Cary 7.250 front end board
Has anyone out in webland got a schematic for the little front end daughterboards used in the 7.250 to convert from balanced (XLR) to unbalanced. I know this SHOULD be dead simple bot the boards contain a bunch of other semis whose function I cannot determine. Amp came in with a deceased THAT1250 which is a very rare beast indeed and theoretically interchangeable with a SSM2141 (which I stock). Regrettably the theoretical did not match the practical and the SSM did not work well.
5C8S and low capacitor value
I decided to buy a few 5C8S rectifier tubes to experiment with because they look cool but also handle a good bit of current, double that of a 5AR4. They're still in transit but I'm studying the specs. Using a translate app to read the datasheet it's saying the capacitor input value should be 4uf? That seems very low for a tube rated for this much current. It's indirectly heated so the startup should be slow enough. Wonder how they came to that figure? https://frank.pocnet.net/sheets/084/5/5C8S.pdf
Inserting a decent DAC chip in a Sony CDP397 player
This player is a Sony CDP397. Inside is mostly empty space. It uses a CXD2500, which produces a set of signals similar but not exactly I2S, which is what the TDA1543 (the new DAC chip) expects. The main issue is that the LRCK signal changes state too early, by 8 sample bit clocks. The TDA1543 grabs the first 16 bits it sees when this LRCK changes state, and ignores any more bits that come along. Thing is, the CXD2500 runs a bit clock 24 cycles times the "word" length. Instead of 16 times the TDA1543 expected. The CXD2500 sends the MSB bit for teh first 8 clocks, then the rest of the bits. But the TDA1543 grabbed 8 bits of MSB and then the next top 8 bits of audio data, which made the sound very low, and would sound like 9 bit audio, yucky. To get around this I decided to build a delay circuit to make a new "WS" (thats what the TDA1543 calls the LRCK signal) off a counter counting out 7 cycles of sample clock, that in turn triggers a latch to grab the state of LRCK and assert it onto a new WS signal that then feeds the TDA1543. This in turn makes the TDA1543 grab all the audio bits correctly.
I didn't remove the old DAC chip (one of those noise shaping thingies) out of the player, it feeds the headphones, and it houses the master timing oscillator.
I haven't built the tube circuit just yet, as I need to round up a power supply for it. Now I'm feeding the DAC output to an audio amp for testing.
The hacked up board used to be a piece of a PC soundcard, one that used the TDA1543.
Sealed box woofer arrangement
After reading a couple of threads, mainly centered around the slot-loaded open baffle design, I wondered if there was a sealed design which would allow drivers to be mounted facing each other.
The only real reason for this was instead of having a line source of drivers that resulted in a tall box, could the effective height of the box be halved using, say, a 2x2 arrangement rather than a 1x4 line source? The volume of the box would need to be compensated elsewhere, so maybe this hasn't been explored much.
Listen to 6DJ8 Triode through Power Chip IC. Easy project.
The idea can be seen in diagram.
This is only a basic simplyfied schematic. I post in more details later.
Should be noted that these circuits are so far only in my SPICE.
But should work good and give fine performance.
Power chip OPA541 can fead 50 Watt into 8 Ohm.
Max rails are for the chip +/-35 = 70 Volt.
Here I run 6DJ8 and OPA541 at 66 Volt.
Even if OPA541 can amplify voltage, in this case it is used as buffer.
Voltage follower at unity gain.
What come in comes out to speakers.
Distortion is low and can not be perceived as effecting sound.
This means that 6DJ8 totally dominate the distortion, the effects on sound signal.
There are 2 alternative circuits.
One where Triode plateload is resistor, 100kOhm.
One where Triode plateload is a CCS constant current source.
Big difference where CCS gives near hifi performance
and resistor load gives more Triode Tube sound.
Enjoy 🙂
Scratchy pot on Tenghong low pass filter
In an attempt to slightly upgrade the quality of the lowpass filters I usually use, I got me two of these: https://nl.aliexpress.com/item/1005...t_main.47.21ef79d2zUlmi4&gatewayAdapt=glo2nld
The picture shows it next to the other filters I have in my spare drawer:
The left one needs 12V DC, the other two between 9-0-9 and 12-0-12V AC power supply. Only the center one has 'proper' Voltage regulators on board.
I connected one board to a mono amp and used the combo to power my subwoofer in the living room, worked fine.
But, after a few hours powered up, the volume potentiometer produced scratching noises when turned, loud enough to be heard over the music. Weird.
Turning the board off and on again the next day made no difference, the scratching was here to stay, no big deal as long as you don't turn it...
Out of curiousity, I swapped the first board for the second one and the same thing happened; after a few hours of working fine, with a silent operating pot, this one also started scratching.
I suspected DC offset, so I measured the Voltage over the outer legs of both pots: 4,45V DC on the first and 4,2V DC on the second board.
The first measurement was with the input and amp attached, so the DC could have come from my input signal (PC soundcard in my shed and the sub out in the living). The second board was measured with nothing else than the power supply connected.
I've contacted the vendor and asked for a schematic, to be able to check things out.
But this is odd, isn't it? Over 4V DC over the volume pot on both boards. No, I didn't measure prior to both boards developing the scratch..
Ideas, suggestions?
Regards, Jan.
Hum even after capacitor replacement
Hi everyone, I bought from eBay a pair of iTeufel box monitor speakers, sold as not working (but I was planning to use them to make a DIY soundbar). That said, I plugged the main speaker and it was actually working, but with a 100hz loud hum. I thought after reading some forums that replacing the 2 main capacitor would have solved the problem (even if the old capacitors that were on wasn't looking bad at all) so I bought 2 new capacitor and put them on.
After the replacement, sure that the hum would have disappeared, I plugged the speakers, but the hum still there 🙁
I tried to check everything, I am pretty sure that is an amp problem and not a ground loop, but I am here as a learner to learn what the problem could be!
I'll attach some photos of the amplifier, but if you need more, feel free to ask for them 😊
Thanks, Marco
Mullard 5/10
I am currently making a component shopping list for the 5/10. For the high-stability resistors (R4+5), I found a metal film type for these at 1%, am I going down the right road or is there something better? As for the remainder, apart from the volt droppers (R7,14+22), would it be OK to use the same as (to keep the supplier down to a minimum), as for the wattage, would Ibe doing any harm by increasing the 0.25 w to 0.5w and so on. My only thought is the cathode load resistors ( R18+19)
Is converting a 220v PSU to 110v as simple as changing the transformer?
