Hi hadi,
check +12v for realy supply. resistor 2k/5w for +75v supply(34mA current) . you should change with your need.
+35v you need 1k/5w resistor (34mA current).
regards
manoj
regards
manoj
i connect input signal
shild conect to GND
+ signal connect to + input
nothing conrct to - input and it is not connect to GND
right ?
Hi Hadi,
connect - input to GND
signal + input and GND
regards
MANOJ
Hi Hadi,
use this site for calculating resistor for your need(supply voltage ie. +35V, for full volume it comes down to near +30v so both you calculate and set the average value)
Ohm's Law Calculators
MANOJ
MANOJ
thanks to sir manoj
the relay have about10 volt
i use 1k 3w beforHi hadi,
regards
manoj
thanks to sir manoj
this speaker dont burning easey
it was 16 ohmHi Hadi,
speaker should be 4 or 8 ohms for first setup.
MANOJ
thanks to sir manoj
thanks dear friendHi Hadi,
MANOJ
thanks to sir manoj
what is your perspective?
in bias between - and + leg we have 11.75 VDC
are you speak about bias or LM7806 ?
HI sir manoj🙂Hi Hadi,
Check 6v rail also(+6&-6)
MANOJ
Hi Hadi,
OK. check the voltage given for TLO71 & 72 IC (GND and -6V, GND and +6V)
it will took max 7.5mA cuurent (35V supply 3.3k/3w you will get 10mA)
if it is below 5V you need to change the resistor value to 1k/3w.
My new AUD600 rev.1.3 i used TL783 ic for +6v and relay +12v supply.
regards
MANOJ
How can creat 25uH selfe arund the ETD29 core for reduse EMI sir manoj amp ?
Hi Hadi,
25uH is used to reduce EMI in output wave. Initially you do the AMP work perfectly. you don't worried about output filter noise . you need to shield for reduce this.
Manoj
Hi Hadi,
0.6mm 24 Turns for 25uH. both winding start point i marked (big dot).first you wound 70uH after complete then 25uH
MANOJ
MANOJ
Hi sir manoj
ver 1.1 was not work
i thing some thing was error in that board
i creat ver 1.0
it was work good for 2 hour
i have 0.8mm wire
i creat 25 uH with 22 turn of 0.8mm wire
i creat 25uH and after that creat 70 uH with 40turn of 0.8mm wire
when i conect the 25uH to the amp board then ETD29 go to truble hot just in several secound and mosfet too and 4.7 ohm resistor near the relay burn
without 25uH amp work good even without mosfets heatsing
what about in your new vertion ?
i creat ver 1.0
i have 0.8mm wire
can i use T106-2 for this amp sir manoj ?
say to me how can i creat filter self with this core ?
Hi Hadi,
Thanks for pointing errors(rev. 1.1) I will re-check the PCB. and get back to you
Yes you can use 106-2. use only single winding.
T106-2 you need 80Turns for @65uH
I think your winding polarity reversed.
MANOJ
yes
i thing too
i creat that yesterday
that time you dont have pm for me
thanks dear friend
do you creat ver 1.3 ?
i dont have a good and power full smps
i realy need one for best testing your amp sir.
thanks for every thing you do.
i thing too
thanks dear friend
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
