First time crossover build… help/advice needed
Please look at what I am planning and provide thoughts/advice/feedback...TIA! Please be gentle as this is my first crack at this not using kits.
I am building a ported MT bookshelf speaker with the following drivers:
Dynavox LW6004HR-N 6-1/2" Honeycomb Cone Woofer
6 ohm
87.92 db sensitivity
50 to 4000hz
Dynavox TD2801XL 1-1/8" Silk Dome Tweeter
8 ohm
92 db sensitivity
2000 to 22,000hz
I used a calculator for a 2-way 2nd order Linkwitz Riley crossover, xo @ 3,000hz. I also used a l-pad calculator for tweeter attenuation and added resistors after the crossover...does this look right to you guys?
Based on vendor specs I will be building roughly a 0.63 ft3 ported cabinet.
"Rogue99" Rogue Audio 99 Clones?
Just bought a nice PCB available on ebay, aliexpress and other similar places, claimed a clone of Rogue 99 preamplifier. Please take a look at the schematics and PCB. Does anyone knows anything about the real one and how this copy compares to the original? Any experience with this build?
First-order vs. Second-order with extremely low Q
Wikipedia told me that "a second-order low-pass filter with a very low quality factor has a nearly first-order step response", so did the VituixCAD2 software. In the CAD, I tried by simulating a 4 Ohms woofer series connected to a 3.5mH inductor for the first-order configuration and then added a very small capacitor--here is 3.9uF--parallel to the woofer for creating the second-order configuration, with extremely low Q-factor. The frequency responses and the impedance curves of the two cases are nearly identical. Are there any other differences between them? What are pros and cons between these two cases?
Philips CD 204, dead headphone amp?
I recently acquired a Philips Cd 204 I'm in the process of restoring to full working conditions. So far I have fixed the tray (gear and belt broken), replaced all caps in the PSU (actually old Nichicon's were perfectly fine), replaced all low quality Philips caps in all boards but the CDM-1.
I have one last problem to fix, the headphone amplifier: if I connect it to the other boards, RCA output is distorted and headphone output is severely distorted; if I unplug it, RCA output is perfectly fine.
Schematic is attached, it is a simple 1x buffer feeded directly by the RCA output; I checked the cable and it is fine, voltages are fine, caps are new and resistors are not shorted. Only remaining option is a faulty op-amp: it is actually a NJM4560 not a NJM4556, but anyway it appears to be a pretty standard headphone amplifier of those days. Is it a common failure ? Do you have any suggestion for a modern replacement ?
I do not plan to use it (fixed volume is useless) but anyway I would like to fix it.
Orion 2500D , High pitch Whistle sound upon power on.
Good day. I am working on an Orion 2500D for sometime now. It produces a high pitch whistle sound upon power on, and it takes around 30 secs then goes down but not totally gone. I had re soldered the output FETS that where loosed maybe because of vibration causing the switching signal to go on and off, but it did not solved the issue. Gone to days of checking the parts and signal but found no defective parts and signal from supply to output is normal as far as I am concern. Note that The amp is working normally when fed with audio. I had read a couple of threads of the same problem but all of them had no resolution in the end. Did anybody found the solution of this issue at this point of time? please share. I will appreciate it much. Attached is photo of the model.
Woden Designs Poplar Build (finally happening!)
INTRO/USE:
I will be building and finishing these before the end of april! (I swear! Well, at least the actual construction, finishing work may take longer).
I searched for a good hour or two for another thread about the Poplar, and besides some threads discussing speakers good for being "against the wall", I didn't find evidence of any actual posted builds. Please direct me to any if you know of one and maybe we can move this thread there. My only prior experience so far is building a pair of FHMK3 last year which I purchased in a kit for from Big Wood Studios.
I have a pair of Mark Audio MAOP 10.2's that I broke in for 3 months last year and they are still waiting for an enclosure. I finished my Akitka amp kit last week (finally), and am ready to pair the Poplars with it in the bedroom. I purchased the plans a few months ago from Scott at Woden designs. 🙂
QUESTIONS:
-What plywood to use?
I want to use plywood, but as a newcomer in selecting the wood myself I do not know at what grade of baltic birch or marine grade ply that no appreciable acoustical benefits are gained from going up in quality. There is a local lumber yard that has "BB" grade baltic birch, and also marine ply, but I have no idea if I should be asking for certain type of core of marine ply, etc.
I am hoping to pick up the ply this week if I can figure this out. Sadly there is no poplar ply available nearby. Any notes of good alternatives that are readily available in the American West would be greatly appreciated.
-Where to orient the port?
(front, or mirrored on sides?)
I was planning on putting the ports on mirrored sides for versatility (oriented towards corner for more bass, away for less). I am unsure how much the different port orientation would effect their presentation. I'm not as keen on a bottom port, as there may be furniture below on speaker and not the other. (I will probably email Scott this question, but didn't want to bother him in the preliminary build phase).
FINISHING:
-Impossible Veneer Plan?
I was thinking of putting a roundover on the front sides of the cabinet from top to bottom. Is it possible to veneer with one piece from back left side all the way across the front and to the back right side with a single piece of veneer? I would assume at minimum a "tight grained" veneer would be needed, and steam or heat of some kind. I have a hobby iron (the type used for finishing rc airplanes) as well as a nice clothes steamer that could be used to try this, but was looking for some experienced input before I get to that point.
My heart is not set on this, but it would be a neat trick to pull off. (I.E. I am willing to put in an inordinate amount of time to accomplish this as it's for my personal enjoyment and learning, vs. if I were making these for profit.)
That's it for questions at the moment.
I really appreciate any input and help. As this project gets underway, I'll be sure to put up some photos and impressions as I make my way through this journey!
Thanks everyone!
Is mounting a driver by its magnet beneficial?
For my GAYA2 upgrade with Purifi drivers, i have an opportunity (technically) to support the midrange PPTT4.0M80-NAC04 by its magnet against a pretty massive part of the cabinet. The top 30cm is filled with a stack of MDF layers with a small cavity of some 4.7 liters . This will be filled with pertinax sheet and epoxy, to be reduced to 1.2liters.
The wall of the cabinet (110cm high) is made of thin layers of pertinax (hartpapier) glued with epoxy. Again heavy, stiff and curved, the horizontal crossection is an ellips. The baffle is made of ticker layers of pertinax, with cld layer in between(also in the enclosure wall).
Massive enough to consider it vibrationally dead. So perfect to mount the magnet against.
The basketframe of the driver will then be mounted with some resilience and vibration absorption putty to both relieve the basket from stress and damp resonances in the basket.
But the driver mounting itself will be difficult. Interesting challenge, the question is: is it worthwhile to do. And if so what benefits to expect?
Has anyone gone into this rabbithole?
And what are the results?
Reactions: lrisbo
Cayin CDP22 sort of working
'Sort of working" means that it can play CD but if you touch it with static from your body, then it stops and sends out a hiss. On one hand, it is my favorite CDP with tube output no less. OTOH, maybe a tech should buy this and make it whole. wired for 220 Volts. $200... Was $1,700 new. Weighs 25 lbs. maybe more. You pay shipping.
>Lower price at this site than US Audio Mart<<<
>>OFFERS WELCOME<<<
Martin Logan Theater Panel Rebuild
Hi all,
I just replaced the diaphragm in a Martin Logan center channel speaker. These speakers are no longer supported by ML, so if you had one with a dead panel, you were SOL. But that ain't necessarily so...
I attempted to copy/paste the write-up from my blog here but the font and background turned wonky, and its a huge amount to retype, so I'm just posting a link below showing the photos and write up:
http://jazzman-esl-page.blogspot.com/2011/11/compensating-diplole-phase-cancellation.html
What does higher emitter voltage mean? Bias tests points
I'm not setting the bias, that is already done. It's just the same test points for reference.
I'm working on a Pioneer stereo / amp that had blown outputs. I've replaced them and have it running, but suspect it may be running too hot. One thing that I discovered was the voltage across the Left channels emitter resistor, which is also the test point for setting the bias, is about 20% higher than the Right side. Meaning: If I send it a 1v p-p sinewave and turn the volume up "half way" I will get 450mV across the right channel test point and 650mV across the left. What does that mean?
Also This emitter voltage discrepancy is with the same RMS value on dummy loads, meaning the output appears to be the same on both channels, but one has this higher voltage.
Ampeg SVT-7 pro power supply issue
Good day to all techs out their , i hope you have great jobs going on. Need your help or tips guys, I am working on a bass amplifier Ampeg SVT-7 pro. I know a lot of techs are having a hard time on this amp ,as i read in some forum as I do. The amp is dead without green light power indicator ON. Upon thorough trouble shooting surprising ly i did not find any defective parts or shorted whatsoever. I suspected on the IC ICE2a165 U2 PWM controller which was getting really hot when powered on, but which I replaced with a higher wattage ICE2a265. The IC is not getting hot as much but still no power indicator and still dead, no response click on the relay REL2 . ANother thing i want to point out is since the TH1 in parallel with the the relay contact has a low resistance its supplying 220 volts ac on the BR1 rectifier. Is this TH1 normal for having a low resistance of 2 OHms? .Can't find any more parts to suspect , if anyone encountered this problem please a small tip might help me. Attached is the schematics.
Using bi-amp in a 2.5way build to avoid a low impedance?
So, I am building a fun 2.5way tower speaker with 2 different bass drivers: the Wavecor WF152BD 4ohm 6" midbass, and a SBAcoustics SB17NBAC-8 or -4 for the lower woofer. The Wavecor will be the main driver in a sealed compartment, and the SB will be either in a separate sealed or maybe ported enclosure (TBD). The SB is really just there to fill in the bottom punch and offer the baffle step correction. Both woofers will be wired in-phase.
If I use a typical parallel crossover, I am looking at a pretty low impedance with two 4ohm drivers in parallel, so I would avoid that. I guess I will try the 8ohm woofer, but that still leaves me with a 3ohm dip right at 150hz. Below is the high-pass crossovers just for the two woofers. (Wavecor is in Green in the Tweeter section, SBA is in Blue in the Woofer section, sum in red. Tweeter is not profiled here, and yes I need to move to a better modeling tool, but I can use this one on my mobile while traveling for work):
I am just using standard FRD/ZMA files at first, to figure out the basics of my design and what components to order for the first try. Actual measurements will come later...