My naive thought is that the original power supply would have a transformer that accepts 220v and outputs X, which the rest of the PSU circuit can handle. So, it would seem that replacing the transformer with one that accepts 110v and outputs X would work, since the rest of the circuit would see the same voltage. Am I misunderstanding something?
DIY Small CLOU design variation
Hello everyone!
It's been a while since I've been lurking on diyAudio, observing what's going on. I'm glad I finally have a good reason to post!
I moved from France to Canada and had to leave my pair of Atlantis Lab behind. Immediately, the idea of getting a new pair while waiting for the other one to arrive from overseas sparked my desire to build one myself for the first time.
Objective
My goal is to build a pair of studio monitors for sound editing and mixing. It's obvious to this knowledgeable community that it's an ambitious project, especially considering my first constraint. Nonetheless, it remains the guiding principle and the purpose for which I will ultimately use them.
Before we continue, I want to emphasize that I am fully aware that what I am about to present is merely a projection. None of what is established here will definitively tell me how these speakers will actually sound. However, one has to start somewhere, and it's best to start off in the right direction.
Constraints
As mentioned in the introduction, this is my first DIY design project. I've learned a lot during these initial design phases that led me to post this thread, and I know I'll learn even more once I get my hands dirty. The first constraint is the price. I don't want to break the bank by making mistakes (especially correcting them) on my first project.
The second constraint is the size. I want to be able to place these monitors on a desk or on stands, in a near-field setup.
The last constraint, closely related to the objective, is the linearity in the speakers' response.
Used Transducers
I came across the Visaton WS17E and Visaton SC10N on Solen.ca while browsing the site in search of the ideal combination for a beginner. The price constraint made me consider Dayton Audio for a long time. However, the Visaton speakers caught my curiosity, and it took me longer than I care to admit to ask the relevant question: Is there already a documented project using them?
Without further suspense, Visaton themselves propose the CLOU design.
You'll see that this project only shares the transducers and part of the enclosure with the original CLOU design. I'm not sure yet if that's a good thing.
Crossover
From the start, I know that the linearity constraint will be difficult to meet. But we’ll do what we can.
I'm using VituixCAD. The amplitude and impedance response curves were obtained using FDGraphTracer from the speaker specsheets provided by Visaton. I started by recreating the network presented for CLOU, but the resulting crossover was far from satisfactory.
CLOU original cross-over network
CLOU resulting SPL response
I went back and forth with FDGraphTracer multiple times, double-checking the value and placement of the components to ensure it wasn't an error. So, I made the decision to design it from scratch.
I began by adding a source-side resistor to compensate for the sensitivity difference between the two transducers.
It quickly became evident that a first-order filter would not be sufficient for either of the transducers.
To my surprise, a second-order high-pass and low-pass filter was enough to achieve what appears to be an acceptable response. You'll notice that I had to reverse the polarity of the tweeter to achieve this result.
The Total SPL graph shows a curve of ±3dB between 60 Hz and 17000 Hz (78.2dB ~ 81.7dB).
Project cross-over network
Project Total SPL, separate SPL and Normal Phase
Project transfer functions
Project group delay and separate phase
Project load impedance
Project null reverse with tweeter polarity switched
Box
The original CLOU design is a tower speaker with two woofers. One woofer is placed in a sealed box near the tweeter, while the other is separated in a larger box that serves as the base of the speaker. This larger box, below the sealed one, has a hole near the base. I'm unsure if it's a simple hole, a port location, or a cutout for the terminal.
My design eliminates the lower portion, including one of the woofers, and only retains the sealed box. Using 16mm panels, the same as CLOU, the external dimensions are 220mm W x 331mm H x 320mm D, with an approximate volume of 16100cm³, excluding the space occupied by the speakers, shelf bracing, and other components.
An absorbing material will also be added. I will determine the quantity during actual measurements.
VituixCAD's enclosure design tool calculates, for a box of this volume and this woofer, a curve with a resonance of +2.5dB at 80 Hz.
SketchUp preview of the box
Box projected response
Conclusion
We've reached the end of the project presentation. I'm genuinely eager to receive your feedback. Please feel free to ask questions and share any remarks or comments.
While I enjoyed the process to get here after many explorations with other speakers and box types, I'm still uncertain about the robustness of these plans.
Some questions I currently have are:
  • I have a network in stock that includes a baffle step corrector. Is it wise to consider integrating it at this stage of the design?
  • I'm concerned about the load impedance curve. Should I incorporate an impedance corrector into the network?
  • I haven't considered any Z-axis offset. Is it worth it to add a ladder delay network?
  • Should I be worried about the box resonance anticipated by the software? If so, what should I consider doing? Install a Variovent to virtualy add volume to the box?
Spawn of Frugel-Horn
As you know Scottmoose has been helping out with MJK sims of the Frugel-Horn (since MJK as yet doesn't do 1/8 space these are only of interest as a design reference when compared against one another)
Anyway, this spurred Scott towards implementing some of the stuff floating around in his brain and has spawned a new member of the Frugel Family... if the original Frugel-Horn is the mama, this is the tall-gangly -- but smart -- teenager.
Inspired by Terry Cain's double mouth BEN series, the Replikon (discussed here http://www.diyaudio.com/forums/showthread.php?s=&threadid=55721 and conversations with GM about the big box (CC) long exponential port bass reflex style horn as respresented by the Replikon, Scott came up with a box that is very tolerent of differing driver parameters. It also requires no curves to be cut.
Scott is building the 1st prototypes now, and will hopefully get a chance to let them get a listen at the upcoming EggFest.
The working name for this horn was the FrugelBEN, but unless Terry Cain gives his blessing, we'll need to come up with a different catchy name -- DoubleFrugel is kinda derivative.
I haven't got detailed plans ready yet, but i will, in the next series of posts, attach some teasres.
dave
19" rackmount chassis for supporting 2-channel tube amp build
Hello, I was hoping to hear from any of you that have ventured into building a stereo tube amp, and what you settled on for a 19" rack mount chassis.
For the amp I am designed up now, I plan to build this on a 1U (or maybe 2U) rackmount chassis in the vintage style, with all tubes/transformers/choke/maybe filter caps located on the top with preampboards, control pots, switches within the chassis.
