What's wrong with the kiss, boy?
Joined 2003
Well, I may try cinemag, just went to Jenson site, and while a search brings up the part, doesn't appear to allow access to it. I will try to call. I have one set on hand already,but would like a spare for another project.
Maybe it's just because it's out of stock?
Russellc
Official Court Jester
Joined 2003
regarding older ( non-final) pcbs , itsallinmyhead is having all info , simply because he already made them
in all cases Lorlin switch , shorting (make before break) , 2 sections -6 positions - that's what you need and want
it can be some other brand than Lorlin , but I made pcbs for them (footprint) , and final is having input showing LEDs implemented
so , for pcb - through hole ( no solder lugs) , example : CK1030 Lorlin | Mouser Europe
pot ........ dunno - pick your own poison .......... just don't waste too much
blue ALPS is good enough ..... and certainly not the only one
if you're going to pay more, substantially - waste of the money , if you ask me
all of them are inferior to proper AVC ........ so - if you insist of making it better - instead of (any of named 3 types of ) autoformer , buy 200$ Slagle set and convert it to Poor Man Iron Pumpkin , tossing resistive attenuator completely out of story
I did explain procedure in Iron Pumpkin thread(s) , will repeat , if needed
Joined 2002
I messed up my build and killed the 5.1V and 27V zeners at the supply to
the relays.
Would using a shorting (make before break?) rotary switch for the input
switching have caused this? (I may have picked up the wrong switch type)
It's quite possible I've messed up the wiring elsewhere as well. If anyone
can post some pics for the wiring at the switch and at the pcb, I would be
most grateful.
Thanks,
Dennis
Joined 2003
the relays.
most grateful.
Thanks,
Dennis
Although I haven't got there yet, I sure it will be very useful for me as well!:D
Russellc
Joined 2003
switch is having nothing with these troubles ; it must be make before brake , to avoid clicksandpops while changing inputs
even if you make dead short on all IDC connector pins ( leading to selector switch) , result could be only all inputs engaged
I can't tell anything if I don't know which iteration of pcbs you guys have, so - pictures and words, please
one thing is important - each channel must use one separate section of selector switch
Joined 2003
take your time ......