I was also considering creating a bi-amp setup, with one amp running the tweeter and Wavecor, and the second amp powering the SB driver. I think this makes it a bit safer? As each amp channel only sees one woofer.
My Marantz receiver can re-assign the surround amp outputs to be additional mains outs, giving 4 discrete mains channels: https://manuals.marantz.com/NR1608/EU/EN/DRDZSYcqhsmjdu.php
I was going to try that setup. But I have no idea what this statement in that link means: "This connection enables back EMF (power returned without being output) from the woofer to flow into the tweeter without affecting the sound quality, producing a higher sound quality."
I know what Back EMF is....I just don't understand it in this context... It seems backwards. I would think it should isolate BackEMF produced from the woofer motion in that channel, and not allow it to Flow Into the other channel.
Information request for modifying Bose 401s
I am new to this site and am hoping you guys can assist me with some improvement modifications to my pair of Bose 401's I picked up at an estate sale. The cabinets are in perfect condition, the grills are good and original, and the drivers and tweeters are fine (I replaced one tweeter with a replica of the size and specs that was broken.)
As seems to be the case with these speakers, the highs are muddled. Those from the left tweeter almost sound as if the tweeter is blown, but it is new, so that is not the case.
A user on a different Audio site said that he performed the following mods on his 401's and the result was a much improved sound. He has not revisted that site recently, so my questions to him about the specifics of how he did it and where he got the materials remain unanswered. I am hoping someone here can provide those answers.
Here is what he did:
_____________________________________________________________________
I got a pair of Bose 401s.
One of the cabinets was falling apart and I ended up gluing the cabinet back together. The cabinet workmanship is pretty poor quality. The woofers have no crossover and the tweeter uses an inferior electrolytic capacitor. The wire that Bose uses internally is small gauge, single strand telephone wire.
  • I added a small Neodymium magnet to the center of the magnet structure on all of the speaker drivers. The result was faster transients and reduced "audio blur".
  • I replaced the tweeter's capacitor with a good quality polypropylene 4uF capacitor.
  • I added an inductor with a 4 ohm resistor across the inductor for the main 6 ½ inch woofer and ran the "surround" 6 ½ inch woofer straight.
  • I replaced all of the wires with 16-guage wire.
The Bose 401s sound much better now.
________________________________________________________________________
Any help you can provide is greatly appreciated! I want to enjoy these speakers, but right now I am just not getting a good quality audio reproduction. I had a pair of 501 Series IV speakers many years ago and they sounded great; much better than these 401's!
Thank you!
Choosing an analog Oscilloscope for adjusting CD laser
I am refurbishing electronics on ebay but never done CD players. I specifically want to refurbish Arcam 7, 8 & 9 CD players that they all use the KSS 240A laser.
I have been told to invest in a Hameg or a decent oscilloscope.
I usually fit a brand new laser which is the most common fault on them but don't really know how to make any further adjustments.
For example I just fitted a new laser in one of them and found that it plays ok up to track 5 but after that you start hearing a repetitive noise with every turn of the CD so I hope the oscilloscope will show me the problem.
Does it matter if the oscilloscope is 20MHz or 60MHz etc?
I have these two in mind will either of them be any good?
https://www.ebay.co.uk/itm/126405974869
and
https://www.ebay.co.uk/itm/186312721171
or can I get away with this one:
https://www.ebay.co.uk/itm/285783384470
I do not want to use it for anything else, just aligning the KSS 240A laser on these three Arcam models so I really specialise my work.
Thank you.
Reviving a Pioneer PD8500 no read
A few months ago “surfing” into Marketplace looking for nothing, I saw a Cd player Pioneer PD8500 announced as “not working but well conserved. OPU must be changed. 20 bucks”. I think: high risk, low amount, ok let's go. The seller was right. The dead OPU had two defects. (1) Low power laser and (2) no movable lens. The mummy was the extinguished PWY-1011 pioneer pickup.
My first visual inspection was the laser power adjust trimmer, suspecting the easy way: full throttle for solve some past failure. And it was, minimum resistance regulation = high current = short laser life. First cause revealed.
The second seeking was for a locked lens or his armature. No news, all was ok. Then, I think, some driver burned, connector or power source out of spec. None of them. All were ok. Next step, resistance of focus and tracking lens coils. Voilá, the focus coils in open circuit, the tracking coils ok (8 ohm). Looking more deeply I found one of the copper tails from the base to the movable part broke, apparently . Second cause was revealed.
Starting with the last issue, I tried to re-weld the broken copper tail, but it was so short and in such a small space that I decided to drop off the 4 tails and replace them with longer wires. The donor was the cable of an apple earbud. After a surgery with magnifying glass, flux, tin soldering iron and patience, all the tails were left reconnected. Silicon glue was applied into welds as an effort dissipator. I had to be very very careful with the rubber suspension. In my opinion, the worst design ever made for lens stabilization (but I´m not a japanese engineer).
I follow. All reassembled, resistance checked (14 ohm focus, 8 ohm tracking), powered on and… the lens goes back to life!!, like a dog wagging its tail. But the laser intensity remained very low. I did not care.3
I put a CD, powered on again, and the focus detection shows began: the nudges for the spindle motor, the swing of lens, the seeking magic sound… but NO DISC fatal error. I did not care. News tests would begin. Laser current measure was 65mA, high, but no so much; power laser measure no possible (who have a pwr meter in this days?). Then a comparison with a healthy cd player, via cell camera, gave low power. Cleaned lens, lubed rails, re-adjusted tilt, but nothing. The fail was the same.
Then, the fact had to be faced: laser diode had to be passed to a better life, and replaced. Here, in a crossroad of change LD or try with other OPU, I took both: buy and replace the laser diode and develop an adaptation for other compatible OPU. The LDs selected were two: SLD105VL from Sony and RLD78MYR1 from Rohm. Why?, both 780nm, 5mW, AKA pinout and they were the best sellers on Aliexpress :|.
The OPU selected was the KSS313. Why?. Because this is cheap, with stock in Argentina and his dimensions appropriated to fit into the carriage, or was it what I expected.
The OPU came first, and surprise: the geometry dont fit any with the carriage… the second crossroads: sacrifice the original carriage or develop a new one, via 3D printing. The second was the election. After hours and hours of measuring, design, trial, re-adjust, the piece was builded.
Regarding the connections between the KSS313 and the board, a cross cable was necessary. The KSS´s flex connector was´nt compatible with the board. When all the parts were mounted and energized, the lens moved, and the LD goes shining. Welll done. A few tests revealed a high current in the KSS´s LD. Why??. Because the RF amplifier, a TA8137 Toshiba has different input sensitivity LD photodiode. Looking for a datasheet, they do not exist on the web (neither deep). Then I emailed Toshiba, and they responded to me (unbelievable!) that this IC wasn´t sold for a massive market and was a special development. Another Pioneer vaulted secret. Investigating other pioneer models, I could see that the issue was the VR for LD power adjustment. The KSS had a 2.2k and the required must be 4.7k. Changed and success!.
With the LD in his comfort zone, the RF signal remained absent. Aghhhh. And now what?. Looking again, I found that the KSS´s PDIC had some contact unsoldered. Surely my KSS OPU was a second hand or surplus. Once corrected this, the RF signal, or some similar, appeared at test point TP1. Yes!!. But not so good. A lot of electrical noise was present as an RF signal. New solutions were applied, shielding, cable re-routing, testing and testing, all resulted unsatisfactory, and discouraging. With a sledge hammer to destroy all in mind, the purchased LDs arrived from China, 4 months after. This is Argentina's style.
The last chance would be the change of LD. The main difference between Sony and Rohm is the focal point. An essential spec for any optical geometry. By similarities, the Sony was similar to the original (none with codes or ID). With a major surgery, the new LD was installed, and tested. It did shine!!!. But.. no focusing was possible, again. Unmounted the sony and mounted the Rohm model, conducted to the same road end: laser on, focus not. The sledgehammer came back.
But, while I saw a photo review of this story, a strange little shiny on the laser lens aroused my suspicion. Watching through a 6x zoom other defects appeared. The lens surface was damaged, with a scratch and a barely noticeable opacity.
And here, the savior ManoloMos magically appeared in this thread https://www.diyaudio.com/community/...ed-and-lost-substitution-and-repaired.390773/. The useless KSS was the lens donor that once changed, and with a new Sony LD installed, the focus signal was detected!!!!!!. Yes!!!!.
Followed by hours and hours of settings in grating, axial and radial tilt, LD current, mech adjustments, spindle balancing, the first tracking closed loop could be achieved and a decent RF eye pattern reached.
It was a lot of effort, technical discovering, schematics readings, included the Cd ISO red book studying, a dead, abandonded, misstreated CD player returned to the life.
Today not all the CDs can be readed, the CDR or CDRW usually fail. But, the commercial works in high level.
I´m apologize about my english, but you, patient reader, if reached this part, you will not give importance.
Speaker choice for low watt SE-UL 6V6 amp
Hello, my first post
I have been looking for a speaker design for a low wattage SE 6V6 amp. I originally wanted to build the frugel-horn and like the design for it's simplicity but my problem is I don't have corners to place them in but I have a large room 20' X 30' with an eighteen foot cathedral ceiling. I started looking at other types of transmission line / horns. I like the funken series and also a double port rear loaded design which is too complicated for me right now. I found the straight voigt horn and from what little I can find for design specs I ordered a pair of audio nirvana super 8 drivers. (after I ordered I got a message that on vacation till April 3rd). I recently found the BIB calc site. I entered the specs for the an super 8 and it calls for a 118" line which is around 9' tall straight? I am guessing the folded length will be a slightly different freq? I don't mind the large size and the voigt pipes like large areas from what I;ve read. Not many sites left that address Voigt design so other than copying another voigt dimension I don;t have much to go on
I'm getting myself confused from over thinking what I want and thinking maybe a bass reflex box would sound just as good although the "ambience?" from TL horns is one of the qualities I like. Are my assumptions for a BIB Voigt pipe correct?