I've been looking at Par-metal and see that there are 3-4 series to choose from - alum/steel, alum on only, Heavy duty alum/EMI RF protection.
Its obvious that for a 100W 2-channel tube power amp, there will be a considerable amount of weight that the tops of these chassis will need to support.
I should probably add that this will likely need at least a 10" depth. And a 1U height will probably be enough to fit preamp boards/switches/potentiometers/jacks, etc...
Were you led to purchase any particular brand/model that provided enough structural rigidity to support the weight of transformers?
Thank you for sharing your experience.
Best,
Phil Donovan
horn lining or TL
There is a product that can be applied to the inner surface of horns or tapered drive lines to improve performance. I am not referring to rumble dampener.
I am thinking, for example, of the rebounds of acoustic waves against the walls. it probably doesn't exist otherwise it would have already been done by the producers, but you never know and it doesn't cost anything to ask.
Thank you
How to tighten Helius Scorpio 1 components
Hello,
I run into trouble to tighten the fixation of the lift,the antiskating and arm standby...
Please have look to the picture enclosed,the second one at the rear shows the hole where you can guess the main bearing allowing the arm movement.. (1)
So ,the support of the three mechanisms listed upside should be fixed thanks to a screw probably hidden by the bearing .
I've tried to dismounting the parts but I failed and i suspect the needs of a specific tools to operate...
Should you own the same arm, please let me know if the mounting looks to be similar
Thanks in advance for any advise, I do not have the adress of Helius service...
Kind regards
Raymond (from center of France
Sealed Box for 12" Alpine Series S
I recently started this thread asking about how to build a vented box for some alpine drivers.
Some people recommended here and on Reddit that I go for a sealed box instead.
The manufacturer recommends a 0.85 ft³ box as the ideal of a recommended range of 0.5-1.5ft³
WinISD tells me F3 will be 45hz for those sizes, though at 20Hz, a 50L box will be around -14dB and a 35L box will be at -15.5dB. Qtc will be 0.772 for the small box and 0.709 for a 50L one.
50L is not much larger than the recommended 35, but it's a bit larger than the recommended maximum 1.5ft3 (42L). And it fits the mythical 0.707 Qtc
Is this a reasonable box for a HT system? I plan on having 2 of them in a small room. Considering room gain and 500W RMS to each, the total SPL at 20Hz should be 107dB at 20hz (115dB after 45Hz)
Old Magnavox console model number label?
Kids bought an old Magnavox console at a yard sale.
I am opining that the turntable is one level above a Victrola and should not touch their records.
The radio portion says Solid State.
I don't expect the speakers to be anything other than 'interesting'.
It might get turned into a piece of cat furniture, but I would like to search for a manual...except I can't find a model number on the outside.
Maybe inside the rear Masonite panel?
There pulls or knobs on the front, but they seem to be decorative only.
Thanks for any assistance finding secret markings
Murray
Threshold SL-10 Recap.What's the Polarity of the 470 uF Black Threshold Caps??
I'm beginning a recap on an SL-10. I know the white stripe on Blue Instrument Device caps represents the positive lead unlike conventional markings. What about the caps wrapped in black with a Threshold logo? Does the "Threshold" represent the positive or negative lead?
I have not pulled the PCB yet. It looks a little tricky to trace since this is the power supply regulation circuitry and I have 4 caps on each side in opposite orientation. I think I'd need to trace them back to the 7815 or 7915 to determine polarity.
I was hoping someone had done this already and could spare me the hassle!
Thanks,
Eric M.
Recapping Paradigm Monitor 7 v1
I a/b tested my monitor 7s against my other speakers and found the tweeters sound dull compared to everything else. I can't help but notice it now and although I'm not in a place to upgrade, I've read that replacing the capacitors can be a quick fix. I think they're 20-25 years old, but couldn't find an exact date. I looked at the crossover and saw each speaker had two capacitors, 6.8uf 100v and 22mf 100vdc.(could be 22mfd, but it was hard to see)
I could easily find replacements for the 6.8uf, but I'm confused by the 22mf. Is this the same as a 22uf 100v capacitor?
Beyond the Ariel Speaker Parts for Sale
Surviving a sudden and highly disruptive relocation five years ago, I am happily back on track with PierreQuiRoule and Troy Crowe to build our version of Gary Dahl's Beyond the Ariel speakers.
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-648#post-4399839
https://www.diyaudio.com/community/threads/beyond-the-ariel.100392/page-354#post-2267501
Jim Salk had cloned Gary's 3 cu ft sealed Altec 416-8B midwoofers to also play down to 70Hz. https://www.salksound.com/
But we are using different horn drivers, horns, tweeters and subs.
So, I have a pair of the 16 ohm drivers for sale: https://www.usspeaker.com/radian 745neoBepb-1.htm
And a pair of the AH425 horns: https://www.azurahorn.com/azurahorn_horns.html
A good price can be had for this package only deal.
Furthermore, Gary had posted the original AND final crossover circuit at the first link. I also have a wealth of build tips I can share with you-including sketches of his low diffraction sealed midwoofer cabinets, interior photos and where to source the prebuilt curved interior sections.
I'd have to clear it with Gary, some of that with Gary, but I have at least a dozen llnks from Lynn Olson's thread where Gary gives copious measurements, design explanations and even his "on the road" show at a local hi-fi club. I can promise that it will all get your DIY juices flowing.
If intent on pursuing the build , shipment of the parts from Jim in Michigan to me in New York would be $159.00. But I will split shipping costs upon your payment for these parts.
Reactions: wwschaff
For Sale 6C45Π Headphone Amplifier (like Papa Rusa, Mainline etc)
** SOLD **
This is a DIY headphone amp using the 6C45Pi tubes, similar to the Papa Rusa or Bottlehead Mainline amps.
It has a switch for HiZ and LoZ (12:1 and 8:1 ratios)
In terms of performance, it has alot of power (500+ mW on LoZ, and over 200mW on HiZ)
The frequency response is within 1dB between 20Hz and 20kHz, with a slight high frequency tilt.
Confirmed that there is no oscillation.
The only issue is a very low-level hum that is only present when there is no signal playing. I confirmed with measurements (attached in the pics) that the hum disappears even with low level music. Due to above, the amp would work best with either dark sounding or power hungry headphones.
