Help modelling subwoofer?
Hey Folks,
I would do this myself but I don't have access to a windows computer right now and I need to make a decision in the next day or so.
I'm looking at the RSS315HE-22 dayton subwoofer.
https://www.daytonaudio.com/images/resources/295-291--dayton-audio-rss315he-22-spec-sheet.pdf
I've tried having a play with hornresp (I actually managed to make it work on my mac), but have had no luck with WINISD.
It looks like a very small sealed box, ~25L gives a Q= .7, but it reaches max displacement really quickly.
My biggest issue is that I don't know how to model a bass boost for a sealed system in hornresp.
I've tried playing with a ported box, and ~80-90L gives a good response, but the port ends up being very very long to reduce port velocity below 17m/s.
Could someone have a quick bash at modelling this and seeing what an optimal design would look like?
I tried searching on the forums for previous modelling and didn't find much if any!
I'm looking for <100L Box with decent response down to 20hz.
I know I'll need a heap of wattage to make this happen. A 105dB Max output would be perfectly acceptable for me.
A small(ish) box is the main priority.
I will have DSP available.
Thanks for your time, even if it was just giving this a quick read.
Thanks!
Yamaha CR-2020 Tr714 low ohms
hi there, first time posting.
i have a yamaha cr 2020 that was working fine, and just stopping clicking the relay and no sound.
its been recapped, and the service buillitens done. it has 2sd525 replacements.
on TR 714 i have 99 ohms and 0.068 in diode mode, reading between base and emitter. is this normal?
i was thinking this was my problem, but i dont know enough to be sure.
i have plus and -59 volts, but i dont know what else to look for voltage rail wise. any help would be much appriceated.
Help! My friend bought a cube
Friend of mine bought this house and this is the ONLY room available to set up as his listening room.
Not exactly a cube but room measures 17'4" x 18'3" with a 9' ceiling. Everyone knows a square room is terrible, but I've quickly learned that a square room where the ceiling height is a multiple is super extra terrible bad.
Initial setup was listening position 38% off back wall, JBL 4435's about 3' from each sidewall which put them almost right up against the main wall when doing an equal lateral triangle. There's no bass, tried multiple speakers with the exact same listening position, JBL L-300, Infinity Quantum 2's, Polk SDA 2.3 TL's, and many more, all speakers that should be able to knock a listener back in this room. Multiple amp's and preamps. The room has no bass, its like there's a crossover at 125hz or so, just nothing below that.
So my friend and I are on a wonderful journey together learning about room nodes! Yay!
My question to you all, if anyone here has any insight, can this be trapped/treated or DSPed out?
DSP would be an adventure, I'm going to try and teach him how to use a UMIK and REW soon, but I'm not great at it myself.
Another friend says lowering the ceiling by a foot and heavy corner and reflection point treatments are the only answer. The owner really doesn't want to have to lower the ceiling, and definitely isn't moving any walls.
Can it be fixed without changing the dimensions of the room?
Schematic for Focal FPP4100 4 Channel Amplifier.
Hello folks, working on this amplifier which blew one side of the P/S FETs (Q53,Q54,Q55). I replaced them along with burnt gate resistors. The replacements are getting hot very quickly so I suspect a bad PNP driver transistor. I’m having a problem locating that transistor and was hoping a schematic could help be locate it’s designation (Q01, Q02, Q21…).
I found some schematics online for other Focal amps, but none appear similar to this one.
Thanks in advance to anyone who can provide me with a scematic.
Navigating the world of amplifier modules for reliable performance at 500-1000w at 8R
Hi all,
I would appreciate guidance for searching the world of Class D amplifiers, looking at a pair of amplifier modules / power supplies that can fulfil the following:
  • 500-1000W @ 8R
  • Subwoofer duty only
  • Reliable
  • Affordable
Can anyone recommend which of the 'Aliexpress' modules (or otherwise) can meet these? I have been burnt before by modules failing under load or just proving generally unreliable. I have been looking mainly at the IRS2092s and the UCD clones that seem to be all over there. I would ideally spring for something like two Hypex FA252 (it's for two active subwoofers), but they would blow the budget out of the water!
Many thanks in advance.
Wideband Multilayer Absorber Panel
I'm interested in hearing how my speaker's sound changes when the room reflections are more controlled. I see lots of thin single material panels however I think I would prefer a wide band multilayer absorber to uniformly reduce reflections and not disturb the spectrum profile too much.
I found a some material tables Material Tables and a multilayer calculator Acoustic Modelling that both seem reasonable. I have (arbitrarily) limited the panel depth to 20cm. I'll post the design with measurements before/after.
If you've built one, I'd like to hear your experience / impression.
Panels Built and room measured:
1) Standing panel (H183 x W61 x D20 cm) - Standing Panel
2) Helmholtz panel (H183 x W61 x D20 cm) - Helmholtz Panel
3) Wall panel RockWool (H122 x W61 x D80 cm) - Wall Panel - RockWool
4) Wall panel foam pyramids ( 91H x W61 x D5 ) - Wall Panel - Foam Pyramids
Reactions: Dave Zan
Maximum typical slew rates in audio
I came across a topic yesterday that had me thinking about the slew rates present in audio and the max/min required for processing equipment - specifically, how to fill in the blanks in the following statement:
The highest slew rates are in the vicinity of <slew rate> and are frequently found in the waveforms generated by <instrument/voice/etc>.
My first guess (admittedly a WAG) would be the initial hard strike of a cymbal or something along those lines. Does anyone have any specific numbers and/or references on this topic?
Thanks,
Hal
Reactions: kd4ylq
Which through-hole resistors for JBL VRX932LAP?
Hello everyone,
I'm working on several of these Class D amplifiers for a friend and have a question.
These are very similar to the JBL EON 515 by the way; they look exactly the same.
Here is the question though. I've gathered all the necessary replacement parts from DigiKey & Mouser but there is one piece of the puzzle which is still a mystery to me.
What specific type of through-hole resistors are these?
From the color bands, one is 24KΩ and the other one is 75KΩ.
I ordered some metal oxide replacements from the stores mentioned above but my worry is that the replacements are much smaller in size and won't be able to handle the load. Someone mentioned these could be "flame proof" elsewhere but I cannot find exact matches anywhere.
If anyone has any input I'd highly appreciate the feedback.
Supertweeter-assisted full-range & phase coherency
So when crossing a "supertweeter" (or just a very high-extension tweeter, no matter the nomenclature) over with a full-range driver with a single low value cap to really flesh out the topmost octave, is phase aligning them important at those nearing 20kHz and above frequencies?
I mean, as critical as phase alignment can be with a range of frequencies.
If I use capacitors as 1st order for the full-range anyway, are the drivers now phase coherent in terms of at least the signal itself? Would they not be if the full-range was ran entirely crossover-free?
In relation to this, how important is physical time-alignment?
Huge Thank you to contributors on this forum - Peavey 1.3K alive again.
Good evening all,
This is my first post here and my first amplifier repair. If it weren't for the details I found here on DIY Audio I would have missed critical bad parts and probably found them the hardest way by damaging new parts.
I revived my old Peavey 1.3k that has been sitting in a failed state for nearly a decade. I found that it failed big time as they tend to do it seems. I found and replaced nearly 55 parts across the drive and output boards. I have a bit more work to do on it, I have a few more electrolytic caps that I am going to replace just due to age but I did a low power test and found that I have clean audio on both and channels.
As I found discussed here, I am going to install an accessory fuse block to add fuses between the rectifiers and the output board to ideally prevent so much damage should an output transistor fail again.
Thank you to the contributors in this thread:
https://www.diyaudio.com/community/threads/peavey-pv-1-3k-power-amp-repair-question.271480/
Can a JBL 2225h really become a 100% 2235h?
I have spent the past few days searching this topic and I kinda hit a wall of contradictions.
For sure the JBL 2225h and 2235h have the exact same basket, and therefore a 2235h recone kit on a 2225h should make it a 2235h. Some will say the 2255h becomes a 100% exact 2235h. While others will say that the 4" motor is slightly different, and that therefore it will not become a perfect equivalent.
So... What's the last word on the subject? The topic is not about if a 2235h is or ain't a good sub. It's about the recone process.
Thanks in advance.
Audio Innovations Alto AM1 and CD Tuner CT1 remote
Hello,
I own an Audio Innovations Alto System, but without the remote control. Due to the design of this system, it cannot be controlled without the remote.
I am using a Logitech Harmony universal remote. Despite the system is in the database, there are important "missing buttons" and it's not possible to control the tuner functions. Only the "BAND" button is offered by Logitech.
Using an Arduino and a IR transmitter board, I have found some additional RC5 codes and now it's possible to control the tuner:
SCAN UP - RC5 code 0x45E
SCAN DOWN - RC5 code 0x45F
STORE radio presets - RC5 0x459
The Logitech Harmony can learn these codes and add them to the remote. Maybe this information can be useful for another Audio Innovations users without a remote or with a dead remote.
