Then with Vituixcad..
1. Simulate the baffle,
2. Set virtual driver locations and acoustic distances,
3. Manage phase.
3. Manage phase.
The enclosure database only does the bass response, you'll still need the response data.
If you're using a single response plot then it will be wrong above approximately 2kHz for the woofer, higher for the mid.. so you should try to cross below breakup.
Tools>Diffractionhow to simulate the baffle
