Technics TT owners check this out
This is for all Technics TT with removable headshells.
I've discovered a resonance in the tone arm contacts to the headshell. The springs which tension the contact pins, holding it to the headshell contacts cause a lower mid peak. Its tiny, but I can hear it with some vocal recordings along with tapping the headshell with the back of your finger nail. I used some dielectric grease behind the pins and it greatly reduced it.
Reactions: benb and vinylkid58
MosFET or other semiconductor substitute for cathodyne?
One of the primary ways to advance is to use the organizing idea of applying known principles to new applications. Tubelab and others have found that semiconductors, specifically some mosfets, can be used in special applications and will not affect the sound in a tube circuit. The best example is in source followers to drive tubes. There a numerous advantages there. I will let others more experienced to advance the argument.
I've recently been interested in phase inversion for push pull right before the finals. The cases where mosfets have been used successfully in tube circuits,( besides CCS) is where there is no gain in the stage. I'm thinking now that a mosfet may be a very good candidate for use in a cathodyne stage. That kind of stage also has no gain. Is there a case to be made for using them there in a tube circuit and not influencing the sound in a negative way? Inquiring minds want to know.
Wavecor TW030WA12 (China) vs. Kartesian Twt30_vMS + Horn-30 (France) for a 2-Way
NEW Title: Wavecor TW030WA12 (China) vs. Kartesian Twt30_vMS + Horn-30 (France) for a 2-Way
Wavecor TW030WA12 (China) vs. Kartesian Twt30_vMS + Horn-30 (France), both 8 Ω tweeters for a 2-Way and a 1st Order (6dB) crossover possibility, big dommes and high SPL (sensitivity), 2kHz-20kHz, no Ferro. Limit 150/200€ for each tweeter. Low budget ribbon considered like Dayton PT2C-8, others models or high SPL to 20+kHz. CDs/Horn combos (like 18Sound XT120) ONLY for a future project. PS 8 or 16 ohms ONLY please. No 4 ohms tweeters. TIA
(Edit for Kartesian 8 Ω tweeter)
https://audioxpress.com/article/Test-Bench-Wavecor-TW030WA12-30-mm-Cloth-Waveguide-Loaded-Tweeter
https://audioxpress.com/article/test-bench-a-high-end-dome-tweeter-from-kartesian
For Sale Bliesma T25B + Scanspeak 12MU+Scanspeak 18WU
Hi!
I had collected them for a build, seems like I will try a high sensitivity setup with CD+Horns. Drivers will be shipped insured from India. 12MU-8731T is BNIB,
Scanspeak 12MU $450 + shipping.
Scanspeak 18WU Sold+ shipped.
Please PM me for more information, will post pictures soon!
Thanks for reading!
Reactions: IamJF
For Sale Audio Precision System One Dual Domains
I'm continuing to downsize my equipment collection, so I have two Audio Precision System One Dual Domains for sale. The first one is a SYS-322G and in very good condition, passes the analog and digital self checks with no issue. It comes with many accessories including several cable kits, original manuals, documentation, technotes, APIB PCI card. I'm also including an APIB USB cable which works with windows 10 and the Audio Precision software.
The attachments include the self check reports, and pictures of the machine and accessories.
These are located near San Luis Obispo, California.
  • 322G_S1-CHECK_COLD.txt
  • 332G_S1-DSPCK_COLD.txt
New Markaudio MA200 8" Driver
I have taken the liberty of making a new thread just for the new Mark Audio MA200 8cm driver rather than have it hiding on page 122 of the MA New Drivers thread. This makes it (and projects that use it) easier to find. Details of the MA 200 here:
https://www.markaudio.com/online_shop/20-cm/ma200-m-multi-midnight-copper/
I'm hoping that people will post their projects and ideas here on how they plan to use this driver. I'm hoping that when they have a moment Scott and Dave will also give their thoughts on this driver and possible usage cases.
I'm particularly interested in the cabinets Scott has designed for this driver (especially the one going down to 25Hz!) and what sound characteristics each box might have. What are the pros & cons of the single versus double ported versions and how much flexibility is there to change box shape (curved sides, rounded baffles, ovals, triangles etc.) provided box volume is maintained? What scope is there to combine this driver into a 2-way or even 3-way system?
