• Locked
GB: APEX A-Class PSU
This is GB for APEX A-CLASS PSU that is designed to supply in parallel (SHUNT topology type) preamplifier and any audio circuit that needs low noise and low TIM.
Output voltage can be adjusted from +/-12VDC to +/-24VDC and max output current is set using R7 and R12 resistor. For heatsink you can use SK574-50-SA or you can use aluminium bracked that is 50mm in length, 8mm thick to cool down output shunt and ccs transistors.
This is improved design from APEX A-CLASS PSU that have improved low noise voltage reference (100uF capacitor at -IN), upgraded JFET-s that is very easy to but from mouser, and using low noise ZTX bjt for lowest noise of PSU. Input filter is RCLC and is used to suppress any noise from low frequency to high frequency. If you don't want to use L in this filter you can install two 4.7R 0.6W resistors.
PSRR is -150dB, output voltage noise is about 10-20nV/sqrt(Hz) and uses easly available TH parts! (For HLMP-6000 if you could not find one in mouser you can use standard 3mm RED LED and solder it under PCB as is in footprint).
Price for 1pcb is €6,00 plus shipping (shipping cost is from €15,00-€20,00 as these days shipping cost is high). Payment Paypal F&F only.
APEX A-CLASS PSU LIST:
nickname (number of pcb) - COUNTRY
Here is pictures of PCB that is professionally routed using all audio technique that is very important in audio psu design.
And here is how it looks when assembled in 3D (Here for GB is only PCB).
And a schematic:
Best full-range driver you've ever listened to in an OB
Hey Guys!
I'm planning some new open baffle full-range concepts and just want to know which are the best drivers you've ever listened to.
I have a weak spot for vintage paper cones and would appreciate recommendations in this field but modern drivers are also fine.
Right now I listen to a 60s 12" Fane driver which I like a lot.. just asking myself if there are better (paper) ones.
(I know that the word "better" could be ambiguous. Of course there are modern full-range drivers that measure much better but I like the naturalness of paper cones)
Thanks for your answers!
Tim
Hypex UCD400MP SMPS failure (B&W PVD1)
I picked up this dead subwoofer at the weekend mainly to harvest the drivers for a DIY speaker project. (They're pretty mighty things)!
I hadn't realised the PV1D has a Hypex amplifier and I thought it would be good to try to make the thing work. Looking online seems that the OEM Hypex with the onboard SMPS are pretty problematic.
Once I'd got it off the heatsinks board I could see an area that looks like has had some intervention before. (C3 and C6). I measure 240v into these.
Also T6 looks suspect, or atleast it's soldering.
I haven't probed much beyond that area, other than various electrolytic caps, and they aren't charging. So the mains AC isn't getting far into the circuit, which I hope narrows a few things down.
Obviously we can't get a scheme for these but is there anyone with SMPS knowledge that might hazard a guess where this could have failed and possible replacement parts. Or where to do some meaningful probing;I'm struggling to see the identity of T6.
UcD HPA: first scratch design
Hey all,
I just cobbled together a sim for a UcD headphone amp. This is my first amp design from scratch.
This is a first step towards a 100W amp. I figured by ruling out most of the power stage, it'll be easier to get something working. My emphasis is simple and easy to build.
Briefly, it's built around the LT6274. One unit for the comparator and 3 as unity gain buffers acting as the power stage. Comparator output is clamped by zeners to limit output swing and not over drive the power stage.. The hysteresis is added in hopes of avoiding driving the comparator into deep saturation. There's no feadback compensation network, just a divider to set gain, and the output filter is heavily bypassed. In a rev. 2, I might revisit a proper comparator and the simplest way to manage differing supply and output voltages between that and the power stage.
I set out measuring propagation delay (285ns) doing all the math for lead/lag networks but in the end I couldn't get it to oscillate much above 150kHz, which is what lead me to rip out all the compensation and bypass the output filter. It switches around 250kHz but still has rise/fall times 200ns-300ns. It provides 5dB gain, clipping just past +/-0.8V input / +/-2V output, delivering ~50mW RMS into 18 ohms.
All in, 4 op amps, 12 passives on split 9V supplies (easy with batteries).
I'm excited to have gotten it working, but not happy about not understanding the lead/lag compensation.
All input welcome.
  • ucd_cmp_hp.asc
    ucd_cmp_hp.asc
BA-3 As Preamp
Is it possible to use the BA-3 front-end as a pre-amp? I think I read it can, but can't find the reference.
Has anyone used it as pre-amp and do you have any impressions on the sound? I'm currently using a BOZ-J and would like a bit more drive for a bi-amp setup running the L'amp CCS and a F5.
Thanks,
Vince
Note:
If using Fairchild mosfets, use 1K variable resistors for P1 and P2.
Volume control- 20K to 50K
Raspberry PI based 8-channel analog to HDMI converter
My first thread, please be gentle!
I own an Involve Audio Surround Master v3 that does SQ/QS decoding, as well as a wonderful job on some stereo content of upconverting to 4.0 or 5.1. The only trouble is that the SMv3 only has analog output, and my AVR only has digital inputs (HDMI, S/PDIF).
Somebody mentioned on the QQ forums in early March that HiFiBerry had started selling an 8-channel A to D hat (“ADC8X”) that might do the trick. So I took the plunge, bought an RPI5 kit, plus the DAC8X and ADC8X hats from HiFiBerry. The ADC8X requires the DAC8X, but as with their other hats the price is not bad.
Success! I loaded up the headless version of Raspbian, added the ADC8X overlay to the configuration file, and found both the ADC8X audio input and HDMI-1 audio output ALSA cards with “arecord -l” and “aplay -l” respectively. After connecting the pieces together (SMv3 to ADC8X, RPI5 to my AVR via HDMI-1) I tried the simplest approach:
arecord -Dhw:sndrpihifiberry,0 -c 8 -r 192000 -f S24_LE | aplay -Dhdmi:vc4hdmi
This (192k/24) uses up about 7% of the cpu (according to “top”), with 48k/16 using about 2%. I could have used 6-channel mode (“-c 6”) but with 8-channels I can wire the two rear channels Lr and Rr to the 7th and 8th inputs, and my AVR will then play those channels on my rear speakers instead of Ls and Rs (as the quadrophonic gods intended!). I haven’t had trouble with underruns or overruns, but I may just be lucky with well-matched ADC and HDMI clocks.
ALSA also provides a simpler command, “alsaloop”, for this purpose. I’ll probably modify the code to add some logic to prevent underruns and overruns. I decided to stick with the lowest level in Linux (ALSA) rather than go up the audio stack into PulseAudio or PipeWire (the KISS principle).
I also have an old Korg D888 8-channel analog recorder that is nicely replaced by just recording with Audacity from the ADC8X on the RPI5.
If anyone is looking for an inexpensive 8-channel ADC, or for an analog to HDMI converter, this seems to fit the bill. The DAC8X makes a nice 8-channel sound card as well.
Accuphase P-7100 Amplifier Clone
Hi. I'm starting this new thread about my Accuphase P-7100 amplifier clone. Most of the owrk is already done, and I just completed both amplifier module last week.
I tested and preset both amp modules today and everything is looking good. I pre-set the bias at 5mV on the final instead of the specs 20mv (20mv / 2x 0.47R = 21ma / Transistors
The front end and Meter/Softstart/Protection PCB are tested and working fine. The main +/-75V Power supply is already assembled on the chassis. It is made of a massive recycled Rotel potted power transformer, two large 51,000uF/100V Kemet power capacitor, as the original just one 35MB100A, 35A, 1kV rectifier bridge and a copper GND bus bar as the original.
I'm trying to emulate as far as possible the original, since I know the Accuphase sound and love it. I went throught the service manual and decoded the detailled BOM that list all the type of resistors and caps used where (film, carbon, MOX, carbon film, and as far as possible the same caps series and type).
The PCB, original clone of very good quality (2mm, gold plated) are from ebay. All the pcb were replica of the original and match the service manual schematic, except the Meter/Softstart/Protection PCB. The original processor amp control was replace with discrete circuit, and the usual uPC1237 protection IC, but there was no info on it, and no part values. I had to find the circuit and test my mods by myself. The input stage pcb is the same circuit but the parts ID are different from the original schematic, and some small differences are there as well. I documented the changes and wire the board accordingly. Chassis is a clone from Aliexpress.
The original amp section used 2SC5358/2SA1986 (230/15A), me I'm using the 2SC5200/2SA1943 (same 230/15A) that I bought years ago, and match them myself.