Am I overlooking anything obvious or not in making a choice? Thank you for any response.
Counterpoint-SA220-pwr to Exicon mosfet 10N20 10P20 TO3
Hello, I don't know if I can get a reply.
I paid attention to the maintenance of all officials in Counterpoint-SA. One of the impressive is the maintenance of Pars 12 years ago, in which Vivavee, who participated, knows Counterpoint-SA220 very well.
My current maintenance status is: I bought 10 pairs of paired yellow ribbons before exicon stopped production to3 10n20 10p20 (at that time, the yellow ribbon was the best). Of course, this 220 needs 8 pairs, but this also means that I can't make any mistakes. At present, I have changed it to pcb to reverse the D and S of mosfet, and also changed the original 10v protection secondary tube to 6.8v horizontal mosfet gat is +-14v to reverse the DS protection secondary tube because D and S are the opposite.
Q1 has burned my location. Only 2n2222A is to18 package. No 2n2222 is to92. They seem to have a difference of 250ft and 300ft, so I changed it to 2n2222A.
The 1n5303 has also been burned, and the 60v diode is not damaged. Oh, if you can't buy 1n5303, I will change it to 1.6ma, which is close to 1n5303.
At present, my question is
There are many different parts specifications and circuit diagrams of this machine, such as r5 r8. The picture is 51r. The machine is located at 681r. I want to change it back to 51r, but the vr1 picture is 100k. The original installation is 250k and has been burned. Should I choose 100k in the picture? Or the original 250k? It should still be changed to a larger 500k horizontal mosfet.
The bias seems to be smaller. ( The yellow bag is 135ma-150ma)
Exicon mosfet gat is max1.5v, but I found two sets of vr, vr1 and vr2 in the circuit diagram. Vr1 seems to write off set for adjusting the article to the current. I don't know much about its use...
This machine is the first power amplifier I repaired is for my own use, and I have never seen this machine work normally. Before I bought it, these machines were abandoned for maintenance for more than 10 years, and there are many uncertainties.
By the way, I have spent $1,000 on repairing and replacing, cleaning up dusty boards to replace broken wires, a pile of previously burned or wrong resistors and aging electrolytic capacitors. I upgraded its specifications to 220uf 400v, and the copper foil is very fragile to make up for countless lines.
... Now the price is close to about $1,500 to buy a working device directly. But this is the first power amplifier I repaired, and I still hope it can be repaired smoothly.
I hope someone can reply to me. Thank you very much!
No pics no proof, right?
And there you have it folks - proof that it actually did exist at one time - the ORIGINAL SPARK-O-MATIC!
Found it while cleaning out the shop for the move. Now to salvage the transformers and heat sink, before the rest of it ends up at the electronics recycler.
Eico HF-81 8ohm with Philips 800 ohm speakers
Hello everyone
I got a pair of Philips 9710AM/01 800ohm speakers and when was about to connect it to my Eico Hf-81 I realized there is inconsistent impedance, since the Eico is 8 ohm
Does anyone knows if need a matching transformer, or if I could just connect the Philips to the 8 ohm terminal of the amp?
I already have a pair of those matching transformers but I’m not sure if it’s a safe idea to connect them
I’m attaching picture of the speakers and transformers, they are quite beefy
Thanks !
Manley Stingray with factory upgrades
I am selling my Stingray integrated amp for $3,300 shipping included in the lower 48 only. It comes with an additional set of Mullard output tubes. I had three options added from Manley:
1) Triode/Ultralinear output can now be chosen by a switch for each channel.
2) Sub out added for each channel.
3) Tape out added for each channel.
40~50 WPC utralinear, 23 WPC triode. Separate controls for each channel. weighs 30 lbs.
Original packing materials and Manley tubes included.
Also, ad can be seen in more detail at US Audio Mart.
HK670 Repair
I’m having a look at a HK670 from 2001 for my brother-in-law.
The symptom is intermittent cutting out of both channels. I’ve searched forums and can’t find a common fault, but have a few starting points.
Two of the caps are bulging and one of the resistors looks to have some corrosion in the leads, so they will be replaced first.
Curious though, I have got the service manual and there’s a marking I’ve never seen before for a cap in a circuit. What does “562M” mean?
Neve 18 Pin Connector Amphenol 133-018-21 143-018-01
Used on most Neve modules, consoles, and racks. 1063, 1064, 1066, 1073, 1078, 1079, 1083, 1084, 1085, 31099, 31102, 1105, 1271, 1272, 2254, and many other modules.
These connectors have accurate original style contacts for both female and male connectors resolving connection and signal loss issues experienced with other current production replacement connector options.
The connector contacts are gold plated and tested to 500V insulation between adjacent pins and pin contact resistance of 1 mOhm or less through mated connector pair.
Sold in sets of one male and one female connector but willing to split and sell separately in males or female
50 USD a pair plus shipping
First order series crossover with 8 ohm fullrange and 4 ohm woofer?
I have wanted to try a first-order series crossover for some time, and to this end I decided to build a FAST/WAW out of drivers and parts already at hand. I have a fullrange with a nominal 8 ohm rating and a woofer with a nominal 4 ohm rating that mate well in terms of SPL at my chosen crossover point, and I have coils and capacitors enough to make a series crossover. The woofer has a rising response in the bass so BSC will not be necessary, and I want to try the crossover without impedance compensation on either driver.
I'm having difficulty analyzing what happens in a first-order series crossover when using 4 ohm and 8 ohm drivers together. All the examples I have seen in my research have shown 8 ohm drivers only, and I'm trying to realize what would happen with the coil and capacitor when they shunt their respective drivers at different impedances. It seems that I should choose the coil value based on the four ohm woofer and the capacitor value based on the 8 ohm fullrange, but it also seems that the electrical crossover slopes would have wildly changed overlapped responses. My understanding is that a first-order series crossover compensates for changes in impedance values by shifting the crossover point slightly, but again that assumes drivers with the same impedance ratings.
I'm hoping that some experienced members can help to ease my confusion. Again, my goal is to build this speaker with parts I have in stock if possible. If it proves impractical to use these drivers with a series crossover I will buy the components to make a standard parallel crossover design.
transistor amp not working after shorting output
hi!!!! i am new here i am looking for answers !!!!
btw before year or two my grandpa was using his old amp and he missconnected speaker wires and amp was dead, i was testing it back then but i am not expert in amp circuits.
so i was not able to fix it back then,. and the amp was sitting dissasembled since then. now i want to fix it but i am not sure from where to start. it was amp made by someone, its not something made commercially , i cant find any info on it. but board for amp seems like it was from some old amp. so i remember when powering it, one of two 2n3055 transistors was getting hot and output was quiet. in the board of the amp there are two resistors that i think are also the problems but i dont know how to measure resistiors so i can find replacements. i dont know what value is used there. also i dont know how to measure other components. if someone is interested to help me on this case i can provide pictures of amplifier board.
Small PA radio system for Puppets
Hey!
I have a conundrum that I cant solve alone.. Thanks for any guidence anyone can give me on this.
I'll try and keep it simple. I have a puppet,
I want to hide a speaker inside the puppets head so the puppet can talk to passers by.
(I can fit a 15cm cube in the head (approximately) - theres some wiggle room for antennas to stick out of that space if needed. )
I need to also hide a mic on the puppet so the puppet controller can hear the passers by and reply to them from a distance.
The puppet controller has their hands full so they needs to be able to speak handsfree.
He needs to stand up to 200m away and may not always have a direct line of sight (So im ruling out bluetooth - have tested and its been crap).
We've tried sticking a small kids size walkie talkie in the puppets head.
the reception works fine except its no where near loud enough and the puppet controller has to wrangle the walkie plus puppet controls.
the passers by cant speak back via a walkietalkie set up so we tried the buetooth mic on the puppet/bluetooth earpiece and recieve on puppeteer but the signal failed us.
We've tried sticking a mobile phone in the puppet.
the recpetion died on us randomly - worked fine on the test!! - and on loud speaker it wasnt loud enough to be heard over 10 kids talking.
It worked great for the puppet controller as they could hear the kids talking to the puppet (when the signal was working) but replying to them didnt work.
We've tried sitting the puppet on a speaker discuised as a chair with a neck radio mic for the puppet controller.
the speaker sounded super mufflely and lower voice tones were not understandable. It was fine for the puppet controller, except our bluetooth mic dropped out again and they couldnt hear the kids. Also the speaker looks and sounds like a great big speaker and the sound isnt coming from the right place on the puppet.
Any advice on what I could try next?
I think radio is the most reliable, could do with it going two ways but having an open channel so no one needs to press any buttons.
Sorry i dont have all the technical lingo, hopefully this makes enough sense?
Thank you thank you!!!
Kind Regards,
Hollie J
SEAS EXOTIC F8 speaker build
There does not seem to be much information from builders using the SEAS Exotic F8 so here goes. Following on from my satisfaction with the Hemp FR8 reflex enclosure I made in March 2021 I wanted to build what I hoped would be an even higher quality one. I settled on the SEAS Exotic F8 for this.
I considered horn and reflex designs for this project but concluded that the closed box would be the best for the present location. The design is basically the 60L closed box in the SEAS data sheet but I altered the dimensions slightly to better suit my den (small room converted from garage).
I drew up the panel dimensions and routing for joints and got all parts cut by a firm specialising in routing sheet materials. The enclosure is 18mm Birch ply with double thickness front and back panels. The bracing is MDF. The reason to get the work done professionally was that the internal bracing has hundreds of holes. I estimated it would take a week working with hole-saw or router and producing huge amount of dust so it was an easy decision. Assembling the speaker then was a pleasant task which took a week to complete. I intended to make it permanently sealed by gluing all parts so I had to make a good estimation of the damping required. I had a lot of light polyester mesh which I judged to be suitable. I put a layer internally behind the cross braces and a layer round the drive unit part of the enclosure. There is some additional thickness from random pads. The enclosure was painted and the front panel varnished before joining the two together. The finish is the same as for the Hemp enclosure. These builds are not regarded as pieces of furniture and I don’t want them to be veneered. They are for use in my den so function is the aim. I am happy with the varnished fronts and the grey painted enclosure. The finish is perfectly acceptable and very easy to do.
