Difference in Inductance - How does it affect MM Cartridge sound?
Hi!
Inductance of MM cartridges plays a role in their sound signature. Obviously i'm not attesting anything new or revelatory.
Not sure i understand exactly how it affects performance but was pretty surprised to find out how much different the same stylus sounded on cartridge bodies with different inductance (otherwise identical).
The two cartridge bodies belong to the same family, with interchangeable styli.
One is a Shure M55E (pre-2000, Mexico made) and the other is a Shure M44-7 (post-2000, Mexico made). Used the same stylus on both for evaluation (N55E Improved, original stylus). Cartridge headshell used, turntable, VTF and all the other variables were kept identical.
According to my LCR meter, the cartridges showed the following values:
Shure M44-7
Resistance: R 681Ω, L 680Ω
Inductance: R 568mH, L 606mH
Shure M55E
Resistance: R 690Ω, L 690Ω
Inductance: R 759mH, L 721mH
Didn't expect them to sound as different as they did, given the above values.
Resistance is almost identical, being only 9Ω and 10Ω higher on M55E, for each channel respectively.
Differences in inductance are more pronounced though. 191mH and 115mH higher on the M55E, for each channel respectively.
Links to audio recordings of both cartridge bodies with same stylus:
Shure M44-7
Shure M55E
When i listen the two recordings, the one with the higher inductance (M55E) sounds substantially wider in terms of channel separation and with less pronounced high octaves. The other body (M44-7), has an overall brighter rendition with a somewhat collapsed soundstage in comparison.
So, is it down to the difference in inductance?
Maybe.
My only reservation is that there might be other factors affecting the result, which i'm unable to identify/measure.
Regards, Nikos.
Transcoding Dolby Pro Logic to 5.1 surround
Hi all,
I recently got a soundbar that doesn't correctly decode/upmix stereo matrix surround sound like Dolby Pro Logic, and I was wondering if there might be a DIY way to take a DPL input and transcode it into something the soundbar will recognise (e.g. DTS 5.1 via optical, or maybe something through HDMI).
I am wondering about a couple of possible ways I might go about this:
1. Using hardware decoding
Seems like there are chips you can buy that decode this stuff. So perhaps I could build a device that feeds a stereo signal through the chips, and then outputs it as a true 5.1 surround signal.
2. Using a DSP
I have been looking at various Raspberry Pi solutions for DSP. I found a github that seems to have profiles for EqualizerAPO that purport to be able to at least somewhat properly upmix these signals (here). So I am thinking maybe I could achieve something similar using Like a HiFiBerry DAC+ Digi with a Raspberry Pi. It would need to be fairly low latency to meet my needs though.
I am not super experienced in this area, I can code and solder but I'm not much of an electrical engineer.. still I would be interested in attempting something like this as a kind of long term project/learning experience. If anyone here has any insight into whether something like this is practical/possible I would be very interested to hear about it! I understand there are some licensing issues around this stuff, but a lot of the discussions I have read online are really old so I am hoping there has been some progress I haven't uncovered in my search.
Any similar projects/recommended reading would also be welcome.
And, if someone has already solved this problem - well that would be awesome!
Thanks.
For Sale Delta Audio Leach Amp
If there is interest I plan to sell a Leech Amp based on Delta Audio 10 transistor design (on eBay). Very nice sounding amp, but I have accumulated too many amplifiers, and this one needs to be rehoused from its prototyping case. With the toroidal transformer it is very heavy, so I would entertain selling the channels mounted on the heatsinks separate from the transformer. I am thinking $100 per channel ($200 for the pair) plus extra for the Bridgeport magnetics transformer (I have to look this up), plus the packing and shipping cost (local pickup in Connecticut possible)
Let me know if the price seems fair.
300B schematic recommendations
Hi Folks,
I already have a pair of this output transformers:
Primary: 2,5k or 3,4k
18W
I would like to build a 300b stereo amplifier or two mono amplifiers for my HiFI.
For the moment I have a SE PCL 86 amplifier with 4watts, which is actually enough for my speakers, but I hope to achieve 2x8watts with the 300b's.
There are a lot of schematics:
I would like to know which one fits my output transformer best - or if there are other schematics - feel free to post them here 😉
What would also be nice: If the amp wouldn't need a preamp - I thought about an aikido preamp to drive the 300b but the schematics from tubecad require different primary impedances.
Have a nice day!
Felix
Mcintosh MC431M in power guard
I have a Mcintosh MC431M, when it is turned on, there is a loud noise in the speakers before the power guard light goes on.
I have removed it from the car and connected it to a power supply without speakers, same thing happens, it goes into power guard mode.
I have opened it up so I can see the circuit boards and components, there are no visible caps leaking or anything.
The problem seems similar to https://www.diyaudio.com/community/threads/pls-help-strange-mcintosh-mc431m-problem.165344/
But there was no solution posted. I only know basic electronics, and I can't find anyone to help with the repair in my area. Does anyone have any clues where to start?
Question regarding dipole driver
Hi all. I have a question regarding dipole drivers. Situation is I have a set of 2-way speakers with a low 1.5khz crossover. Tweeters are toast and no replacements are available. Having looked around I have found a ribbon tweeter that is a near perfect replacement. The only issue is it is a dipole design while the speakers are a sealed box. My question is what effect will the sealed box have on the tweeter response? I know there are a ton of variables so I don't expect a specific answer but more of a generalized one.... will it change low end response of the tweeter or it's power handling or efficiency? Since I want to use it in a sealed box anyway would it work better to seal the back of the driver? Thanks for any insight.
Phonic P8A reloaded
Hi everyone,
I want to share with you my experience of the last half a year spent modifying these "monitors" made by Phonic. After reading the only review online ( Test: Phonic P8A - Studio - AMAZONA.de ) I acquired them for something like 200$ which I considered to be a goo deal. And it is, to certain extent - the P8A have some issues.
Let's start with the bad:
  • Unknown origin metal dome tweeter, slightly different model in each speaker (!) that sounded extremely harsh
  • Front firing ports are non-functional. The extremely cheap plastic they were made of was all warped, God know how someone could manufacture this. (No photos, I threw them away but trust me those were THE worst imitations of ports I've seen)
  • Extremely unpleasant sound, with weak bass, elevated 1kHz range I had my ears hurt after an hour of listening.
  • The crossover was all over the place, I have the transfer function of xovers, see attachments. Obviously the "24dB/oct LR" is a bit overstated in the specs. Not to mention the ridiculous 15dB boost at 20kHz.
Now the good:
  • Reasonable build quality, nice finish of the cabinet box.
  • Very nice and compact amp design with toroid transformer (I'd estimate about 250W), all enclosed in nice metal casing.
  • Plenty of circuitry to play with (2xTDA7293 for bass, another one for the tweeter, auto-off circuit, overload protection, plenty of opamps in the signal path to play with)
  • Nice looking woofer with cast frame, from the looks identical to the one used in Behringer B2031 ( http://i836.photobucket.com/albums/zz286/my_graphs/Behringer B2031P/DSC03709.jpg?t=1290059946 )
So now that I had a pair of crappy speakers, some spare money and a huge motivation to learn more about speaker building, I started modifying the hell out of them. Here's what I did:
  1. Relocated the ports to the sides of the cabinet, changing them to 4cm PVC tubing in the process (WinISD helped a lot)
  2. Completely refinished the cabinets
  3. Laid about 1" of rockwool on inside walls
  4. Changed the tweeters to Seas 27TFF
  5. Completely redesigned the crossover and settled on a mixed active/passive solution
See attchments 2 and 3 for what I ended up with. I'm very pleased with the sound and new appearance of the speakers, it was a long but very interesting journey to this point, with some quite radical design choices. There are things I'd do different now but that's probably the case with just about any project.