I have not found the PROG button code for the CD Player. I looks the remote uses also NEC codes for CD player functions. My Arduino reports the system code 0x21B2 and different codes for the PLAY, PAUSE, etc. keys
Best regards
18Sound 18NLS4000
Hi, as the title suggests, I just want to point out this new interesting 18sound subwoofer:
https://www.eighteensound.it/en/products/lf-driver/18-0/4/18NLS4000
The parameters are interesting, in particular the xmax of 22mm and the xvar of 25. The peak-to-peak excursion is not indicated but seeing the thickness of the suspension I would say that it's very high. It's really atypical for a "pro" subwoofer, it seems more meant for home theater use. Another interesting thing is that, in relation to the size, it doesn't require huge cabinet (qts 0.35), less than 150 liters (B4 130L Fb @30Hz), not bad for 18" bass reflex but of course it can be profitably used in closed boxes with good equalization, the huge excursion makes it possible without issues
Humble One. Class A Push-Pull 11 Watt. Uses OPA189 opamp.
Hello.
Humble One is a small Class A amplifier.
Output is 11 Watt into 8 Ohm and 12 Watt into 4.
The amplifier uses only parts that are possible to find and buy.
Humble One is controlled by a quality opamp, OPA189, for low distortion.
https://www.ti.com/lit/ds/symlink/opa189.pdf
Output devices are MJE3055T and MJE2955T TO-220 transistors.
https://www.onsemi.com/pdf/datasheet/mje2955t-d.pdf
Bias in output is 1.25A Class A.
The power in each output device is 20 Watt and will produce heat.
Gain is set to x10.
The offset is very low thanks to the CMOS opamp.
Transformer should be 2x12VAC, preferably 100VA.
The circuit is simulated with very good results.
  • Locked
Balanced Audio Technology VK-D5SE
Hi All, new here and looking to get some help troubleshooting a Tube CD player. I know it's not an amplifier, but I thought I would find more help here in tube amps than the digital cd realm. This is a BAT VK-D5SE tube CD player that uses 4 6H30 tubes for the output. One channel (2 tubes) works fine the other channel has a couple issues I think are related but maybe not. I do have the schematics, and before I go into gory detail and upload the schematics, I wanted to make sure I was in the right spot and could get some help?
Thanks a bunch
jim
My SE amps sound harsh without NFB
I have two DIY SE tube amps I built. One with 6V6 tubes and the other EL84. Both are strapped as triodes. I prefer the triode sound to pentode wired and don't need the extra couple watts. I have tried to listen to them with no NFB but they sound a bit too harsh and aggressive through Klipsch Forte's without some global NFB using a 10K resistor. I read about similar amps with no NFB and how great they sound. So please fill me in on what could be going on.
You are currently viewing STK4141 Ic Stereo And Mono Amplifier Board Input And Output Connection Details
Music Lovers Today In This Article We Are Going To See The Stk4141 Ic Stereo And Mono Amplifier Board Review And Connection Details
[IMG alt="stk4141 ic
"]https://i0.wp.com/easyamplifier.com...e5-1-1024x512.jpg?resize=1024,512&ssl=1[/IMG]
This Stk4141 Ic Can Be Operated With a Dual Power Supply DC. This STK Series Ics Comes With Many Types For Example STK4141 Ic Can Give You 25 Watts Of Power Output Per Channel, Stk4191 IC Can Give You 50 Watts Of Power Output Per Channel, And Stk4231 Ic Can Give You 100 Watts Of Power Output Per Channel. These Types Of ICs Are Mostly And Easily Available In The Market.
We Also Wrote An Article About The Best Amplifier Board In The Market. You Can Read That Article To Select The Best Amplifier board according to your needs. These STK Series ICs Are Stopped Manufacturing From Long Ago. Now, These ICs Are Available In The Markets Are Duplicate ICs That Come From China And Korea. These ICs Also Give The Best Results Equal To Original ICs.
Nowadays, STK ICs Are Available In Two Variants: The ON Series And D Series.
This Is D Series IC. When It Comes To The STK Series Amplifier Board The IC And Driver Circuit Are Available Separately You Have To Solder By Yourself.
When Compared To D Series ICs ON Series ICs Are Given The Best Results Rather Than D Series IC.
This STK4141 ICs Power Supply Range Is As Per The Datasheet You Can Give A Maximum Of 40v DC. But You Can’t Run Continually With That Supply. Because These ICs Are Not Original If You Give That Much Power Supply It Will Damage Your IC Very Soon.
So In My Point, You Can Give A 24-0-24v Power Supply To This IC When You Are Using 4 Ohms Speakers. And You Can Get A Maximum Of 25 Watts Of Audio Power Output Per Channel. Whereas If You Are Using An 8 Ohms Speaker Then You Can Get A Maximum Of 25 Watts Of Power Output Per Channel With 27-0-27 DC Power Supply.
If You Assemble A Stereo Amplifier Then In My Recommendation Use A 20-0-20 Transformer With 3 Amps To 5 Amps And If You Assemble A 5.1 Amplifier With 3 IC Then Use A 24-0-24 Transformer With A 5 To 7 Amps Power Supply.
Now We Are Going To See This STK4141 Ic Stereo Amplifier Board Input And Output Connection Details​
This STK Series IC Comes In Many Varieties But Nowadays Only Three Types (STK4141, STK4191, STK4231) Or STK ICs Are Only Available In The Market Maximum.
STK 4141 Ic Connection Diagram
STK4141 IC Comes With 18 Pins, Pin No 11 To Give Positive Supply, Pin No 14 To Give Negative Supply Input, Pins No 3 And 16 To Give Ground Supply, Pin No 1 To Give Left Channel Audio Signal Input, Pin No 10 To Get Left Channel Speaker Output, Pin No 18 To Give Right Channel Signal Input And Pin No 13 To Get Right Channel Speaker Output. All The Connection Details Are Clearly Mentioned In The Driver Board PCB. If You Have Any Doubts About The Connection You Can Ask Me In The Comment Section
STK4141 IC Mono Board Connection Details​
If You Search In STK4141 Ic Datasheet You Couldn’t Find To Stereo To Mono Conversion Method. But Our Technicians Find La4440 Stereo To Mono Conversion Method Will Also Works On The STK Series IC. And Also Successfully Made It Too… Hays Off To The Technicians To Make That Happen.
Connection Details
All The Connections Are Clearly Mentioned In The PCB. And You Can Ask Me In The Comment Section To Know More About This Board.
And We Can Make This Board Stereo To Mono And Mono To Stereo If You Want To Know How Please Ask In The Comment Section So Will Write A Separate Article About That.
Determine the input voltage of the rcore transformer
Determine the input voltage of the rcore transformer. Hello everyone, I have an Rcore transformer that I want to use for an audio preamplifier circuit. I have determined the secondary and primary wire groups by measuring the resistance of the wire groups. However, I cannot determine whether the transformer is a 220v or 100v input. We hope to help
XY LM3886 Kit Review & Measurements
Disclaimer: I do offer a competing product for sale: Neurochrome LM3886 Done Right, although, my kit is about 5x the cost of the eBay kit reviewed here, so I'm obviously not competing on price. Still, some may perceive this as a conflict of interest and I figured I should make it publicly known up front.
There are many LM3886 boards available in the market today and they all seem to implement various bits and pieces of the Typical Application schematic from the LM3886 data sheet. Some include the components necessary for good stability. Others don't. Most of the layouts are of dubious quality to say the least, but some are pretty decent. I decided to take a look at one of the circuits that looked pretty decent in the eBay pictures.
The XY LM3886 Kit is very popular here on DIY Audio and judging by the pictures of the circuit board, it looks like the layout should be decent. So I threw $11 at it (the kit was on sale) and had the kit within a week.
The kit came with the parts pictured and an instruction sheet in Chinese. No schematic or top level hook-up diagram was included. Basically, if you understand Chinese, you have enough information to put the components into the board but you're on your own from there. Thankfully, the silk screen on the board indicates the part values so I could assemble the kit. The kit included two shoulder washers, which aren't needed, and an M3 machine screw for securing the LM3886 to a heat sink. Excellent!
The passives look decent. You get a couple of noname 100 uF electrolytic caps for supply decoupling (National Semiconductor recommends minimum 470 uF) and the mute capacitor, along with another noname electrolytic for the feedback capacitor. The input cap appears to be a Wima polyester cap. Not the best choice of dielectric for low THD, but it could be worse. The resistors appear to be ±1 % metal film and measure within the ±1 % tolerance of the value marked on them. There is also a 0.15Ω, 5W power resistor that appears to be used to keep the amp stable with a capacitive load. Interesting choice. The three terminal blocks accept wires ranging from AWG 22 to AWG 14 and are of the leaf spring type rather than the better rising cage clamp type.