The total cost of the speakers was £1650 in June 2021.
The sound was as expected initially very bright and forward and revealing of detail though thin at the lower range. They are very easy to adjust to your liking in situ as the tuning is done by components in the speaker leads. I added an inductor and resistor as SEAS suggest and then adjusted these values after careful positioning of the speakers in the room.
After months of listening I am very happy with them indeed. They are still a work in progress as I can tweak them. I have a few inductors and resistors wired up with switches to allow easy substitutions. I will also make some spiked stands to see the effect.
Reactions: Freedom666
Akita "AllInOne" Amp based on TPA325x PFFB+ and LLC PSU in one board.
Hi guys and girls (if any)))))
Many people know my amplifier, low price and good sound. I have a desire to improve it a little more by using high quality components such as OPA1656 opamp, Panasonic caps in power line , and Wima output caps.
Write all desires here.
100-265V AC
Size - 180x90, height ~50mm
My paypal - ledsscp7@gmail.com
group buy closed, the cost of a amplifier is $160 , delivery is 30, depending on the country.
Cardone - 1 + Case+++ Send
leszczu - 1 ++
multisync - 1 ++
vizeta - 1 + Case +++
Vunce - 1 ++ Send
mamocel - 1 ++Send
manniraj - 1 ++ Send
San4 - 1 + Case +++
ElliJ - 1
pinnocchio - 1 ++
audioillness - 1 + Case +++
routhun - 1 ++
Billy Graham - 1 + Case +++
al2813 - 1 + Case +++
Nerone -1 + case +++ SEND
Mission835 - 1 ++ Send
johoya - 1 ++
paproch - 1 ++
Jogi -2 ++
Ordered:
Case, connectors and pots
OPA1656
Ferrites for transfomers and inductors.
Litz wire
Elna Silmic II
All capacitors
Ordered PCB.
TPA3255 and another parts
MOSFET for PSU
Cheap but powerfull PA system!
Hello everyone,
I currently own a very cheap PA System : Devine brand triphonic system (Devine b118a mkii active subwoofer + 2 Devine Trono 12 heads)
In terms of value for money, it's excellent but I would like a more powerful system, with more impact (feel).
I considered purchasing an additional subwoofer, like The box TA18, but I don't think it's ultimately a good idea and I prefer to start with a blank page and a new project.
✅ Budget: 600€ (i already have amplifiers)
✅ Use: Indoors, party with friends, birthdays. Generally 50 people, let's say 100 to gain some margin
✅ Source : a Pioneer DDJ-RR controller, connected to a Behringer FBQ3102HD equalizer. I will buy an active filter.
▶️ What I had imagined:
  • Subwoofers:
(I already have an amplifier : T.Amp TSA1400 (1x1400w / 4ohms))
2 MTH30 with The.Box speaker 12-280-w (250€) or LF12G301 (400€)
  • Heads
(I already have an amplifier : Crown XPX900 ( 2 X 180W / 8ohms or 2 X 300W / 4ohms)
I hesitate between:
  • 2 DIY speakers based on 1 Fane 12-250TC (77€ each + wood and accessories = 100€ / speaker)
  • 2 used speakers (Yamaha S112IV or JBL FRX115, etc... ) (approxiamtively 200/250€ pair)
Looking forward to reading your reviews!
If you have any comments, suggestions, I am open! 🙏
For Sale (Balanced) Iron Pre Essentials Kit + a few components
Hi
I have too many projects and too little time, so I am selling my IP with a few suitable components.
Parts:
  • 16 x UFG1E221MPM (14,64€ - OBSOLET PART)
  • 2 x UHE1V471MHD& (1,88€)
  • 4 x 3296W-200LF (10,66€)
  • 4 x 3296W-1-472LF (10,66€)
All is unused and comes in the original packaging from the store or DigiKey (please see pic)
Cost all together (what is on the pic): 200€ + shipping
Shipping costs by arrangement.
For the time being only EU members (except UK, sorry to much customs paper work)
Links:
Thread: https://www.diyaudio.com/community/...e-register-your-interest.390509/#post-7128942
Store (Sold out): https://diyaudiostore.com/products/iron-pre?_pos=6&_sid=3d084349f&_ss=r
What would be the least damaging x-over frequency
If you could put the x-over at any frequency without concern for physical constraints, what would be the least damaging x-over frequency for a 2-way or 3-way speaker?
For example, many speakers cross the tweeter over around 2kHz (just an example- may not be correct) because it works best for the drivers even though the ears are most sensitive to anomalies at that range.
Another example, what would be the least damaging when crossing over a bass driver - 50Hz, 200Hz, or 400Hz?
Leak Stereo 70 question
Hi All,
First post. Hope everyone is well. I am about to start repairing my dads Leak 70 amplifier however he also had my late Uncles Stereo 70 which 'didn't work' - I got this first as a trial run to get familiar with the insides and the schematics, with no risk of any further damage to my dads when Is I start on it. My uncles one was deemed to be gubbed beyond repair, however I noticed very quickly there was no DC voltage getting to it, then noticed that there was no way it could since there was a small bracket thing mounted on the transformer body (3 pin) with a leg going to the transformer and the other leg going to the diodes. There was no connection between the two, so basically it would never work. This was not reflected on the schematic I had or most pictures I could find of the transformer which showed no such 'interruption' to the circuit.
I eventually found an image showing this part and an alternative schematic also showing it, a green part that looked a bit like a high wattage resistor but I assumed it was a thermal fuse. The transformer in my uncles amp had clearly been replaced (also had a date code sticker of the year of his passing) so I think that someone has replaced the transformer but not fitted the part in question. I linked the two pins and hey presto, amp working well and sounding great.
So the question is, what is this part ? Is it a thermal fuse ? If so was this just a bodge to get around UL standards that came out stating transformers had to have one (I think for northern US and Canada), the schematic I have which includes it perhaps refers to it as a Temperature compensation diode? If it is a Thermal fuse, I fail to see how it could ever get hot enough to pop given it is not in contact with the transformer windings (I believe the common way of incorporating these is in the windings. Picture of the missing part attached (the green part).
Many thanks!
Paravicini's Solid State Models "312" (Control Centre/Pre-Amplifier) + M100A Mono Power Amplifier - internal Images wanted
On the web there are no internal images to find.
Thank you for upload.
Some URL's:
https://www.enjoythemusic.com/magazine/equipment/0502/paravicini312.htm
https://www.technologyfactory.eu/en/ear/preamplifiers/ear-paravicini-312/a-3052-10000191
https://www.hifinews.com/content/paravicini-312-preamp-and-m100a-monoblocks
https://www.audio-markt.de/market/ear-yoshino-paravincini-m-100a-paravincini-312-374157086
https://www.stereophile.com/solidpoweramps/earyoshino_m100a_monoblock_power_amplifier/index.html
https://www.diyaudio.com/community/...former-coupled-single-ended-amplifier.391567/ (#3-5)
https://www.diyaudio.com/community/threads/o-h-schade-1938-meets-mosfet.144105/ (#20)
under
https://de.scribd.com/document/7199624/Paravicini-312-Control-Centre-Large-Memory
there is to read this:
The Paravicini 312 Control Centre
For over 20 years, Tim de Paravicini’s EAR brand name has been associated with valve amplifiers of legendary quality and reliability. Classics such as the 500-series power amplifiers, the 802 preamp, and more recently the V20 integrated and the 800-series ‘Enhanced Triode Mode’ models are among the most prestigious hi-fi products ever made and have attracted praise and awards the world over.
Although Tim de Paravicini has been designing transistor-based circuits since the days of the very first commercial transistors, he has never before produced a solid-state amplifier under his own flag. But now, after years of breaking with everyone else’s traditions, he has broken with his own and produced the 312 Control Centre, a fully-featured preamp which redefines the world of solid-state just as EAR amplifiers have done for the world of valves.
Taking into account the current growth in the number of sources in many hi-fi systems, the 312 offers no less than eight inputs, three of which are balanced and transformer-coupled. What’s more, there are six outputs: three each balanced and unbalanced, and because they are also transformer- coupled it is perfectly possible to use both types simultaneously (for instance in multi-amped systems) without upsetting the balanced outputs. This means that six stereo power amplifiers can be driven at once.
As you would expect from an EAR product, the phono input also features transformer coupling for moving coil cartridges, ensuring the lowest possible noise, and in order to ensure very high overload headroom and complete stability the RIAA equalization of the phono stage uses an inductor in a unique EAR circuit configuration.
The basic amplifying circuit uses just three transistors in a single-ended configuration, a ‘valve-like’ approach that harnesses the gain of the transistors in such a way as to give sound of unequalled sweetness and clarity. Complete compatibility with other equipment is achieved through the very high input and output headroom of all circuits, plus their low noise.
Again drawing on de Paravicini’s expertise in the field of transformers and inductors, the power supply uses a choke input filter to give very low noise and ripple, and very low dependency on the purity of the incoming electricity supply: it also generates very low levels of interference on the household supply without requiring any additional suppression components.
Simple and intuitive operation has always been a feature of EAR products, and to this end the 312 uses a very high quality and high accuracy volume control with a conventional single-turn range, in conjunction with a unique meter-like scale which clearly indicates circuit gain. Channel balance is maintained to close tolerances right down to whisper-quiet levels.
Finally, it should be hardly necessary to mention that like all EAR products the 312 is built to the highest standards and immaculately finished so that it
looks as good as it sounds. It will set standards for a long time to come.
Bamberg Audio Closing
I received the below email today. I still own, still love, the S5-MTM standmounts I purchased in 2005. They have been in daily use ever since. They sound amazing!
Bamberg Audio, "Speakers For Life", indeed. Thanks for everything, Phil, best of luck in your retirement:
Hello all,
I have decided to retire my efforts with Bamberg speakers. Thank you to everyone who has purchased any of my designs, and for the support and positive feedback you provided me with over the years.
To this end, I have just three sets of speakers left in stock, and they are listed on the Sale Page.
The website will end on April 30, 2024. But you may reach me directly at pebamberg@gmail.com.