If anyone is interested, i can post some (a lot) more details.
K.
Visaton WG148R Waveguide: Highest SPL tweeter with flat faceplate?
There are several threads here about matching tweeters for the Visaton WG148R waveguide which is a powerful addition to the speaker designers' toolbox.
I am looking for a 1" dome, w/ flat faceplate, with the highest top-octave efficiency as possible. I want to match it to a woofer that's 94-95dB 2.83v/1m. The max efficiency of the system ends up being constrained by the tweeter.
Most 1" domes don't go past 91-92dB. In the top octave, mass prevails over horn coupling, so the waveguide won't increase the SPL much if at all in that range. Therefore we need a tweeter with high BL, low impedance, and low mass.
Also for this waveguide you need a flat faceplate, otherwise you have to mess around with gaskets and mods.
Are 28-29mm domes too big to match the WG148R?
Other threads have discussed SEAS and Peerless 25" domes, ie https://www.diyaudio.com/community/threads/xt25-visaton-wg-148-r-with-pictures.285240/ and https://heissmann-acoustics.de/en/test-wg148r-noferro-900/ but none of them reach into 94dB sensitivity territory.
Any suggestions?
18 Sound ND3ST
18 sound ND3ST compression driver. Barely used. Mostly employed for tests. No sign of use. See pictures.
The price for the pair is: 490€
European shipping is 25€, international shipping is 55€, if you want insured shipping please ask for price. Payment by PayPal, satispay or bank transfer in advance.
my email is franco.cauda@gmail.com
Pioneer SX-1250/5590 EQ board issue
Having a problem with an SX-5590 that has a problem on the equalizer board. The receiver had already been serviced and recapped by a previous tech.
I couldn't duplicate the issue at first but then noticed a bulged cap (470uf, C12). When I pulled the cap it read 63uf so, I replaced it. After I replaced it I monitored the output of a 1khz sine wave on my scope, through the phono inputs (I use a little RIAA circuit in-line to match the signal before going to the input). What I noticed was at about 9:00 on the volume, the wave would get distorted and then it would trip into protection. Lowering the volume took it out of protection but I didn't like that distortion. So I pulled the board and replaced all the transistor pairs in the right channel where I saw the bulged cap, and when I tested, R44 and R45 (150r) smoked. Nothing was installed backwards, and I used the correct subs (KSA992, KSC1845) or so I presume based on research and other threads that give viable substitutes. Dim bulb does not protect the resistors from smoking. So I pulled the board again and went through rebuilding it; new caps (again), all transistors replaced including both 2SA850/628A with KSA1013, and replaced the burned resistors. Put back together, tested on the bulb, no smoke. Ran a signal through the phono stage for about 15 minutes and everything was fine but then R44 smoked again. R45 was fine. I checked D5 and it was shorted/open. Replaced it with a 1N5252B, replaced the resistor again, and the same thing happened on power up.
I've never had an EQ board smoke before. Any insights on where to look? Obviously I'd have to disconnect power to the EQ board to test the power supply otherwise it will just keep frying that resistor in the meantime.
Tone Control for LM3886
LM3886 based amp with sub output
I want to build a LM3686 gainclone based amp with sub output.
Im beginning to find parts – mainly the mechanical parts, but plan to begin making the pcb´s in late October.
I have come across a sew problems, so I hope you can help me out.
The Sub
Im planning to make the sub signal just like the left and right. But should I add extra electrolytic capacitors for the sub channel?
My plan is to use the sub, just as a supliment to my normal speakers(Old Rauna Njord), that might need a little extra in the lower frequencies.
How do I “Make” the sub signal? I would like to merge the left and right signal, and cut off the frequencies above lets say 500Hz. But I would like to be able to adjust the cutoff frequency with a digital potentiometer, so I can control the cutoff frequency with a micro.
Tone Control
I want a tonecontrol. But I want to be able to control it from my microprocesser and not by buttons. So it can be controlled with a digital potentiometer. This way I can make my amp really minimalistic, but still have the features that an integrated amp has.
So Im looking for a good 3 channel tonecontrol solution with bass, mid and treble and volume control.
Any links og suggestions is highly appreciated.
Peter
newbie question about RPi+Volumio/Moode sound quality
Hi there,
Before I ask my question here's a very little bit about what I have and what I'm trying t do.
I've recently been trying to evaluate different computer based digital audio streaming solutions.
My current setup is 2x Raspberry Pis, 1x 3B+ and/or 1x 4B.
USB to a Topping E50 then RCA to my amp then Duntech Marquis speakers.
I have my CDs ripped to FLAC and SACDs to DSD and sitting on a NUC running Win10 and available via a network share.
I'm currently trialling Volumio and Moode and trying to do AB listening tests.
Configuration of both is stock standard straight out of the box....no plugins, no CamilaDSP etc.
There is a slight but almost imperceptible difference between an RPi3B+ and the RPi4B with either software.
I was however surprised to hear quite a difference between Moode and Volumio.
Considering both should be able to deliver bit perfect streams to my DAC, can anyone advise why Volumio ad Moode sound different out of the box?
Thanks in advance.
Krell CD-1 Player: Successful repair of Remote Control unit
Purpose:
  • To share my experience repairing a Krell CD-1 player's remote control unit.
  • Although this content is relevant to both the Solid State and Digital Source forums, as the primary focus of this report is the identification and replacement of broken components, I felt best to share this content on the Parts forum.
Equipment:
  • Krell CD-1 player serial number 99209281 (Fig. 1), supplied with infra-red remote control (Fig. 2).
Figure 1: Krell CD-1 player, serial number 99209281 - photo taken August 2023.
Figure 2: Krell CD-1 remote control unit - photo taken after repairing, August 2023.
Background:
  • This Krell CD-1 player I purchased new in 1992 from Loyalty Sound Ltd in Calgary, Canada. Overall, I was very pleased with the performance of this CD player throughout 10 years of worldwide assignments. Although it was in full working condition, sadly I had to put my Krell CD-1 into storage in 2001 due to shortage of living space.
  • Unfortunately, during the last international move the remote control unit got packed in a different box from the CD-1 player, with the 3 AAA batteries remaining inside the remote control unit. This led to leakage of the battery's electrolyte, further leading to corrosion and damage to the remote control's internal components rendering it inoperative (Fig. 3). Note corroded battery terminals, damaged electrolytic axial capacitor, broken (missing) resistor - more to come later.
Figure 3: Remote control unit circuit board showing corroded, broken components.
  • Other than the Owner's Reference manual that came with my original purchase, I have no access to Krell's circuit diagrams or service instructions, and so contacted Krell customer service to enquire what could be done. Krell's Customer Operations Manager, Timothy Rogers kindly replied that it may be possible to send the unit back to Krell for repair, however with a minimum service charge of 1hr ($125) plus international shipping costs we deemed it probably wasn't worthwhile.
  • Although I had no experience with repairing a remote control unit, I decided to investigate and attempt local repair if possible.