Lastly, the paint job is not the best and has some imperfections.
This build is a result of this fairly long thread --
https://www.diyaudio.com/community/threads/5842-headphone-amplifier.370857/page-4#post-7384124
I am building a few of these, and this was my prototype in order to iron out details for the "final" build.
This amp is using high quality parts throughout --
  • Hammond 269GX power transformer and 155H choke
  • Hammond 119DA output transformers
  • Hammond chassis
  • Nichicon LKX power supply caps
  • NKK gold-plated switch
  • PEC KKA volume potentiometer
  • Custom cascode CCS PCB's
  • Includes a matched pair of 6C45Pi tubes (matched on my uTracer)
This amp would be fairly easy to tweak, whether it is to try LED bias (or add a cathode bypass cap), new coupling caps, or even rewiring the tube sockets for a 5842 or D3A (of which I have selection if that is something you're interest in)
I am asking $350 + $20 flat-rate shipping within the US, which is well below the cost of parts.
Preamplifier/Buffer/Impedance converter to the E1DA Cosmos ADC
Who actually owns a preamplifier or buffer/impedance converter that has been proven to work with the E1DA Cosmos ADC?
My input is a sensitive sound module with output of 0.2 Volts. Output impedance is 150 Ohms. It will be inputted into the E1DA Cosmos ADC which I recently acquired. But the input impedance of the E1DA is:
1.7Vrms 640Ω,
2.7Vrms 1kΩ,
3.5Vrms 1.3kΩ,
4.5Vrms 1.66kΩ,
6.7Vrms 2.46kΩ,
7.6Vrms 2.82kΩ,
8.5Vrms 3.12kΩ,
10Vrms 3.48kΩ,
43Vrms 13.6kΩ
Note: Unbalanced impedance about 30% less."
Since my source is unbalanced mono. The input impedance would be 630 Ohm less 30% = 441 Ohms and mono would be half or 220 Ohm. So at 1.7Vrms, 220 Ohm dip switch setting. A source output impedance of 150 Ohms and 0.2 Volts will be too low. I need to amplify the 0.2 Volts to say 8.5Vrms to take advantage of the 3.12 KOhm input impedance of the E1DA ADC. What preamplifier (besides the APU) or even Interface that can do that with low distortion not far from the E1DA Cosmos APU? I want alternative because the APU gain has only 34dB and 60dB select switch (with no way in between). Thanks.
Short and wide WAW help
I'm looking into making a WAW to use as desk speakers for my gaming PC. I have three monitors and the goal would be to have the speakers fit under my side monitors. Right now I have MTs laying on their sides, and they don't quite fit under the monitors, so they're more behind them, and it's okay...
My height constraint is about 6" but shorter would be better, maybe around 5.5". Width and depth are more forgiving. I'd say 16" wide and 12" deep, but I'd have to measure again and make sure.
Since all of the drivers have to be laid out horizontally, I like the idea of a WAW since I can run the full range down to 300-400Hz and have a woofer on each side of it without having lobing concerns. This should produce a favorable off-axis response in all directions, which is ideal since I'm not known for sitting still while at my desk. Maybe a max listening window of +/-20deg in all directions?
I've also looked at coaxials, but it seems on the budget end that a 3-4" full range will do better than budget coaxials. Which is sad, since I love coaxials. I use 15" PA coaxials for surrounds in my home theater. KEF makes nice coaxials but doesn't seem to sell the raw drivers anymore which is disappointing.
Another option is a combined mid-tweet like what Morel sells, but those are more expensive than full ranges as well and I don't think they'll do what I want...
I will have two subwoofers in the room as well so the speaker doesn't have to play THAT deep, but I'd like solid performance down to at least 80Hz to maintain some semblence of directionality.
So to sum up the constraints:
  • 5.5" max box height, width 16" and depth 12" should be fine
  • Woofer-FullRange-Woofer arrangement, with two discrete subwoofers
  • Crossover will be active, with ideal points of 300-400Hz to the fullrange and 60-80Hz for the sub
  • Max off-axis angle of 20deg, but it's variable
I like the look of the 10F/8414G10 as the full range, but they're expensive and hard to find. I have two on order from Ebay, but they won't ship till September potentially... Another option is the Peerless TC9FD as used here: https://www.diyaudio.com/community/...-waw-ref-monitor.273524/page-188#post-7077022
For the woofers I was looking at Peerless SDS 5.25" woofers since they have the flat sides which will help limit height.
Any other driver recommendations or ideas would be appreciated! Unfortunately ditching the three monitors to allow a more "normal" speaker is not a good option here...
Active (opamp) output splitter
Hi, I'm a solder slinger so I was hoping someone more design savvy could check my schematic for a basic active splitter. This was designed to connect to the output of my R2R passive preamp, Vicol Audio's Maya. I don't need gain, just current, so this is meant to be a unity gain buffer. I have some old NE5532 that I plan to use, but I'm hoping the circuit is general so I can play with OPA1612 or OPA1642 if I'm unsatisfied. I also have some old Taka A5W-K two channel signal relays, which I would like to use to switch the outputs and bypass the buffer from the front panel. I'm planning to use a standard regulated PS with 7815/7915 (+-15V). Schematic is for one channel. One question is the location of the parallel film output caps. I put them on the output of the opamp rather than at the preamp output. My idea was that this would allow the buffer bypass relay/switch to retain as much as possible the current signal path of the passive preamp. All feedback welcome. THANKS!
Hello from Sweden!
Hi, Magnus from Sweden here, new to the forum.
Having built my own electric guitars and amps for the past 15 odd years, I was introduced to the world of headphone amps earlier this year by a friend of mine and have just completed my first build, a Starving student II.
This build let me combine my hobbies of woodworking & electronics tinkering, thanks for having me!
Burning Amplifier BA-1
This is the place to discuss the latest Pass amplifier, the BA-1, which is documented in the article here:
http://www.diyaudio.com/forums/diyaudio-com-articles/154777-burning-amplifier-ba-1-a.html
As most of you are aware, Nelson "Papa" Pass distributed a bunch of almost complete amps at the second Burning Amp Festival, lacking only the gain stage. You can read all about it here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=131663
The Burning Amps are modular in that you choose a Gain Stage and an Output stage to create the amp of your dreams.
