Hi
this amp is sir manoj amp ver 1.0
nobody have schematic for this amp
short question
what amp do you have build ?
can you send me schematic
hi hadi regarding your question : i etched manojs amp but i did not make it because of complex issues i wanted a simple powerful amp.
i made irs 900d it is simple and very silent i think because it is non ucd that is why it is noiseless . but i plan to use it with manoj power supply board because of the oc protection in manoj power supply board. will post pictures soon
i try turn on your amp without power section
i use one lm7812 for bias but it dose not worked. why?
Hi Hadi,
you should connect -75v(or your supply voltage what you given) supply to PIN 13 of IR2110.
and your car cd player you connected from 12V BAT or SMPS(12V)???
MANOJ
SMPS
Hadi:
You can check the bellow design for SMPS.
http://www.diyaudio.com/forums/power-supplies/187973-1000w-smps-based-ir2110.html
Raj
Hi Hadi,
MANOJ
Hadi:
Raj
thanks to sir manoj
i use + - 30 VDC for your amp
i dont know what you mean
i used 12v DC and conect the + line to + leg of bias and connect - line to -leg off bias.
i donot connect any thing to center leg of bias
what is my wrrong ?
my car cd player connect to 12V BAT
my car smps is not issolated
thanks
Hi sir manojHi Hadi,
MANOJ
what is my wrrong ?
thanks
design
this design are:
NANOTECHNOLOGY:
Foros de Electrónica - Comunidad Internacional de Electrónicos
Primeira Página - Primeira Página
This forum is not what its name is.
hi all the correct artwork of irs900d
this design are:
NANOTECHNOLOGY:
what is my wrrong ?
Hi Hadi,
For BIAS connection +12V line connected to (+) sign and -12V/GND line connected to (-) sign and (-)sign should be connected to -30V supply(without this amp will not work). no connection for center leg.
do not use same 12v for bias and CAR CD Player, it will damage your amp/cd player. use separate supply.
MANOJ
thanks to sir manoj
input gnd and output gnd is same in car converter then amp gnd and cd player gnd and bias gnd is same
what can i do ?
my car smps was not isolatedHi Hadi,
MANOJ
what can i do ?
what can i do ?
Hi Hadi,
Use 12v7AH BAT(old UPS like 300VA/500VA/600VA using this ) for 12v bias(testing only).OR use separate winding for bias supply
can you show me the schematics / pictures.
MANOJ
this correctedTo chago25,please check
this right now
Uploaded with ImageShack.us
Nano
hi,
greetings,
are you like to clone any branded amplifier smps for high power output,
if you like try QSC power-lite3 amp smps
hi andrew,Hello
greetings 3 pair IRS3000 getting packed with smps in crown cabinet
need higher power smps
warm regards
andrew lebon
greetings,
Hi
thanks sir manoj for your best quality amp
Hello
warm regards
andrew lebon
what voltage did you use with irfp260n ?
Hello
warm regards
andrew lebon
What sort of joke is this Andy.
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