Failed components:
  • With no circuit diagram, no service instructions and unable to identify the values of the corroded/damaged components presented a challenging puzzle.
  • After cleaning as best I could the circuit board (Fig. 3), I then attempted to recreate a circuit diagram by observing and continuity checking each of the circuit board traces. Hopefully, Figure 4 describes a reasonable recreation of the Infra-red transmitter circuitry, with the unidentifiable components labelled in Red.
Figure 4. Presumed circuitry (broken) of Krell CD-1 remote control - infra-red transmitter section only.
Damaged Capacitor:
  • The only remaining legible markings were the number "10" and the letters "PHIL-". Judging from the blue jacket colour I assumed this to be a Philips electrolytic capacitor, rated 10 V.
  • Testing the capacitor out of circuit measured a capacitance of 17.2 uF and an ESR of 8.3 ohms. Presuming this to be a 22 uF, 10 V rated capacitor, the measured capacitance was low and the measured ESR was high, necessitating replacement.
  • This was replaced with a fresh 22 uF, 16 V rated electrolytic axial capacitor.
Broken/Missing Resistor:
  • Before this resistor fell apart and crumbled, I was lucky to observe three colour bands; 1st Blue, 2nd Red and 3rd Silver. This colour band combination equates to a resistance value of 0.62 ohms, which seemed suspiciously low.
  • Assuming the 1st and 2nd colour bands of Blue and Red respectively were correct, but unsure what the proper resistance value should be, I inspected the third colour bands of some actual resistors (Table 1).
Table 1. Comparison of actual resistors, their resistance values vs. colour codes
  • Side note, I first learned the resistor colour code when I was a teenager in high school, where the Black coloured band signified a blank or non-value.
  • However, after researching this I now learned that the colour White can also be used to signify a blank or non-value, which solves the puzzle of the original installed resistor. The 3rd colour band was most likely White, not Silver - shows you can still learn something 50-years after high school!
  • So that's what I used, a fresh resistor of 62 ohms having colour bands; 1st Blue, 2nd Red and 3rd Black.
Test Measurement:
  • Still apprehensive whether a 62-ohm resistor was the correct value or not, and with no visible indication to the human eye whether the infra-red photodiodes were transmitting or not, I conducted a test to observe how the circuit performed. Test setup is described in Figures 5 and 6.
  1. 62-ohm resistor lightly tacked in place for the test.
  2. External 4.5 VDC supply connected to the battery terminals.
  3. Oscilloscope connected from the minus battery supply to anode of the two infra-red transmit diodes.
  4. Touch pad buttons were activated to start signal generation.
Figure 5. Test setup - External 4.5 VDC connected to terminals, oscilloscope connected to battery minus terminal and photodiode's anode.
Figure 6. Test of infra-red transmitter section after circuitry repaired.
  • To establish a baseline position of the oscilloscope trace, with no DC power applied the oscilloscope channel 2 input was grounded (Fig. 7).
Figure 7. Zero-signal reference, oscilloscope channel 2 grounded.
  • With the 4.5 VDC supply connected, a stable rest voltage of ~ 1.51 VDC was observed on channel 2 (Fig. 8).
Figure 8. Rest condition, touch pad buttons not activated.
  • Finally, when pushing the buttons on the touch pad, different coded pulse trains could be observed. An example of one pulse train captured on the oscilloscope is displayed on channel 2 in Figure 9.
Figure 9. Active condition, example of a coded pulse train when touch pad button activated.
  • Based on this test result (Fig. 9), it showed the remote-control unit to be functioning.
  • After removing external DC power, the 62-ohm resistor was fixed properly to the circuit board (Fig. 10).
Figure 10: Repaired circuit board of remote control unit - note 62-ohm resistor colour coding Blue, Red, Black (not White).
  • Operating the remote control with the CD-1 player, I was pleased that 17 of the touchpad's 19 pushbuttons functioned properly, the only two inoperative buttons being the "PREV" and "NEXT" buttons. These two buttons are situated closest to the corroded battery terminals and probably became contaminated from the battery's leaking electrolyte. Still, 17 out of 19 working buttons is 90% functional (far better than 0% or having to scrap the remote control).
Next issue:
  • After operating reliably for several days, the remote control suddenly stopped working.
  • Opening the unit up again found nothing untoward, all replaced components still intact.
  • Tracing the signal flow from the touchpad confirmed control pulses of ~ 1.2 V amplitude were flowing to the input of the infra-red transmitter section (Figs. 11, 12).
Figure 11. Test of touchpad's control pulses.
Figure 12. Example of control pulses coming from touchpad when button activated - approx. 1.2V amplitude.
  • This test showed the touchpad and its digital circuitry were functioning properly, suggesting something wrong again in the infra-red transmitter circuit.
  • Suspecting the input transistor 2SC548B (#7003 in Fig. 11), a check of its Base-Emitter forward bias showed an unstable and strange voltage, > 0.9 V vs. an expected ~ 0.6 V (Fig. 13).
Figure 13. Measured forward bias of original transistor 2SC548B - note unstable voltage with fluctuating final digit.
- The 2SC548 being an obsolete series I replaced it with a spare 2N3904 NPN transistor I had. A check of this transistor's Base-Emitter forward bias showed a typical ~ 0.6 V and stable (Fig. 14).
Figure 14. Measured forward bias of replacement transistor 2N3904 - typical voltage value and stable.
  • With the new 2N3904 transistor installed in the circuit board pleased to report the remote control is now operational again!
  • Just a minor issue, the physical orientation of the Emitter and Collector leads is flipped between the original 2SC548B and the replacement 2N3904. The easy remedy is to install the replacement transistor 'backwards' to align the Emitter and Collector positions (Fig. 15).
Figure 15. Orientation of transistor at 7002 (left) vs. reversed orientation of replaced transistor at 7003 (right).
  • What caused the original 2SC548B transistor to fail? It was only when I gently removed this failed transistor from the circuit board that I noticed its plastic case was broken (Fig. 16). One theory could be the leaked electrolyte from the batteries penetrated the transistor case causing it to weaken and eventually fail.
Figure 16. Original transistor 2SC548B with broken plastic case.
Final Notes:
  • The reason for this writing is to share my experience repairing the remote-control unit of a Krell CD-1 player, it's not to bypass factory repairs, just to share what worked for me. Hopefully no more failed components.
  • Finally with the circuit board installed back in its case (Fig 2.) and fresh AAA batteries installed, pleased to report the repaired remote-control unit now operates happily with my CD-1 player!
Reactions: newvirus2008
TSE 2A3 C3
It wasn’t supposed to make a difference but, my monoblocks vastly improved when I replaced the recommended Elna 4700uf with something fancier. I’m not saying what I used so as to keep any discussion theoretical. I’m not shilling for anyone.
I understand that ac has a direct path to ground at the other (-) end of the filament but this cap sure looks like a cathode bypass cap across the 1 ohm filament of the 2A3.
The reason I became even curious about this is because I also recently built a 45 version TSE that utilised (fancy) filament regs (that have no cap at all there, in addition to other “thought-provoking” properties) and it sounded so good I thought my 2A3 amps were broken.
I’m curious what the ee’s and George think. Am I trippin?
While I’m here, I’d like to say thank you for all of it. I learned a lot from building these circuits and have enjoyed their sounds immensely over the years.
Jason
LM337: a new epidemic?