With respect and appreciation,
Philip Bamberg
ADKq_NYdvmidox3Tcz_tY9II2e3S-FGnb-0-GQeY3w9S8ePZmWxzcFdrJd3e6gN_ZpT-cttFYlntrR6VtahTsc_SZFN-cEAk32sTUARL3NaTBFfVBVY8NySAcJoUmbwrePEPRkYw8n8qTKBnb0FXMnK8EGFIO9vFlI3VMIE=s0-d-e1-ft
http://BambergAudio.com
Bamberg Audio on Facebook
Sale page
Reactions: Pallas and bwaslo
5" Intermodulation Distortion Testing
Another IMD (Intermodulation Distortion) test. The first in the 5" driver size. I will be comparing the Sb Acoustics SB15CRC30-4 with the Wavecor SW146WA01, these measurements have been made under the same conditions as my other tests done in 14 liters such as the slighter larger 6-7" tests https://www.diyaudio.com/community/...ootout-purifi-anarchy-plus-maybe-more.371979/
The Sb Acoustics SB15CRC surprised me with how crystal clear the midrange is, this showed up in measurements and in listening tests. The Sb had one of the cleanest three tone tests at 800 hz of 20 drivers (only surpassed by a 8" Purifi, but out performing a Magico midrange). With music, I noted in songs that had duets that you could pick out the singers individually as opposed to a kind of a combined vocal that comes out of most drivers.
The Wavecor SW146 also did very well in some of the tests especially the 60 and 144hz bass IMD test. The Wavecor has a low loss suspension and will give a good punch to a kick drum. However, having tested the very slightly larger SW182 (see size comparison in attached photo) I do prefer that one for cleaner deep bass output.
Testing conditions are as follows: The test enclosure is a .5 cu ft (14 liter) sealed box with the bottom lip of the speaker just 2 inches above the floor. The microphone is on a stand 49"high with the base of the microphone 33" from the driver. A distance of about 1.5m from the speaker to the microphone. As I'm not measuring in an anechoic chamber my measurements are not comparable to anyone else's but comparisons can be made between the drivers I test.
For information about how to read the graphs see here: https://www.facebook.com/.../posts/1938870303135464/...
As always, I'm open to feedback and driver testing suggestions.
Fan inside audio chassis: variable speed, temperature controlled, analog - No PWM
Many diyAudio projects generate significant amounts of heat, particularly the ones which operate in Class A. Builders work very hard to get rid of this heat, most often by using the largest heatsinks they can find. However, this approach only cools the exterior of the chassis; the air within the box is usually not cooled by active means. Builders simply select a chassis with ventilation holes, and hope the arrangement will be adequate.
On the other hand, there are many DIYers who believe: why build it safe when you can instead build it extra safe? "More cooler is more better"; you can never have too much heat removal.
I decided it would be a fun project to create an active cooling fan for the interior of an audio chassis. A sensor (NTC thermistor) measures the temperature of the air inside the box, and this continuously varies the speed of a DC fan. When the interior air is very hot, the fan spins at its maximum speed, cooling the interior as much as possible. On the other hand, when the interior air is quite cool, the fan spins at its minimum speed, since no cooling is needed. At in-between temperatures, fan speed smoothly varies from slowest to fastest. It's a continuous, analog, quantity.
Since fans also create unwanted acoustic noise, this scheme keeps the fan as quiet as possible while still doing its necessary job. When the interior air is cold there is no need for cooling and no need for fan noise; this circuit slows down the fan to minimum speed. When the interior air is hot, the fan speeds up and makes more noise, while preventing the electronics inside from damage due to overheating. It's only loud when it's preventing disaster.
A fan control circuit using a 24V DC power supply seemed like a reasonable choice. 24 volts is a good match to quite a number of Class A amplifier projects here on diyAudio, which all run on ~ 24V supplies, including several First Watt designs such as ACA, F5, Aleph J, M2, etc. The 24V DC fans themselves are plentiful and cheap: not only does Mouser carry them, so do DigiKey, AliExpress, eBay, and Amazon. You can use a "2 wire" or a "3 wire" or a "4 wire" fan with this all-analog circuit. It only connects to two of the fan wires: red and black. All other fan wires are left unconnected and floating.
For experimental purposes, I bought three 24V DC fans from Mouser.com, shown in Figure 1 below. Connecting them to a lab power supply, I measured the minimum voltage required to guarantee each fan would start spinning from a dead stop. Below that voltage, a stationary fan "stalls", and fails to begin spinning:
  • 40mm fan: starts reliably at VCC >= 6.3V
  • 60mm fan: starts reliably at VCC >= 8.1V
  • 92mm fan: starts reliably at VCC >= 7.9V
Thus it seems that many 24V fans will be happy as long as the analog control circuit never gives them less than 8.1V (34% of their 24V nominal supply). I decided to add a little margin-of-safety and so I set the Vmin to 37% of the supply. If you hate this decision you can redesign as discussed below (zener diode section).
My answer to the question "How Hot Is Too Hot" is shown in Figure 2. This is the design target I chose, shown in red. I've tried to make an analog fan controller circuit which actually implements the red curve in Fig 2, as closely as possible
The fan voltage hits 100% when the thermistor reaches 45 degrees C. In my circuit design the fan voltage cannot exceed 100% of the supply, so further increases in temperature do not cause further increases in fan voltage. This is shown by the dotted blue horizontal line at top right.
At about 30 degrees C the fan voltage has fallen to 37% of the supply voltage. Then a zener diode in the circuit prevents it from falling any further, so the fan voltage remains at 37% even when the temperature falls well below 30C. The horizontal blue line at bottom left shows this effect. The zener diode's spec is (100-37 = 63%) of 24V, namely, 15.1V. Buy a 1N5929B and be happy.
If you remember algebra from school, you know there are several ways to define the red straight line on Figure 2. I choose to define it this way:
  • The line MUST pass through the Anchor Point at (39 degrees C, 75% fan voltage)
  • The slope of the line is 4.2% per degree C
Other designers might choose other ways to define the red line, and that's okay with me. This is just the definition I happen to prefer.
For the temperature sensor, I chose an NTC thermistor made by Vishay. Mouser.com has tens of thousands of these in stock, even in Portugal and Finland. It is Vishay part number NTCLE100E3104JB0 . Resistance at 25C is 100 Kohms, a relatively high resistance, chosen to reduce self-heating. Vishay's datasheet presents the (nonlinear) equation of the thermistor's (nonlinear) resistance vs temperature response. Here is a summary:
Code:
   Temp  R_thmstr        Temp  R_thmstr
    19    132200          40     51750
    20    126100          41     49610
    21    120300          42     47580
    22    114800          43     45640
    23    109600          44     43790
    24    104700          45     42020
    25    100000          46     40330
    26     95540          47     38720
    27     91310          48     37180
    28     87280          49     35710
    29     83450          50     34310
    30     79810          51     32960
    31     76340          52     31680
    32     73050          53     30450
    33     69910          54     29280
    34     66920          55     28160
    35     64080          56     27080
    36     61370          57     26050
    37     58790          58     25070
    38     56330          59     24130
    39     53980          60     23220
A circuit schematic is presented in Figure 3. The thermistor and resistor R2 form a voltage divider at node BBB. When the temperature goes up, thermistor resistance goes down {it has a NEGATIVE temperature coefficient}, and so the voltage at BBB goes up. The rest of the circuit amplifies and offsets this temperature dependent voltage, then applies it to the fan. When temperature goes up, fan voltage goes up, and so do fan speed and airflow.
The fan is driven by a P-channel MOSFET called "U1". This allows the circuit to apply all 24 volts of supply across the fan when it's really hot, without any voltage loss due to VCEsat or emitter/source follower drops. Capacitor C1 filters the fan voltage and absorbs any "spikes" that may occur as the fan motor rotates. I selected a special electrolytic capacitor rated for more than 1 ampere of ripple current (Panasonic EEU-FS1V331LB), yet it's in a modest 8mm diameter package. C1 also provides frequency compensation for the negative feedback control loop as a whole.
Adjusting the trimpot R3: let's hit the Anchor Point!
The goal in setting R3 is to make sure the temperature versus voltage curve does in fact pass through the Anchor Point: (39 deg C && 75% of VCC). See Figure 2. To get 39C, a resistor is needed whose value is 53.98 Kohms according to the table above. However instead of 53.98 Kohms, I found very it convenient to simply connect two 27K 1% resistors in series. 54.0K, close enough.
Then I temporarily remove the thermistor, terminal block screw connectors make this easy. I replace it with my 54.0K fixed resistor. To adjust the fan controller's R3 for actual field use, connect the circuit board (and the fan itself!) to the internal 24V power supply network of the audio equipment to be cooled. The adjustment can be performed with the chassis open and its top plate & bottom plate removed, we're not measuring stagnant air temperature just yet.
MEASURE the supply voltage inside the audio gear. It's probably a little bit above or below 24.00 volts. Then switch the voltmeter probes to measure the voltage directly across the fan, and dial R3 up and down. Stop dialling when the fan voltage is exactly 75% of the supply. Done! R3 is now set to the correct value for *this* power supply voltage, and for the device parameters of *this* particular Pchannel MOSFET, on *this* specific fan controller board. Yes, Virginia, two MOSFETS of the same part number really CAN have threshold voltages that differ by two thousand millivolts, just as the datasheets warn. Replace the fixed 54K resistor by the thermistor and its umbilical cable, job done.
A word of caution: this circuit contains so few parts, that each individual part has an effect upon several different aspects of circuit behavior. In other words, everything interacts. Strongly. When designing or redesigning a circuit like this one, it takes a lot of tweaking and adjusting and juggling to get the circuit to work well. Fortunately for you, I have already performed this miserable job; it took me about a half a day to get it completely dialled in. The schematic in Figure 3 works nicely ... but only for THIS supply voltage (24V), and only for THIS choice of thermistor, and it only implements one specific design target curve of Temperature-versus-FanVoltage (shown in Figure 2).
If you want to modify the circuit to operate at a very different supply voltage, or to use a different thermistor, or to hit a different design target T-vs-F curve ... then you will need to tweak and adjust and iterate and juggle component values, to get your new circuit working and meeting your new specifications. It will take effort. Do I know of any time saving procedure(s) for this? Not really; all I can suggest is to thoroughly explore and experiment and keep good notes. And don't forget to have fun!
