MXR headphone amp(i need help)
- By jeremy400
- Headphone Systems
- 3 Replies
I tried to simulate the mxr circuit with the pspice, but the results don't seem to come out as I thought, so I'm going to ask a question. The closer the original volume resistance is to zero, the bigger the waveform should be
It's true that it gets bigger when it's actually simulated, but the output signal is too low compared to the input signal, so I don't know what the problem is
I thought I drew the circuit diagram wrong, so I redrew it, and the results were the same.
I think it's an opamp problem, so I changed the opamp, but the same result came out
What's the problem?
What's the problem?