The power supply of my mckinnie pre-preamp died, so I bought a small 317/337 PS kit to replace it.
The negative leg didn't work, no biggy, I ordered a handful of LM337 from Aliexpress. All bad.
I ordered another small batch from eBay, Germany. All bad. It turned out they're the same items as Ali.
The prob appears to be some kind of a short between Vout and Adjust, so Vout is always ¦Vin¦ - 2V, regardless of the setting.
Out of curiosity, I ordered another batch from eBay China, but they've not arrived yet. We'll see if this is epidemic level.
Finally, I've got some NOS Motorola 337 from eBay France, and all is well.
I don't usually have problems with parts from Ali, but stay away from the 337 for now,
Reactions: rockies914 and TNT
Group Buy for mosfets for FC CEN IV through hole US and Canada ONLY
Dear all,
This is a group buy for US and Canada residents only for ZVN3306/ZVP4424 matched sets for the FC CEN TH group buy.
Please list your name and the number of sets you would like. US and Canada residents ONLY.
I will compile the number of sets needed and in the future give an exact amount of dollars per set. At this time, cost is approximately $3.00 for a set and around $10.00 to ship. This is subject to change.
Reactions: alazira
Solid Audio F2000 Demons
GD gents,
Does anyone have any schematics or similar schematics for solid audio f2000 amplifiers? The board is very similar to American Bass SQ3000 amplifier.
I got this one in and several demons to work out, severely mixed amplifier components, to-247 and to-220 in both channels, with the shorted components removed, the unit goes into protect. Disabling protect, the unit powers up ok with good rail and regulated voltages. But there seems to be DC at the R-ch Spk terminals.
Haven’t disassembled fully yet, still assessing.
  • Poll Poll
Found an old Fluke 8030A...
What would you do with an old Fluke 8030A in my place?
  • Keep it as it is and display it as a museum item as it's not worth using anymore
    Votes: 0 0.0%
  • Do a quick internal cleanup and use it for very basic stuff only
    Votes: 3 50.0%
  • Restore it as much as possible (new caps, resolder everything, cleanup contacts) and use it normally
    Votes: 3 50.0%
  • Restore it (as above) + have it recalibrated for everyday "workhorse" use
    Votes: 0 0.0%
Hi all,
while cleaning up my attic, I found an old Fluke 8030A bench Multimeter. It works, but shows imprecise readings. Getting rid of it is out of the question, but I don't know what I should do with it...
Cheers
Denis
Capacitor input causes Offset Increased
Recently made this schematic, and working properly, but my problem is without any capacitor when I connect from mobile out as a input direct there is no offset change or ZERO OFFSET WITH 1uma current, but I want to ad a opamp for that have input a cap but when I ad a cap offset goes 45mv , so do I need a servo circuit?? Or any circuit changes that will fix d problem 🙏
Spitfire Mk9 model made for me by my son
Hi guys, i thought i would share, what i think is a wonderfull model my son made for me
I used to make lots for him when he was a young boy, so he said he wanted to return the favour by making me one.
He does commisions so he is way better than i ever was, and i think you will agree, its pretty good as he works off the original design plans from supermarine and adds all of the wiring and pipework etc that doesnt come with the standard kit-he also replaces some items with more acurate after market parts 🙂
Transformer volume control - TVC by dvb
This stereo 23 steps transformer volume control is a 6th generation proprietary design. Its primary function is line level control volume but contains such a high quality permalloy that you can use it also - inverting cables in the back - as fixed step-up line level transformer or adaptable to DAC stages or MC step-up for moving coil cartridges!!! It is also small (actually the smallest I've seen), compact layout and nice looking 🙂
The basic version is a 1:1, 10k:10k, 80H@20Hz, but other transformer ratios can be made. The logarithmic curve is according with IEC 60393-1 code 15A law. For this 1:1 version see the THD figures for 0.7Vrms at highest step (with the soundcard having about 0.0005% THD in loopback), also the frequency response 10-100kHz, these specs being of course in the same ballpark at any step.
Price: 650 Euro w/o shipping for basic version
(other transformer ratios and balanced options available for some extra - to be agreed what's possible or not 🙂 ). Also, I can provide it wire terminated to be mounted inside your chassis.
Thanks, take care!
My Horrible Day
Began two weeks ago when I got partway through assembling a PSU for an OMICRON HPA. Then realised I'd ordered SMD rect. bridges not THT. I devised a cunning plan to straighten the legs on the SMT parts and solder them in place. It worked just fine the legs went over the THT holes. Then I discovered that the res. caps that sit close to the bridges wouldn't fit because the SMT parts protruded 0.5mm too close to them.
So I ordered some THT parts. They arrived and my day began.
I desoldered the SMT bridges. The holes in the PCB were full of solder of course. 6 of the 8 cleared with braid, the other two were complete swines. Eventually got them clear using liquid flux and a fine pointy iron bit and banging the board on the table. Was just finishing up when my sleeve caught the top of the flux bottle and I had a flood of rather nice smelling liquid flux.
I got workpiece, components and tools clear in the nick of time, fortunately the flux is quite thick and flows relatively slowly. I cleaned up with IPA. Soldered the replacement bridges in and the res. caps fitted. Hooray!
Then I put in some smaller film caps, almost as soon as I'd done it I realised I'd soldered the wrong caps in two places. This was especially irksome because I'm aware of my lack of electronics knowledge, how much harder it makes fault finding, and I bust a nut to remain organised and double or triple check everything before soldering. But not this time grrrrrr.
Desoldered them, cleared the holes (eventually) and went looking for the correct caps. I know I've got them, but can I find them? No. They were in a box with all the other bits for the PSU with their board references written on their bag. But not any more, they've been stolen by aliens. Obviously.
Also, I kept finding sticky patches on my worksurface where I'd swear no flux got to, and having to break out more IPA to clean them.
At that point I decided I was doing more harm than good and went for a break. Came back, looked at the mess and decided I'd had enough for the day...
Questions about making Hi low, low high Z box for using mics with guitar pedals.
Hi there,
I have started to build a box that I want to use on stage so I can run my own effects. Vocal pedals are too limiting imho. Something like the eventide mixing link or the radial vocoloco, but more simple and not $350+
So mic in > transformer > fx loop > transformer > mic out
I’m wondering: do I need a preamp and not just a transformer? If so, is there a simple/small diy xlr preamp kit that could fit into a small enclosure? I keep wondering what is in an audio interface because it probably costs next to nothing.
Also, is there a specific set of transformers someone could recommend? I took one out of DI box and another one out of an in-line low-high z plug. But after the first run prototype I want to make a better one with any revisions that come to mind. I hope to keep the cost as low as I can but still sounding good.
I’ve seen some very small preamp pcbs on Ali express but not sure if I should but the bullet or if I will run into issues with PSU requirements/complexity.
If you were going to build such a device and wanted to keep it simple, how would you go about it?
Polystyrene Cap Replacement, any Benefit?
Hi Gents, I've read so much on this, but don't think reached any kind of definitive conclusion - what is the consensus here on any benefit to replacing polystyrene caps?
I'm working on a rotel amp, they tend to use these in the signal path - any benefit you guys think of replacing these with WIMA polypropylene? Or maybe something with different tolerance?