The input "Gain Stage" section which increases the voltage can be used for any of the Burning Amps. The first gain stage is no longer in production, but the Second, confusingly called the BA-3 is available in the diyAudio Store.
So you can combine the gain stage with either one of two "Output Stages" which are also available in the Store
One output stage is single ended and the combination with a gain stage is the BA-1 Amp. The output stage consists of 2 small PCB's and two longer ones.
One output stage is complementary and the combination with a gain stage is the BA-2 Amp. The output stage also consists of 2 small PCB's and two longer ones. but they are all diff.erent than the ones for the BA-1 output stage.
Single-ended amps are quite inefficient, and only operate in pure Class A. The are the Audiophile Purist choice and probably have a small sound quality advantage, depending on your preference.
Complementary amps are more efficient, and transition smoothly from pure Class A operation to Class AB when more power is required
Nelson will be publishing a series of articles right here on diyAudio documenting designs for the various chassis that were distributed. They have different output stages so there will be at least an article for each of these configurations. That's good for us as we will have a multitude of great new designs! We will produce boards so that even people without the head start of the generous "gift of amps" will be able to make them. Nelson mentioned that these designs are to be a fundraiser for diyAudio, so the boards should only be available from here.
Question about port position on my sub
Recently I made a subwoofer enclosure for a 10" 250W RMS driver. The port that I have made is based on the calculation that WinISD made (6x36x90cm tuned on 31Hz) and at the first try sounds decent.
After I tried using the sub with the amplifier outside the cabinet for make some inspections. To my surprise the sub sounds a lot higher on volume and I can't still figure out why. I temporary made a hole in the back of the sub (with also the port open on the front) but the higher sound seems to be heard only in the back, not watching the front.
So I tried to make another hole in the front (covering the back one) but all returns to the original low volume sound.
I'm tiring to understand why the front port and the back hole produced so much volume in order to try to replicate it.
Feedback on first tube amp power supply design...
Hi!
I'm looking to build a Baby Ongaku (see attached PS schematic) but the power transformer has a higher voltage secondary than what is specified (360V vs 420V/480V). Since this is my first build directly from a schematic I thought this would be a good opportunity to play with the power supply design to accommodate this transformer - both because I have it and because it's a chance to learn something.
Since the voltage on the PT secondary is higher than specified, I thought this would lend itself to a choke input - as opposed to the sorta choke input in the schematic - to drop the voltage for a B+ of 350V. I have the current at 146mA as I intend to make a stereo version of the amplifier. It doesn't seem like much will chance downstream of the power supply.
I've modeled the PS in PSUD (see attached) to the best of my ability and am curious to get some feedback. Again, this is my first PS design and there's a good chance I've missed something. To date, I've built a couple of point-to-point kits and a couple of amps from a schematic with wiring diagrams and great documentation from MJ magazine (Japan).
The things I'm the most curious about are the values for the filters, the current draw, and how the ripple looks.
Thanks in advance!
B&C 18TBW100 4ohm speaker subwoofer
I'm thinking about reusing 4 of these speakers that I currently have in some Keystone subwoofers since I'm doing shows in smaller clubs where front loaded could be a better fit. could someone please tell me if these figures look right? not much of a port according to the subbox.pro designer.
https://subbox.pro/en/b/aPuzX0mJS
https://www.bcspeakers.com/en/products/lf-driver/18-0/4/18tbw100-4
Quick feedback on some tweeters
Hello all, I'd like to build a small monitor speaker for my bedroom with nearfield usage. I am flip flopping between two tweeters to use. I intend to use a waveguided tweeter as they simply sound much better to me, I have really grown tired of the typical dispersion mismatched 1" dome to most woofers. I intend to utilize these for mixing purposes, but also keep things within my budget (no satori stuff for instance).
My two tweeters of choice are the ND25FW and XT25/DX25+Wg300. My current main living room speakers utilize the ND25FW and I find them to be totally inoffensive tweeters that just do things right to my ears. I don't feel the need to apply corrective EQ to them and my mix translation is good. I seem to be able to work with them for hours without much in the way of fatigue and I feel they image well.
I also have in my possession a WG300 and DX25 + adapter. It appears as though the DX25 and this waveguide have a pretty rough dome reflection that causes a dip in the upper treble (I found this to be problematic) so I'd like to try the XT25. It does however look to have very narrow dispersion (referncing heismann data) but I'm not sure how much of a concern this would be.
Should I stick with what I know works well, or try for something different with the XT25+Wg300? My dumb consumer brain tells me the costlier option would offer better performance.
Rega Mira 1: Rising DC offset in right channel
Hi folks,
I’m currently trying to repair a Rega Mira 1 Clamshell with a DC offset problem. The issue is that DC offset in the right channel is quickly rising when turning up the volume. DC Offset at zero volume is around 10mV. From the 8 o’clock setting the DC offset in the right channel starts rising. At around the 9 o’clock setting the DC offset has risen to ~300mV and the protection circuit kicks in.
What I've checked so far:
  • Power supply seems fine. Power rails +/-15V, +/-40V measure ok with low ripple. Caps have been replaced.
  • Preamplifier output looks fine so it looks like a problem in the right power amp circuit.
  • When injecting a test signal, the sine waveform in both power amp channels looks fine at various volume levels (no clipping).
  • I’ve checked the power transistors and compared some voltage measurements on the left and right output circuits but haven’t been able to find any obvious faults.
Any tips on how to troubleshoot this issue?
Thanks you.
PS. Circuit diagram for Rega Mira 2000 (similar): Rega Mira 2000
Upgrading drivers of an existing old cabinet (pics)
Hi all,
I got this vintage Japanese speaker set sometime back, it's a 50w speaker and some drivers are blown/damaged. Now I'm thinking if I could upgrade it to a better speaker meaning I'll replace drivers and crossover but keep the same cabinet.
It's external dimensions are (made of 20mm plywood)
H 62cm
W 36cm
D 31cm.
Has a 10in woofer. Would be great if I could convert this to something like Scanspeak Discovery 3w classic. Is it a worthwhile project? I have attached some pics .
Audio Note amplifier Mystery
Hi Tube community at DIY Audio, I was hoping to get some help. I've been very fortunate to get hold of a pair of what I'm certain are a clone of Audio Note Kegon - Balanced for a steal... I'm confident that they're made by Alp Audio, who used to be Peak Audio, who distributed Audio Note in Hong Kong.