I used thermal spread aluminum bars to mount the power amp transistors, and to add rigidity to the clone heatsink made of two section. The output amp module is now solid as a brick. The amp pcb also inclded nice brass bus bar and input transistor pairs rubber caps, as the original.
Here some pictures of the PCB. There are some extra PCB such as the rectifier PCB and Softstart and Ground Lift PCB.
Linesource measurements and xoverbuilding
I have build a 2,5 way linesource with 8 Peerlees fls-0512 5,9 inch midwoofers per side, and using a Audax "gold" TW025A28 in a WG as tweeter.
Diffucult to measure with a speaker thats 152 cm in hight, and have drivers from bottom to the top.
The linesource will also be mounted on the wall, with tweeter at 3/4 up on the tv.
Measurements done with speaker 1 m obove the floor, faceing into biggest reflexfree area in my house.
measurements on 2 lower woofers together from 1 m (connected 8+8 ohm)
Done measurements on 2 higher woofers together from 1 m(connected 8+8 ohm)
Done measurements on 2 lower midranges together from 1 m(connected 8+8 ohm)
and done measurements on 2 midranges over and under the tweeter "MTM" together from 1 m(connected 8+8 ohm)
and tweeter measurements from 1 m
The drivers are then paralellconnected in pairs to 16 ohm, and then in serie outside at the xover so 8 ohms load.
Problem is that measuremenrs still become 16 ohms, and when i put it in VitauXcad nothing becomes "right"
So making simulations doesen´t help mutch, and don´t look as my test measurment on hole speaker.
And room is 3,8 meter frontwall to backwall, speaker steals 24 cm and in total with my head and sofa tha maximal listeningsdistance is 3,2 meter.
Speaker play real good today crossed at 1,5K and ca 3K (with lots of xover work), but would like to be able to do correct simulations in VitauXcad.
One more problem is my health, so can´t carry around the ca 35 kg high "thing"
Any suggestions on anything of my problems?
  • peerless_fsl_0512r01_08.pdf
  • TW025A28-8.pdf
    TW025A28-8.pdf
Help with 2 Subs not summing at certain frequency
Hi all,
I'm wondering if I can get some advice.
I have 2 subs. DIY BMS18" in sealed boxes.
places in front corners of room on the outside of the left and right speakers. (typical setup)
I have used various room correction software e.g. Dirac version 1, YPAO, Manual EQ etc
my issue is that, even though my subs are time aligned and level matched to each other and I verify with REW. when I measure the FR of one sub, then the other sub, and then combined, most of the frequencies sum greater when combined like they should.
but there is a specific frequency that doesn't. 40 to 50hz huge null.. this doesn't happen in the individual sub responses. once combined the magnitude at this frequency is lower than that of a single sub. As if they aren't aligned.. but they are. for most frequencies. Just not at 40 to 50Hz.
if I reverse the phase on one sub they sum beautifully at 40 to 50hz, only to ruin the rest of the frequencies as this is obviously incorrect.
How do I fix this? I have read that all pass filters work to change the phase but keep the magnitude the same. But others tell me its not a phase issue but a room issue?. have I not just confirmed that the phase is the issue? I just need to know why this is happening and the correct approach to fixing it.
thanks.
Isobaric speaker design questions
I was watching some videos from Audiophile Junkie on YT where he's covering the Montreal Show.
I saw this new speaker that looks like a G Clef that has the woofer / mid as a face to face isobaric design.
In their design It looks like each speaker is in a sealed 1/2 shell and there's a gap of about 2 or 3 inches. (Estimate from looking at the video and pictures)
see:
https://www.stereohifi.nl/loudspeak...aker-t/stereowise-l-speaker-treble-clef-audio
I'm trying to understand the benefits of a face to face isobaric design.
In some other speakers, it looks like you have both speakers facing each other attached to the same baffle so there is no gap.
So here's the questions...
1) Benefits of isobaric in general?
2) Benefits of face to face isobaric.
2a) One side sealed, other side open? (A different speaker design...)
2b) Both sides sealed, but there's a gap between the two drivers.
3) The gap between the two speakers... advantages/disadvantages ?
3a) Is there any math concerning the width of the gap?
4) What other considerations?
I mean its an interesting design... I'm curious about the acoustics. Imagine taking a 6.5" purifi woofer (extended range.)
The data sheet says sealed bottom frequency is ~77Hz, Ported drops to ~44Hz. What could you expect from a face to face isobaric ?
Is there any good material on isobaric speaker design?
I know that Mon Acoustic has an isobaric speaker (face to rear)
I realize that doing this sort of design gets expensive really quickly and its more of a thought research project while I'm out walking my Husky.
Thx
For Sale Pair of Beyma 12xa30nd (Austria)
Selling two new, unused Beyma 12xa30nd coaxial drivers for 600 Euro + shipping fees. The drivers were purchased for a project that was never realized. Since then, they have been stored in a cabinet. The speakers have always been stored upright to avoid cone sagging. I live in Vienna. Shipping is, of course, possible, and if you're interested, I can check the shipping costs.
Threshold S150 II with transformer hum
I have been lucky enough to score said amp for a really good price, but sold as defective because the transformer humms - you can hear it from at least 2m (7 feet). The seller, knowleadgeabli in tube amps said a new transformer is needed (also mentionet that all s150 he encountered hummed).
My first question would be regarding the humm - is there something i can do to improve the situation? Also might it have something to do with the voltage in the EU (currently 230 as opposed to 220 in the past).
Another question would be regardin the mod - moving the transformer further away from the left sided pcbs.
As i have more projects started, this will have to wait a bit, until i fill a mouser cart at least, for the ageing parts (caps, diodes and trimmers).
The sad (or is it funny?) part is i have no means of hooking it up at home, as i have no preamp or amp with jumpers to use as a pre.
Pictures will have to wait.
Krell KSA 100mkII Clone
KSA-100 used 2 of those tunnels.
Speaking of KSA-100...... is anyone out there interested in persuing this amp as a project? I would definately want it to be the MK-2 version. All semi's are still available excepting the VN and VP series mosfets. These however could be easily subbed by modern IR units, perhaps using the IRF9610 and 610 devices.
This would require a new board design (Al Perhaps)? I would be willing to front the $$ to make up say 100 of them so they are available.
This seems like the next logical step in creating our own Krell Klones... then perhaps on to the KSA-80 or 160.
Let me know your ideas and opinions on this(constructive only please).
Thanks!
Mark
Silly Nusery Rhymes Twists From the Past
I still remember some silly nursery rhyme variations from my younger days.
Here are a few that come to mind. Please add more if you can remember them:
Jack and Jill went up the hill
Each with a buck and a quarter
Jill came down with two and half
They didn't go up for water.
Mary had a little lamb
And the doctor almost fainted.
Jack be nimble
Jack be quick
Jack jumped over the candle stick
And burnt his ***.
Heathkit Transistor Substitution
I started working on a Heathkit AP-1800 Preamplifier that lost the left channel. The included documentation of this preamp is very thorough, but many of the transistors have a proprietary Heathkit part number that I can't find information or datasheets on.
There many of these two BJT's used:
SM07275 (NPN) Heathkit Pt#417-283
SM62186 (PNP) Heathkit Pt#417-284
I pulled several and tested with a Peak DCA75 analyzer.
NPN's: Hfe 220-320, Vbe 0.770V, Vce 0.040V
PNP's: Hfe 230-285, Vbe -0.765V, Vce -0.070
BC547B/557B could be a possibility, but with so little info known about the originals, I'm not confident enough about this choice.
The PNP's have the dreaded black legs up to the transistor base with webbing connecting the three legs.
Any information would about substitute BJT's be greatly appreciated.
Howdy Yall!
I'm into home audio and all things nerdy and tech. I run a Classe preamp and amp, Magnepan front and surrounds, and 2x SVS PC-4000 subs.
I'm into cool gear and excited to see what people have got!
I'd like to tinker with some weird bluetooth modules and other components and have previously built a neat IR blaster to interface with my Classe CAV-75 since it doesn't have a remote 12v signal and can only take a pulsed turn on signal.
Amplifier Preamp Gain proportions how much db with tube pre and solidstate pre
I have been thinking about the gain structure of pre and power for a home theater amp or stereo amp with pre section being solidstate and tube
consider a tube pre with gain of 20 and power amplifier with gain of 20 log 33 or 30.37 db so how much this ratio needs to be where in tube pre I cannot change the gain but can change the gain of the power amp. I do understand the total gain ratio but what is the usual case i feel even amplifier with 26db is quite high if we have a tube pre with 20 gain
Another scenario with solid state pre with 6db gain and power amp at 30db gain so what is to be taken into consideration
For HT application
For Stereo application
Now do commercial HT amps comes with pre gain stage inbult? as the AV processor or receivers dont have a proper standard some give 1Vrms out and some are capable 3.5Vrms out
Can anyone please provide few inputs on this
That song stuck in your head…
It happens to me all the time.