QUAD FM4 problem
Hello all! I recently bought a Quad 44 that came with a faulty FM4. It couldn't pickup stations and was drifting. After opening it up I saw a number of faults, leaking capacitors and a blown AFC capacitor. The battery though had been replaced and had not leaked on the board, which was nice. I scraped away the paint around the areas of the leaking electrolyte until the copper was clean, put some flux and solder on and cleaned up with a solder braid. No traces seems to have received any serious damage. After that I performed a full recap and replaced some resistors that had taken some damage.
It's now working, stations are precisely at the frequency they should be and reception is good. The bandwidth ends at 104.3 which seems kinda low though. The problem I'm faced with is that at turn on number 3 on the pre set is on, and the rest of the pre set's, as well as the "Tune" button, is not selectable. So it's stuck at number 3. I've measured the 1n823 diode and there's 6.21volts across it. I've also replaced all 1n4148 diodes. I've also replaced the LED diode which was broken. The rail voltage sits at exactly 12volts. Could this be a fault with the TMS1000 chip? Anyone else had this problem and know's where to look next?
6CM5 (EL36) Vacuum Tube pinout question
HI All,
I am just beginning my journey with vacuum tubes and was hoping to build an amplifier. I picked up a mixed box of old/used/nos tubes that contains 16 x 6CM5 (EL36?) tubes that may be candidates for an amplifier. I have noticed several brands of tubes (AWA, Mini Watt, Radiotron, Toshiba) with either 5, 6 or 7 pins on the base. I don't have a tube tester yet but thought I would just check continuity for the heater between pins 2 and 7. This checks fine for all the tubes but I also get continuity on pins 3 to 8 on the 6 and 7 base pin models. Is this correct or are these tubes shorted ? I managed to find several datasheets but that often indicates pin 3 is an "Internal connection".
Any help appreciated, clearly I have a way to go 🙂
Richard
The new Mark Audio CHN-110 6" driver
Did someone already build something with this driver? It took my attention also when they were announced a year ago or so and they finally (thanks covid for the delay) came availeble in my region so i ordered a pair. I'll probally design an own enclosure but i was wondering if someone did already do something with it and what their impression was.
Specs and graphs that are published promise a lot i have to say, and my first sims also. I'm thinking to make a 40L ported cabinet tuned to 38Hz with it after simulating some options. If the data is correct this could be a deal breaker at 60€ for such an 8"(actually a 6.5" if you distract the bezel) i think...
Fet10HL Audio/Video Input not working
My Threshold Fet10HL works perfectly with the exception of the Audio/Video input. I have tried known good sources and other inputs to make sure the problem did not exist in the source. It is definitely the preamp Audio/Video input that is causing the issue. I get no sound from any source using the Audio/Video input on the preamp. Any idea what conponent/components could contribute to this problem only existing with that particular input?
Troubleshooting a Dynaco ST-35 noice scratching in one channel
Hi. I recently changed out all capacitors in my dynaco st-35. All was working great afterwards. Then suddenly a receive scratching clicking type noise in one channel. I take out all tubes and it is silent. I have changed the tubes out but the same problem.
I then notice after about 3-4mins smoke coming from #5 eyelet on the circuit board. Could this be too much voltage on this point.
What should i replace to solve.
Many thanks. Regards. Martin
Use Z680 Pod control in the Z5500 subwoofer, wiring provided [solved]
Hello,
I have a Z5500 subwoofer unit (PID R745), I managed to enable as subwoofer for my home theater following other guides.
Recently I got a Z680 pod control for free, but sadly is not compatible with the Z5500.
Both uses de DB15 connector (like VGA), I connected the pod to the subwoofer and the pod powers and lights but I get no sound, luckily nothing blew out.
After research a wiring diagram without success I spend a few days to investigate, I managed to turn on the subwoofer and control four channels and the subwoofer (I cant get the center channel working)
Explanation of the table
The table of the left enumerates the pins in the Z680 pod (DB15 female), the third column indicates in which pin is connected in the Z5500 unit.
GND: Ground
NC: The pin is not connected to the Z680 pod
A dash is placed where the pin is not connected to the Z5500 subwoofer
The table in the right enumerates the pins (DB15 male) in the Z5500 unit
Enable the subwoofer (PID 745)
Is important connect the pins 7 and 8 of the Z5550 to pin 13 in the same connector of the Z5500
this is enable and mute to ground. Without this the amps does nothing.
Check for your PID label outside in the bottom (is a heavy unit). Other PIDs may need another bridging or +5v supply
Weird ground in Z5500
I don't know why. But the ground in the Z5500 behaves bad with the Z680. Testing with the multi meter and the Z5500 powered off, the pin 13 is the only one connected to the general ground. But if I connect only this ground to the ground of the Z680 and the +8v. The ground sucks a lot of current. The Z680 cannot regulates the +5v of the standby and the LCD fades out. The only ground that work for my unit was the pin 11 of the Z5500. You can connect to any ground of the Z680. May be this is related to the center channel Issue.
This problem was the stop point for me in these days.
Z680 How it works
The Z680 receives +8v on the pin 10, and enter in stand-by, when the power button is pressed the LCD screen lit and the stand by pin (#7) provides +5v. May be this was the signal to power on the amps in the unit.
I suggest to test this before go for the full cabling. (pins 10 and 11)
The +18 and -18 provides the voltage to drive the audio preamp. You can connect headphones with only the +8v but the sound is weak. The +-18 volts provides the power for a proper preamp of the signal before send it to the unit.
In fact, the Z680 unit is a nice preamp as stand alone. May be you can drive a heavy headphones with this. But the +-18 is necessary.
Center Channel
In this config the center channel is not working. May be my center channel amp is blown, but I cannot get any sound from this. Or may be is related to the grounding issue. In fact i get sparks when I open the Z5500 subwoofer to fix the +18v problem.
DB15
The DB15 connector is the same used in the VGA cables, you can cut and reuse a VGA cable, but I think is better use new solder connectors, these are cheap and easy to solder.
The pins are numbered viewing the male connector by the side of the pins, the wide part on the top. Top to bottom, left to rigth: This is the standard way
Fix +18v supply of the Z5500
When i was testing, I connect the +18v supply to the +8v in the Z680 pod (Don't do that). This fixed my poor grounding issue and the LCD stays lit... for a few seconds (30s may be) and then, I get nothing in the +18v pin of the Z5500.
Checking the Z5500 PCB, the 78M18A regulator provides the power for the +18v. near of this is a 35.5 Ohms resistor (brown). This is the fuse for overdraw current in the regulator. I tested +31volts in one leg of the resistor and nothing in the other (was burned). I replaced the resistor with a 33 Ohms (0.25 watts rating) and the sub work fine.
Be careful
Open the Z5500 is risky, for you and the unit, take care, disconnect before check. The capacitors are big and have enough power to make a short circuit and damage the components.
Always power off the unit before plug or unplug your custom made cable to test it.
Be very careful with the multimeter points..
I made this post after read many others. Thanks to all who managed to provide diagrams and tips.
Sorry for any typo or grammar mistake, I'm mexican, and english is not my native language.
Any suggestion or question is welcome.
F5 buzzing issue
Dear guys,
FInally, i have made F5 - took the longest time ever....
Aynway - when i connect the amp input to ground - it does not buzz...
When i leave the input of the amp open - it does not buzz....
When i connect the source to my F5 amplifier (i am using M2Tech Young dac with variable output as a dac and preamp right now) - it does buzz... i an listen to music but it buzz....