Unfortunately, it came with two out of five tubes. I know two of the tubes are 300b's and there is a gain stage with a 6j7G (which deviates from a AN Kegon but came with amp). The Kegon is a 10Y - Interstage - 300bPSE.
It appears to be a 6j7G - Cap Coupled - unknown tube (10Y?) - to 2x 300b's. The other tube I'm unsure of is the Rectifier. I would assume it's a 5U4G, as the other amp I got is and the majority of Audio Notes amps are too.
Anyone have an idea on where to start?
Pictures say a 1000 words:
Single high voltage cap vs 2 lower in series for split rail power supply?
I am currently working on making an aleph m amplifier and am working on the power supply. I have some caps that are rated at 63v and this value is much higher then what my rails are for the amp. It runs at plus minus 17 volts. I could be wrong but could I not just put a cap from the + 17 to the – 17 as it would only be seeing 34v and that would be much lower than the rated value and would give me more capacitance then if I put 2 of the 63v caps in series. I looked for a few hours yesterday and could not find an answer that made me feel assured.I am currently working on making an aleph m amplifier and am working on the power supply. I have some caps that are rated at 63v and this value is much higher then what my rails are for the amp. It runs at plus minus 17 volts. I could be wrong but could I not just put a cap from the + 17 to the – 17 as it would only be seeing 34v and that would be much lower than the rated value and would give me more capacitance then if I put 2 of the 63v caps in series. I looked for a few hours yesterday and could not find an answer that made me feel assured.
DIY DAC + Streamer suggestions?
I got a spare Raspberry Pi3+ and a 2.5" 500GB SSD, I am sick of the amount of cables and AC adapters not to mention my DAC which I can't stand any longer (a Beresforf Caiman SEG), I'd like to put together in a single box both a streamer and a DAC as to get rid of my Caiman SEG and the MacMini which even tho does well takes space and extra cables.
The DAC would need one-two optical inputs (one for the TV and eventually another one for the CD player even tho it's built in DAC does sound very well), dunno if an R2R or a chip based one.
Should not be hard to build a PSU to power both DAC and storage-streamer.
Do you have any suggestion to what to look at?
Grazie
JJ EL509s in Triode - specs ?
Saw that JJ sell an Octal version they label EL 509s. Never looked at this tube before. I know there are the original top-plate versions out there too.
I've seen it referred to as a Sweep Tube and these are often very nice when wired up in Triode mode. But JJ provides nothing about triode wired operation.
Anybody using this tube in triode mode ? (it's not a low cost tube, not sure who is buying it in enough volume to justify JJ to keep it in production ?)
https://www.jj-electronic.com/en/el509s
150W overload protected amplifier
My first 150W amplifier using TIP2955/3055 transistors with overload protection using op-amp.
This amplifier is motivated by the need to protect the whole system against inrush current when the input signal is high. In fact, these protected amplifiers are specifically required to do some modal analysis tests in vibration labs to drive shakers. We have come across high failure rate of amplifiers due to sudden application of input signals while the shaker is connected. Therefore, I designed this circuit to limit the current of the output stage using op-amps and few other components.
I also tested it with audio signals and speakers and it worked like a charm.
THD: 0.003%
Frequency response: 1 Hz to 37 kHz
Supply voltage: +/-24 to +/-30
Lifesaver components that eliminate HF oscillation even with no load/light load condition:
1. Feedforward resistor R24 (1k)
2. Bootstrap resistors R14 and R15 (1.5k)
3. Zobel RC on the output
4. Feedback capacitor C8 (100pF)
5. Also C5 and C2 have helped a bit more.
Note: You will need a good power supply and a big heat sink for the power transistors.
Rx is wire jumper or very small resistor say 1.2R
NE5534N best quality replacement?
I have a power amp that uses NE5534N op amps for the electronic balanced inputs, it is in a unity gain configuration. It looks as though these are dead and I would like to replace them with the best quality modern op amps having the same pin out. Can anyone tell me which would be the best new device in terms of sound quality? Since there are only two of them I am not too concerned about the price, quality of sound is most important.
DIY Amplifier and Preamplifier Chassis
Two very nice chassis for DIY projects. The Krell Amp Chassis is of course a knock off (Aliexpress) but is still very nice quality and great value. The silver Preamp (or small amp) chassis is super nice as well.
$250 CAD each or $400 CAD for both. Local pick up in Vancouver, BC only.
Cheers and all the best.
High quality ADC
Hi
Looking for a high quality analog to digital converter with SPDIF output, have a Flex 8 that only has digital input and I'm trying to find a good performance ADC to connect the turntable to the minidsp.
Found two good suggestions here (ADDA24QS and nihtila.com ADCs) but both been out of stock for a while and don't seem to be in production anymore.
Thank you.
The Rhombus sub
This project is pretty straightforward except for the enclosure shape. It is a passive 4 cubic foot sealed enclosure loaded with a down firing Dayton Ultimax 15. Power is provided by a bridged Crown XLS1002. I've built many subs over the years and listened to far more and am very pleased with the Ultimax 15 for both music and home theater. My main speakers (Campbell/Holtz Bourdeaux kit) are capable of excellent bass themselves and after much tweaking I settled on a low pass to this sub of 50 hz with a 12 dB slope.
I originally settled on the shape as a joke to myself in that my carpentry skills are unable to produce anything with square joints 😛 At the same time I believed the shape would provide visual interest. The enclosure is of 3/4" MDF and sits on furniture legs sourced from Amazon and bolted to the recessed downward facing baffle.
I realized as I began construction that due to the shape of the enclosure and the viewing angle from the listening position it would appear visually smaller than it actually is. This illusion is due to the fact that the front face of the enclosure is not orthogonal to the line of sight from the listening position; it's receding plane fooling the eye.
Test fit of driver. Baffle will face the floor when installed with furniture legs bolting into the corners of the recessed baffle. Two horizontal window braces already installed and additional vertical bracing is being added between the baffle, window braces and top.
Another interior view before all sides are attached. Short vertical braces installed at each of the woofer screw hole locations reinforce the baffle by spreading loads into the window braces and cabinet sides. Inside of cabinet top (bottom in this view) will have an X shaped brace installed for reinforcement.
Initial "does it work" test. I ended up shortening the legs considerably as I found these too tall. Spring type binding posts can be seen as well.