The LM3886 and the rest of the parts were in a regular plastic zip-lock bag inside of an ESD heat-sealed bag. From an ESD perspective, that's a no-no. The outer ESD bag is basically for show as the inner plastic bag will still be able to accumulate charge. Considering that XY has a machine to seal the ESD bags, I' surprised they didn't follow regular ESD practices and precautions and double-bagged the parts in ESD bags.
Now about the LM3886. I've always wondered how these Chinese eBay vendors can make money selling $11 kits that contain $20+ worth of parts. I think I've figured out how. The LM3886 that was included with the XY LM3886 Kit is pictured next to a brand new LM3886 from Mouser in the attached images. Note that the "LM3886" from XY is marked in ink whereas the LM3886 from National Semiconductor/Texas Instruments is marked with a laser. Note how the National logo on the XY "LM3886" isn't as crisp as the LM3886 from National? Note how the text on the "LM3886" appears to be right-adjusted whereas the text on the LM3886 follows western convention and is left-adjusted. The ink markings are a dead give-away. I worked for National Semiconductor from 2005 until we were acquired by Texas Instruments in 2012 and continued with TI until last year when I decided to pursue other opportunities. I have seen many, many National parts none of them were marked in ink. I did give XY the benefit of the doubt, though. It could be an old stock part... So I had a friend at TI look up the lot code "PM52AE". This lot code does not exist in the TI/National system. The "LM3886" that I received as part of the XY kit is fake. I am 99.999999 % certain of this and will send the IC to TI for analysis to find out for sure. Update: See the results of TI's analysis in Post #216.
Considering that Wima's capacitors are popular targets for copycats as well, one is left to wonder how many genuine parts are in this kit.
Those in need of more detail on the marking of National Semiconductor parts, please have a look at:
TI: Former National part marking Info
Chipdocs: National Semiconductor
OK, fine! You get what you pay for, right? I can't ship the kit across Canada, never mind to China, for the amount I spent on the kit. What's the big deal!? Hey, maybe it's a factory reject that failed on one parameter that I don't care about. Or maybe it's a completely different die in a package marked LM3886. Who knows? Needless to say, I was very careful when I powered up the kit.
The PCB layout is decent. There's a ground pour on one side of the board for the power ground and a pour or the top side of the board for the input and feedback ground. You really don't want the feedback and input ground together as the feedback current is pretty nasty and will create an error voltage across the input ground with high harmonic content. The two grounds should ideally also connect at the output ground rather than at the supply decoupling caps as done in the XY board. The saving grace is that the board is tiny, so the impedance of the pours are relatively low, thus, not much error voltage develops.
I do like that the supply routing comes in from the left (pin 1) side of the LM3886, though. This allows for the lowest possible supply impedance and keeps the traces close together to minimize rail-induced distortion. To me, this is the only supply routing for an LM3886 that makes sense. I'm actually a bit puzzled why so many have the VEE supply come in from the right. Anyway. Good for XY that they got the supply routing right. Aside from the ground pours (not planes!) and supply routing, the board is a basic "connect-the-dots" layout similar to what I'd expect for a beginner's first PCB layout. Pretty good, but there's room for improvement.
The kit came together very quickly. I think it took me 15-20 minutes to solder it up. For the test, I used a heat sink with a thermal resistance of 0.4 K/W to ensure that the IC would run cool. I used a pair of HP 6643A laboratory power supplies to power the board. I measured the THD, IMD, etc. with my Audio Precision APx525. The time-domain measurements were performed using an HP 3312A function generator and TEK 2465B 400 MHz oscilloscope (limited to 20 MHz bandwidth to provide the cleanest measurements). The frequency response measurements were performed using an HP 3563A Dynamic Signal Analyzer for the low end and HP 3577A Network Analyzer for the high end. Markers are placed at the -3 dB frequencies (3 dB down from the level at 1 kHz).
The supply voltage was ±30 V for all tests. A 10000 uF capacitor was placed on each supply rail to ensure a good and stable power supply.
Enjoy.
Tom
Reactions: ring and jwdevos
Voltage regulator chart
I made this chart of all the voltages you'd get using standard 1% resistor values for all the combinations of R1 and R2 where R1 is 120R through 1K and R2 is 120R through 10K. It makes it really easy to choose fixed resistors to get near the voltage you want without having to look up numerous standard values and do each calculation until you find something.
For example if you want to heat a 6.3V tube filament just find your voltage and R1 will be at the top and R2 at the left, in this case 6.25 volts is found at the intersection of 300R (R1) and 1.2K (R2) a nice voltage for the tube just under 6.3. If you wanted to hit it nearly spot on 6.28V is found at R1 = 820 R2 = 3300. Thought it might come in handy for others so contributing it here.
Listening to music via matrix decoders
I absolutely love listening to music via DPLIIx and that is how I listen to all my music. This has become my preference and I'm wondering whether there are fellow members of the forum who prefer and enjoy the same. Having said that, I'm not happy about the fact that DPLII has now been eradicated from all the new processors and receivers. Got to hear music I know well via the new DSU codec but was not impressed, not sure if it has been improved to be as good as DPLIIx. I know DSU is designed to work with Atmos configurations but does it sound as good as DPLIIx is the question.
I suppose music that is mixed and mastered specifically for Atmos will definitely be more refined but 2 channel music content is still mainstream.
Are these OT Winding Ratios correct?
Greetings,
I'm getting ready for my first tube amp project ever, although it might be challenging I'm trying to build a guitar amp inspired from a Mesa Boogie (for personal use).
I bought a new transformer rated for the original amplifier, which supports 2x 6L6 + 2x EL34, with the following specs:
75W max. Raa ca. 3.6k
M6 Lamination: 3,75", Stacking: 1 9/16"
Mounting on 79mm x 54mm
Primary: Orig. colors in brackets
A1 6L6 Blue (Blue)
A1 EL34 Violet (Blue/White)
B+ Red (Red)
A2 EL34 Orange (Brown/White)
A2 6L6 Brown (Brown)
Secondary:
0 Ohm Black (Black)
4 Ohms Green (Green)
8 Ohms Yellow (Yellow)
As you can see the OT has two separate taps for 6L6 and EL34.
Since I don't want to destroy anything, I decided to do the math/simulation first and test the output transformer by connecting a variac on the primary and measuring the unloaded voltage on the secondary (8 ohm tap), until the secondary voltage reaches exactly 1V (as suggested by Uncle Doug on a YT video).
The values that I measured are:
For 6L6: Brown-Blue: 19.1V, Black-Yellow: 1.0V
For EL34: Violet-Orange: 15.27V, Black-Yellow: 1.0V
It gives an primary impedance of ~2918 ohm for the 6L6 tap and 1865 ohm for the EL34 tap, using the formula (8 ohm)*(Wratio^2)
Are these values compatible with a PP of the given tubes? I usually read much higher primary impedence values used for those tubes..
The specs say that it should have a Raa of about 3.6K, but my values are quite different. What am I overlooking? Perhaps should I have measured it using an 8ohm load?
LX521.4 auditions
Dear all,
happy to announce, that we are resuming demos of Siegfried Linkwitz´creation LX521.4 in
Corte Madera, CA (Nov.13th),
Healdsburg, CA (by appointment),
Houston, TX (by appointment) and
Stuttgart/Germany (by appointment).
Enjoy new cascaded, phase coherent analog crossover and low distortion 22cm Magnesium driver. These reports may be a teaser.
Feel free to book via email
Best
Frank
Reactions: Juhazi
For Sale Audio-GD NOS 11 Discrete PCM1704UK DAC + Headphone amplifier / Preamplifier (with upgrades)
Audio-GD NOS 11 Discrete PCM1704UK DAC + Headphone amplifier / Preamplifier (with upgrades).
https://www.icloud.com/sharedalbum/#B0yG4VTwGGYt1IF
Asking Price: £1,100 (But sensible offers considered).
I bought this new (Feb-2017) from the wonderful people at Magna-HiFi in the Netherlands. Jos helped me immensely.
I had an upgrade (silver wires/connectors) installed by Jos before shipping to me in UK.
I then returned it and had Jos fit an upgraded Singxer F1 USB interface in Sept-2018
Works really very well.
Comes with: Original Aluminium remote; VDC mains cable with Wattgate 320evo Standard on one end
No original box (I never envisaged needing it as this was a keeper!)
I'm also including its companion M-Way – ACSS NTRL Ref Analogue balanced interlink (mini-xlr to 4-PIN XLR) for connecting this unit to an ACSS-capable power amp.
COLLECTION ONLY.
However, I'm happy to come to an arrangement to meet-half-way-so to peak and within reason.
I'm prepared to drive up to 30 miles from Malmesbury as part of the sale price.
I'm prepared to drive between 30 miles and up to 100 miles from Malmesbury @£0.40/mile (I'll charge for full round trip) to drop this off.
Please don't ask me to ship as I wont.
This is a great piece of kit. I'm selling as I have no where to put it and it's been under my bed for 2 years.
I'm happy to discuss more via messaging - just reach out.