Sometimes I wake up in the morning and it’s just playing for one reason or another…in my head.
There could be a million reasons I suppose. I could have heard it anywhere.
Sometimes I know where I heard it…sometimes I can’t figure it out for the life of me.
Sometimes it’s a song I love…other times not.
This morning it was “I’m gonna sit right down and write myself a letter”.
I quickly realized a version of it was playing in the background from the Eiji Kitamura Hit Kit Party while I was tinkering away at my workbench on my Iron Pumpkin project yesterday afternoon.
Funny that it was instrumental and so kind of just snuck in there without me paying much attention.
It actually made me want to hear the song and so I went searching for one of my favorite renditions which is by Madeleine Peyroux in her Dreamland album.
What’s bouncing around your head today?
Reactions: vinylkid58
Quicksilver Mono Amp noise on startup
Hi everyone,
I made a trade for a pair of preowned Quicksilver Mono amps on the weekend. One amp makes an odd noise a few seconds after it is turned on. It only lasts a second then goes away, so I'm not sure if it's something I should be concerned about. It's a mechanical "whumm" sound and isn't coming from speakers. Kind of sounds like a lightsaber from Star Wars, lol. I've attached a video so you can hear it. The noise happens 12 seconds in.
Any idea what might cause this noise? I think it's one of the transformers, but I'm not sure. Amp seems fine otherwise, but I'm worried it could lead to bigger problems down the road if not dealt with. I also emailed Quicksilver, but thought I'd ask here as well in case I don't hear back from them. The seller said I could return amps if I'm not happy, so I'd like to make a decision soon.
Thanks very much.
Login to view embedded media
Ikea spherical speakers, first build done.
I thought I should post pictures of my first build.
Project was inspired by Cabasse and the curves employed in B&W 800 series, although on a much smaller budget. Had the idea to use bowls, Ikea had the wooden Blanda which seemed perfect. After scouring the net, found several others using these, although none using the 28cm versions. Design is an active 2 way design.
First completed photo (no tweeter), initially using Zero class T amps.
Current incarnation, using rotel 6 channel amp, channel for tweeter and mid, bridged for 15" sub, experimenting with solid oak sleeper stands and granite plinths.
Tweeters rather delicate positioning on top, seems to be fine without an enclosure, however I am experimenting with casting tapering tubes using champagne flutes.
The Sound: To my humble ears they sound rather good, haven't obtained a microphone to do testing. Definitely better than my Mission V63, which have an rrp of over £500. The 'no baffle' 15" add good low level sound reinforcement, as they don't go terrifically low or have very much bass
The drivers are Peerless M16GH (link below to drivers and excellent seller from eBay) Peerless & CO M16GH/4 Mid Woofers X 2 New/OldStock. on eBay (end time 25-Jan-10 10:15:24 GMT)
The tweeters are also Peerless metal domes, model unknown.
Currently crossed at 15" Sub 20-150Hz, Mid 50Hz-3Khz, tweeter 3Khz-20Khz
The sphere's come in at around 8L, (9.1L before cuts and driver displacement) One has eggfoam stuffing the other is naked will aquire some different materials for testing when I have a good mic.
They need another sand down, better integration with the stands and experiments with internal wadding, and the new tweeter housing, when time allows.
Reactions: AlmaAtaKZ
Converting soft start to work with maintained contact switch
Hi, I accidentally bought a maintained contact switch and a soft start that is designed for a momentary contact switch. Is there any way to convert the soft start so that it works with a normal switch
Here’s a link to the soft start that I am using
https://www.audiophonics.fr/fr/soft...et-protection-pour-amplificateur-p-10225.html
On the soft start there is a Texas Instruments NE555P which acts as the timer delay for the soft start but I’m assume it also gets the input from the switch.
When I read the data sheet for the ne555p it said you could use it in monostable or astable configurations. Is this what I need to look at to figure it out or can I just solder the switch into two points on the soft start to fix the issue?
harman/kardon AVR 255/230 no audio
Hello, I recently bought an harman/kardon AVR 255/230 second hand. I set it up, everything worked fine until I was setting up my Fire TV Cube to be able to control it. It tried to send some command where it switched sources (not exactly sure what it was trying to do, maybe it also had something to do with muting the source?) and since then there is no audio.
I have tried:
  • using multiple sources (HDMI, digital audio, analong cinch; both back and front panel ones)
  • factory resetting it with holding OK button (Tho there is a reset button in the back near the RS323 port, which I don't know how works)
  • tested speakers - there is no short
Additional information:
  • video out works fine
  • there is no error message on the screen (both built in and hdmi out)
  • while playing the test tone (speaker level setup) there is noise coming through the speaker at max volume
  • noise coming through the phones port while trying to play music at max volume
    • at first after the speakers stopped playing the phones port continued to work, however i disassembled it to look for burnt components / bad soldering points / overall loose things (found none)
  • I tried testing resistors labeled 0.27ohmKx2 5W KW0807 but was getting weird readings - all were 0.0-0.1ohm across them so I figure I was measuring them wrong
  • I tried testing transistors behind them (diode mode on multimeter) got readings: left to middle pin is 0.6v, left to right pin is 0.6v, middle to right pin is 1.2v - this is on the ones I could access (only two of them)
Anyone have experience with something like this? Any advice on what I should try / test? I have no problem disassembling it and sending photos of things / testing individual components.
In advance thank you for any help.
For Sale Lot of 10x high end Oyaide US/JAPAN plugs and more
hi there,
I want to sell a lot of US/Japan power plugs, the lot includes the following:
3x MPS HADES - new, unpacked, but unused, never installed on any cable.
2x Oyaide - removed from oyaide Black Mamba V1 cable and Oyaide power distributor. These seems to be unplated phosphor bronze. Used
5x Oyaide beryllium copper silver and rhodium plated. ---> these are truly special and you cannot buy them on the market. Shells are taken from other original Oyaide plugs (c037 and P004). These plugs (blades to me more precise) are made exclusively for AcroIink in Japan and were removed from US/JAPAN standard high end acrolink power cable.
Contacts: beryllium copper
Coating: polished silver + rhodium
these five plugs (blades) are IMO one of the best money can buy. I compared them to Oyaide P037, P004 . I dount count Furutech as generally speaking I am not NCF fan.
I have no usage for US/JAPAN plugs here in EU, therefore want to sell these.
400 EUR / 440 USD via bank transfer. economy worldwide shipping included. This is my best price already. If youre into DIY'ing power cables - try these five oyaide plugs and you wont be dissapointed.
Apogee Scintilla - Another Project!
It is finally the time to post my Scinnies...
One Ohm model. One speaker OK, while other has bass ribbon panel damaged & removed...a multimeter fell onto the foil as I was completing the "Silicone fix" years ago (still have not gotten over it)...
  • Both tweeters are there and functional, albeit both ribbons appear stretched.
  • I do have a pair of replacement Bass Foils (actually the entire Kit) from Patrick in Germany that I bought many years ago (not cheap at $1300).
  • Covers are painted Matte Black (used to be that ugly Beige)
  • Been sitting in my back room past few years....wife would like them gone.
  • Pics taken years ago attached...
Pick up in West Sub of Chicago, no shipping. I also cannot assist on the repair.
Asking $1500.
Reactions: TheFinisher
question about the needle on the front of the Pass Lab XA60
Hello, I have two Xa60 mono blocks that I love and that I use for my Tannoy Kensington GR with a Mcintosh pre-amp. I bought them used some time ago from a professional. I wonder what the needle on the front is for, in fact when I turn on the device, the needle blocks towards the right, I don't know if this is normal, because I see an intermediate position at noon but the needle never went there. I would like to point out that I don't listen at very high volume. Thanks for help
Monitor Audio One recycling project
Hi there!
Inspired by the Monitor Audio Monitor 3 enclosure recycling project
i am thinking about the recycling of a very old pair of Monitor Audio Monitor One speakers
I have some very different chassis already available for the exchange of the old chassis
I have a mini DSP 2 X 4 HD box and still struggling with the power amps
best thing would be to flip to something like Hypex FA122 but for the first development approach i will probably use the power amp section of an old Yamaha AV receiver
next post with some options about the new chassis
I have the CLIO pocket measurement system and unfortunately a big lack of ability to use Vituix CAD but a dozen of years of experience with Visaton Boxsim
Building Euro21 801A tube preamp
Building Bela's aka euro21 801A preamp https://www.diyaudio.com/community/threads/801a-tube-preamp.395883/
I will use Ale's Moglia aka Bartola Hybrid mu-follower as anode load.
