Rockford Punch 300-1 Bias
You don't set bias with a load. A slight (normal) DC offset could affect the readings.
I don't have this diagram but Rockford give 2mv for a lot of amps. For me, that's a bit high, especially on larger amps. I generally use 1mv if I'm measuring but generally just increase (from the full CCW position) the bias until I just see a small increase in current draw from the 12v supply.
To confirm that there is enough bias, connect a load (2 ohm or 4 ohm) and drive the output to about 1v. Run a sweep to 20kHz to check for distortion. At 1mv, there shouldn't be any but you can increase it slightly if there is.
