I was able to successfully power up and test the preamp. Now I need to put them in the enclosure and was wondering if there are any suggestions on how to mount the boards?
You can try this from Mouser: 30468-N RAF Electronic Hardware | Mouser United Kingdom
shirtbox cardboard, bubble wrap, and hot glue?
Nope wires stiff enough to hold up dead bug style, sounding so good haven't had time drill three holes.
Heavy sheet of corogated stuff Underneath. If you look back at my pics, you can see it
Russellc
Blue silicone seal was used on mine. It has special audiophile damping properties.
Hmmm... I wonder if blue silicone seal might be good for the Korg B1....
As in the JB Weld type for gaskets?
I've also used these little zip tie cable anchors (which have tape on the bottom, and just put a square of good foam tape on the top, it works great!
Amazon.com: 250 Adhesive-Backed Zip Tie Anchors by APTronix. Heavy Duty Professional Grade, UV White Cable Tie Base: 3/4 x 3/4 Inch, Screw Hole Anchor Provides Additional Strength. XGA Anchors (S, White): Home Improvement
And 3M double foam tape like this - Amazon.com: Scotch Indoor Mounting Squares, 1/2-inch x 1/2-inch, White, 96-Squares (111-SML): Home Improvement
Yes the gasket making silicone seal. Permatex ultra blue sensor safe.
Thanks Wayne!
linestage rebuild
Well here it is, finished for now.. Balanced input from my Buffalo DAC, +/-25V rails from a Salas "UltraBiB", way oversized power transformer from an unused amplifier project, Jensen's wired as autoformers for more gain to my F4's.
My own build has some "character" with the signal iron, but I would say Wayne's circuit is very low distortion as advertised, detailed and accurate. If that's what you're looking for and need the gain, I would say it's worth trying out. My diy audio stuff is in a much less ideal room than it used to be, so I'm unable to really give it an honest assessment. Since I changed the PS in my build (from the one shown in post #612), I'm hearing some "roughness" that I did not notice before. I need to maybe try some series resistance or something to get that sorted out. It may not be playing nice with this shunt regulator.
Thanks Wayne and Jim for the wonderful linestage. Its quite and very detailed preamp with good soundstage. I am using it with a 10k relay attenuator and all I can say that its fantastic. The chassis and all the guts are old and the gainstage replaces a B1 buffer. The only change I made was using 27k for R17 to lower the gain to 2.
Dine, please share us more information about the relay attenuator.
I got it about 10 years ago...
New project : R-2R Attenuator With Remote Control V2
Thanks,
Dinesh
Thanks!
Enjoying this preamp... I added a bit of length to the wires from the shunt supply to the boards, not a lot, couple of inches per wire. Salas mentions that the local termination capacitor type and the cabling to the load are important for stability in this supply. Listening for a few hours tonight and found myself getting sucked into the music rather than obsessing about the equipment. Always a good sign. Also I think there's some nice benefit to having this big toroid in there now. Bass is solid and effortless with great control. It replaced a 25VA Hammond that had an annoying mechanical buzz audible from any distance, the main reason for wanting to replace it. Thought Wayne's boards might just be a cheap temporary experiment to try for fun. But damn, my ugly little linestage is actually "really" good!
- Wayne's BA 2018 linestage
