Might some here critique the power supply I want to buy
- By Lawnboy
- Power Supplies
- 38 Replies
I’m unsure if the purpose of this forum is a little above my head. I consider what I do diy in the way that I don’t go to Best Buy and choose a big box store brand. I’m getting into using pre made components like amplifier boards, raw drivers and the like to create my audio equipment. I just wanted to preface the question with an attempt to show respect to the legit circuit builders.
I’m about to order this power supply
https://www.trcelectronics.com/View/Mean-Well/EPP-500-24.shtml
and be done fiddling with lower power amazon units. I’m currently using a 24v 6a open frame supply,
Zerone AC 100-240V to DC 24V 6-9A Switching Electricity Supply Module 150W High Power Industrial DC Electricity Supply Bare Board https://a.co/d/drK2azZ
which may be introducing noise into my Dayton Audio Kabd boards, or, maybe the boards may have an inherent low level noise. Either way I like the versatility of the kabd boards and have decided to move into a power supply that will be plenty for my needs with room to grow.
Is there any dissuasive feedback on the mean well 500w 20a unit? Maybe a lower cost route that is as good or better? The amp boards will be In close proximity to the power supply in this small 7”x6”x3” steel electronics enclosure. Is this arrangement too close because of noise issues? I’d be willing to switch to a similar enclosure that would allow maybe ~6” spacing between supply and boards if necessary. Thanks in advance, happy new year also.