Enclosure is veneered with paper backed mahogany using contact cement; my preferred method.
Experimented with a somewhat distressed finished on this project. I liked it.
The forced perspective in photographs usually disguises how slanted the front and back sides really are. This view shows true shape to good effect.
Final placement in the living room/theater/listening room.
Free: NOS on-wall speaker cabinets
Back in 2005-2006 I developed an on-wall speaker for use with flat panel TVs which sounded good for its size and application. I have a bunch of extra cabinets for which I’d like to find homes.
Here’s a link:
http://www.dnaudio.com/DNA-Sonic-Decor-Model-100-On-Wall-Speakers.html
They’re made from 1/2” MDF with a horizontal brace between woofer and tweeter. The cabinets measure 15.75” H x 10” W x 4” D with 6L internal volume. Mounting holes were for the Vifa D27TG35 and Peerless 832873 but can accommodate any of their 5-1/4” HDS woofers.
Cabinets are in white and black textured paint. I had grilles made in white, light gray, and black.
The speakers are design to have a decorative trim panel attached using Velcro. I still have some in wood veneers and solid gloss black and white and can include until depleted.
They’re wall mounted using a Hangman bracket.
I’m offering the cabinets with 1 pair of grilles for free - you only need to pay $50/set for ground shipping anywhere in the lower continental US. Free local pickup at my storage unit in SoCal is also an option. No woofers or tweeters or crossover components are included, but are available for sale separately. I can also provide a copy of the crossover schematic if you want to build it as I originally designed
4EDCFD33-387D-41C9-861E-C8D3DC19DA44.jpeg 3FAEFACD-4E89-417A-A118-76BC7A7B8D33.jpeg 8EB2207A-F8F0-4A22-AF3F-005A0E325449.jpeg
Balanced preamp Input Level Sensitivity
I need some advice, how to change gain in this balanced preamp board? Which resistors I should to change?
There is small description about this board:
The distortion and noise of this line is much lower than that of a normal circuit, so the circuit looks less complicated and slightly more complicated, and the purpose is low distortion and low noise. In general, to convert the balanced signal into an unbalanced (single-ended) output signal, you can use 1/2 NE5532 plus 4 10K resistors, which can be achieved by connecting IC2A in the figure. At this time, R5~R8 are taken as 10K, a pair of balanced signals are input from the left end of R5 and R6 respectively, and a single-ended output signal can be obtained from the right end of R9. This differential amplifier circuit is quite simple. The output noise is also low, which can reach -104dBu (0dBu=775mV), but still feels a lot of noise. For this reason, the so-called double balance stage is adopted, that is, two differential amplifier stages are composed of IC2A and IC2B, and the balance is received at the same time. The input signals are added together to partially cancel out the uncorrelated noise, resulting in a 3dB noise reduction and improved circuit common-mode rejection ratio (CMRR).
Further improvements are also added to the first stage voltage followers IC1A, IC1B before IC2A and IC2B. This not only improves the input impedance, but also reduces the resistance of the eight resistors R5, R6, R7, R8, R13, R14, R15, and R16 of IC2A and IC2B from the original 10K to 820 ohms, greatly reducing the thermal noise of the resistor. Finally, the noise of this stage is reduced by -112dBu, which is 8dB better than the traditional single-difference circuit above.
My amp Class D need at least input 200mV-6V 102db. At the moment I have only +-120mV
Thank u!
Sabaj A20a modification... worth the effort?
This little MA12070 "Merus" based amplifier that could... Can it be modified? Does it need to be modified? And what do we do to the poor creature then? Nah, we just do it like we always do 🙂
Post your modifications please and tell us:
1. what the improvement or the "improvement" was
2. what gave you the idea?
3. was it worth the effort?
Preferably with pictures in a reasonable resolution and a clear description what part/type numbers you have used. Avoid "blacker than black" to avoid the curse of the burned woofer that may come upon you!
build an active Classix II flat pack kit!
I wanted to share this project with everyone as it's a simple and great sounding combo. This started as a desire for a pair of active speakers for an outdoor covered patio and pool area where a flat screen tv is already mounted. My original thought was to design a project from scratch, but once I found myself headed towards the now third summer of saying I should have a pair of speakers outside I decided to press the easy button and get things moving along! Things I desired: self powered, Bluetooth capability, remote control, external input so I could connect the television, full range sound in a package light and small enough to wall mount and a subwoofer output might be nice too.
My all in one solution was to combine the flat pack Classix II speaker kit from Parts Express with the Dayton WF60PA digital plate amplifier also from PE. This digital amp is capable of (x2) channels of 30W at 4 ohm with a remote control for input select and volume while also providing a line level sub output. For connectivity it accepts Bluetooth, wifi, a Toslink input, a pair or RCA inputs and a 3.5mm jack. For my use I stream audio via a phone using Bluetooth and the tv is connected via Toslink.
The Classix II speaker has no right to sound anywhere near as good as it does for this price; it's a true gem with surprisingly low bass abilities and the WF60PA drives them plenty loud! These Classix II speakers are built exactly to the instructions using nothing but components included in the flat pack kit. Only additions are the cutting of a rectangular hole in the back of one cab to mount the plate amp and an additional hole in front for the remote sensor assembly.
Flat pack cabinet glued up and brad holes filled. Fit of the parts was excellent.
Rear of the active cab getting ready to receive the opening for mounting of the plate amp.
Backside of plate amp. The ribbon cable extending out to the left of the frame allows remote mounting of the remote sensor and LED status assembly. Red and black wires will connect internally to the crossover board.
Backside of cabs showing active and passive units. Plate amp connects to its crossover inside the cabinet with the external binding posts allowing connection of the passive cab to the amp. Remote sensor assembly temporarily hanging out of port for testing.
Passive cab has crossover board mounted to back wall.
Active cab has plate amp in back wall, crossover board on floor and hole for remote sensor assembly under the woofer.
Closeup of remote sensor and LED status indicators. I used a step drill for this hole and hot glued the sensor assembly into a recess I made in the back of the baffle. The plate amp provides a tinted plastic disc trim that will flush mount to the baffle.
Exohyde textured paint applied and trim fitted over sensor port.
Active speaker with LED showing power on status. I added handles to the top for carrying.
Rubber bumper feet on bottom of cabs.