UK ONLY - I WILL NOT SHIP THIS ITEM.
Thanks.
Help with Kelvin Labs Integrated
Hi everybody
Long time since I posted here in the forum but need some help/advice with this amplifier.
It is a Kelvin Labs Integrated (early series) that after a problem in my house wiring (damp in the walls) got hit by a surge after one of the many power cuts.
The problem is that now sounds like the is a car engine running in the background with or without signal in all inputs not changing with the volume settings.
I allready checked the power supply and changed all the caps (after 20+ years was in need) without change to the problem.
Traced the problem to the preamp, if I disconnect the preamp connection to the amp (at volume pot) the amp goes dead silent.
Here is my problem, on the preamp are no elcos just mylar and tantalum capacitors and don't know were to go from here.😕
Do I replace the tantalums with same type or can I use other type of caps ?
Any advice is welcome
Ric
PS; Don't know if this is the right forum but the amp is a Class A (?) one
preamp 6J1 used separate, transformer ct hot
try to repair the 6j1 preamp, the same scheme follows the original, only there is a modification in the psu, the plate voltage is 28 volt ct, the output of the regulator is lm317 and 337, the transformer is 3 ampere, the heater uses 1 ampere, the voltage using 9 volts is turned down using lm2596 to 6.3 volt dc... which makes I'm confused, originally I used 12vac 1 amper (it's safe) then multipliered it to 28 vdc. When using a model like this, it often makes noise, so I modified a separate PSU (the hum is gone, the noise is gone). The question is why the 3 ampere transformer heats up quickly even though the regulator IC is still there. It's just cool.....maybe someone can help
Cubie2
Taking of from here (post #485), I adopted this lovely gain stage as the part of a power amp - Cubie sounds great but Cubie2 manages to sound a bit better. 🙂
So Cubie2 is an extension of BAF 2013 preamp idea, with current mirror (Q3/Q5 and Q4/Q8) instead of resistor/CCS and introduction of negative feedback loop (R7/R16) which sets the gain at about 19dB. The LATFETs in the output stage (Q9/Q10) work in source-follower mode, without source resistors, providing some extended class A regime due to the square law transfer characteristic of MOSFETs.
The input JFET pair can be of any flavor (GR, BL or V), it's just important to dimension R11/R13 so to get about 10-12 mA flowing through the folded cascode branch (Q6/Q7/Rbias). Values on the sch. are based on JFETs' Id of about 6.5 mA. With such JFETs I got about 10mA through Rbias=330R which sets the LATFETs Vgs_Q10 + Vgs_Q9 = 3.3V and the output pair's Id at about 0.7A, but you can use the 1k pot instead of Rbias to set the output stage current to different value or to accommodate for LATFETs' differentiating Vgs/Id characteristic (my current batch of k1058s need 1.70-1.75V for Id of 0.7A and J162s need 1.55-1.60V for the same Id). P1 sets the 0V DC offset at the output, and it's very stable: +/-10mV from cold to hot and +/-2mV when hot. It's also very stable into reactive loads - testing it, I didn't succeed to make it misbehave.
R25 is there to load the folded cascode and determine the OLG (about 45dB) while the C3 shorts the gates of LATFETs for AC signal.
Full power before clipping is 34W_peak at 4R load with 1.3V_peak input signal and about 19W_peak at 8R load with 1.4V_peak at input.
The PCB dimensions are 70 x 25 mm, copper side view. The GND connection for decoupling caps (C5/C6) should be made with separate wires to main GND point, independent from signal GND on the PCB.
The PSU is same as here (post #62).
I tested the amp without the feedback loop (R7 and R25 go out, Rbias is split into 2 x 160R and from their middle point 1k connects to GND) and it sounds great too but with feedback loop it has a bit more definition and bass firmness. Those who enjoy "velvety" quality of BAF2013 preamp might like it more without the feedback loop.
WTB Linear Audio - Autoranger
I am looking for the Linear Audio Autoranger (or similar). Sadly, I didn't know I needed one, until they're out of production it seems.
https://www.linearaudio.net/la-autoranger
I've built a few voltage dividers and other reasonable solutions, but I'd like something more elegant / consistent / better.
If you have one you're willing to part with and/or could provide a link to alternatives, I'd be grateful.
Thank you in advance.
Summer Project - Replication of MBL loudspeaker 101mkII
I have a good 2 months out of school and i decided to build a replication of the loudspeakers MBL 101 mkII. The monetary resources to build a clone at least parts of it are taken care of . The following are the complete information of construction regarding the MBL 101 mkII. This project is inspired by this thread My MBL 101E replicas
DELAYED
The Tweeter :
Number Of Petals - 24
Lamella Material - Uni-Directional Carbon Fiber
Lamella - 24mm x Unknown
Lamella Bending Radius - 25mm
Lamella Type - Non-Stitched Epoxy Bonded
Lamella Resin - MGS System 285 (H287S MGS HARDENER SLOW)
Lamella - Bake Temperature And Pressure Unknown
Lamella Prepeg ratio - 54% Carbon Fiber 46% Epoxy Resin
Lamella Glue - unknown
Dampening - Polyester Fiber
(Twaron Angel hair)
Top Cap - W x 44.45mm
Top Cap Hole Diameter - Unknown
Mid Support Rod - W x L Unknown
Voice coil - Diameter 37mm ( 3.7cm )
Voice coil/Former - 4n Copper Wiring Used
Voice coil/Former - Aluminum Former Used
Voice coil/Former- Glue used is car break glue ''burned in at 500 Fahrenheit''
Voice coil/Former - Floats In Ferrofluid
Top Plate Diameter - 120.40mm
Bottom Plate Diameter - Unknown
Magnetic Material - Neodymium
Magnet size - 70mm ( 7cm )
Tweeter​
Additional Known Driver Info​
The outside of the lamellas are coated with a thin anti resonance film. The inside of the circular lamella configuration is filled with sound absorbing fibers witch have been confirmed to be of polyester origin.​
IN-PROGRESS
The Mid-Range :
Number of petals - 12
Lamella material - Cross-Woven Carbon-Fiber
Lamella Tow - 1K
Lamella Type - Spread tow ( PrimeTex ZB )
Lamella cut - Bias
Lamella - 12.5mm x 1 sheet x 62mm
Lamella Bending Radius - 55mm
Lamella - Bake Temperature 176F And Pressure 200psi
Lamella Prepeg Ratio - 54% Carbon Fiber 46% Epoxy Resin
Lamella Glue - Silicon Rubber Glue (Wacker)
Dampening - Polyester Fiber (Twaron Angel Hair)
Inner Ring- 40mm x 12.5mm
Inner-Ring Material - AL-MG ( Aluminum/Magnesium)
Inner-Ring Hole Diameter -
13mm
Outer-Ring - 90 x 12.5mm
Outer-Ring Material - AL-MG ( Aluminum/Magnesium)
Outer ring Hole diameter -
9.525mm ( 3/8" )
Inner-Hollow pass through -Rod - (OD)13mm x 5"
Inner-Hollow pass through -Rod (ID) 6.25mm
Inner-Hollow pass through -Rod Material - Graphite
Outer-Steel Support-Rod - 9.525mm ( 3/8" ) x 60mm ( 6cm )
Outer-Support-Rod Material - Super-Refined Steel
Voice coil Diameter - 5cm ( 50mm )
Voice coil/Former - 4n copper wiring used
Voice coil/Former - Kapton former used
Voice coil/Former - Floats In Ferro-Fluid
Top Plate Diameter - Unknown
Magnet material - Neodymium
Magnet size - 12cm ( 120mm )
Mid-Range​
The thrust bearing is a single side coated with a heavy tar plate to reduce resonance. The inside of the lamella group is coated with a special rubber material, and thin anti resonance film is also applied to the lamellas. The four rods are super refined steel. Both ends of the lamellas are glued using the silicon rubber glue, all the lamellas are glue together with a bead. polyester fiber fills the inside, and is sealed off by a rubber material.​
Delayed
The Melon :
Lamella material - an alloy of Aluminum,magnesium,and silicon
Alloy ratio - Unknown
Lamella - Raw 50mm widest point x 20mm at end points x D x 360mm
Lamella - Assembled 10in x D x 16.5in with a lamella end of 4inch
Lamella Bending Radius - Unknown
Dampening - Polyurethane Foam/Polyester Fiber
Copper Rods - L x W Unknown
Top Cap - W x D x L Unknown
Top Cap Hole Diameter -Unknown
Mid- Hollow -Rod - W x D x L Unknown
100mm OD (10cm)
Voice coil/Former - 4n copper wiring used Likely
Voice coil/Former- Glue used is car break glue Likely
Voice coil/Former - Former Used Unknown
Voice coil/Former - floats in Ferrofluid likely
Magnetic Material - Ferrite
Magnet size - 200mm OD (20cm)
Spider ID-OD - 100mm (10cm)
Melon
Additional Driver Info​
The aluminum lamellas are a sandwich construction of two aluminum wedges held with epoxy resin Wrong. The petals are given 2 days to cool like airplane parts. layers of polyurethane foam are slapped on the back of each lamella to provide damping and additional mass. Each lamella is fitted with 2 thick reddish copper ''wires''. The wires are fitted into the vertical recesses of the petal. The wires add mass and an aesthetic beauty. The recesses of the driver are rolled and not stamped. The whole assembly rest on a cast aluminum plinth coated in automotive grade atracite metallic paint.