My amp boards are from diyAudio store
Tried to connect the 10R resistor on the amp pcb and that to my signal ground... it did nothing or very little....
will attach the some pic's and grounding schematic (sort of)....
thank You all for your time.....
edit: on the inside - two smaller boards are soft start and protection from Welleman
Dual 866A display questions
Hi! So first things first, I understand everything about the dangers of these tubes and how to properly heat them and all that other jazz. I also have worked on guitar amplifiers for a few year. So, I’m green but not green green. With that said, I’ve always wanted to build a MV display of sorts, flip switch ohhhh ahhhh kinda thing. I have two NL866a and their filament transformer that came out of a Kepco power supply. I’d like to somehow not use a second transformer for the plates and just stick to the two tubes and the FT. I crudely made a sketch. Laugh away 😂. Am I in the ballpark? Do I need resistors on the leads going to the plates? Again, Just trying to get em to glow for a display. Thank you!
300b drives 300b, with interstage transformer
Hello…
Driving a 300b always seems to be a point of discussion, but I can’t seem to find a mature schematic for a 300b driving 300b - any out there?
(I also note that some designers, like Thomas Mayer have also made 211 driving 211).
Ideally I’m looking for a two stage 300b pse/pp amp with interstage transformer and an input sensitivity around 2v or thereabouts.
NAD C270 (C272) Power Amp Protection Mode - Stray Negative Voltages
Hi everyone,
I bought a non-working NAD C270 power amp a couple of weeks ago. I've made quite a bit of progress but there is still a problem somewhere (I believe) in the LEFT channel Power Amp Board. I’ve already repaired the oft-failed 68V power supply (see photo).
I wouldn't say I am at the end of my tether, but I am out of my depth understanding the fault on this one. I've read a number of forum entries here for fixing the NAD C272, which is very similar and I am using the C272 schematics because I can't find ay C270 ones. Clearly many people here on diyAudio understand schematics waaaay better than me and also some have first hand experience of these models. So any guidance or insight would be fantastic.
Current Symptoms
Amp stays in protection mode unless L channel Power Amp Board disconnected. Offset bias test points (TP2 and TP8) giving more than 56V on L channel compared to 25mV on R channel. Looking in more detail shows that the Power Amp Board comprises of a 68V end and a 64V (power transistor) end. These two ends are joined by only two connections; R328 (100 Ohm) and R356>R319+R322 (a L-FDBK call out on the schematic). All around R328 I am seeing high NEGATIVE volts compared to the right hand Power Amp Board (relative to ground).
I can't work out exactly which end of the board (68V or 64V) these volts are coming from. Initially I suspected Q311 as it was showing -64V at the collector compared to -0.03V on Q411 (same transistor on R Power Amp Board), so I replaced Q311 and then Q310 (positive side equivalent) and then the 4 diodes (D303. D304, D305, D306). Just about every other component (save a few slightly low capacity electrolytics) seemed to test ok in circuit.
TLDR;
I've got high NEGATIVE volts running along the signal path (e.g. at the offset bias test points) on the LEFT channel only. The amplifier runs correctly with just the right channel in circuit. I can't work out how to begin finding the shorted/failed/open component on the L Power Amp Board. I've marked some schematics with my measured voltages (with CZ719 disconnected). Can anyone read my numbers into the schematic logic and suggest where I look next to find the source of these high negative volts? Main schematic attached. Any help appreciated!
Finishing a C3M-300B
I've been off-and-on working on a C3M-300B two-chassis amplifier for a while. Everything is completed except some of the final grounding in the signal chassis. I wanted to ask the forum for advice on these last few ground connections before drilling any new holes in an otherwise finished chassis. Here's the info:
The two chassis are connected by a 10-conductor umbilical. I have 2 free signal grounds and one dedicated chassis ground running through the umbilical. The chassis ground wire also connects the umbilical copper shield at the PSU end. The L+R channels are outlined in the schematic diagram below. How would you best connect the left and right ground busses as well as speaker grounds with the available connections?
Thanks for your input. Picture are below.
Need amplifier tester - NE FL/SE Georgia
I have three tube amplifiers including two kits recently constructed (one of them still in progress actually). I'm looking for someone in Northeast Florida or Central Florida or Southeast Georgia who can spend a few hours one afternoon with me putting them on a 'scope for testing. I'll drive them to you. I haven't touched a 'scope in over 30 years and don't have access to one. Even if I did, I'm not qualified.
Anyone within a few hours of driving available for some testing? I'm in northeast Florida near Jacksonville.
Thanks!
Help buying or building 2-way 350hz xo
I would like to take my already made 2-way monitors and make them into a 3-way by adding another driver, ideally I would like to just add a 12Db butterworth XO at 350hz between them and hopefully without issue.
Question - Can I just design it in xsim and build it Or is there one out there I could just buy? And… how hard is xsim to learn / do ( I haven’t even downloaded it yet) if I have to? If no to both could someone just design one for me and I’ll order the parts and build it?
Details…
1. See photo - The tops are 2-way HTM12’s (green) and the bottoms are single 18” pa460’s in a 42hz box (Blue).
2. I have been running theses for two years as a 3-way (red) on a nu1000dsp amp (three amps - 6 channels - six speakers). Before eq these are an spl match so no l-pad will be needed, only some light peq will be enough.
3. These will be FULL RANGE (NOT AS A SUBWOOFER) so I WILL BE running the 18” pa’s from box tune (42hz) to 350hz and the HTM’s from 350hz and up.
4. I will be pushing a couple hundred watts to each 3-way…. Let’s say 400-600 for fun, I’m going to mono my nu1000dsp amps for each set.
5. The Htm’s and the pa460’s are 8ohms.
Source(s) for large project boxes for external crossovers (
I want to move my crossovers into external enclosures, but I can't find any ABS or polycarbonate project boxes that are large enough. I've found some industrial-type enclosures, but the prices are ridiculous.
The PCBs are 16" x 10", and a few components stand about 3-1/2 inches in height. I'd like to have a little extra room so something a minimum of 18" x11", and at least 4" deep, would be ideal.
North Creek Music had some big enclosures for their B&W 801/802 crossovers, so something similar to those.
  • 2891257-39a0a7f9-north-creek-crossovers-external-for-bampw-matrix-802-series-3-loudspeakers.jpg
Schematic wanted for VTL Preamp "Maximal"
For this preamplifier I need schematic diagram
I don't find a download aera about
Music creates the dimension
and
Manley_Laboratories_Hi-Fi_Main_Page
perhaps one of you know, where I can ask - thank you very much.
in the attachement some pictures of this preamp:
Vintage SABA oval fullrangers?
I just bought a pair of those vintage Saba Oval Greencones Alnico. They are 17cm x 11.5cm. Apart from the classified stating that these are 5 ohms and have the 1678 CU 60 reference printed on the backs, I cannot find any kind of informations about them. I browsed some very old school german website & forums, but still couldn't find anything.
The seller said these were sold as tweeters, but are actually very competent fullrangers. They're made of paper, and the magnet looks pretty big and heavy.
Does anyone have more informations about them? I think they look really cool and would deserve a really beautiful cabinet. Although I'm pretty sure they would need some assistance in the bass region, probably...
