my micro project
progres in this project is 80%
have nice time
http://uploadtak.com/images/i3317_micro_project.rar
have nice time
i think sir manoj amp is best amp until today in all diy class D amps
i mean AUd600 is the best until today
thanks again sir manoj
I also think so. Thanks to Manoj for sharing.
Hadi very strange irs 900 its easy work may by a cut in the out the capacitor or the inductor very strange y use various ,vmos and inductors work chek the diodes tensions and the 12v auxiliar the negative its -vrail comon and the external wire gnd to te imput
ruben.berron1 skype
ruben.berron1 skype
IRS900D dont work again and generate smoke when conecct input signal to car player
what part did smoke ?is your connection correct? input ground to main ground?
its weird
Hiwhat part did smoke ?is your connection correct? input ground to main ground?
its weird
10 ohm resistor and one 1n5819 burned
nearest the ir2110
above ir ic
Hi robenHadi very strange irs 900 its easy work may by a cut in the out the capacitor or the inductor very strange y use various ,vmos and inductors work chek the diodes tensions and the 12v auxiliar the negative its -vrail comon and the external wire gnd to te imput
ruben.berron1 skype
how can i know about cut in the out capasitor ?
i was used T106-2 and wire 0.8 mm and 43turn
i was used original lm317 board for 12 volts
i was used another power source for 12 volt board and my negative amp power not conected to lm317 negative power and not common
i dont conect my input gnd to out put or power gnd
please show to me on a picture
thanks
Hi
thanks sir manoj for your best quality amp
Hello Hadi,
This Amp is nice and good, is it Aud600 by Manoj Sir??
Before going into this, I would like to make a budget, How much it costs you?
Pravin
Hi
Hello Hadi,
Pravin
Hi
Its send me the files in this amp?
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
HI@Hadighorbani
you used 1n5819 in place of MUR120??? if so replace 1n5819 to mur120,,, irs900 freq is 250khz output filter should be around 47uh
i have IRFP250N
i can use this amps in 250KHZ only
about filter: i was used 25uH
i try with 47uH
thanks
thanks againPls see file
and input ground should be connected to main ground
i was try VER2.0 of IRS900D but it not worked
when i connected in put ground to power ground the amp have above 10V DC in output
without that i had 5V DC in output
in ver 1 of this amp i had 5V dc in output too
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