The sub woofer
[FONT=Verdana, Arial, Helvetica, sans-serif][SIZE=-1]The woofer is a 12" driver with a 4" voice coil. The voice coil is composed of black anodized aluminum that has a very low thermal resistance, approximately 1 K/W. This gives the system large power handling capability. The voice coil wire is also constructed of high temperature material able to withstand temperatures of up to 360¡C. The wire is glued with the same glue used in the fabrication of motorcycle brakes, and is able to withstand a temperature of 260¡C. As a result, it is almost impossible to destroy the speaker. The air gap is 10 mm high and the moving coil has a winding width of 24 mm. Thus, the speaker possesses an extremely high linear throw, with a maximum of 14-mm peak to peak. The maximum mechanical throw is two times greater -- 28 mm maximum peak to peak.[/SIZE][/FONT]
For this i hope to substitute for this driver
TC Sounds Axis 12Q1 12" Quad VC Subwoofer 293-638
The cabinet :
Material - MDF
Material thickness - 30mm (1.25")
Port Holes - 2 inches in Diameter
Additional cabinet info
the cabinet has rectangular cross configuration to both stabilize the walls and hold the magnet with polyurethane supports.
specifications:
Crossover frequencies: 105Hz, 600Hz, 3.5kHz (Linkwitz-Riley, fourth-order). Acoustic center: 45" (1140mm) from floor. Frequency range: 24Hz–40kHz. Sensitivity: 81dB/2.83V/m. Nominal impedance: 4 ohms. Power handling: 320–500W continuous, 2.2kW peak.
Right now i am hopping to simply replicate the mid-range and used them as my stereo setup and as research and design along with resources progress the replication of the other 2 drivers will begin. I am learning to use Femm so that i can design and build the magnetic circuit for the mid range.The processes for building the mid range will hopefully be done in parts such as
Step 1 : Magnetic circuit fully designed and optimized in femm
Step 2 : ferrofluid properties such as viscosity,heat tolerance,and Gauss rating can then be calculated
Step 3 : Carbon fiber baking methods can be R&D
Please tell me your thoughts on such a project
Listening about things
I've been recenlty doing all sorts of listening experiments, trying to get more familiar with my DIY speakers and speakers in general. Experiments from trying to find out how room affects perceived sound to how vibrations (knock) various parts of my speaker structure makes the freestanding waveguide resonate 🙂 Plan is to post about these for fun, even though they are not translatable through posts like this so you could have the same experience as I have had live doing these, hopefully my posts encourage everyone develop their listening skills and systems of course.
if you have some fun listening tests / experiments, please post them so me and others following can learn more 🙂
Here is fun set to start. Bought few compression drivers and was interested in how much their sound can differ in application, meaning that each was adjusted as part of complete system very close to same response would there still be meaningful difference? Well, didn't quite get there yet but had some time to make one round of measurements drivers playing alone, and thought to record small snippets out of that. There was 5uF capacitor in series with all, otherwise measured fullrange but then while exporting sound files I applied crude 4th order high pass at 1300Hz, about where it would be adjusted in application.
The test was not very scientific, although I tried to keep everything untouched, except change the driver. Waveguide is RCF H100 and drivers are hf10ak, cdx1-1747 and nd350.
HF10AK is measured three times actually, once with the same setup with cdx and nd350. Then twice with slightly different measurement setup with motivation to compare if there is difference between 5uf protection cap or series resistor with parallel inductor making high passinstead. I had to level match the inductor measurement as the resistor works as a pad.
Anyway, behind link thre is some wav files if you want to listen to. There is a snippet from a song and short white and pink noise files for each DUT. Also gated frequency response sweeps form on-axis. The files are level matched quite close, but frequency responses vary some. See text file inside to see which DUT-x- in file names is which driver 🙂
Well, haven't done much yet with the data. Plan is try to EQ match them with some tools and by ear and so on, just to manipulate them for a while to learn what the sound differences are. If you have a good methodology how to compare drivers in/for application, how to EQ match each for example, I'd be interested, thanks!🙂
https://www.dropbox.com/scl/fo/1kgiujc85ffjon3c9rppk/h?rlkey=ra4f89gldoabrjidc0swr1h1y&dl=0
FOR SALE Audison Thesis HV Sedici (EU)
For sale two of the most amazing car audio amps that I've ever owned. A legendary piece of equipment if I can say.
Pure class A quality sound. With tomahawk chips at perfect working condition.
Photos will be uploaded soon.
Price is 800 euros per amp plus shipping costs and PayPal fees if any. In case someone wants them both, the price is 1500 shipping included.
Lab12 - Tapped Horn
Thanks to Don Snyder & Chris.
attachment.php
Split off from this long post,
http://www.diyaudio.com/forums/showthread.php?postid=1819879#post1819879
- 2-sheets of 3/4" 15-ply ApplePly used.
- The blue CAT5 will be used to power some RGB LEDs to illuminate the 1/2" Green-Edge CNC Carving / access panel.
- Coil will be installed later
Here are my current build pictures:
Old Canon 10D, 28-135mm USM-IS, ISO100, F16, 1/80sec.
Some CNC V-Bit Carving Action:
Setup took about an hour
Reactions: stewin
New cheap OB Line array build begins
As fall and winter approach, time to start my yearly exercise in self indulgence. The introduction last year of the two dual 18 dipole subs to the studio has taught me not much can beat OB in this space so the focus on this project will follow suit. Hopefully these will fall into use as dynamic midfield mix/mastering monitors as we expand.
We added a 16 channel Trident console for a hybrid system this spring so the budget is blown for the year…..all spare change for this one resulted in driver element choices are all value driven. High efficiency means we won’t need a lot of power to drive these to crazy levels when needed…..a repurposed Parasound 5 channel home theater amp we picked up at an estate sale a few years back along with a miniDSP should take care of things.
Reactions: ScottG
Benefits of the ACP+
I recently completed a pair of ACA’s from the store and the Redux version from Nelson Brock.
I like them both very much and they will be in regular rotation on my Forte IV’s. I think they just need a little push to live permanently in the living room.
I’m currently using a Schiit passive preamp with them and I’m satisfied. But I’m wondering if I build a ACP+ preamp, if I can expect to get anymore volume out of them? Connected through my BottleHead Moreplay I don’t notice much improvement, so not sure the ACP+ will give me anything.
Any insight on this would be helpful. Thank you.
DC coupled 4P1L + ECC81
I learned about the FP230 series of transformers from Triad. These are flat pack, 2 primaries and 2 secondaries wound on a 4 chamber bobbin, so with guaranteed insulation between the windings. The 230 refers to the secondaries: 2x 115V. I used these as filter chokes in two Futterman OTL amps, where they perform very well.
https://www.mouser.ch/c/power/transformers/power-transformers/?q=fp230
Another application is as a center tapped PP choke. Due to higher RDC at secondaries, I connected the transformer as shown. The resistors and pots are to increase the voltage drop, which is used for biasing the output tubes. The amp uses an input transformer, I choose the cheap TY-250P, also from Triad. The cathode resistor is 154R. I choose it over LEDs or CCS as it helps in keeping the current through the output tubes stable with varying mains AC (tested with a Variac). The actual B- is rather - -190V DC. For the output stage, the 4P1Ls were wired as triode, and fed from a VCCS.
The power supply uses a PT from a defect SS amplifier, which puts out about 88VAC. This goes in the doubler, and with a level shifting cap, to form the negative supply, with some additional filtering.
As directly heated, the 4P1L starts drawing current way before the ECC81s are hot and conducting, so I combined the capacitance multiplier with a crude current limiter, based on the 2x 6.2V zeners (had these hand, 12V Zener also ok) and the 2x 10R resistors. When too much current is drawn, the zeners start conducting and the gate of the Fet is pulled down. This works indeed. As a DC coupled amp, it is indeed nice to have a current limiter if something fails during operation.
As output transformers, I used Talema 7VA toroidal power transformers (230V to 7V). Unloaded, they measure about 8V at the secondary, so they present a 6k6 primary at 8R secondary.
The amp works, currently biased at circa 35mA per output tube. 1W at 0.35% THD, about 2.5W max. The frequency response is circa -2dB at 20kHz, and this is solely due to the used OPT. At the plate of the ECC81 the frequency response is flat until at least 30kHz. Amplification is 60x and very low distortion, so the PP chokes are doing their job.