My Latest Preamp and New Features
Presented here is my lastest DIY audio project. Actually, this is my 2nd preamp I've built using the base preamp PCB that was designed by my friend and fellow DIYer, Jan Hofland. This has turned out to be an ultra-quiet preamp board built around the OPA1656. It is stunningly quiet. More information about the PCB can be found over in this thread here. The preamp offers a lowpass subwoofer output, selectable at 80, 120 or 200Hz. In addition, it also offers selectable gain at 0, 6, or 12dB. I find with most of the inputs I use 0dB works just fine.
For this project I had a few objectives. Use the same model case I had used for an amplifier and streamer I completed last year. Integrate a new and improved(modernized) source selector, and add a Bluetooth adapter PCB.
The case is a Goodisory mini-ITX case. There was different mechanical casework, and 3D panels that required unique customization. The most exciting objective was met with my design(functional) of a 4-input pushbutton selector switch. Pushbutton selectors are not new, but I wanted one that did not use relays, or would make a noticeable click when changed. I also wanted to integrate a visual queue(LED) into the pushbutton itself indicating the active input. Another criteria was the switch needed to be small and operate with slight tactile feedback. After a bit of looking, I found the perfect little micro switch with built-in LED on Aliexpress. I also didn't want the switch module (PCB) to introduce any audible artifacts into the circuit. I turned to my designer friend and ran my idea by him. He was up for the challenge of designing a circuit board that would perform to my specs.
His final solution provided a nice, small PCB with no clicking added to the circuitry. And, as required for any audio application, the switch is silent, and does not add any noise to the switched input going to the output stage of the preamp. To get the pushbutton switch to integrate into the pre I had to put a couple jumpers on the pre board to force an 'unmute' function that was designed into the preamp PCB. And, for obvious reasons, I'm only using one of the original inputs for the output of the pushbutton switch PCB. All the RCA source connectors now wire directly to the silent switch PCB using MolexKK male headers.
Front side of Silent Source Switch(SSS)
The other feature I wanted to add to this preamp was to make it Bluetooth capable. Once again, Aliexpress to the rescue. I found this LDAC that was 5.3 compliant and seems to work as advertised. Now, I'm not under any allusion that Bluetooth provides a super quality audiophile experience - even with hi-res tracks. However, the latest LDAC Bluetooth standard sounds decent enough for casual or convenience listening. With 4 young adults children visiting from time to time(whom live by their cellphones) 🙂, this adds a nice touch to my system. I also have a DAP that I can now connect to this preamp with ease. It was an effortless experience pairing to my phone and DAP.
LDAC 5.3 Bluetooth module.
With my 2 major features met, I proceeded to assemble the preamp using my standard support hardware (remote switch and soft-start board). I also designed the back panel to accommodate the typical IEC inlet, and RCA jacks. This was then 3D printed and fitted to the case as shown. The most challenging part of the case work was fitting the pushbutton PCB to the front panel super-structure. I ended up using kind of a kludge solution, but it works. I used JB Weld adhesive to secure 6 brass standoffs to the inside front piece of metal. There is no binding at all on the little plastic switch covers, as there's essentially no travel depth of the switches. I had some practice using this technique with 2 other standalone switch-boxes I built. After much thought about internal layout, I decided on what is shown. I wanted to keep all the AC connections in the right-back corner. It was a tight fit for the IEC inlet, but doable as can be seen. To save space I've also adopted the method of raising my remote start PCB using standoffs. I've found that I can usually fit the PCB(remote start) using 2-3 standoffs anchored to the bottom, while a nylon standoff can easily rest on an open spot on the pre PCB. I've used this method in a couple other builds where horizontal space was limited.
In all, I'm pleased with the final result. It sounds great - as I've come to expect with Jan's designs - and the pushbutton selector is very functional, and cool. My next project will be to go digital with a UI - that has yet to be developed.
Greetings!
Hi, I'm Neil from North West England.
I've been tinkering for years, and often find this page a place of inspiration. At the start of lockdown, I restored the Thorens TD-150 Mk II that my Dad bought new in 1970. It didn't need a lot doing, but Rubber parts, the PSU and a few other things needed attention.
So, I am here to learn more (we can always learn more), ask questions, and maybe able to help others in their DIY audio journey!!