Fortunately, if all you want to do is change the supply voltage a little bit (for example: use this analog fan controller inside an Aleph J which runs on a 22V power supply instead of 24V), and if you leave all other design goals alone, then you will only need to adjust R3 using the procedure above. Just hit the Anchor Point. I haven't personally tested every single possibility but I do think a simple R3 adjustment is probably all you need, if you keep the power supply voltage within plus or minus 15% of the design value, 24V. That is, (20.4V <= VCC <= 27.6V) only requires a simple twist of R3 to make it work. If you go outside this range, adjusting R3 might be all you need to do, but honestly I would be a little surprised.
To test out the circuit, I bought some fixed resistors in the range (40K < Rfixed < 80K) and labeled each one with its corresponding Thermistor temperature from the table above. This let me measure the data shown in Figure 4. Eyeballing Fig 4 and Fig 2, it seems to me this design hits the target reasonably well.
I built the circuit on "Stripboard" sometimes called "Veroboard"; Figure 5 shows a photo. The MOSFET's heatsink is from Tayda, 17mm x 17mm x 25mm, to give me the option of connecting a really high current, high power, high airflow fan ... someday, if I feel like it. The puny little fans in Figure 1 don't actually need an aggressively heatsinked power transistor to drive them. VeeCad cuts-and-jumps CAD drawings of the Stripboard are shown in Figures 6 and 7.
Finally, I suppose I owe readers an answer to the question "Why on earth build this as an analog circuit?" After all there already are LOTS of temperature controlled fan PCBs for sale on eBay and AliExpress and Amazon, at super cheap prices. There are also four hundred budjillion Arduino projects to make a temperature controlled fan.
It's true. There are. Unfortunately, all of these use PWM (pulse width modulation) which commutates the fan between 100% ON and 100% OFF, using digital circuitry. The relatively high-current, relatively fast-risetime digital pulses driving the fan, can couple into other nondigital circuits, creating electromagnetic noise which corrupts low level music signals. Indeed many diyAudio members refuse to include any digital circuitry of any kind, inside their all-analog audio equipment. For them a PWM fan controller is utterly forbidden, therefore an all-analog solution is required. Additionally, some fan manufacturers explicitly state that PWM control of their fans results in greater acoustic noise than analog control, at certain speed settings. Who wants a noisier fan? Nobody.
I should mention that Microchip sells a wonderful family of embarrassingly simplistic non-PWM chips, called MC620/MC621. These implement a bang-bang control system for thermal control of a DC fan, exactly like the HVAC heating and cooling system in office buildings. It's digital, but not PWM. Also, Maxim makes the MAX31740 chip which is a full featured, ultra simple, thermal fan controller using PWM. If you don't hate PWM, check it out. If you are both ambitions and a little masochistic, you could figure out a way to do it with a pair of NE555 timer ICs. Those chips were literally made for PWM.
If you despise PWM, but for some reason don't like the 3 transistor discrete circuit in this message, you could consider designing yourself a new circuit using opamp chips. It's an ambitious project but diyAudio members are brave souls. You'll want ICs that work on 24V supplies, such as LM324 or OP07 or even uA741. Oh and you'll need to pay careful attention to frequency compensation / instability / unwanted oscillation, since opamps have lots of gain while common source power transistors have lots of phase shift. Especially when you decide to keep the deluxe 330uF smoother outer capacitor! You win extra bragging rights if your design does not require or use "single supply" opamps, "rail to rail" opamps, or "over the top" opamps. When you're all done be sure to compare the parts list of your opamp design, against the parts list of this discrete design. I bet you'll find that both need a fan-driving transistor, so the difference becomes (opamps + resistors) versus (two NPNs + resistors). Which is cheaper? However perhaps a circuit with opamps can eliminate the trimmer pot, whose cost is surprisingly high for its mundane function. Have some fun with it!!
_
  • Thermal_Fan_24V_schema_in_LTSPICE.asc
Stealing the output from a DAC chip (Topping D30 CS4398)
I have a DAC that sounds very good to me, it's the Topping D30. The chip is the CS4398, a chip that I have listened to in several implementations and always found it very musical.
I would like to try to improve the output stage. I have several ideas in mind (transformers or tubes). As a first step I should steal the analog signal at the output of the chip. Below in photo I show the PCB. The red arrows indicate the points connected to the positive/negative output pins of the two channels.
What do you think is the best way to get the signal? Try soldering the wires to the pins directly? Or act on the four holes indicated by the arrows? In the latter case I guess it is easier, but I don't know how to remove the blue layer covering the conductor. I would be very happy if someone could point me to the right technique.
Aiwa AA8700 bias adjustment
Hi, I have a problem with adjusting bias on my Aiwa AA8700 amplifier,
Service manual says that you should connect a probe to TP6 ( it is on emitter of Q8) and reach 23mV turning SFR2 potentiometer. The value of that pot. is 100R.
Actually, after warming up, I have like 66mV and turning SFR2 gives nothing ( maybe +- 1mV).
This is on the right channel. On the left channel which is the same I have like only 1mV and also turning a potentiometer has no reaction.
I thought that maybe the pot is broken so i replaced them but no change.
Maybe I should put a bigger value potentiometer ?
This pot is between transistors Q4=2SB648A and Q5=2SD668A maybe they should be replaced but for what ?
There’s also diode D6=STV-4H acting as temperature sensor ( it is attached to heat sink) the diode looks ok, passes the diode test but now that diode can be replaced by a transistor e.g. BC550 + 3K3 and 1k resistors.
What do you guys think I should do ?
Headphone amp for QUAD 405 amp
Hello
Back in the 70s when the Quad 405 power amp was designed, it seems that little boxes were available that amplified the 405 speaker signal output for a headphone output. The box has a switch that either feeds the speaker signal to the headphones or continues the signal to the speakers. The 405 manual has a simple schematic that shows a provisional design.
I thought I would find such a box very easily .. but I have not. Would anyone have an idea where I can find such a thing, preferably as a kit? I am not an audiophile, so I don't need anything very sophisticated.
Many thanks
Audio System in a gym
Hello everyone, I have been asked to recommend suitable loudspeakers for a sound system for a calisthenics room in a gym.
The room is not very large but has quite considerable reverberation.
The amplifier is already present and is a Pioneer (I don't know the model, it is very similar to the a10ae) designed for a home hi-fi system, bi-zone.
As the customer doesn't want to spend a lot, I'd like to know what speakers I could buy to complete the system, he'd like 4 speakers, I have to use the bi-zone so I assume the speakers would need to be 8 ohm. What would you recommend?
USB transport I2S 32bit/384kHz, DSD512, multichannel Out 4xI2S, stereo In I2s, surround up to 16-channels (TDM mode)
There are two of them. They're called Reflex 2.0 & Reflex 3.0
  • Playback of PCM format with a maximum sampling frequency of 762 kHz 32 bit, DSD512 native or DSD256 DoP playback.
  • Playback of S/PDIF - 384kHz
  • Plays multi-channel Surround audio in PCM format.
  • Recording stereo sound with studio quality with a maximum sampling frequency of 762 kHz 32 bit
  • Two I2C ports for controlling external DACs and ADCs
  • Two SPI ports for controlling external DACs and ADCs
  • Addressable LED (Neopixel) control port
  • Thirty two GPIO pins for connecting external controls and indications (potentiometers, buttons, switches, LEDs, encoders)
  • Programmable using ChipStudio, SigmaStudio, PurePathStudio software
  • Hardware adjustments
  • Free change of USB Vid/Pid
  • ASIO drivers from any third-party manufacturers
Sync Modes:
  • Master with internal sync
  • Master with external sync
  • Slave
Possible audio output channel configurations
Configuration
Surround audio
PCM, kHzDSD256
DoP
DSD512
native
44,1
48,0
88,2
96,0
176,4
192,0
352,8
384,0
705,6
768,0
Until
11 289,6
Until
22 579,2
2.0​
3.1​
4.0​
5.1​
7.1​
12 channels​
16 channels​
Ask me!
Oleg
ChipDipDAC
KiCad projects:
Reflex2.0
Reflex3.0
Chip Studio v0.99.5 (19/03/2024)
ChipUpdater_v1.2
firmware Reflex_2.0_v2.4
firmware Reflex_3.0_v2.4
Reactions: tschrama
For Sale Klein Hummel Telewatt VS56 tube amplifier
For sale is the legendary Klein + Hummel Telewatt VS56 tube integrated amplifier, first model.
Great tube amplifier that is in original condition with all new tubes (4x ECL82, 5x ECC808). They are all measured on RoeTest V10.
Unfortunatelly, I do not have enough room for all this equipment, so it is for sale.
Specs and info:
http://www.tube-classics.de/TC/GermanTubeHifi/Integamps/K+H VS56/VS56.htm
https://www.radiomuseum.org/r/klein_telewatt_vs_56_vs56.html
Price 650€.
For Sale Gold Note PH-5 phono section
Hi to all,
I have this great phono section for sale. It is NEW, only used for about 15 hours ...
I purchased it to compare it to my DIY tube phono sections to hear the difference because this phono is something that all say is the best buy in the price range of 1000€ and I couldn't agree more. A lot of features, MC and MM section, touch screen, load and gain adjustment 'on-the-fly'. Great value for money.
Link to site:
https://www.goldnote.it/phono-stages/ph-5/
Reviews:
https://www.analogplanet.com/content/gold-note-ph-5-phono-preamp
https://hifiplus.com/articles/gold-note-ph-5-phono-stage/
https://hifiknights.com/reviews/gold-note-ph-5/
I have everything original including package, manual ... just like from the store.
Price: 650€
First HiFi Tube amp
Hello everyone 🙂
I only have guitar amp experience so hifi its the first time, i made a schematic and i'm gonna need help to confirm it if possible:
The first part (The preamp) is an existant project from "diyaudioprojects.com" so this one is ok but i'm not sure about the phase inverter do you see an issu there ?