I will need to mod the Vout LT PSU for filaments, I have a couple of Lundahls Filament Current Choke LL1694 that can be configured as serial or parallel also common mode choke and choke input. Could be configured as choke input CMC?
More questions will follow.
TIA
Philips CD104 tweaks
Planning to mod my CD104.
Anyone suggests any mods ? I have replaced the captive leads.
I was thinking of first looking at the capas in the analogue section. My main problem is how you get the analogue board out . I figure you go in from underneath and remove a torx screw holding the board in place. Is there much more dismantling to be done , or is there a special way of removing the card ?
Bipolar regulator PCB with "De-Noiser", a different PCB layout from the known schematic
Recently I came across Mark Johnson's thread "VRDN: bipolar regulator PCB for line level ckts: ±11V to ±20V @ 1.5A with "De-Noiser" "
https://www.diyaudio.com/community/...l-ckts-11v-to-20v-1-5a-with-de-noiser.355883/
and instantly became a fan.
Here is a redraw of his schematic done just for fun. I named it "Butterfly DN". The PCB can be made by hand if you like, it has only two layers.
IT HAS NOT BEEN TESTED YET!
I have ordered some PCBs and will be testing soon.
I will be updating this thread with pictures.
For how to set it up, please visit the first post of the original thread:
BOM, Part numbering on the PCB and component sizes are exactly the same.
Heat Sink thermal resistance: 6.2C/W - 11.4C/W, depending on the length of the heatsink used (ref. attached pdf)
Board Size: 103,5mm x 91,5mm
Added:
  • Optional half rectification diodes D98 & D99 have their own place on the PCB. Remember, they are only used for half rectification, when using a transformer with only ONE secondary. They are marked with a *
  • Added an optional resistor (R23, R24) in parallel to every one of the Variable resistors (VR1, VR2), in case you want to replace the Variable resistors by a fixed one.
  • 2x Outputs, CON1 and CON2. CON1 supports many readily available connectors. CON2 supports Faston terminals OR Europlug
  • Added R100, a way to connect the ground plane to chassis via the top right mounting hole. You can short it or use a resistor 3-10ohm
Have fun!
Alexander
Disclaimer
This thread is made by a fan, it is not affiliated in any way to Mark Johnson's work and the original VRDN thread.
This layout is a DIY project done by me, provided "as is", with no official guarantee it will work.
Another corner array project
In the next few months I expect to start the build of a corner vertical array pair of speakers.
This will be used in a fairly small lounge living room with multiple sources, digital and analogue.
  • Vinyl
  • CD
  • Streaming, media etc
  • TV
  • Computer files
My hopes and expectations are.
  • To put them right in the corners, out the way. I took the pic attached when moving the furniture around just to show where they would go, right in the corners outside where the current speakers are standing at the time of the picture. I should explain that the current speakers are not normally diverging and the polystyrene sheet next to the TV is just old packaging! – the sound bar etc would go. The room is very asymmetric, the left “corner” of the listening area being created by a pillar that holds the structure for upstairs. I don’t know what happens with the structural beam running across, in terms of reflections.
  • To significantly exceed the sound quality available from commercially available loudspeakers.
  • To reduce to a minimum the listening position sensitivity one normally finds with two speaker stereo speakers, which I understand these should help with.
  • To hear some of the magic attributed to vertical arrays of full range speakers.
  • Ultimately to make it fairly simple to operate and control, remotes for source and volume would be nice.
  • I imagine my project would be a decide, design and build and use project, not numerous constant experiments, and so would not follow the depths and details of projects like the two towers, admirable though I am sure they are.
I need to decide what to build, I have taken some ideas from kind, patient and encouraging friends and read about the Roger Russel IDS 25, and I have looked carefully at Murphys Corner array. I have read lots of the threads on the forum and it’s fair to say one can easily become confused!
Consequently I thought to start a thread that others might follow later if they wished.
Some current outstanding questions for starters are;
  • Amplification, I have an existing old Musical Fidelity A100 that might be pressed into service?
  • EQ, I have no experience other than that gathered from operating my Hypex plate amps that drive the bass and provide room EQ of my 3-way system I built a few years ago to the Troels Gravesen Fusion design for another room. So I have the UMIK1 and measured and adjusted to achieve a reasonable in room plot with those.
  • I have read about different wiring, shading etc and am rapidly moving out of areas I understand!
  • Currently I would intend to build a wooden cabinet (maybe black MDF) version of Murphys Corner array or some of the others, with around 50 (25 per side) Vifa TC 9’s, and move on gradually from there.
  • If I build a cabinet with 25 units at 83.7mm each that totals 2092.5mm and the room is 2425 high. What happens to the remaining 332.5 mm, a little bit for the base etc, but then the arrays are not fully floor to ceiling, does this matter?
  • I understand its sensible to buy some spares, so maybe 55 units, I wonder if I can get a reasonable price somewhere on that number?
  • I have read of volume per unit at 1.5 to 2.7 litres, some sealed some not………..To fit the corners neatly the small end would be easier, a triangle section or similar with knocked off corners.
  • If the cabinets are suitably designed they could bolt into rawl bolts on the walls to keep them as rigidly mounted as the walls?
  • A black grille finish, as seen on threads appeals to make them as inconspicuous as possible.
  • A foam/felt strip either side of the driver lines might keep the grille/cover at a reasonable clearance and deal with some edge effects satisfactorily?
I am comfortable with the woodwork and simple electronics.
I have read a good part of the many threads and contributions and would greatly appreciate input of guidance, knowledge, experience and expertise from those of you who have the kindness and patience!
I would then document decisions and results as they come along.
Many thanks in advance
M
New Member in Chile
Hello Everyone, Thanks for accepting me. I'm from the US and retired in Chile. I've been interested in Hi Fi audio since my 20's using primarily Sansui, Teac, and Akai components. Alas, all that equipment was sold long ago and I can't replace it with my current budget. So I've decided to try my hand at DIY and buying some kits online. Will see how it goes and maybe learn something along the way.
PCB or not PCB, this is a problem
hi All,
I'll explain right away that this is not about any kind of design, vector, cutting, milling or anything else - I have any design and drawing program for work experience and staying in a home made creation, I wanted to understand from you, crossover experts, what you use and how you make them.
I made one with the multi-hole base, but I won't show it to you otherwise you'll laugh until late, very late 🙂
Help With a PCB Project - Passive Volume Control
Hi All,
I am a total noob at electrionics and audio gear. I'm hoping to learn some new stuff by working on this first project. Basically I have an Audio Technica LP60X that outputs a signal at around 36dB LINE (100mV @ 1kHz) and currently it goes to a set of Logitech desktop speakers with a max input rating of 10W and a continuous rating of 5W RMS. (I know its probably an insulting setup to any harcore audiophiles but Im working on a budget).
My goal is to create an ESP32-S3 Mini 1 controled PCB, which will act as passive volume control in between the turn table and speakers. It does not need to amplify the signal, just be able to fade out and then fade back in using the ESP's wifi function and a digital potentiometer. I did some consulting (chatGPT and Youtube) and settled on using the MCP4231 as it seems to be the only chip that can handle stero input with single power supply and SPI control. (its also cheap).
The plan here is something like this: Audio from record player --> Passive Wifi-enabled volume control --> Speakers
I have attached a schematic I drew up in KiCad. Would you be able to look it over and let me know if there are any crucial errors I might be missing? Also if you have any tips/tricks or recomendations that would be appreciated too.
Kiitos! (Thank you so much in Finn)
Joel.
For Sale Pair Faital 12RS430, pair 10RS430, pair 8RS340
One lightly used (no scratches, never abused) pair Faital 12RS430 woofers. Very nice curve for a big-motor twelve, high x-max & Qms, deep bass, Faraday ring. $370/pair + shipping. https://faitalpro.com/en/products/LF_Loudspeakers/product_details/datasheet.php?id=151050115
SOLD: One lightly used (no scratches, never abused) pair Faital 10RS430 woofers. Same excellent motor and high Qms as 12RS430 on a lighter 10" cone. $340/pair + shipping. https://faitalpro.com/en/products/LF_Loudspeakers/product_details/datasheet.php?id=151040095
One lightly used (no scratches, never abused) pair Faital 8RS340 woofers. Easily notchable 1.5 dB bump @950 Hz, otherwise smooth to 2.7 kHz. $250/pair + shipping. https://faitalpro.com/en/products/LF_Loudspeakers/product_details/datasheet.php?id=101030204
3-Way Crossover/EQ Set-Up (Using Hypex Filter Design)
My cabinet conversion is nearing completion and I am getting ready for set up.
