UCD 25 watts to 1200 watts using 2 mosfets
Hi Hadi,
AUD600-Rev1.1 there is nothing see any error on PCB.cross checked every track,only i changed 2x 47k 0.25W replaced to 1x 100K 1W and 1k 1% changed to 1K trim pot and added temp switch provisions
For this trim pot do not set to zero Ohms (shorted) minimum value is @200 Ohm.And first setup is, trim pot set to 1K value. other wise remove trim pot and fix a 1k 1% resistor.
I think you are done a mistake something has happened may be component value change or track shorted etc... re-check again
MANOJ
Hi
you change 10uf 100v cap with 1uf 100v too and some chage too near ir ic
PLZ wait for stewin amp
if he have like me error then must chek again
i dont use trimer
i use 1k 1% and 1k 1w
i must send to you my picture
i use 80 turn around T106-2 and conect the filter to board
i dont here like this before and every thing is good and cold.
not heat any things
the sound is so cleare and very good
i must say very very very thanks sir manoj
i like to have your new vertion
can you please send it to my email ?
thanks dear friend
HI HADI,
YES I AGREE THAT, BUT NOTHING WILL HAPPEN WHEN YOU CHANGE THE VALUE 10uF/100V TO 1uF/100V THIS IS VB SUPPLY FILTER OF IR2110 FOR USING HIGH SUPPLY ie.+75V OR MORE YOU NEED TO REDUCE THE VALUE THAT IS WHY I REDUCED TO 1uF/100V.
NOW YOU CAN INCREASE THE FREQ. TO 300KHZ AND TEST IT FOR THIS FILTER YOU REDUCE TO 47uH.
REGARDS
MANOJ