There is also no feedback do you think i need one and where should it be, around R7 (like in guitar amps) or maybe R4 ?
I made also the first version of the power supply, well its a bit exotic 😆
Thank you for your help
Alexis
A big rock tumbler for aluminum surface finishing?
I'm thinking of getting this big rock tumbler to use in surface finishing aluminum front panels, heatsinks, etc. Prior to anodizing them all at home. I've tried sanding, buffing, lapping on glass, random orbital vs rotary sanding, etc. all sorts of ways, I get good results but not "repeatable" results from piece to piece, especially if I'm progressing through six to eight different grits of sandpaper. I thought well maybe I should get a glass bead blasting cabinet, but thats still a manual operation, and I dont have much room left in the garage. And also its a skill I'd need to learn and you need a very high CFM air compressor for one of those. I certainly dont have room for a large floor standing air compressor. I also looked at vibratory tumblers, but they are expensive and usually use a bowl with a rod down the middle which would mean I cant do long plate stock. The largest ones run close to $2,000
Then I thought I had a brilliant idea (those usually fail me)... Maybe I can find a large sized rock tumbler to do a "set it and forget it" tumble of my aluminum parts so that all the parts of an amp have precisely the same surface finish. The largest size panels I plan on doing would be 12 inches by maybe 9 inches, because that fits nicely in my mini CNC machine. Heatsinks, there are a few I like from heatsinkusa, the 6 inch wide and 4.5 inch wide ones usually cut to 3 inch length. So those are my largest part sizes.
Well, I found this large rock tumbler model which is widely used in the commercial rock tumbling world, it has a 15 inch by 15 inch drum to hold any sort of tumbling media I could think of and also hold the largest parts I'll be making... (link below). It sells for about $850 bucks everywhere and I can drive to pick it up. I'm figuring I could machine all my parts and heatsinks, then simply tumble them for a set number of days, hoping they will emerge from the magical drum with consistently the same and beautiful surface finishes. It's even water tight so I can tumble with wet media, try out different media, walnut shells, ceramic media, 2mm stainless beat shot, plastic abrasive media, corn kernals, etc. Then I'll anodize them (which I am already set up for in the garage).
What do you guys think? Will this work?
https://kingsleynorth.com/65t-heavy-duty-commercial-tumbler.html
For Sale Used Black Gate standard polarized capacitors
ALL SOLD
Genuine Black Gate standard polarized capacitors, all purchased by me from Parts Connexion when they still had stock. Revered by many, reviled by some, my experience with them is that they DO sound better than any modern cap. The leads are short, just long enough to reach through a pcb with matching lead spacing. None of these saw high voltage or excessive heat, used for DC blocking in CD players.
Two large caps shown are 220uF 50v. They measure 209 and 220uF. Lead space is 7.5mm. $10 ea
Four medium caps are 47uF 50v. They measure 40, 42 ,42, and 41uF. Lead space is 5mm. $8 ea
Two smallest caps shown are sold.
Not shown are two brand new caps with full leads, 220uF 4v. They both measure 180uF. Lead space is 2.5 or 3mm. $6 ea
These have been in storage for a while, and I don't anticipate ever using them, so I would like to see some other audiophile enjoy them. I would prefer to sell the entire batch to one person for $50 total, but I could be persuaded to break them up. Add $6 for shipment of any quantity, to USA only.
TI DACx1001 discussion - I2S input, Vref etc
Im planning to build a DAC11001B based DAC and will share any progress here inc. measurements, aiming for uncompromised measured performance from the chips.
First, I wanted to see if the suggested 24bit RJ glue logic for DAC11001 could be adapted to work with a normal I2S input.
After a read of the datasheet, I attempted to simulate it (the first frame of the sim has an error):
The DACx1001 wants the audio data left justified to the 23rd bit and an 8 bit shift register will shift the I2S MSB accordingly, sound about right?
Something I'm trying to understand is why the main shift register has 2 inputs held high instead of one.
I think it could be to have a longer LDAC pulse so that the LDAC minimum low time (20ns) is satisfied even at the highest clock rates,
however the shift register output also drives the XOR and it causes the audio data MSB to be inverted.
This couldnt be right, so I figured instead the shift register output may be delayed by 1 bit because of some hidden issue in the sim.
If this proposed delay is corrected the input data will no longer be effected, but this changes the register address from DAC-DATA (01h) to DAC-CLEAR-DATA (03h) and this doesn't seem right either:
Can anyone clarify this?
Few other small things I managed to figure out about the glue logic circuit that may not be obvious to everyone:
DAC will be sensitive to BCLK jitter, as the LDAC pulse is clocked out of shift register by BCLK.
The circuit should be directly compatible with the 18 and 16 bit versions of the chip.
  • Locked
For Sale TD-124 Turntable (The original series not MKII)
I am selling vinyl related hardware, first up is my old TD-124.
This is what I would refer to as an unrestored but heavily refurbished TD-124. Short of the chassis and motor everything else had to acquired to restore it to running order. Most components are original Thorens, there are some significant improvements.
*The slip platter brake needs pads and to be adjusted to be functional. It does not have the 45rpm integrated adaptor. *
This table has its original E50 which I serviced more than a decade ago (and have lubricated periodically). Note that the eddy current brake is adjusted for 120V+ AC mains, and that reduced voltage (110V - 115V) will allow you to ease off on the eddy current brake which results in quieter running.
It has Hanze HI-Fi motor suspension springs, and the an Audio-Silente idler.
It has the more desirable Thorens OEM cast iron platter. It is equipped with a Gem Dandy Cork & rubber mat.
Short mp4 files of it running are attached.
The wiring to the switch and neon lamp has been replaced.
It comes with a plywood plinth mass loaded with roughly 10lbs of lead shot capped off with epoxy. It also comes with multiple arm boards including 2 that are suitable for use with Jelco 12 inch arms like the 750, 850, and 950...
The TD-124 is PICK UP ONLY, and I will accept cash, PayPal Friends & Family, bank transfer, and certified checks in the amount of $850. I am located just a couple of miles south of Boston, MA. I will NOT ship this item. The price isn't negotiable and I am not interested in trades as I am trying to reduce my collection of misfit toys. 😀
Reactions: dBel84
Help with Fostex’s Newer FE103NV2 Thiele/Small Parameters
Good afternoon everyone. So this is the second set of drivers in this series that Fostex doesn’t really give a lot of info on the Thiele / Small perimeters for this driver. Am missing the following information?
1. Sd
2. RMS
3. Z
4. No %
5. RE
6. XMAX
So what can I buy to get this missing info I need? Here’s a picture from Fostex’s website. Thanks Jeff
My first passive crossover design!
I recently made a post trying to get some information on how to design a crossover as I had previously no knowledge on how to and wanted to renovate some speaker cabinets and remake a crossover to do this. To inform my design I used frequency and impedance graphs from the manufacturers. I know this doesn't deliver the best results as the boxes used for these tests aren't the same as the one that I'll be using for my speakers. Nonetheless I decided to use them as I don't have the equipment to make my own graphs. Here are the data sheets for the drivers that I used; Bass driver: https://www.farnell.com/datasheets/2623802.pdf , Horn driver: https://www.parts-express.com/pedocs/specs/290-5634--eminence-f110m-8-spec-sheet.pdf and tweeters: https://doc.soundimports.nl/pdf/brands/GRS/DTM-8/DTM-8 Specifications.pdf. Here is the resulting circuit
And the resulting graphs from this
I can tell from the frequency graph that the tweeters aren't doing a lot, now I'm not sure if this is from how I've tried to link them in parallel or how my attempt at a Zobel network has affected the level of these drivers. Or whether it is a good idea to have them connected at all or if I should just use the horn and bass drivers to make the speakers. Any advice on how I can better improve this design or use this design to inform another design would be greatly appreciated!
3-way crossover help
Hello all!
I'm designing a 3-way as a spare time project, in a WMTM alignment. The baffle is 30cm wide, 45cm high and the drivers I have at hand are:
Peerless 830868: https://www.samodelka.ru/pictures/peerless/peerless_830868.pdf
VIfa TC9FD: https://doc.soundimports.nl/pdf/brands/Peerless by Tymphany/TC9FD18-08/TC9FD18-08.pdf
Seas 27TFFNC/CG: https://www.costruireaudio.com/PDF/SEAS/h1406_27tffnc_cg_datasheet.pdf
Made a mock-up baffle (open-backed, so disregard everything under 400Hz or so). and attached the drivers to it. I plan to surface mount the drivers and made a similar roundover to baffle edges as the finished enclosure will have. Made some measurements with UMIK outside, so there's a bit of ambient noise form neighbors and birds etc. Also measured the impedances with DATS. The mids are measured separately. The measurements are at 1m distance, at 0, 22 and 45 degrees, at tweeter height. The height from ground is 190cm on tweeter level. For anyone wanting to lend a hand, they are at this onedrive folder: https://1drv.ms/f/s!AoJmX0yPPNWy6QfpAWANbmA_d65c?e=gFeOVe
Designed for a bit in VituixCAD, and this is the best result I got so far. The phases are quite nicely aligned, the only problem I currently see is that the impedance dips quite low in the 10kHz region, around 2Ohm. The reference angle response is a bit hot but realistically they would be listened to around 10-20degree angle anyway. It's been a few years since my last speaker design/build, and I am rusty as hell. Life tends to get in way of hobbies sometimes 🙂
Would really appreciate if you have any tips and points on perfecting the crossover. Thanks in advance!
EDIT: Updated the onedrive along with VituixCAD sim for 2 mids, measured separately.
For Sale UGS - Muse Edition Bare boards
I'm offering a full set of bare boards to build a UGS Muse preamp, including Sala's shunt regulator and power supply , the power supply board is partly assembled. If you are interested please contact me.