As a newbie, I am in danger of trying too many things at the same time and therefore getting confused. So I have to try to move in clear, simple steps, in the right order of priority, with clear objective, constraints and method for each.
So far I have the following plan which is limited by my current level of knowledge. I was mainly using this thread by @AllenB for guidance (although it goes more into passive filter design and is not specific to active filters) and I am now trying to make it more specific to active/DSP. I also used advice given in the build thread so far by @Busdriver02, @svp, @temp25, @Juhazi, @hifijim. I would like to build this guide so I can follow it myself and also make it available for others to use with DSP-based 3-ways. Would appreciate if experienced people can have a look and help me put it together.
Another Chinese PP amp
Hello all. I built a Chinese PP tube amp I have had laying around for a few months. As we know there are no instructions aside from the schematic they send with it, which isn't great.
I followed as best as I could here: https://www.diyaudio.com/community/threads/problems-with-chinese-pp-kit.353111/
I have the transformer marked as 110v, same or similar to the one in post #98 in the above link. I am still not sure how to wire the primaries or the 2 yellow and one black (Yel-Blk-Yel). They show going to the 6.3v/0 and I assume the black go to chassis ground. And the primaries? Red-Blk/Red/Blk. I see only 6+ volts on one of those primaries. Are they marked incorrectly, perhaps?
For Sale Miro TDA1541 USB-I2S Stackable DAC
This is a very compact and cool looking TDA1541 DAC for your consideration.
I am providing quite a bit of details, so please read with patience.
The first thing to note that the TDA1541 chips are de-soldered from Cambridge Audio CD2.
I have obtained it from a very kind member here, I only paid for shipping from UK : TDA1541
The chips came with the boards, with aluminium plates glued on as heatsink or other purpose that i may not know.
As i removed the aluminium plates, most part of the prints on the chips were stucked to the adhesive used.
The chips were all removed by me, no pins are damaged, all in full length and clean.
If you mind the cosmetics of the TDA1541 chips, then this DAC board is not for you, I suggest you skip this post.
More details of the DAC board in the post below.
What's best forum...
Here's a list of various drivers I've tested. The vast majority are garbage tbh. I don't intend to update this list or publicly rank drivers going forward though hopefully this list provides some benefit to diy builders of the world. I've ranked those which I prefer in the top section. Then beneath are those which I find "good" and below those are garbage labeled "The Ugly". There are a handful of drivers in the ugly section which I intend to retest at different less strain inducing crossover bandwidths though the vast majority of my sentiment is specified here albeit a bit negative. I haven't tested every driver ever and there are certainly many gems to be tested that are not on this list.
Call it conspiracy or what you will... There's an inner circle of pagan colonialist imperialist federalist guitar worshipers who seem to hold chair as gatekeepers of various audio industry related things and speaker gear. These people may also happen to be stingy as hell. That fact aside, as such, many of the best products, high sensitivity low mms cone drivers for example, are disguised within the realm of guitar speaker drivers. Two example companies are Celestion and Jensen. Both make some fine drivers and again some junk... The ladder makes at least a couple drivers that I consider to be among the best and competitive with any I've tested. The brands which I consider to be honest, science oriented and therefore gain the rank of S tier are: Visaton, Fostex, Beyma, Mark Audio and Seas. Of similar quality though presenting a less consistent and or less focused and or less updated product line are Jensen, Ciare, 18Sound, LaVoce, Kartesian, and Faital. Oberton, PHL, and Audax seem to be landfill grade. B&C, Eminence and Celestion exhibit an imperialistic monopolistic political brand identity that I deem gross and reflective of oil baron level greed and orkishness. Through the lines I observe some sort of mining union business scheme clinging to stale traditions as though somehow holy, and claiming both land rights and music as of their own invention. Celestion does make some good products available to the masses... In general my preference is for less landfill quality quantity best business practices stagnant christian values anal retentive control freak bs. Preferable would be zero corporate influence in favor of scientific progress, though also an acceptance that we're dealing with mundane devices here, and if applicable achieve quality through real innovation.
Here's a simplified list of my favorite drivers in order of preference from best to worst. With regards to crossover frequency and driver size selection I am mostly optimizing for midfield level playback.
Sub Woofers // ~0hz-~50hz
-18Sound 15W500
-B&C 8PE21
-Seas H1878-08
-Visaton W200
Low Mid // Mid Drivers ~+40hz-~+1200hz // FR
-18Sound 10NMBA520 // 18Sound 10MB400
-Fostex FE206NV2
-Beyma 8MI100
-Visaton B200
-Seas Exotic W8
Mid Drivers // ~+600hz-~+10000hz
-Visaton B100
-Visaton B80
-Mark Audio CHN-40P // CHN-50P
-Kartesian Wib70_vPA
-Bliesma M74P-6
Tweeters // ~+1200hz-20,000hz
-Seas 22TAF/G
-GRS PT6816-8
-Visaton SC4.7ND
-Visaton DSM50 FFL
Full Range Drivers
-Fostex FE206NV2 // Unnamed favorite
-Visaton B100 // B200
-Mark Audio MAOP 7
-Mark Audio CHN-50P
-Jensen 10 Tornado Classic 100
Compression Drivers:
2":
-JBL
-Beyma CP800TI
-TAD TD4001
1.4":
-Beyma CP755ND Al
-Great Plains Audio 288C
1":
-Faital HF108
-BMS 4552
-Kartesian CMP35_VPA
Here are two additional lists of drivers which I tested for my project. The "Good" list are drivers which I found to be very performative though inferior to the my "Favorite" drivers. And the "The Ugly" are drivers which I found to be inferior:
Good:
Tweeters:
-Visaton BF32
-Visaton BF45
Bass // Mids // FR Drivers:
-Atlas PD5VH
-Beyma 12XA30ND
-B&C 8PE21
-18Sound 6ND430
-18Sound 10MW400
-18Sound 12NMB1000
-B&C 6MDN44
-B&C 8FMB51
-B&C 8MBX51
-B&C 10PE26
-Beyma 8G40
-Beyma 8MC300ND
-Beyma 8MC500ND
-Celestion CF0820M
-Celestion CN0617M
-Celestion G12H 55/75 Heritage
-Faital 6PR160
-Faital 8PR155
-Faital 8PR210
-Faital W8N8-150
-Fostex FE83NV
-Fostex FE126NV2
-Fostex FE166NV2
-Fostex FF105WK
-Fostex FF165WK
-Jensen 10 Mod 70
-Jensen Classic 100 Tornado 10
-Jensen Classic 100 Tornado 12
-LaVoce FSN020.71F
-Mark Audio Alpair 7MS
-Mark Audio CHN-40
-Mark Audio CHN-110
-Mark Audio CHP-70
-Mark Audio CHP-90
-Mark Audio CHR-70
-Mark Audio MAOP 5
-Mark Audio MAOP11
-Monacor SPH-102KEP
-Oberton 6NM150
-Purifi PTT4.0X
-Purifi PTT6.5M08
-Seas CA18RLY
-Seas CA22RNY
-Seas ER15RLY
-Seas FA22RCZ
-Seas OR002-04
-Seas OR004-04
-Seas OR005-04
-Seas OR006-04
-Supravox 165 GMF
-Supravox 285 GMF
-Visaton SL713
-Visaton W130S
-Visaton W170
-Visaton W250
-Visaton W300
-Wild Burro Betsy
-Zenith 49CZ852
Bass:
-18Sound 12MB1000
-B&C 10MD26
-Beyma 15G40
-Beyma 15P80FE/N
-Beyma 15MI100
-Seas CA22RNY
-Seas L26ROY
-Wavecor SW270WA1
-18Sound 1480A
-B&C DCM414
-B&C DCM50
-Beyma CP22MF
-Beyma CP385ND
-Beyma TPL200
-Celestion AXI2050
-Faital HMF200
The Ugly:
Tweeters:
-Beyma CD1ND
-Beyma CD10ND
-Beyma CD11ND
-Ciare HT050
-Fostex FT17H
-Hivi RT2 Pro
-Seas T35C-002
-Visaton BF32
-Visaton TL16H
Mids // Low Mids:
-18Sound 5W430
-18Sound 8MB500
-18Sound 8NMB420
-18Sound 12W500
-Audax PR170Z0
-Aurum Cantus AC165
-B&C 2NDF26
-B&C 320K/C
-B&C 4NDS34
-B&C 6NDL44
-B&C 6PEV13
-B&C 6PS44
-B&C 6MBX44
-B&C 8FMB51
-B&C 8MDN51
-B&C 10CL51
-B&C 10MD26
-B&C 12MH32
-B&C 12NDL76
-B&C ALT002NDF
-Beyma 10BR60v2