Live Edge Dipoles - #1 at Parts Express 2023 Speaker Design Competition - Updated Design
Live Edge Dipoles: 2023 Upgrade Advanced Application Notes
The Live Edge Dipoles took 1st Place at the Parts Express Speaker Design Competition August 4-5 in Ohio. 59 contestants. My Open Baffle design on a slab of live edge birch won top score in the Open Unlimited category.
Judge Jerry McNutt said, “The best way to not sound like a box is: Don’t use a box.” Listener comments: The Beryllium tweeters are extremely transparent; bass is rich, expansive and authoritative; thorough top-to-bottom coherence and integration; warm, ambient and enveloping stereo image. Can effortlessly fill a large room to overflowing with palpable output and dynamic range.
I hosted the Chicago Audio Society a few weeks prior. Listeners were consistently impressed not only with rock and jazz but string quartets and large orchestral works. One listener said they combine the open, room-filling sound of Magnepans with the slam and dynamics of a JBL. Sound stage is huge.
The Live Edge Dipoles were featured on the cover of AudioXpress January 2021. The article there provides a thorough description of the system as it was at the time: https://audioxpress.com/article/you-can-diy-perry-marshall-the-live-edge-dipoles or tinyurl.com/LiveEdgeDipolesAudioXpress.
I have since made numerous upgrades. Before I dive into details, a few insights about speaker design; and why, out of thousands of possible choices, I selected the format I used here.
Why ordinary speakers are doomed
When you visit any audio show, 90% of the speakers share the same weary collection of baked-in assumptions:
  • They all have boxes
  • They all sound boxy
  • Wife Appreciation Factor is low or sub-zero
  • Simulated woodgrain finish
  • On-axis frequency response is obsessed about
  • Off-axis response is ignored
  • Radiation pattern is ignored
  • Bass is omnidirectional
  • Drivers interfere with each other
  • They have 1” dome tweeters
  • Crossovers butcher impulse and phase response
  • There is one “center of the will of God” sweet spot
  • The room is ignored (and room acoustics are voodoo)
  • Inefficient: 1 watt / 1 meter is often mid- to low-80s
  • Hard for amps to drive because of extreme impedance variations
  • Drivers are small and sound anemic with real (non-audiophile) music
This consigns you to one predictably boring demo room after another. The Live Edge Dipoles sidestep every pitfall listed above. Giant notes roll out of the speakers. You enjoy a huge sound stage. You are immersed in 3D ambience, clarity and resolution. Dry recordings become spacious. Drums and toms hit with visceral, fist-on-sternum impact.
I don’t believe vocals are the toughest thing to get right in a speaker. Percussion is the hardest! Especially with other instruments. Most speakers fail to excel at percussion because they butcher time response; you can easily measure it.
Check the sidebar that reports Step Response in every Stereophile review and witness the butchering with your own eyes. Woofers and tweeters fire with opposite polarities on different dates. Average speaker designers claim you can’t hear the difference. I insist you can. Once you hear the “boxiness” of box speakers, you can’t un-hear it.
With the Live Edge Dipoles, the most delicate of sounds, the wires and shell of a snare drum, are reproduced the startling precision. When the drummer slams the floor tom (like in “Hatesong” by Porcupine Tree), you feel it in your bones.
40 Years of Design
My early teenage years were, shall we say, less than fun. I escaped into Audio projects. I fell in love with a pair of Boston Acoustics A60s but couldn’t afford ‘em. Laid my hands on a McGee catalog and made my own with a Peerless polypropylene woofer and the same Tonegen tweeter as the A60s.
I sold my first pair of speakers to a paying customer when I was 14. I briefly sold my own brand through a local dealer alongside B&W, Denon and PS Audio when I was a senior in high school. Then an Electrical Engineering degree with accent on Control and Communication Systems. Worked as an acoustical engineer for 3 years at Jensen designing OEM drivers for Honda, Ford, Chrysler and Acura.
Since then, audio has been my hobby, with occasional articles in Voice Coil and AudioXpress. I’ve made almost every type including acoustic suspension, reflex, bandpass, transmission line, horn, dipole, ribbon and shaded arrays. I’ve built Motional Feedback subwoofers and used active, passive, analog and digital crossovers. Homes, cars, churches, studios and live bands.