I tested current disbalance in the FP230-25, and it can take some mA without getting much worse (I will get the exact numbers). The toroidal OPT were tested with a 5mA disbalance (so one side pulling 5mA more than the other). The THD doubled (to 0,6% THD at 1W) and the bass response suffered a bit. I will be using these as mid/high amps with a 12dB HP at 600Hz, so I do not care much about the bass performance.
There are no caps in the audio signal (not that I think that they hurt, but wanted to try it like this). There is still caps in the PS, so I am considering to feed the OPT through a choke, to isolate the amp from the PS and force class A operation (learned that from Lynn Olson’s website).
What I do specially like is that one can have quite a good performance as PP choke from a 10 USD part. Also, the 6 USD TY-250P surprised me.
Now I still have to listen to it!
A Day in the Life of diyAudio
This is one of those days. Many of us have experienced similar days, I’m sure.
I started my day off with some good coffee. Kettle on. Fresh ground beans of my favorite variety that is easily bought locally. Slow pour into my hodgepodge design of cotton fabric filter plus tea infuser. Then I performed the ritual powering-on of my audio systems. There are of course multiple ridiculous steps, just like the coffee. Preamp (two switches), power amp, speaker selector… No magic smoke. Preamp and power amp in the secondary system. Then fire up the music server. I have to restart squeezelite on two of my four synchronized piCorePlayers after multiple hours of inactivity for whatever reason, so I tapped multiple things with my phone browser to do that. Finally, ready to select some music. What do I feel like today? Kid in a candy store! Random mix of locally saved music felt right for today.
Time to sort out breakfast for my kids. After that’s done, time to casually read diyAudio threads.
After mulling over the myriad unfinished never-ending audio projects I have catalogued in my brain, I decided to do some DSP PEQ tweaking of my speakers. Many “WOOOOoooooiiiiiii” iterations later, I thought I had reached a significant improvement in the low end. That was the goal for this tinkering exercise, so I felt rather accomplished. It sounded pretty good.
Time to futz around in the back yard a bit before the rain comes. The weather has been deliciously autumnal in the mid-Atlantic the last few days. I harvested the waning tomatoes from my container garden and dead-headed some flowers for seed collecting.
With the success of PEQ fiddling, why not see how it sounds in the vinly rig? Sure. Sit back and rela— But what? The right channel is very weak. Oh no. Did my beloved vintage RIAA stage finally go belly-up? After testing all the physical connections and not getting any benefit, I decided to bring the whole vinyl rig out for troubleshooting. It is not a trivial task to disconnect equipment from the main system. Carefully threading cables in a tight corner. I brought it all to the dining room table to see where the problem was. Thankfully I have any number of unused power amps not in rotation to contribute to the effort. Commandeering the entire table with the turntable, multiple preamps, buffer with gain, an ADC, a power amp, and test speakers… It was an operation. should have grabbed a picture of it, but I was trying to be efficient.
To my surprise, everything worked fine. No recurrence of the weak right channel. All components working perfectly. Relief, but perplexing. I switched things around enough to make sure all was well, then hauled it all back to the main system. More futzing with cables and tight spaces.
Finally, all things checked out. Time to sit back and enjoy an album.
Insight, execution, joy, shock, fear, perseverance, vindication, wonder, all in the day of diyAudio.
Enjoy the journey!
Reactions: ra7 and Captain B
Denon AVR 3802 stuck in protection mode?
I have the above amp that was stuck in protection mode (red flashing LED). I removed the covers and saw the main reservoir caps on the PSU were swollen, so I replaced those and all the other electrolytics on the power board and for a few days, it seemed to work ok. This morning, it's dropped back into protection mode without anything connected to it.
Does anyone have any ideas where I should look to try and get to the bottom of this? I've measured all output devices and they seem to be fine (speakers are also ok).
Also, does anyone have the full service manual for this model?
Bore Hole in Granite
I have a two 3" granite surface plates that I use for a turntable stand. I recently found a new bearing that is taller than the stock one and would like to bore a 2 inch diameter hole in the lower plate. The original cut-outs were done by a water-jet machine but transporting the plate is difficult and I'm not sure if they can do it without a CAD drawing anyway. Any opinions as to the feasibility of a DIY solution? The hole doesn't have to be perfect. It is just for clearance. The hole would go in the second picture basically in the center there the heaters meet.
Mysterious Environmental Hum
Hey guys! Just recovering from a late summer c0uld and inflamed middle ear/s (there's 2 of them, right? Not actually a 3rd whole ear as such?). My hearing has been mostly down a few dB, but strangely UP in the bass. Particularly at about 77 Hz, and something has been making a rather steady tone at that frequency 24/7 and it has been driving me up the wall.
OK, I'm no professional like Clouseau, but I've been motivated to do some serious sleuthing. This is what I've got so far:
SPL: extremely low. Maybe 5 or 10dB above absolute zero. It easily fades and disappears momentarily with the onset of louder sounds, and if there's too much other noise I just won't hear it at all. It seems loudest at about 4 or 5am. Right in the middle of my beauty sleep!
Initially, I had to rule out mains electricity, so I switched off the breakers late at night. No fridge, no pumps or anything. I put the clock in a cupboard. No change.
Maybe it was tinnitus? Nope. From experience, that was usually some transient ringing that would shortly fade, and only on one side at a time. Or maybe a high frequency cicada like noise, but not constant bass in both ears.
I'd heard it before, but initially wrote it off as probably a water pump, so I put it out of my mind. But then we moved house, and then it dawned on me that the new place was producing the exact same sound from a year ago. As if the walls themselves were throbbing, and the tone seemed a bit louder if I was close to a wall or in a corner.
I haven't tried recording it yet. With my current non-setup it will likely be all noise and no signal, but it's coming.
I tried to pin-point the frequency by humming it and finding it on my keyboard, and eventually got a D# almost 2 octaves below middle C.
Then I found that if I played a D (natural) really softly with a mellow Rhodes-like sound and waited for the levels to balance out, I could get the two tones to interfere! Gotcha!!! The bastard!
Maybe it was underground mining or a factory or something nearby? The two houses are only a few km apart, so it still could have been a local source. But then I visited family over 40km away, and it was the same.
At this point, the only thing that seems to vaguely make sense is that it's a Schumann resonance of the earth (one of the harmonics anyway). But those are meant to be radio waves. Bizarre!
Vifa silk dome tweeter? Came out of an old M&K bookshelf. Is it worth keeping or just another silk dome?
Vifa silk dome tweeter? Came out of an old m&k bookshelf. Is it worth keeping or just another silk dome? Looks like another Polk audio silk done without the trilaminate coating I highly doubt it can handle the volume that a poke silk dumb can handle but I might be surprised. Denmark sounds impressive
TDA8932 and TDA7492 are very quiet - what affects power amp volume?
I'm a gigging guitarist, and until recently I was using a 30w Mooer Baby Bomb as a power amp to drive an 8 ohm load for performances. However, the Baby Bomb developed a harsh ground loop noise reminiscent of chirping crickets- I'm not sure if it's the power supply or not, as a new one has not arrived yet, but I decided to try building a DIY power amp of my own, as it sounded like a fun project.
I stumbled upon this diagram of a stereo amp using two TPA3118 chips. I only needed it in mono, so I essentially cut the diagram in half. I also ended up going with a TDA8932 chip and a TDA7492 so I could try multiple options- the TDA8932 is listed as 35w at 8 ohms, and the TDA7492 is listed as being 2x50w at 8 ohms, which I bridged- if my understanding of impedance and power is correct, it's still 50w at 8 ohms (going down from 100w at 4 ohms), but it should be putting less strain on the amplifier.
I wired everything up according to the diagram above, using the specified capacitors and potentiometer for volume. I let the solder cool and plugged everything in to test, and while I was able to get sound, they're both pretty quiet. At half volume, the Baby Bomb would be peeling the paint off the walls (and would distort past there), but at full volume with a 24v power supply, both of these weren't even loud enough to keep up with a drummer. By absolutely cranking the output of my preamp, I was able to get the TDA8932 nearly there, but at that point some kind of overload protection seemed to kick on and the chip started to cut out.
What might be affecting the volume level of these chips? Everyone else I've seen online seems to get plenty of volume out of these, but I'm not sure what I'm doing wrong. Should I be using a different chip?
Sooo many questions about preamp Equivalent Input Noise (EIN) measurement. please help!!!
I encountered a significant setback while studying the process of measuring the Equivalent Input Noise (EIN) of a microphone preamp. There are several tutorials on EIN measurement available online, but I have many areas of confusion, which has resulted in me spending over a week without fully understanding how to calculate it.
The simplest method I found is to obtain a known gain and then insert a 150-ohm plug to measure the noise. In my case, the RMS meter in Reaper shows -80.8dB, with a gain of 57.7dB. This results in an absurd value of -138.5dB, whereas the EIN (Equivalent Input Noise) should typically be around -130.X. Clearly, there seems to be some issue.