-Beyma 10G40
-Beyma 10MI100
-Celestion AN350
-Celestion G10 45 Creamback
-Celestion G12H Heritage
-Ciare HW210
-Ciare HWG130
-Ciare HWG160
-Ciare PNDI 2.25CP
-Dayton Exciters
-Dayton RS180P
-Eminence Legend 1028K
-ER Audio Mini Panels
-Faital 2FE24
-Faital 5PR160
-Faital 6RS140
-Faital 10FE200
-Faital 10RS430
-Faital 15PR400
-Fostex FE208E Sigma
-Fostex P1000K
-GRS PT5010-8
-Hivi DMBA
-Jupiter 10LAP
-Kartesian Sub120
-Kartesion Wib50_vHP
-Kartesian Wom120
-LaVoce FAN030.71
-LaVoce FSN020.72
-LaVoce FSN021.00
-LaVoce FSN021.02
-LaVoce FSN030.72
-La Voce WSF121.70G
-Mark Audio CHR-120
-Monacor SPX-32M
-Oberton 8M150
-Oberton 10M150
-Peerless NE85W04
-Peerless TA6FC00
-Peerless TC5FC07-04
-Peerless TC7FD04
-PHL 1752NDU
-PHL 2530
-Satori MD60N-6
-Satori MR13P-4
-Satori MW19TX
-SB Acoustic 65WBAC25
-Scanspeak 10F/8424G
-Seas CA12RCY
-Seas FA6RBND/2
-Seas FA22RCZ
-Seas M15CH002
-Seas MCA12RC
-Seas MUR10RB-SL
-Seas U22REX
-Supravox 285-2000 MK2
-Visaton FRS 5 // X // XTS // XWP
-Visaton FRS7A
-Visaton FR8
-Visaton FR8M
-Visaton FR8TA
-Visaton FR13
-Visaton FR 6.5
-Visaton R10S
-Visaton R10STE
-Visaton SC8N
-Visaton SC13
-Visaton SL70NDV
-Visaton SL87
-Visaton TI100
-Visaton TW70
-Visaton W170S
-Visaton WS13E
-Yamaha JA-0801
Bass:
-18Sound 12ND610
-18Sound 15NTLW3500
-18Sound 18W1300
-Audax PR240M0
-B&C 10PE26
-B&C 15NW76
-Celestion TF1525
-Faital 12FE330
-Faital 15HP1020
-Faital 18FH500
-Kartesian Sub250
-Seas A26RE4
-Seas CA26RFX
-Seas ER18RNX
-Visaton AL200
-Visaton W200S
-Visaton W250S
-Visaton WS20E
-Visaton WS25E
-Altec 290
-B&C DE500
-B&C DE980TN
-B&C DE1095TN
-Beyma CP380M
-Beyma CP750TI
-BMS 4591
-Faital HF1440
-Faital HF206
-JBL 2453H
-Yamaha JA6881B
Bypass B+ caps voltage tolerance
Hello guys .
I have in my pre for b+ two 100mf 400v film caps installed. I want to bypass them with 0.1 mf film caps which rated 250v. In the b+ rails i have in tubes plates 217v dc measure exactly. This voltage is after the ECL82 and goes to tubes plates . The transformer winding output is 230v ac and i suppose (didn't measured) that is approximately the same after the diodes and to the 100mf caps.
My question is.....
Is it safe to bypass them with 250v caps? Is it enough 250v . I ordered them and i didn't pay too much attention by mistake to the voltage rating.
I will post pic of my external tube preamplifier PSU.
Also pics of the actual pre inside. 12au7 12at7 per channel. All hook up cables are pure silver, dact pot, visay and takman film resistors and all film caps , tube sockets of teflon and pure ofc cooper , rca jacks pure cooper. Aslo in the PSU the heaters regulators are SPARKOS discreet regulators SS7812. The construction is pure dual mono from pre to psu. The preamplifier WAS KORATO KVP20 dual mono version from factory. WAS. ........ Now is something else . Its completely reconstructed and rebuilt but the circuit remains as it was from factory and the actual values of all the new and higher quality parts (resistors caps diodes regulators) also as it was from the factory.
Success - No one wants a Loser
SUCCESS by Graham Parker
The dreams and hopes of men are powered by addiction
And who am I to say that this is an affliction
When everybody gets suckered in and lives their lives like fiction
Writing their own stories of success
They say they want you for your colourful evocation
The way you turn a cliche into a sensation
But all they ever wanted was that same vibration
The one that shimmers round success
Success success
All you ever need:
Success
You can't be happy while someone else has a fistful
They glow from TV screens healthy strong and fiscal
And everybody slaps their back while you're alone with a wristful
Jerking to the rhythm of success
Success success
All you ever need:
Success
Spectrum analyzer setup using USB soundcard
I'm working on a setup to measure amplifier noise output, SNR, crosstalk etc. and see that a number of people are using a USB soundcard as the basis of such a setup.
Can anyone comment on improvements to the following setup?
  • Scarlett 2i2 USB interface (this seems to be a popular USB interface). Are there USB interfaces with a better noise floor than this one (at a similar price level)?
  • Is anyone using the TinySA?
  • Oscilloscope 10:1 probe with 1 MOhm input impedance to connect between amplifier output and the USB interface. Will this impact the measured noise?
  • Software - SpectraPLUS-RT seems good but I'd like a cheaper or free alternative, preferably that works cross platform.
Audio Precision SYS-1 or Quantum QA403?
Hello,
I am undecided what analyzer to purchase. Currently I am using EMU0204 with SprecraPlus and for the most part it gets the job done, however when it comes to measure balance phono, it becomes tricky to get proper results. Plus the voltage range and therefore performance dependency it too large.
'This prompts me to get a new analyzer and since there are nice Audio precision on the market some system one and two at a more reasonable price. However they are old need special interface and computer and if they break it is not easy to repair.
In parallel I was looking at QA403 and I was wondering if nowadays, it is still worth to look at this older equipment as this perform as good but yet cheaper and more reliable, or these analyzers still set a standard?
Thanks!
Workshop layout ideas?
How do people structure and layout their workspaces?
I do a variety of work, maybe metal for amplifier case or woodwork for speakers, also the usual home renovation, bicycle maintenance etc.
When I moved it all ended up in boxes, tolerably well sorted, like Hammers box, Saws box and so on, easy to find.
Time to unpack and layout the workshop, and "easy to find" may not be the best way to do it. For instance if I do a metal chassis I probably want a hacksaw and perhaps a soft face hammer or other metalwork tools conveniently co-located, while for speaker boxes I want the wood saw near the claw hammer and other wood tools, no use to have the wood saw next to the concrete saw.
But lots of tools are not material specific, drills for instance, or measurement tools.
One option is a kind of work flow layout with a materials input and preparation area (saws to cut to size etc), assembly area (spanners and screwdrivers etc), finish area (sanders, polishers, paint etc).
But not so suitable for ad hoc repairs and the like.
So, what do people find convenient and efficient?
Curious to have some fresh perspectives.
I have about 32 square metres at the moment but plan to at least double that.
Little Big 18" Subwoofer Build
I’ve been building subwoofers for years now, and I’ve always used car audio drivers. However, I recently started building speakers using pro-audio drivers, specifically mid-woofers and horn loaded compression drivers. I love how dynamic and clean-sounding these drivers are, so it was only natural that I decided to give pro-audio subwoofers a try.
I did some research on pro-audio subwoofer drivers with relatively low Fs (resonant frequency) and high Xmax (maximum linear cone excursion), and the Lavoce SAF184.03 stood out as a promising candidate. It features a beefy 4" voice coil and 1500W power handling. Some might scoff at the Lavoce’s 30 Hz Fs and 13 mm Xmax, but keep in mind that I plan to build multiple subwoofers in tiny sealed enclosures – at least by 18" subwoofer standards, so deep bass output likely won’t be an issue, and I’ll still be able to keep enclosure sizes in check.
I eventually settled on an enclosure design featuring generous 4" radius rounded corners even though I knew it would be somewhat challenging to make. Using 15 mm kerf-bent Baltic birch plywood not only keeps the enclosure weight in check but also is stronger than MDF, not to mention the wood grain looks very nice when stained a light color. The braces and baffle were made from 18 mm MDF.