Rear of active cab showing kit provided flared port installed. Antennas only need be in place if wifi connectivity is to be used.
Speaker sits atop plywood mounts on side of home underneath covered patio. Remote is stored next to it.
Commercial available discrete OP-AMPs - Overview wanted
There are many threads concerning discrete operational amplifier - here some examples:
http://www.diyaudio.com/forums/pass-labs/120445-pass-discrete-opamp-dip-8-package.html (BF862)
http://www.diyaudio.com/forums/soli...screte-clone-comparison-seven-variations.html
http://www.diyaudio.com/forums/solid-state/154131-anyone-have-made-those-diy-discretes-op-amps.html
http://www.diyaudio.com/forums/vendors-bazaar/127371-discrete-opamp.html
http://www.diyaudio.com/forums/parts/156870-discrete-opamp-help.html
http://www.diyaudio.com/forums/solid-state/51604-my-discrete-opamp.html
http://www.diyaudio.com/forums/analog-line-level/205332-discrete-op-amp.html
http://www.diyaudio.com/forums/solid-state/156474-yet-another-discrete-op-amp.html
http://www.diyaudio.com/forums/solid-state/123538-discrete-cfp-op-amp.html
http://www.diyaudio.com/forums/solid-state/93356-discrete-op-amp.html
http://www.diyaudio.com/forums/solid-state/61888-improved-discrete-op-amp.html
http://www.diyaudio.com/forums/solid-state/83517-discrete-lm3875.html
http://www.diyaudio.com/forums/chip-amps/17873-discretes-better-than-chip-amps.html
http://www.diyaudio.com/forums/solid-state/108731-ics-vs-discretes.html
http://www.diyaudio.com/forums/analog-line-level/221406-discrete-opamp-vs-regular-op-amps.html
http://www.diyaudio.com/forums/solid-state/163905-tl071-hand-made-simulation-using-discretes.html
http://www.diyaudio.com/forums/solid-state/156674-my-take-buildable-discrete-op-amp.html
http://www.diyaudio.com/forums/solid-state/165961-simple-60db-discrete-low-noise-amplifier-lna.html
http://www.diyaudio.com/forums/pass-labs/86681-need-help-discrete-op-amps.html
But I want to know commercial manufacturers of discrete op-amps with highest sonic quality - maybe like Burson
Logitech Transporter - what a stunner! - pink fish media
http://www.seventhcircleaudio.com/OpAmps/sc99_about.htm
http://sparkoslabs.com/discrete-op-amps/
http://newclassd.com/index.php?page=55
http://www.johnhardyco.com/990OpAmpDetails.html
http://www.sg-acoustics.ch/analogue_audio/discrete_opamps/
http://www.purpleaudio.com/discrete-opamps/
http://fivefishstudios.com/diy-kits/doa-17-discrete-opamp
http://www.hairballaudio.com/shop/p...products_id=140&osCsid=vYniZF3d6TbK1ZGULz5T52
http://mnats.net/JE-990.html
http://www.hellotrade.com/sound-skulptor/sk99b-discrete-op-amp.html
http://www.tonelux.com/opampinfo.html
Thank you for your advices.
Baffle edge diffraction and round-overs with near-field listening?
For near-field listening (say ears 24" or 60cm from the driver or so) I'm beginning to wonder if baffle edge/corner diffraction is more important than for longer listening distances; or at least quite important. Partly because there aren't other room reflections (of such great significance) to mask it in our perception, partly because a small distance between driver and baffle edge will be larger in an angular and directional sense, when sitting so close.
If so, this might make quite a difference on how I'd want to design a baffle - more rounded (or chamfered) at the corners, and therefore probably wider to accommodate the radius. IIRC Linkwitz said that a radius needs to be greater than 1/8th the wavelength to have much benefit. Which begs the further question how low in frequency is important for reducing edge diffraction; tweeters would be easy but full-range (or mid-range) drivers would indicate quite a significant radius or chamfer.
Three possible criteria I can think of are: low enough to reach the baffle step, below our most critical hearing range (e.g below 1khz, possibly lower), or to cover the range of the driver in the baffle. In the former case that could become slightly iterative, since a bigger radius means a wider minimum baffle width, and therefore a lower baffle step frequency. In the latter things could get quite big - if we take an example of a 500hz (e.g. WAW/FAST type) crossover, then better than 1/8th of the wavelength would indicate about a 9cm or 3.5" radius.
Thats if it is even worth bothering, of course. TBH I don't really know where I'm going with this now. But some thoughts (or perspective) from people who understand things rather better than me would be very helpful, if anyone could offer some?
Thanks,
Kev
California Instruments PRECISION OCILLATOR SERIES 800T Module -- NH USA -- 251T 560-2222 AC power source
$299 pick up
Or $320 shipped USA, Venmo or Cash app or no fees Paypal
Whole unit if you pick up. I can only ship the module.
SOLD AS IS
I know nothing about it
CALIFORNIA INSTRUMENTS 251T 560-2222 AC POWER SOURCE INVERTRON 67.5V 135V 270V
Reference discrete amplifier inspired by Wolverine and Cordell book
Hi all,
I am in the process of learning about amplifiers and have came up with a design that is closely resembles that of Wolverine.
I wonder what is the point of using cascodes for the IPS and so I omitted them.
I am also not sure about capacitance multipliers.
I am thinking about separating the whole thing into two boards. I am also planning on using SMD components which will reduce the size of boards significantly.
Doing research on different transistors I am looking at following:
Dual matched 5401 and 5551:
FMBM5401
FMBM5551
Single 5401 and 5551:
MMBT5401
MMBT5551
I am also considering SMD version of KSA992 (not sure where to use them in the build - looks like they are mainly used for cascode)
FJV992
And it looks like MPSA42 is great for VAS so I have found SMD version for that one:
MMBTA42
Other decent hfe at 65V SMD transistors are:
BC856BW
BC846BW
Dual / current gain matched versions:
BC856BS
BC846BS
And medium power
BCP53-16HX
BCP56-16HX
For power supply I am thinking about using transformer 400VA with 32V secondaries - should be able to deliver 44V.
With that high of the power I wonder if LTP transistors will be fine or should I cascode them?
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,788
Members
7,888,588
Messages
Filter
Forum Statistics
Threads
406,245
Messages
7,888,588
Members
507,788
Latest member
ShepCasey