Login to view embedded media The second method I tried was from YouTube. The challenging part of this method is that my sound card has analog knobs, so I cannot precisely control the dB gain. I used the same -50dBV generator as the person in the video and tried adjusting the dBFS portion in REW to exactly increase it by 50dB. However, using their calculation method, I only obtained an EIN of around -126dB, which is a completely different value from the previous method.
The third method, I'm not entirely sure about. I used a known voltage, such as a 1mV input, to calibrate in the RTA interface within REW. Then, I disconnected the sine wave input and plugged in a 150-ohm load, switching directly to the dBu interface to view the values. This value seems to be very close to the "normal EIN value" of around -130dB, but I highly suspect it might be a coincidence because I haven't come across anyone using this method, at least not in tutorials available on the internet.
https://benchmarkmedia.com/blogs/app...c-preamp-noise
and this one completely different… I can't understand it at all.
I am soooo confused,and need some help.
Planar magnetic tweeter/mid with huge dispersion?
I made some weird planars with a 180 degree arc. and here are 2 tunes. where i show the dispersion, but besides that... its weird how it interacts with the room, when gated i get a flat response (relative) but then in real live its waay to mid/high heavy.
So i might need to tone that dispersion down so it does not interact so much with the room ? since it only adds up from 500hz to 10 khz or something.... (see measurements)
well who knows.. here it is
Login to view embedded media here are 2 measurements in the midle of the room one gated... and one not gated. and you can see there is quite some excesive mid/top added when not gated 5-9dB, while the top top end above 11khz does not add. witch makes the perception of me listening in the room pretty mid forward.... at least thats what i think. its sounds incorrect, while i love the stereo image.
i know there shoudl be a difference between the 2 but it looks excesive compared to flat panels. (i guess way more reflections because of the dispersion?)
Teac PD-H500 CD player missing part question
I've disassembled a Teac PD-H500 for cleaning and a new belt and after removing the CD tray the following part came out, but I have no clue where it came from and where to put it back.
Service manual is silent about it and only shows a drawing of the complete assembly. I only know it came from the side where the gears are located.
Any ideas? I think it's a kind of spring meant to prevent the CD tray from wobbling when moving.
Designs for loudspeakers for party
Hello. I recently build a subwoofer with 18in la voce. Thinking of using it for a party and do not want to risk damaging my speakers. Was wondering if there is a post showing how to build a simple and loud 2 way speaker. Since i do not have a big amplifier it should be efficient. Wanted to try a horn loaded tweeter mid and a big woofer arohnd 10". Any suggestions?
2nd order Allpassfilters with high Q and group Delay
Hello, maybe a noob question but I’ll ask it anyway.
I recently took a look at allpassfilters with a few webinars and now I’m wondering if you could possibly „change“ group Delay with a 2nd order allpassfilter with high Q factor.
Allpassfilters shift the time delay of the lower frequency’s where the filter is applied.
If you use a high Q factor it would shift the time at the frequency where the filter is applied even more than below that. I attached a picture to show what I mean.
Following situation:
Subwoofer with high group Delay at for example 40hz, with a downward sloping group Delay to 80hz. (Tapped horn)
Wouldn’t it be possible to introduce an 2nd order allpassfilter with high Q at 80hz to shorten the time distance between 40hz and 80hz? I know this would result in an overall higher group Delay. But isn’t it better to have for example 50ms at 40hz and 20ms at 80hz with a 20ms difference than 40ms at 40hz and only 5ms at 80hz with 35ms? Of course you would have to delay your mains more, but my main question is if you can get tighter bass out of a sub with this method?
Crossover upgrade advice needed
Greetings to all,
first thing first, I have very basic knowledge in crossover build so please be kind.🙄
A couple of years ago I bought a pair of KEF Q950 speakers really cheap. Now I want to upgrade their crossover parts to better ones to see if I will gain any sonic benefit. The reason for doing this is that the crossover is rather simple and uses very little part count, hence small fundings needed and not that complicated to be done from me.
The schematic and a picture of the crossover is in the attachment.
I did a little research of my own about sound signatures of different components. Taking into account on how the sound can change and what sonic difference I'm after, I have already bought the capacitors (30uF Jantzen CrossCap/ 5.6uF Jantzen Superior-Z), resistors (Mundorf MOX 10W), Jantzen brass binding posts.
I'm very sensitive to harsh treble so that is the main aspect that I am trying to avoid. Also I would appreciate some additional juiciness in the midrange and guitars / piano.
Now comes my concerns about the rest of the parts and where I need the most help.
For the inductors I can't measure the DCR for now(just ordered some LCR meter from china). But if we hypothetically say that they are equal in DCR:
1. If I change the coil for the low frequencies from the stock ferrite core inductor 2.0mH/DCR?/ AWG ? to an air core Mundorf 2.0mH/0.45ohm/18AWG how will this affect the sound? Will it be worth the effort?
2. If I change the coil for the low midrange from the stock ferrite core inductor 0.85mH/ DCR?/ AWG ? to an air core Jantzen 0.85mH/0.45ohm/18AWG how will this affect the sound? Will it be worth the effort?
Any advice will be appreciated!
Who made this cassette deck? Major MC 11A
I just repaired this awesome cassette deck made in 1978. The brand is totally unknown to me and I wasn't able to find who is the actual manufacturer of the deck.
Posting some pics in case anyone could help.
Do i need a XLR splitter for a dual 15 inch speaker?
Hi guys, I'm new here.
I struggling to find an answer for a basic question online.
I'm currently running two AVE bassboy 18inch powered subwoofers and two powered psx112 wharfedale 12inch speakers via xlr cables.
I've just had a a friend offer his two powered wharfedale ax215 dual 15inch speakers to me.
I've noticed that at the back of each ax215 speaker , they have two separate xlr inputs labeled A & B.
Can I just buy a couple of Xlr splitters and connect the ax215's to my AVE subwoofers? Or is it more complicated?
Any help is greatly appreciated
DVC driver parameters - how to get it correct ?
Hello everyone.
First, sorry for my probably not very good english.
I have 2 different DVC drivers for different subwoofer/bass speaker projects (Ciare HSG200-44 and Ciare HSB320-44). I simmed only dividing Re by 4 but i just read that Bl also has to be divided (by 2).
However i still don't know how to sim with 2 separate amps as the BL apparently also has to be divided by 2 (same for Re) which doesn't match with Qes.
Btw, I have to say i still have doubts as many 4ohm drivers often have close Bl characteristics to the 8ohm models (for drivers that have both 4 and 8ohm available).
And if Bl has to be somehow proportional to Re, is it really possible for a 8" Deaf Bonce driver to have 2x1ohm impedance (Re not specified) with a Bl of 18,4 and a Qts of 0,55 (while this Bl would mean a qts of around 0,26) ?
Could someone help me to make it a bit clearer before i start building everything ?
Thanks a lot for reading.
Embedding loudness compensation to the speaker
I know the loudness circuit is generally embedded in the preamp section of the amplifier system. But I wonder are there any passive devices that are installed in the passive crossover of the speaker and allow the speaker to perform as if it had a loudness compensation itself?
The device should have the ability to vary its resistance (inversely either current or voltage of the amplifier’s output) and be connected only to the woofer.
Graham Maynard Class A Preamp
I'm trying to simulate this very interesting circuit by Graham Maynard. Essentially a discrete op amp with Class A output stage.
It's oscillating pretty nastily in LTSpice. I've tried higher values for the feedback cap and lower values for the feedback resistor (lower gain), and it just gets worse. With even 27pf in the feedback loop, it simply doesn't work at all - only oscillation.
Any thoughts on why it's not working? Maybe it needs some sort of internal compensation?
JBL 2450 J with Aquaplas
For sale, JBL 2450 J with recent Aquaplas new diaphragms. With the new diaphragms the JBL becomes an 8 ohm CD (H version).
I have 2 for sale for 800.00 includes Fedex ground shipping in the continental US.
Also if someone is in Southern California and wants to pick them up I will throw in two nice Goldwood 2 inch waveguide's at no additional cost. The Goldwood's work well down to 550 hz.
Bluetooth module high frequency and buzzing noise
Hello,
I've recently got a 5V bluetooth receiver audio board to play music remotly to my speakers, before I soldered the power I tested it via a 5V phone charger and it worked fine..
When plugged into the DC-DC step down board the BT receiver board is making first high frequency noises and then it's just buzzing.
Any ideas how I could fix that problem?
Bluetooth board:VHM 314 Bluetooth Audio Receiver board Bluetooth 5.0 mp3 lossless decoder board Wireless Stereo Music Module-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
Wiring diagram:
Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/builds
Paraflex & Super Planar High Order Compound QW & Compound Horn variants /dev/builds
The builds you will see in this post are based upon designs provided by yours truly😀 and skillfully handcrafted by a man named J.R Vansickle of Paragon Concept audio in North Carolina ... Mr Vansickle has excellent woodworking skills, a great ear, and also a strong background in Home/Audiophile & Car Audio😎 ....
