Low-distortion Audio-range Oscillator
I have an old stock of Soviet precision metal film resistors S2-29V that I use as a reference. Compared them to Dale's 5 ppm resistors and there was no difference in the measurement area. Statistics and various practices indicate that they are most likely linear, as far as I can currently measure.
But in general, each sample of any resistor and capacitor should be tested individually before it is used in critical locations.
Reactions: Kruger and anatech
IMHO those, as Demian wrote: Vishay doesn't even publish linearity info on the Bulk Metal resistors. https://foilresistors.com/docs/63140/var.pdf
In the old days there was the Alpha Core as also none inductive as in a black plastic block.
As mentioned:
At that, negligible capacitance/inductance of foil resistors (when compared to wirewound resistors) significantly reduces
probability of self-excitation or "ringing" of amplification circuit.This is why Bulk Metal® foil resistors are such a good
choice for low-noise applications...
MELF resistor from Token Electronics as none inductive as RFM series
Reactions: diyralf
The better resistor is two resistors in series instead of one. 🙂
Yes, in many cases.
Also, by connecting four identical resistors in a series-parallel circuit instead of one and comparing the results, we can understand whether the resistor is linear or not.
One resistor ARG05FTC1502:
https://content33-foto.inbox.lv/albums/e/elterra/ResitorLinearityMeasurements/1R.jpg
Four ARG05FTC1502:
https://content33-foto.inbox.lv/albums/e/elterra/ResitorLinearityMeasurements/4R.jpg
This is my version of Victors 1kHz oscillator.
I must explain, my design is with leaded parts, because I cannot design with surface parts because of my eyes.
I plan to use the 1kHz oscillator in an existing design (see photo’s)
This is a 1 kHz ref. signal source with a 60dB attenuator (1dB step) and a dual output driver (very low output impedance). All is controlled by Arduino.
The 1kHz oscillator works great.
I have some difficulties getting the oscillator to start, but I received fast and good help from Vicnic.
The specification of my 1kHz version is not at level of the original Vicnic design, but I will later optimize according to Victors recommendations.
For you information ......... a couple of photo's of the system, my layout of the oscillator and the very first test results.
Hi Pizzigri,
I will absolutly not make a commercial project for any of my projects.
If anyone is interested I will be happy to share.
I have been using the setup of:
My own Soundcard interface - USB 0204 - Audio Tester - TrueRTA for more than 10 years (perhaps 20 years now)
Testing classic audio products like amplifiers - gramophones - FM receivers ect. in my small company Classic Audio.
I have now sold Classic Audio.
I have really a number of project for audio testing allready made with good documentation.
But I am not going to make any commercial project for any of the designs.