An electronic device that I developed to sequence power and control 4 wire fans
I'm posting this on the multiway forum because I designed this for a 3 way stand mount I made and converted to an active setup. I hope it can stay here because I think there might be some interest to others in this forum. Based on some advice I received on this forum I picked up a QSC Basis DSP on eBay and a multichannel power amp on Craigslist. The problem I needed to solve was powering on the the DSP because it has no 12V trigger input. Initially I put together a simple relay with a delay board I found on Amazon. It worked, but the delay board was a pain to program. So, since I started my career as an electronics technician I figured I can do better. At this time the Raspberry Pi 3B+ was cheap and readily available so I wire wrapped up a board to connect some relays to the GPIO bus. Little did I know at the time what was going to happen to electronic component availability and especially what happened with the Raspberry Pi. Once I had the prototype I solved the second problem I had, the micro fan in the DSP was very loud. To solve this I added an A2D chip to read the internal temperature of the DSP and replaced the fan with a 4 wire Noctua fan. Now since the fan has a tach output I added a frequency to voltage converter to read the fan speed. Finally I added more connectors to use all the unused I/O ports. All this is the usual project creep we all experience. At the same time I was learning Python to make this thing work, my programming experience had all been with assembler, C and C++ so my Python code might not look right to a Python programmer. I designed the code to be configured by editing json files or using a networked programming interface. Lastly I used NodeRed to build a web front end.
First off, I am not selling it, it is completely free to any body and I have documented it the best I can on my website. Now that Raspberry Pi are obtainable again I am releasing it to the community. I had 5 printed circuit boards made for each component, an I/O board, 5 amp relay board and 15 amp relay board. I have a few left and I will give them away. If you want a board stuffed with the electronic parts I am willing, but you would have to pay my cost for the parts. Here is a link to everything, BoMs, Gerber files, code and documentation. If you find any typos (well not if, when) let me know. If you you have any questions ask her, Pm or use the contact me on the website.
https://www.bellarossafabrica.net/av-power-manager
Reactions: kipman725
Putting out some feelers today. Would anyone be interested in trying to build a Lil' Pucker if I upload the files to Printables.
Putting out some feelers today. Would anyone be interested in trying to build a Lil' Pucker if I upload the files to Printables. Also thinking about doing a series of build vids. Just a notion, but if there is any interest I might move ahead.
Reactions: alighiszem
About QUAD 606
In fact, I have already produced QUAD707. So there's no need to make QUAD606 again
However, due to some DIYER currently producing QUAD606 (TO3 transistor version)
I think this version is too difficult to install.
Moreover, QUAD707 has a relatively large width.
So I made QUAD606
In fact, he is almost indistinguishable from QUAD707.
Okay. It's just a difference in appearance. So I don't need to repeat the characteristics of this amplifier.
You can refer to QUAD707.
https://www.diyaudio.com/community/threads/quad-707-diy.399543/
It's just that its shape is a bit different. It is more like the installation method of L20 amplifier.
I think it can replace QUAD405. It is indeed more effective than QUAD405.
There are many circuit introductions available online on QUAD606. Interested parties can simply go to Baidu.
crossover circuit : 2nd or 3rd order?
Hi everyone, I'm a new member, honored to be part of this community of fans.
(I'm Italian, sorry but I use google translate)
I have a technical question to ask you: I have a Berhinger equalizer and I can not understand the operation of its high-pass filter shown in the figure (the section in the blue box), or rather it is not clear to me how to identify the model that determines the order of the filter. From the bottom of my ignorance it seemed to me a 2nd order and calculating the min and max cutting frequencies you get values equal to about 10Hz and 250Hz. On the potentiometer instead 10Hz and 400Hz are indicated and in the description of the command we read: "The LOW CUT regulator establishes the lower frequency of the limit of the ULTRAGRAPH PRO. The high-pass filter (18 dB/oct) is adjustable in a range of 10 to 400 Hz. If this filter is in the 10 Hz position, let the signal pass through without affecting it in the slightest."
Can you help me understand the pattern and determine the formula to calculate the cutoff frequency? Does the 100 Ohm resistor (R176) have anything to do with it?
Thank you very much if you can clarify this point for me.
(the goal is to replace the potentiometer with a switch and resistors to have preset frequencies)
"The Wire" Ultra-High Performance Headphone Amplifier - PCB's
A new run of these boards is now available! Please see the following thread for details:
http://www.diyaudio.com/forums/soli...ble-here-bal-bal-se-se-lpuhp.html#post3516741
There is a Wiki here which contains all the project information, documentation and details for all "The Wire" projects:
The Wire - All Boards and Kits Explained Here!
Hi Guys,
I just finished building my latest headphone amplifier project, and this one is definitely worth sharing with the community. After a few prototypes, I went ahead and had some PCB's made, and there are plenty extra available if people are interested.
I basically wanted a headphone amplifier that was as close as could be to a wire with current gain. I didn't want it to impart anything at all to the source signal. That led me to the following design criteria:
- Perfectly flat FR from DC to over 100kHz
- No phase shift from 0-100kHz
- No capacitors (except for PSU)
- Extremely low harmonic distortion
- Extremely low IM distortion
- Extremely low noise floor
- Ability to drive down to 4 ohms with no load dependence
- Enough voltage swing to drive any reasonable headphone set.
- Excellent input CMRR
- Simple circuitry using the best parts available.
I needed a balanced input, and wanted to use a standard 1/4" jack for the output.
The resulting amplifier is basically an instrumentation amp using three LME49990 op-amps and an LME 49600 buffer nested into the last stage. These parts represent the absolute best you can get for this sort of application. I used all 0.1% Susumu thin film resistors, and all X7R ceramic bypass capacitors placed directly on the supply pins. Bulk caps are all solid polymer for the absolute lowest ESR and best HF performance. Layout was optimized for short signal length, low noise and low crosstalk.
The circuit provides differential input, or the option to ground one phase and drive the circuit with an SE input. Gain is set to 1, but can easily be changed to pretty much anything with just two resistors It runs on +/-5VDC up to +/- 15VDC and has enough drive to run anything you can throw at it.
As for sound, having a DC coupled amplifier makes for some of the most stunning bass I have ever heard. I'm driving a pair of Denon AH-D2000 headphones, and there's a world of difference between this amplifier and every other source I have ever tried when it comes to performance below 100Hz. It has incredible impact, depth and cleanliness. In the midrange and top end, it passes on the characteristics of the source like nothing I have ever heard. I've driven it with an Aikido linestage, a BZLS, straight from a DAC and a multitude of other devices, and all you hear is the device driving it. I now use this setup as my primary means of evaluating all preamps and sources since nothing else I have ever used even comes close to exposing the true nature of the sources like this circuit does. It's honestly like it's not even there... hence the name.
I've attached some pictures of the finished product below, and I'll follow up with some measurements done on an Audio Precision. Schematic to follow also.
Owen
Goldring 1012 GX Cartridge Head Shell Compatibility
Hi - I am planning on changing the head shell on my Audio-Technica AT-1005 Mk2 tonearm and am wondering about how I will re-mount my 1012 GX cartridge as the two head shells are quire different. My existing head shell is an Audio-Technica MG9 which has the mounting screws screwed from below the cartridge into the body of the head shell, whereas the replacement head shell, an Audio-Technica S8 is of a more skeletal design that looks as though it would need nuts to secure the two bolts. Perhaps I just need to purchase the nuts? Are they all a standard size? I'll attach a couple of photos of my existing arrangement and one of the new head shell that I have ordered. Thanks.