The compound loaded concepts discussed within this post started off as a configuration that had repeatedly proven itself to be viable (and practical) in simulation, so it became apparent to me that this was something worth exploring.... During this time Mr Vansickle was coincidentally receiving many requests for PA cabinets....
We had already worked together on a few designs that turned out well in the past, and now it was time to try something new:bulb:
The compound loaded simulations looked like they would deliver exactly what the application called for so Mr Vansickle built the first set and they worked like a charm! .. ... A few of these successful designs are currently in use by a few of Paragon's customers in the Eastern United States ..... If the cabinets did not sound right to his ear we would have fallen back to simpler designs for the customers but the first set of these that he built sounded fantastic, so we went with it!:happy2:
At this moment there are no detailed measurements, only a few crude approximations and a few low-res videos of them in action, but that should be remedied as Mr Vansickle has vastly increased his commercial shop space (new location) and is about to be outfitted with some gear that will be able to produce the detailed measurements that we sound fanatics desire🙂 ..
First of all to be fair i have to say that this is not a new idea by any means, compound horns have been around for a long time so i cannot take credit for that:goodbad:..... It is an old idea but sometimes old ideas are worth revisiting because new levels of performance are made possible with the use of modern drivers and modern software:cheers:..
In other parts of the world some people have recently constructed 6th order subwoofers and bass cabinets that they call "Planar Wave Horns" , the plans have been floating around for a while but the popularity has not caught on here in the United States as far as i can tell ....... I pondered that higher performance might be possible if i swapped out the rear resonant chamber/vent set in the Planar Wave Horn design and replaced it with a true quarter wave resonator (with or without expansion) ..... I tried this out in Hornresp (and yes you can do this in OD mode it just requires some creative usage of a vented rear chamber:sly: )..
The result is that you can utilize the resonance of the smaller chamber tuned to a higher frequency to fill in the dreaded response "hole" which typically plagues Back Loaded Horns , Rear Loaded Horns , TLs (QWPs) , Scoops etc .......... It is interesting that filling in this "hole" not only increases the usable bandwidth but also seems to improve general efficiency just a bit as well ....
Here is a generic sim to demonstrate this useful effect:
As it turns out the bandwidth can extend well beyond the "hole" that we filled in with our upper resonance ..... This makes it possible to create something like a high performance Kick-Bin cabinet with bandwidth that extends surprisingly high ....
OR
If gain and output take priority over bandwidth (as it might in a subwoofer design) then you can make that upper tuned chamber larger or longer which increases efficiency of the system while sacrificing bandwidth ......
Note: I have been calling this upper tuned chamber the "front chamber" or "MF waveguide" for lack of a better term at the moment .... and I have been calling these designs "SUPER PLANAR"
Here is a generic example of a subwoofer based upon this design can do:
This design can under the right circumstances compete directly with Front Loaded Horn and Tapped Horn designs of the same cabinet volume and tuning, loaded with the same driver but only if the driver has the appropriate T/S parameters for this design ...
In the case of a low tuned subwoofer loaded with a large diameter driver the cabinet volume requirements can be quite large unless you choose a driver with high motor force (relative to the diameter of it's diaphragm) and this sort of thing simply wasn't possible back in the 1930s (or whenever it was when the first compound horns were devised) ...
We will revisit this idea as a subwoofer later because we did produce a set and they work well , but for now we shall go back to kickbin designs because that is what we started with and we don't want to get ahead of ourselves ....
To demonstrate how the Super Planar can compete directly with a FLH (or Tapped Horn in some cases) here is the CV B36A (which i use for a kickbin) compared to the Super Planar using the same 188EB driver and the same cabinet volume .... I prefer the Super Planar's response here ..
Not bad eh?😀 Ideally the upper response would taper off and produce something roughly resembling a "house curve", but technically due to the 18" driver this one will be limited on the upper end (certainly no higher than 500hz without becoming too 'beamy").. ....... There is a way to have some amount of control over the contouring of the upper response, and it can be seen as a red panel in the following sketch .. More explanation on that later with accompanying Akabak modeling to demonstrate alterations in the response contour ......
Here was the sketch I came up with for J R Vansickle's very first SUPER PLANAR build! This set worked very well and ended up being used as Wideband Kickbins in a night club sound system installation located in North Carolina ...
As you can see this sketch originally gave us the option of building it without the front chamber (waveguide) which would have made it a plain offset-driver Back Loaded Horn but with the front chamber included it becomes a Super Planar BLH.:happy2:
The red panel can alter the midrange contour considerably but at the time Mr Vansickle wasn't set up to take detailed measurements so we left the panel at 50% depth of the waveguide because we knew that it would produce sufficient results ... With dual Dayton PA310 drivers the response reached reliably up to nearly 1khz ! We were pleasantly surprised by this :cheerful:.
I modeled this in Akabak in an effort to get an idea about how the contour would be altered by changing the length of our red panel ... I suspect these curves are a bit exaggerated (i did squash them vertically) but it gives you an idea of what is possible .... We are calling the red panel the "H-Panel" in this comparison...
I used a very non-scientific method in an attempt to get an idea of where the dips and bumps in response really landed in the real world cabinet ... I did this by running Mr Vansickle's recorded low-res cellphone video files (of multiple music tracks being played over these speakers) past my software RTA in peak-hold mode ...... I am happy to say that there doesn't appear to be any holes in response but there is what looks like might be a bump between 250hz-280hz and a dip centered around 310hz followed by another dip around 500hz but it is hard to say if the anomalies were just a feature of the music being played or some room interaction or boundary bounce or something else like the response of the microphone on his cellphone ..... Like i said it is the furthest thing from scientific 🙄 but promising. :scratch2:
Lets move on to some build photos:
He made this cabinet out of 3/4" ply (the dimensions were calculated for 1/2" ply , so needless to say the 12" drivers fit VERY tight but he made it work:smash:
You can see some more of the internal bracing on this next photo
These are 3-way cabinets with a Selenium D250X midrange compression driver coming in at right around 1khz and a Selenium D220Ti coming in at around 4khz-ish ...... The PRV horns that we put these drivers on produced responses that were very far removed from published curves 😱 (and this was obvious even without detailed measurements) so we had to redesign the crossover .... The woofers were actually run "Dry" and i didn't want to go into too much detail about the crossover network here (since it is unrelated to the compound loading concept) but in the end our filters were kept simple and sweet......
NOTE: Without the recommended HL14-25 horn the D250X does not want to reach very low.... In the PRV horn that we used there was a tremendous honk at 1khz, and if we reduced the series capacitance enough we could tame that 1khz bump however when set up that way there was no chance of significant output from it much below 1khz, so it was a good thing that the PA310s had no problem reaching up to that range despite the fact that they were recessed behind the waveguide which composes the front chamber on this cabinet .......
ANOTHER NOTE: On the PRV horn that we used the Selenium D250X is very loud (as if we traded some bandwidth for efficiency perhaps) and so it did require some padding/attenuation to better match the 220Ti and the parallel PA310s..
YET ANOTHER NOTE: We found that the D220Ti needed to be phase flipped in order to integrate smoothly with the midrange ..
AND NOW FOR SOME SUBWOOFER CABINETS
The goal was to build some subwoofers that could fit underneath the stage.. These would be installed at the same nightclub where the Super Planar tops were going to be used .... There was 23" of vertical clearance underneath the stage, and a heck of a lot of depth that we could utilize ....... Due to the height limitation and the design of the cabinet we knew it was going to be a tight fit for the driver so we came up with a few different baffle shape options ....
Mr Vansickle chose the "S" shaped baffle in the following sketch
We went with a Faital Pro brand driver but there are many more options that will work as listed on the right, some are crossed out because their excessive mounting depth means that they won't fit unless the box dimensions are made taller . ...
Many (if not the majority of) PA sub applications don't require such a low tuning , so in that case the cabinet would not need to be 60" deep, the path can be shortened a bit....
. These are some BIG boxes!😱
Lovely holed braces
Yes yes, I know ... He chose this banana jack binding post set (instead of Speakon) for a good reason i am sure, possibly having something to do with the tight quarters underneath the stage ...
For Sale FOR SALE. Audison HV Venti absolute best car amplifier on the market
For sale,
An absolutely fantastic piece of art.
The Audison HV Venti 2 channel audiophile audio (new price about 13.000 dollars).
This is the best amplifier you can buy in terms of sound quality.
The amplifier is very heavy, so it's preffered to pick it up at my house. Insured shipping is possible, but it will be expensive.
New price is about 13.000 dollars
My price is 3500 dollars.
It's fully functional and sounds fantastic!
For more information or interests, feel free to send me a message.
Reactions: beak81champ
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,916
Members
7,893,559
Messages
Filter
Forum Statistics
Threads
406,486
Messages
7,893,559
Members
507,916
Latest member
Lonk