I used a biscuit joiner to cut slots in the plywood. The two MDF braces are attached to the plywood using biscuits, essentially serving as the form around which the plywood was bent.
The braces also feature circular openings to support the heavy subwoofer motor, which probably weighs close to 15 kg (~33 lbs) by itself.
The front baffle and rear panel were painted black, and the birch plywood was stained white with a two-component oil. I lined the walls with polyfill sheets.
I placed four pillows filled with polyfill inside to improve deep bass response. In total, I used about 1 lb of polyfill per cubic foot. The gross internal volume, before accounting for driver displacement, is approximately 3 cubic feet (~85 liters), which is about 25% smaller than the typical minimumenclosure size recommended for a standard 18" car/home audio subwoofer.
With the addition of polyfill, the subwoofer’s resonant frequency decreased from about 61 Hz to 56 Hz. The impedance curve reveals that inductance is well-controlled, allowing this subwoofer to be easily crossed over as high as 500 Hz. The nominal impedance is 8 ohms.
The near-field frequency response indicates a roll off that’s less steep than the expected 12 dB/octave for a sealed enclosure, thanks to the driver’s strong motor. When placed along a wall in a typical sized room, the subwoofer should deliver flat frequency response down into the mid-twenties, especially after reducing the ample mid-bass output using EQ or an AVR’s room correction capabilities.
Finally, a complete build video is available below. Please let me know what you think.
SOMOS. Sound of One MOSFET Headphone Amp
One MOSFET and One resistor ...
This amplifier is for you who have a headphone: 8, 16, 32, 60 or 64 Ohm impedance.
The trafo is 2x12VAC.
The MOSFET can be any TO-220 or TO-247.
For example IRFP240, IRFP140, IRFP044, IRF540. (IRF520 and IRF610 gives a little more distortion = more MOSFET sound)
The resistor should be 5 Watt.
If you have some MOSFET laying around, this project is for you.
You get good use of your MOSFET.
I have not built it. But the SPICE test shows it is a good, solid and fun design.
It works 🙂
Thanks to Pa and ZM
Hello guys!
I think its time for a giveaway!
This morning I woke up a bit early and like usually I started with checking my emails.
Well there was a particular email that jumped into my eyes. Always when I receive emails from this person and another particular one makes me very happy.
Well this time the email made me double happy 🙂)
To mention that I am not a rich guy, impression that I left around here because of giving away stuff.. its quite the contrary. In life no matter if rich or poor.. if you want to get you always have also to give so.. here I am making room for new stuff 🙂)
This time a stereo xa252 pop kit will be given away, the shipping will be on me.
One channel in the kit looks like this.
Both channels are new, tested and working. I will provide the thd measurements to the winner.
How it'll work:
To enter, just copy the list of entrants, paste into a new comment, add your DIYA username to the bottom of that list and post. Sunday at 10pm my time(or a bit later if I forget), I'll make a comment saying that entries are closed. I'll take the final list of entrants, paste them into an online randomizer, and the name that appears in the top (#1) position will be the winner.
And big thanks to everyone specially to Pa and ZM!
For this giveaway you should thank to them and not to me, if it wasn’t them to be so generous and share their ideas this wouldn’t have been possible.
Good luck!
New Tectonics force balanced Symmetric Drive Woofer (SDW)
Hi all, I was browsing through Tectonics website to check out some BMR's. And I saw this, which seems just released:
"The SDW70C is a force balanced Symmetric Drive Woofer (SDW), combining an ultra-compact dual diaphragm structure with an efficient motor. This allows for incredible bass in space constrained products such as displays and soundbars."
It's a very small woofer (96 x 96 mm size) that uses some nifty technology. Seems excellent for some very small nearfield desktop speakers. Combined with their smaller BMR's they might be nice for a small surround/atmos speaker too. Here's a link to the spec-sheet.
The technology reminds of one patent that two young Dutch guys sold to Sonos. Ah found it: this one.
I can't find it on any webshops yet, but might also not be available for consumer-sales. That would need to be asked, I guess.
Anyways, I wanted to share this with you guys and share thoughts.
  • Thank You
Reactions: VoxCelestial
DAC I/V measurements
Multibit DACs with current output have had a cult following for a long time but recently they have become very popular at diyaudio e.g. due to Miro's diy dac boards. Diyers have tried a variety of I/V stages and there are quite many subjective evaluations of these. However not that many measurements. So I decided to provide measurements of some of the popular alternatives.
DAC
The DAC used in this test is my PCM1702 board that uses PMD100 as digital filter. The board has PCM1702 L-grade chips that were used in Denon CD players. L-grade is not specified in the datasheet but all my L-grades measure about the same as K-grade. I have also J-grade chips but they measure much worse than the L-grades.
Here is the DAC board with separate I/V stage.
The DAC board caters directly for OPA1611, AD844 and AD811 (by populating appropriate I/V resistors and capacitors). Other I/V alternatives can be built as small "hat" boards that fit directly to the op amp sockets on the DAC board.
Here is a picture of the test setup.
The PSUs for the DAC board and the ADC board (ES9822PRO) are my "silent switchers" powered by power banks. DAC PSU board has 2 TPS7A39 dual regulators for +/-12V and +/-5V and a "raw" 5.5V output for the digital filter regulators on the DAC board. The connection to PC from DAC/ADC is provided by my STM32F7 USB-to-I2S board.
Lineup
Here is the I/V lineup for this test.
From left to right: OPA1611, AD844, AD811, OPA861, Folded cascode CEN clone, BJT
OPA1611
OPA1611 is often recommended for I/V duties. Here it will be used as typical op amp I/V stage in DAC datasheets so it will act as a baseline for other measurements.
BOM cost (single): 5 EUR.
AD844
AD844 is used without feedback (as in AYA dacs by Pedja Rogic). Input impedance is relatively high (50 ohms) so some stack 3 or more AD844s. Here only one is used.
BOM cost: 15 EUR.
AD811
AD811 I/V stage is based on Walt Jung's article in Audio Amateur 2/92. I used 1k stabilizing resistor. Input impedance is about 1 ohm.
BOM cost: 15 EUR.
OPA861
OPA861 is used as in the I/V stage of AYA II by Pedja Rogic.
BOM cost: 10 EUR.
This is based on the folder cascode CEN by EUVL. This is not the original folded cascode CEN but a clone.
I used 2SK209GRs as buffers. Input impedance is about 13 ohms up to 100kHz.
BOM cost: 30 EUR. This is the only one of the tested I/V stages that uses obsolete parts (2SK170/2SJ74). BOM Cost assumes matched jfets from diyaudiostore.
BJT
This is a slightly modified version of ES9018 I/V by Sérgio Santos (@smms73).
I added a similar 2SK209GR buffer as in CEN and modified some resistances for lower current consumption.
On paper (i.e. simulator) this I/V stage has very low impedance (200mOhms up to 100kHz). Parts count is high but it uses ubiquitous BJTs.
BOM cost: 10 EUR.
I/V resistor and cap is 1.5kOhms || 2.2nF on all tested I/V stages.
Measurements
I made the following measurements on each I/V stage:
  • THD(+N) at 0dBFS
  • Noise (DAC playing -180dBFS)
  • THD vs. level sweep at 997Hz.
Measurements are shown in subsequent posts.
Oopsy...
I tripped, fell and accidentally purchased a giant lot of tubes 'n' other goodies. I can't recall how I first caught the tube bug but never the less here I am. Sooooo, now I have a hangar full of tubes of all kinds and conditions. I kinda have an unlimited supply of a variety tubes to play with. While I don't expect to find large lots of the popular tubes, they are popping up here and there. I have have barely scratched the surface though so I have high hopes to find some gems as I make my way through them.
I hope of find fun and interesting ways to use what I find. AF amps, RF amps, power supplies, etc. etc... I am a ham, somewhat of an audiophile (ok, not really) and have a decent understanding of electronics and have been boning up on tube knowledge. My hope is to enjoy the journey of learning more about electronics, "vintage" electronics and tubes 'n' stuff. I think I have most of the basics covered from a tools and test equipment standpoint and I aquired a few chassis with the lot of tubes so now I just need to pick a project and get started.
So by now my reason for being here should be relatively obvious. I need to absorb some of that juicy knowledge from y'all and hopefully share my journey along the way!
Looking forward to it!
Pete...
I want engineering drawing for LP12 sub chassis
Hi 👋everyone
My uncle always talked about how he is going to build a lp12 subchassis one day, but it's been years already. So I would like to spend time and build it for him as a surprise.
