Hi dear friendHi
thanks sir manoj for your best quality amp
Hello Hadi,
This Amp is nice and good, is it Aud600 by Manoj Sir??
Before going into this, I would like to make a budget, How much it costs you?
Pravin
this amp is best class D amp in diy steel
yes. this is AUD600
in iran we dont have good quality of part and every things we have is MADE IN CHINA
the price is about 15$ for me
hi
i sent 2 pdf file in gmail for you
have nice time
what part did smoke ?is your connection correct? input ground to main ground?
its weird
in this picture
bias gnd connected to -vss
about +vdd: can i connect the input pin lm7812 to +vdd and connect the out put pin lm7812 to + bias ?
what about gnd ? i mean can i connect the input lm7812 to gnd and out put pin lm7812 to +biass ?
thanks friends
Hello Hadi
I wonder why you get a lot of problem on this,,have you replace the defective ,,getting dc on output maybe you got problem or short on layout,commonly on tl071 tracks check voltage on 5.6v zener if they are balance,,bias is negative (Vss) reference
sprint layout
In part this file SPRINT LAYOUT, that only found in PDF format.
Just came across this other Sprint Layout PCB, upload image I did find.
Hardi a working one
Hi
this pcb had error
look at the blue mark
104 cap not connected to any vere
Connect it to the ground plane. (102 cap left to it).
no need to redesign
thanks
Hi Hadi,
Over current preset point connected to 104 this line should be connect to zener ZD5v6
MANOJ
MANOJ
Hi Hadi,
MANOJ
thanks sir manoj
Hi IRSound
greetings TRY detex audio 2 pair amp with ocp post# 3219 FIRST PICTURE
i used orignal cores which detex audio used 2 cores parallel 2 srx speakers on 2 ohm load
NO ISSUES with amp heatwise and sound
warm regards
andrew lebon
warm regards
andrew lebon
Hi IRSound
warm regards
andrew lebon
Hi andrewlebon.
You can send me the layout you are using the plates?
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
Hi Andrewlebon ,
Thanks for guides..
yes , i should try it ! but can you tell me about output inductor ? what is the part number , manufacture and where the core originally from ? what is the value if you measured it with lcr meter ?
did you use FDA69N25 ?
IRSound
Thanks for guides..
IRSound
Still to test on 120 volts dc +/- sameerx1
warm regards
andrew lebon😉
Hi andrewlebon.
You can send me the files of smps and amplifier?
Thank you
DETEX
Well then the PCB of this other part is that if you do not mind. that looks great (DETEX), if it were in sprint layout, or other software would be great, thank you very much in advance to all
Also if they could climb the source information and the delay speakers(off delay)
in this picture
thanks friends
D
Deleted member 148505
@jlester87
gates diodes 1N5817/5819
Hi irvinejay,
Why is 1n4148 not suitable? It has a trr of 4ns.
Should the gate diode be a schottky type?
Thanks 🙂
Trr 4ns but at 400mA current will heat. 1N5817/5819 has 1A will do just fine or MUR120 the best, low Trr and 1A (this is what i use in my comercial amps)
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
