UCD 25 watts to 1200 watts using 2 mosfets
Hi
thanks sir manoj for your best quality amp
Hello Hadi,
This Amp is nice and good, is it Aud600 by Manoj Sir??
Before going into this, I would like to make a budget, How much it costs you?
Pravin
Hi dear friend
this amp is best class D amp in diy steel
yes. this is AUD600
in iran we dont have good quality of part and every things we have is MADE IN CHINA
the price is about 15$ for me
what part did smoke ?is your connection correct? input ground to main ground?
its weird
in this picture
bias gnd connected to -vss
about +vdd: can i connect the input pin lm7812 to +vdd and connect the out put pin lm7812 to + bias ?
what about gnd ? i mean can i connect the input lm7812 to gnd and out put pin lm7812 to +biass ?
thanks friends
sprint layout
Hardi a working one
In part this file SPRINT LAYOUT, ​​that only found in PDF format.
Just came across this other Sprint Layout PCB, upload image I did find.
Hi Andrewlebon ,
Thanks for guides..
yes , i should try it ! but can you tell me about output inductor ? what is the part number , manufacture and where the core originally from ? what is the value if you measured it with lcr meter ?
did you use FDA69N25 ?
IRSound
DETEX
in this picture
thanks friends
Well then the PCB of this other part is that if you do not mind. that looks great (DETEX), if it were in sprint layout, or other software would be great, thank you very much in advance to all
Also if they could climb the source information and the delay speakers(off delay)