After searching online I can't find any schematic for the actual subchassis itself.
Can someone help provide me a schematic for it so that I can mill it?
I am studying for bachelor of engineering, so I have access to tools but I don't have much knowledge. Please tell me anything I needed to know
Sincerely
friendlyengineer
Reactions: dazcwl
2024 Subaru Outback with HK - audio upgrades
Overall, I am pleased with the sound of the upgraded HK system in my 2024 Outback Touring. I would describe the sound as balanced and enjoyable (after tweaking the 3 band eq to my liking). It is just lacking punch and only plays so loud, lacking upper detail and after 2/3 - 3/4 volume it just breaks apart and goes to crap. Now, after 1 year of driving around, it is time to do some upgrades and get it to the next level. The HK system is basically a black box but I have found some good info on the Outback forums.
Lets get to what I have done so far and what I am planning in the future.
I have replaced the left and right factory mid/tweeters with JL Audio C2-350x 3.5" coaxials. This was a PITA as the factory locations do not allow a 3.5" to drop into place. The factory speakers are mounted to a plastic base which is just too small for a 3.5" speaker. Time to pull out the dremel with the flex shaft extension and start grinding away. I would give this a high difficulty rating (luckily no damage to my dash or windshield)
These sound pretty darn good I have to say! I was a bit worried as the HK amp/DSP is tuned for the OEM speakers. Definitely an improvement from the crappy OEM speakers.
I pulled the front door panels off and applied sound dampening pretty much everywhere. But first the plastic membrane had to be carefully taken off.
I first instlalled JL Audio C1 - 650s (93 dB; just used the woofers) and then later replaced them with Hertz C-165 woofers (93 dB) not sure why I didn't use the C2-650 to match with the dash speakers (oh right they seemed pricy). As I found out later by others in the Subaru forums, a higher sensitivity speaker works best here. Both the JL and Hertz can't match the levels I am getting from the dash speakers. (need a bit more midbass) This is the problem you get when dealing with a black box. So that raises the question whether I install an aftermarket amp/dsp. I will probably add this design in a future post if i plan on going that route.
A was brave enough to pull apart the car to get at the OEM subwoofer. You have to remove the rear back seat bottom (pretty easy - 2 clips and pull up) Then unbolt the back seat section on the driver's side where the seatbelt runs through. Then pop away the panels, remove the rear tie-down points (4 or 5) and 2 other screw/bolts that are hidden away Then the whole plastic panel pulls off and then you can access the subwoofer.
I replaced it with an AudioFrog GS8ND2 8" thin-line subwoofer. I just had to make a spacer/bracket out of 3/4" mdf to mount the sub to as the factory holes don't line up. There is definitely some improvement from the OEM sub; namely cleaner/less muddy bass. But it is lacking the whole point of a subwoofer in my opinion.
Again...
The black box...
need more juice to get things moving.
Next step will be installing a link1000.1mini amplifier. My plan is to install it in the rear cargo area to the left of the spare tire. Will be cutting out the styrofoam that lies below the cargo bed so that it will retain the factory look. Autoharnesshouse.com makes some harnesses that I will be using. I plan on tapping into the front door speaker signal as it provides a full range signal and is prob not as adultered as much as the sub signal. The 1000.1.mini has a built in low pass and parametric EQ for my tuning needs.
Okay, thats's it for now. Sorry for the long post. Check out the pics as well.
Linn Sondek DIY mods that work
Are there any, or should we believe the view an LP12 is like an old violin?
despite reading many threads, views on the commercial products vary widely. As for DIY mods, damping is thought to be the wrong principle for its design, or so it is said.
But in which case there seems little on diy stiffening.
Mine has Valhalla/ Basik LVX.
Replacing the psu with an external one is an obvious path but are there no mechanical DIY projects that work?
Anyone had any success with table or arm mods?
For Sale Sony CDP-C100 10 Disc CD Player w/TDA1541 Chip
For Sale: Sony CDP-C100 with Philips TDA1541 chip. I installed a socket on the motherboard so the chip can be swapped. Original TDA-1541A chip replaced with the TDA1541.
Works great, but some of my CD that are in bad shape do occasionally skip, but good CD have no issues...
Would like to sell locally to confirm proper operation. Pickup in West suburb of Chicago.
Jadis Orchestra Tube Amp cage
Bought this Amp cage thinking it would fit my amp and as my luck would have it, a little too short width-wise... so up she goes...
Its a tube cage for a Jadis Orchestra tube amp.
Bought it for $50, so $50 + ship
For Sale Pro-Ject Integrated Stereo Amp Box RS (Hypex + 6922 Tube pre)
For Sale: Pro-Ject Stereo Amp Box RS Integrated Tube based amplifier.
Many inputs including XLR. Pair of 6922 tubes driving a pair of Hypex UCD 180LP based amplifiers. Works perfectly, but does not come with stock +48vdc / -48vdc power supply. A DIY power supply was made for this amp (more amps than stock), and is included.
Case has some wear and tear form previous owner, but functions as intended.
Comes with aftermarket universal remote programmed for power on/off, volume up/down, and input selection.
$525 + ship.
  • Manual_Stereo-Box-RS.pdf
DIY PCB repair books/ adult classes
I’m trying to teach myself a new skill/trade and I was wanting to know if there any go to books that I can read on PCB repair. It’s something that I have always been interested in and I thought I can be a good hobby for me to pick up. I have engineers on both sides of my family and it was always my dream to go to college for engineering but poor life choices I’m my early years ruined that. If I could make it work I’d love to take some adult classes for it as well if anyone knows of any in the Philadelphia region. An apprenticeship at a local shop for a few hrs a week would also be amazing.
Any help would be greatly appreciated.
Nearfield vs outdoor measurement on Tham10 and ThMini-clon
Hi.
Ive tried/tested/thought about many different (compact-ish) sub-configurations around 10" and 12".
The scope is not HiFi or accuracy, More like an exercise in output vs size vs price.
Here I would like to present the measurments on 2 different subs (one of them, maybe not actually in the "sub"-category...): a Tham10 and ThMini-inspired Tapped Horn with a 12". The ThMini-inspired horn is 40x60x60cm outside with 20mm ply and thus around 100L actual internal volume. A Tham10 is approx half the volume.
Ive measured both like this:
  • Indoors in my basemest right at the horn-mouth
  • Outdoor at about 1m distance. Sub and mic placed on a piece of ply, on the lawn. Some buildings 5-10m away. Windy day, and thus high noise-floor.
The measurments are imported to google-sheets and adjusted to be around the same level for indoor vs outdoors. Raw data and a smoothed version shown. My interest was not absolute level, but response. My measurments are very crude, but Im supprised how well the indoor response line up with the outdoor measurments.
If the measurements are correct, the Tham10 drops off at 70Hz, but it works supprisingly well for playing very loud modern pop/dance. - yes the lowest notes are missing, but I very much doubt that most people notice. As far as I remember the measurments for both tapped horns were at similar settings and if thats correct the Tham 10 is as efficient as the ThMini above 70Hz. - but much, much smaller.
Maybe of interest to some of you. Please share thoughts and ideas.
ThMini clone with a 12-280/8-W from Thomann: Thin line: raw data, Thick line: smoothed by google sheets.
Tham 10 with a Car-sub from Eminence (very solid driver): same setup as above
Reactions: Booger weldz
Pairing Markaudio CHR-120 with a tweeter
Hello everyone,
I've been designing a tower speaker lately with the chr-120 and the sb acoustics sb29rdc-c000-4. The main reason why I'm pairing a tweeter to a fullrange is because the off axis response of the chr120 alone is not the best and I wanted to make a tower that would sound nice in a good range of positions in my room.
The design is a 60 L ported box, the vent is 18,3 cm long and 9 cm ID, made it so that turbolence is not a problem even at the highest volume the speaker can play.
I started the design by tracing the responses from the manufactures datasheet and modelled this crossover in the image (i attached also a zip with all the files). Since I don't have the speakers in my hand yet and am not prepared to make measurements I was wondering how far off this design would be from reality, especially considering the phases are calculated from vituixcad and in the woofer i set a z offset to match the impulse response calculated by vituix as well.
Since I'm a student and don't have much money to spend experimenting, am I fine designing a speaker this way and getting all the parts, rather than buying parts and changing them later?
I'm open to any kind of advice!
  • Project Files.rar
    Project Files.rar
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,743
Members
7,886,335
Messages
Filter
Forum Statistics
Threads
406,147
Messages
7,886,335
Members
507,743
Latest member
Fitodiod