Best capacitors for power supplies update
Electrolytic capacitors types for power supplies come and go. They attend different demands than stages interface or other more subtle applications.
Some are large and recommended for main raw filtering, usually before regulators. Some are small and have to take care of smaller currents.
Raw supply filtering usually requires low-esr and high temperature, even if large cans rarely fulfill any of those. That's why some people use smaller caps wired in parallel. Caps after regulators usually DON'T have to be low-esr.
The question is which brand types have worked for you in both places.
High Efficiency Open Baffle w/ 10" Woofer
Greetings all,
I’m planning my next system to correspond with a new apartment. It’s a 700sq/feet with lofted cielings. The walls are very thin so I can’t bring my previous system with me. I’m trying not to disturb the neighbors. The follow are my thoughts on a system using parts on hand, but I'm open to suggestions about what would work best with the space
I already have two full range audio nirvana super 8s laying around so that’s where I’m starting. From there I have two choices: build an enclosures or go open baffle again. I have the room to set the speakers a yard away from the real wall with ample room to either side—near to mid field listening. Behind the listening position will be the kitchen.
I want to use 10” woofers in open baffle for the form factor and because I can’t have a lot of bass without disturbing the neighbors. I’ve invested in a nice set of headphones for bass heavy music. This system will primarily be used for jazz and some classical (opera).
I have an iNuke amp as well as the dual 50w ice power module to play through a miniDSP: although, I’m not beyond building a traditional 1st order crossover as well to keep amplification more tidy.
I’ve used the eminence 15a and Acoustic Elegance 15” infinite baffle thus far. Both are fantastic woofers. While the AE does really well with R&B I find the eminence’s reproduction of the upright bass fidilous in a way that makes me nostalgic for my days plays bass in high school.
The Audio Nirvanas are about 96db.I figure a bass shy system dedicated for jazz listening will keep me in check. I’ve only ever built mono systems so I am especially keen to hear in stereo for once. Sound stage and imaging are things I really want to explore.
For jazz I really appreciate a dry nimble bass.
I much prefer open baffle for ease and cost of construction, but please weigh in on what you think is right for my particular space. I’m enclosing a floor plan. No windows except on the right side of the drawing. Room treatments would be a next step and the floor is carpet.
What should I look for in a single or double 10” woofer setup that will reproduce the upright bass faithfully? I’m looking for dry and articulate.
My budget is $200 for woofers.
I’m going to cross over at 200hz and these are some of the woofers I’m looking at; although, other suggestions are very welcome.
Here’s some possibilities:
  • GRS 10SW-4 (QTS 0.93 90db)
  • Visaton WS25 (QTS 1.43 but 88db)
  • Acoustic Research, available on eBay, (Qts 0.715 93db)
  • Goldwood GW-410D (Qts 0.61 96db)
  • Faital 10FE200 (Qts 0.5 96db)
6GB5 and Variants as Screen Driven Amps
I've been semi-obsessively collecting 18GB5/LL500 horizontal output tubes, as they are cheap and have a nice tall, skinny form factor. Has anyone out there tortured them in a screen driven amp? They have nice, thick glass envelopes, and the only disadvantage that I see so far is that they need a magnoval socket. I suspect that they are fairly common in Europe, as even the domestic versions are largely made in Holland, probably by Philips. They are rated for 17.5W plate dissipation, just like a lot of their squatty duodecar siblings, but I suspect the plates can take more, as they look pretty substantial for all manufacturers I've seen so far.
Death of Zen 15 watt Power Amplifier
DOZ - Death Of Zen 15 Watt Power Amplifier
Hi all.
The existing threads on DOZ seem to be about complains targeted to people who are not related to this amplifier and/or hollow debates on the supiriority of one amp over another.
So here is a thread where we can concentrate solely on DOZ as a standalone amplifier which produces music comparable to the sound of the best DIY Class-A amplifiers available.
I built both Capacitor coupled and Direct coupled versions; both with their advantages and disadvantages. The cap coupled version has less demand on the PS filtering and is less complex, while the direct coupled version has more stable bias and subjectively cleaner sound with no capacitor in the output and the feedback path.
Cheers...
PS. No Flaming Please, Comment only if you are interested in DOZ in a positive way.
Luxman M03
In the luxman M03 designer placed transistors on heatsink one by one, one N and one P.
That creates a mess on the pcb resulting copper flat bars installed for power distribution.
I understand that a practice like that will equalize tenperature better and probably in combination with the copper bars might also have equal or better rail distribution or equal draw of current between a number of transistors.
I expect that this will have some effect on the distortion figures of the amp, and i also expect that if the amp is pushed wilk behave better due to better and equal power distribution. That can also effect the sonic signature providing better kick for example or better drive abilty.
I think though from one hand that this type of diference will be marginal but on the other hand Japanese never did anything that is marginal
To proceed with a thing like that something waa important.
Opinions?
Am I missing something else here?
Sony CDP-M11 and optical laser KSS-240A replacement and adjustment
I'm restoring and old CD player Sony CDP-M11 for my brother in law.
The first problem was that after 1 min 30 sec, the reading was in default, and run directly to the end of the disc.
First I've cleaned the optical laser with the Isopropanol, but without success.
Then I decided to change the KS-240A.
The replacing was easy and without any problems.
Then I've tested the reading with an new and Original CD.
First, the optic control the disc and recognize it, it notify that they are 16 tracks on the CD.
I launch the playing, and read the disc correctly, but, only on the five first tracks, when it comes ont the 6th, it stop and say that they are no disc into the reader.
I've tryed with another one disc, with 10 tracks, long player songs (5 to 7 min each). And it does the same things, it read only the first four tracks, but stop at the fifth track
How may I to adjust the optical lens for having a complete reading of the disc?
For information, I've no knowledge in electronical and have no scope.
Sorry for my approximative english.
Thanks for your help and advices.
Model TH request for sph-390tc
Hello,
Would a TH expert be so kind as to model a TH tuned around 18hz (or lower if possible)? Curious to see what this driver can output in the very LF. Crossover will be @ 80hz. I have zero experience with hornresp.
I have a sph390tc and a second one coming soon. I would like to build 2 tall subs with a small footprint that will function in a home theatre.
My current sub is a large vented one that does the job pretty good. It's time to change things up and take advantage of the low distortion and high spl that comes with a TH.
A nad 214 (2*80W @ 8 ohms, 2*120W @ 4 ohms) with power cap mod will power the setup. Reviews have shown that the specs are conservative which leaves a little headroon. A minidsp will do some HP protection and in time REW.
Much appreciated!
Best flatpack enclosure for 8” Sub
Just got an 8” SB acoustics sb23mfcl45-4.
https://sbacoustics.com/product/8in-sb23mfcl45-4/
I want to build a compact subwoofer to go with Neat Iota’s that have a frequency response of 60Hz–22kHz. Does anyone have an opinion of either of the below Denovo boxes or know anywhere to source plans that could take to a wood shop.
https://www.parts-express.com/Knock-Down-MDF-0.56-ft-Bookshelf-Cabinet-300-7064?quantity=1
https://www.parts-express.com/Knock-Down-MDF-0.67-ft-Subwoofer-Cabinet-300-7068?quantity=1
Next question is sealed Vs passive radiator.
Cheers
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,757
Members
7,887,071
Messages
Filter
Forum Statistics
Threads
406,168
Messages
7,887,071
Members
507,757
Latest member
jossdorn
