SIT measurements, Mu Follower, and amplifier build
Clearly I must stand corrected regarding the relative availability of the 2SC4793 and 2SA1837. Since they are no longer being manufactured, I would still like to recommend the substitutions of TTC004B and TTA004B.
In the newer schematic, it seems that the cascode transistors M1 and M2 can be substituted for a wider variety of small Mosfets, perhaps even some from the ZVN series, such as ZVN2106A and ZVP2106A. M3 and M4 are handling the workload of driving the output stage.
Here is the folded-cascode FE driving the SIT3X OS.
It would be useful if we could find some SPICE models for the folded cascode FET and BJT alternatives. My suggested parameter requirements are:
  • M1/M2 (2nd stage of folder cascode):
    • Vds(Vce) >= 80V Watts >=1W
  • M3/M4 source follower output stage:
    • Vds >= 80V Watts >=3W
Just for fun, here are some models for the lateral Mosfets that I would try in place of M3/M4.
Also probably close enough for the old Hitachi parts and the newer Exicons.
.SUBCKT MSK1058 1 2 3
* TERMINALS: 1 2 3
M1 9 7 8 8 DMOS L=1U W=1U
RD 1 9 80.4M
RS 3 8 5.28M
RG 2 7 21.4
CGS 7 8 410P
EGD 12 0 7 9 1
VFB 14 0 0
FFB 9 7 VFB 1
CGD 13 14 128P
R1 13 0 1
D1 12 13 DLIM
DDG 15 14 DCGD
R2 12 15 1
D2 15 0 DLIM
DSD 8 1 DSUB
LS 30 3 7.5N
LD 1 9 4N
.MODEL DMOS NMOS (LEVEL=3 THETA=85M VMAX=163K ETA=2.2M VTO=.2 KP=.999)
.MODEL DCGD D (CJO=128P VJ=.6 M=.68)
.MODEL DSUB D (IS=29N N=1.5 RS=61.4M BV=160 CJO=802P VJ=.8 M=.42 TT=252N)
.MODEL DLIM D (IS=100U)
.ENDS
.SUBCKT MSJ162 1 2 3
* TERMINALS: 1 2 3
RD 9 1 110.4M
RS 8 3 25.28M
RG 7 2 17.4
CGS 7 8 760P
EGD 12 0 1 2 1
VFB 14 0 0
FFB 9 7 VFB 1
CGD 13 14 467P
R1 13 0 1
D1 12 13 DLIM
DDG 15 14 DCGD
R2 12 15 1
D2 15 0 DLIM
DSD 9 8 DSUB
LS 8 3 7.5N
LD 1 9 4N
.MODEL DMOS PMOS (LEVEL=3 THETA=90M VMAX=183K ETA=6.5M VTO=-.2 KP=1.109)
.MODEL DCGD D (CJO=467P VJ=.6 M=.68)
.MODEL DSUB D (IS=29N N=1.5 RS=61.4M BV=160 CJO=900P VJ=.8 M=.42 TT=252N)
.ENDS
Pushing around equations today (no solder fumes) to better understand WHY the distortion cancellation circuit works. All of my previous analysis was of the 1st order small signal behavior which does not include any non-linear harmonic behavior. I do not know if my attempt at 2nd order behavior will succeed in discovering anything useful or not.