1 x UC Board v1.2 / 1 x Left Preamp v1.2 / 1 x Right Preamp v1.2 / 1 x Left Rear v0.0 / 1 x Right Rear v0.0
1 x logic power v0.0 / 1 x trigger amplifier / 1 x trigger inputs / 1 x subwoofer board
2 x UGS Modules v3 / 2 x Buffer Modules / 2 x Encoder Boards / 2 x Salas Shunt Power Supply v1.0
1x External Power Supply v1.0 , including 24 Omron G6S-2 5Vdc Relays
Selling all Boards for 130€ + shipping
The prices do not include PayPal and shipping costs. Shipping from Germany. PayPal is accepted, the buyer pays the additional 5% PayPal fees. Or Payment as Friend than the shipping costs for the EU are 12€ as standard ( PayPal friend) or 23€ by registered mail up to 100gr. Outside the EU it may vary by country. If you are interested send me a PM.
Tube Amp Buzzing Noise Varying with Volume and Changes Channels
Hoping to get some help from the tube experts here, let me preface this with I am a very new to electrical engineering and DIY audio (as in built a bottlehead crack and that's about it) so apologies for likely some incorrect terminology use. I purchased a unique tube headphone amplifier off Facebook Marketplace and I'm having an issue with it I was hoping to get some help in diagnosing.
The headphone amplifier sounds great, but I get a fairly loud buzzing sound when using it that has an interesting behavior:
  • At no-low volume on the potentiometer: the buzz is only audible in the right channel and decreases (as far as I can hear linearly) as the potentiometer increases, until the potentiometer rotates 90 degrees and the buzzing is minimized.
  • After a 90 degree rotation: the buzzing increases with the potentiometer linearly but only in the left channel for another 90 degrees
  • After 180 degrees of rotation: the buzzing appears in both channels again for the rest of the range.
Currently I'm using it in that "sweet spot" at 90 degrees on the potentiometer where there is very little buzz in total and it sounds great, but I'm curious to know if there's a way to fix the buzz at other volumes.
Does anyone know what could be causing this or how to fix it?
Things I've tried so far:
  • Reflowing solder joints, doesn't appear to have any cold joints
  • Used multiple different sets of input/power chords and other sources, tried multiple locations in the house and the behavior is consistent
  • Deoxit D5 on the potentiometer
Some information on the build:
This is built on a TubeCAD 9 pin PCB. The PSU is a VR tube and MOSFET combo. Here's the link I was given:
https://www.tubecad.com/2004/blog00...u8wgPO2ZcM6vOlPV-NQ2fQYt7SuRA4jdCYCnbFCbnPeDZ
PSU Circuit, it's powered by a 0D3 VR tube:
https://wtfamps.com/2017/10/19/simp...FYeK7JORvnn-nHKWg0iEk86TQh4dtnkgPZc528sRnypMh
Do I need to roll all OpAmps in my stack?
Tl;dr - Do I have to roll/upgrade all my gear for best results, or just my preamp? I'm assuming I do.
I have an FX-Audio Tube03 that I have been hot-rodding. It has been upgraded with Riverstone 5654 tubes, and has been rolled to Muses02 OpAmps and I have Wima caps.
Since then I have added an FX DAC-X6 MkII (upstream of the tube pre, obviously) and an Aiyima 07 for the amplifier (I used to have the FX gear hooked up to an old receiver).
So am I now wasting (or at least significantly losing) the benefits of the upgrades in the tube pre if the DAC and amp are running inferior chips? Do I need to roll both of those, or at least the amp for full benefits?
3 way active floorstanding speaker - dad's birthday
Hey everyone,
This will be my first speaker build and I am building a speaker for my dad's birthday. I chose to build a pair of 3 way floorstanding speakers. I would just like for someones opinion if anything seems out of place before I order everything. I hope the speaker will play well since he loves music and hasn't had a good pair of speakers for the past 10 years.
Sub: SB Acoustics SB23MFCL45-4
Mid: Dayton Audio Reference RS150-8
Tweeter: Dayton Audio Reference RST28F-4
AMP: Hypex FA123 FusionAmp
The woofer volume is about 62l, the mid woofer volume is about 17.2l The rear port will be D68mm x 160mm.
Thank you for your help and happy easter,
Cheers Nic
PCB DIY Art Journey-Creating a 7.1 Home Theater.
Hello everyone, the sentences in the article may not read smoothly because my English level is not high and it was translated using software. However, we have common interests and hobbies,, we love music, DIY, and life.
A month ago, I planned to build a movie theater in my room so that I could watch movies happily.
So I bought a projector and a 150-inch curtain. But the sound effects are not exciting and happy enough. If I bought off the shelf amps and speakers the price would be out of my budget. Since I like electronic products, I have experience in DIY computers before. and was able to achieve my goals and expectations within a limited budget. Thus, the idea of DIY amplifier equipment and speakers was born.
First of all, I chose TDA7850 as the type of power amplifier chip, which supports 4 independent amplification channels. Two such chips can have 8 channels. Realize 7.1 panoramic sound system.
After learning more about the 7850 amplifier on the Internet, I ordered two PCB motherboards. As well as the required capacitors, inductors, connectors, power supplies, wires, speaker units, boxes, and tools needed for manufacturing.
Amplifier PCB and audio input filter mainboard, some capacitors and resistors, and wires.
The multimeter is used to detect whether the circuit, voltage and current are normal. My plan is to use a wooden box to place two power amplifier motherboards, as well as a prescaler and an audio input filter. Therefore, a 7 cm fan is prepared, and the temperature controller is used to control the starting fan to dissipate heat.
6.5-inch woofer,
3-inch midrange unit,
1-inch tweeter
The total power of the power supply is 350 watts. It can connect three devices at the same time, with rated voltage of 15V and maximum output current of 23.3A. I only use it to connect two devices, so the maximum current that each device can get is about 11.56A, which meets the power required by each power amplifier.
Some accessories arrived first, and some are still on the way.
Start soldering some components of the amplifier motherboard. Others will be installed after the courier arrives.
In order to facilitate the replacement of different capacitors later and have different sound effects, I prepared a base for the capacitors.
Only 20 attachments can be uploaded, so I will publish them at the next level later.
Dayton Audio SA1000 with very little output
Hi folks. I have a friend's Dayton Audio SA1000 subwoofer amplifier on the bench. It puts out very little amplification regardless of input level and/or gain level settings. It also starts distorting once input or gain is increased moderately.
Hoping for some guidance and/or documentation. I can't find a service manual or schematics for this thing which is a hurdle for my level of knowledge and skills.
  1. It maxes out at 7 volts AC as measured at the speaker terminals into an 8 ohm load using a 50 Hz sine wave input from a pre-amp.
  2. The only component that gets hot is a resistor (labeled R19) which measures 218 ohms. Looks to be 2 watt size. It is visually browned from heat.
  3. Capacitors all look ok visually and are of the 105 degree spec. On the older revisions capacitors were a problem per forum searches.
  4. DC rails are +/- 137 VDC. There's approx 4 volt sawtooth riding on the negative rail, and approx 1 volt sawtooth on the positive rail. Of note, the main circuit board has 165V silkscreened where the power supply wires connect, so wonder if the +/- 137 volts is a symptom to explore.
  5. The qty 3 of 18 VAC power supply lines all measure at 19 VAC
  6. The 15 volt points on the boards measure +14.8 and -14.8 VDC
  7. The output transistor's junctions measure ok with a multimeter. (Qty 2 of TTC5200 and qty 2 of TTA1943)
  8. There are many FET's of which I am uncertain their junction condition.
FYI - I am not a business, just trying to help out a friend.
Building speakers with VituixCad, Umik-1 and DATS v3!
Hello!
I have never built any speakers, but I have read a lot about the subject and have practiced a lot in VituixCad and WinISD.
Now it has come to the point that I want to build my own 3-way speakers. I have a Umik-1 and DATS v3.
I know that I should have bought an XLR measurement microphone with a small amplifier for measurements with loopback, but now I have what I have and thought to run with it.
I was thinking of doing the measurements with 'acoustic timing reference' in REW. This using a small dome tweeter in a fixed position from the mic, and only move the speakers during the measurement process.
I thought to do according to the following steps (I will edit the steps gradually)
1. Design a ported speaker cabinet with WinISD.
2. Build the box with 19 or 22 mm MDF and 3D-print the port with flares.
3. Measure the tweeter on-axis with a distance of 1 m (set Impulse/Actions/Estimate IR Delay and "shift and update timing offset"). Continue with the rest of the measurements with the same settings. Repeat for off-axis in steps of 15° hor and vert. Use the same volume/settings throughout all measurements.
4. Measure the woofer's near field on-axis (5 mm away from the cone), measure nearfield of the port, measure woofer on-axis at 1 m distance (gated measurement to minimize room reflections), repeat measurements for off-axis in steps of 15° hor and vert.
5. Measure the midrange on-axis with a distance of 1 m and repeat for off-axis in steps of 15° hor and vert. Measure tweeter and woofer in paralell, so I can confirm the delay later on.
6. Merge the woofer's nearfield+port with farfield using VituixCad.
7. Measure the impedance of each mounted driver with DATS v3.
8. Import the measurements into VituixCad.
9. Set the listening position on Y-axis for mid and woofer (distance from the tweeter). The drivers are centered on the baffle on X-axis. Import and compare the tweeter+woofer parallel response and double check if drivers are set properly.
10. Design the crossover, order the components, build the crossover outside of the speaker cabinet.
11. Make test measurements. Make adjustments if needed. Finalize the build.
Questions I have:
Have I got the steps right or am I missing anything?
What type of stuffing material and how much to get rid of standing waves? I know it's a subject with many different opinions. How do you do it?
Capacitor for Super Tweeter Crossover
Help please for a real beginner. I would like to add super tweeters to my 2-way active monitors. I have a pair or Cole’s 4001 16ohm drivers, and I am hoping I can get away with just adding a capacitor. The nominal impedance of the driver is 16ohms and the DC resistance is 23ohms. I am planning on a crossover frequency of 12500Hz. I presume the output impedance will be in the range 16 to 23ohms(?). I do not know how to find the input impedance if that is even necessary. So far I think I need a 0.8uF capacitor, but this may be completely wrong. If by some miracle I am right, what type of capacitor should I use. I think 0.8uF is an odd size as well. This is my first venture into diy and my first post on this forum. Any advice would be welcome.
Mitch
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,672
Members
7,883,534
Messages
Filter
Forum Statistics
Threads
405,994
Messages
7,883,534
Members
507,672
Latest member
rooomn
