version you will use.
After customizing Jivelite you need to save your changes to the next reboot. This is done on the webpage ("advanced tab" in the bottom and choose "backup").
Download
https://sites.google.com/site/picoreplayer/home/download
This software has been around for a couple of years now, but has a fairly low profile at diyAudio.
regards
Steen & Greg
Reactions: Bas Horneman
Gauss meters, any reviews?
Anyone know much about gauss meters?
Just wanting to measure strengths of permanent magnets for projects ranging from massive subwoofer builds to robotics? Neo, Ferrite magnets what ever.
Not to expensive maybe under $400 or $500 obviously cheaper the better like it doesn’t have to spot on accuracy but a reasonable one would be good!!
Any recommendations?
Cheers
Sound of various Pass amps
Sound of various Pass designs
Nelson,
It would be interesting to know your thoughts on how the Sony VFET amps sounded vs the Pass SIT amp vs the current (and maybe past) Pass 240 based products, the F series and maybe even the Aleph sound.
Perhaps a short description of each and what that design did really well and perhaps what it could have done better. Also perhaps how it performed into low impedance loads.
I realize how each sounds is subjective and all have sounded good. However, since you're likely one of very few people who have heard each topology, your perspective on each would be great info to know. I also think it could be useful for folks buying Pass equipment (new or used) who are wondering how a particular piece might fit into their system. Finally, it would also help those interested in DIY who may be trying to determine what to build. Essentially, it could serve as a guide that would evolve over time and could even perhaps be a sticky.
I realize you have a long list of to-do's, but given the number of designs over the last five years or so, I think it would be very useful. As this site has grown, it's become very challenging to wade through thousands of posts on each design to try to determine how each compares to others.
Thanks,
Steve
Reactions: Freedom666
0.68uf paper oil caps any use in audio?
Also got some 0.1 here all made by rubycon.
If they have no use in audio I will move them on, but I know people go crazy over paper oil caps, but don't want to hoard too much stuff!
They are rated at 1500V, so may be useful in high voltage circuits that use transmitter tubes perhaps?
AIKIDO Glassware Preamp
To the point. I have a Glassware Aikido preamp that I have decided to sell for $500. Free shipping within lower 48 states. The unit was built with the following:
1) Manley Labs RCA jacks
2) All silver plated copper wiring.
3) Obbligato copper output caps 600V
4) Special connections to allow tube access to be easier for the owner
5) Glassware PS-21 Power supply made for this application
6) Quality Hammond chassis.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,491
Members
7,874,388
Messages
Filter
Forum Statistics
Threads
405,583
Messages
7,874,388
Members
507,491
Latest member
nobodyfamous
