UCD 25 watts to 1200 watts using 2 mosfets
higher power smps
small smps under construction😉 trafos 2 heavy😎
thanks to exflaco
Hadi IRS 900 its easy and work cheap material use a correct pcb and the out filter coul use
ei33 old pc with gap 1mm and the sound its very good start 45v and irf640 good choice
Hi🙂
mey be my pcb was wrong
but i dont have another pcb file
do you have it ?
i have T106-2 and dont need EI33
i was used IRF250N and 1K ohm OSC resistor
in 45 volt my IRS900 generate smoke in filter capasitor
how much power with IRF640N can generat this amp ?
Hi Manoj: I think my wiring is as per your diagram/instruction. Attacing a picture for better understanding, is it okay.
Raj
Hi Manoj:
You may see from the attached picture that the volume wiring is okay as per diagram. Still no sign of luck, finally given audio input to pin 1 (by passed tl072) now the sound good, no HF noise. I changed couple of IC's, same result.
I would like to increase rail voltage, please let me know which part need to be changed and what is the threshold voltage limit of this design?
Raj
For the diyers friends.
These 3 class d amps IRS (900-1500-3000) the same topologie and schematics
the 1500-3000 ad OCP (overcurrent protecttion) personally prefer irs1500
with biger vmos like 90n20 (90a200v) or better irfp4768(93a250v)and work fine
2ohms load.
Depend the load and the +-vcc inductor coul use 22-50uh no problem.
look the little secrets down the pcb 😉
A smd little 100nf decoupling and use pcb 3000 only one vmos per side.
Other mistake its the 12v auxiliary better 1,5-2a (use two paralel 7812 or lm317)
one 7812 work in irs900 only