A memorable leap in my journey as a speaker designer was my first Open Baffle design using 12” Faital coaxials. The huge size of soundstage and the lack of boxiness made a striking impression on me, playing quiet classical guitar music at 7 o’clock in the morning. The energy of pro-sound drivers without compression sealed the deal.
Radiation Pattern
Polar pattern is one of the great underappreciated secrets of great speaker design, and it’s a secret to these speakers’ performance. The capacity to deliver low distortion, flat frequency response, transient response, etc. is admirable. But to achieve an excellent distribution pattern at the same time separates the men from the boys. When response is only flat on-axis, your design will sound more like a speaker and less like real music.
When room reflections don’t match direct sound from the speaker, it sounds unnatural. Textbook speaker designs pretend the room is not there. But not only does the bass have room modes and standing waves, but the mid and high frequency reflections add LOTS of clues for your ears. Good clues make your ears happy.
PERFORMANCE SUMMARY
  • 30Hz to 25KHz with silky-smooth response in a real room that has real reflections. Not just in an anechoic chamber.
  • True Constant Directivity sound pattern 30Hz to 25KHz so imaging is superb anywhere in the room
  • Open Baffle Dipole sounds great even behind the speakers
  • High Efficiency – 95dB 1 watt/1 meter. Sounds great and plays loud even with “flea watt” single ended vacuum tube amps
  • High Power Handling and High Output – 100 watts & 115 dB running full range; 500 watts & 120 dB with subwoofer
  • Near-perfect impulse response
  • Near-perfect phase response
  • Low Distortion (<2% above 60Hz; <1% above 150Hz at 90dB)
  • Easy to drive
  • Live Edge wood is so beautiful, non-audiophile wives of non-audiophile men gasped when I showed these on a screen in a Zoom meeting.
  • 3-way system is bi-amped (not tri-amped) using a MiniDSP 2x4HD.
The Live Edge Dipoles exhibit true Constant Directivity from 20Hz to 20KHz on both sides of the speaker. Full dipole behavior front and back with a Figure-8 radiation pattern. Constant Directivity means the speaker is consistently directional. Much louder on axis than off, and levels drop consistently across the whole range as you move off axis, instead of only dropping at the top end of the woofer and tweeter’s range.
Above: Polar spectrum of the Live Edge Dipoles, 150Hz-15KHz. Beamwidth is defined as -6dB points relative to 0 degrees, which is the cyan color in the graph. Beamwidth stays between +/-30 and +/-60 degrees across the entire range.
Above: Frequency response in a real room at 0, 15, 30, 45, 60, 75 and 90 degrees. The number of commercially available speakers that come close to these off-axis curves, you can count on one hand. I discuss the polar pattern below. They have a rear-firing “ambience” tweeter which makes the rear radiation very similar to the front. To my ears, dipoles without this don’t sound right. A level pad lets you tailor the ambience to taste.
A true Constant Directivity speaker yields good stereo imaging even if you are standing right next to one of the two speakers. It delivers outstanding sonic images to every seat in the house. When arranged in a triangle pattern with the speakers pointed towards the listener position, every seat sounds great.
Great Stereo Image Everywhere
Below is a crayon drawing of a room with Constant Directivity Dipoles. It shows why Open Baffles with uniform response, toed in about 30 degrees, image better than every other type of speaker.
Stereo imaging is strong anywhere inside the yellow boundary, starting at A.
B, right in front of one speaker, is the only spot where imaging isn’t good.
When you stand at C you hear the right speaker across the room just as well as the left. And yes, you get a decent stereo image there.
Same is true even at D. You can hear the right speaker clearly, even standing just behind the left speaker.
There are no sidewall reflections at the wall near C because it’s in the null plane of the dipole.
1, 2, 3 and 4 illustrate that rear radiation reflects from the wall back into the room. This provides ambience but does not override direct sound.
The “sweet spot” is somewhere between F and G, depending on how “headphone-like” you want your sound.
Place your turntable at T, the null for both speakers. Cuts acoustic feedback 10-15dB.
As you walk from C to E to H, the stereo image remains stable and the volume grows louder. E and H, though much farther away, are louder than C because the directivity pattern is so well-controlled.
Very few speakers do any of this. To my knowledge the number of available commercial designs that achieve constant directivity across the entire spectrum is zero.
Above: Frequency response of the Live Edge Dipoles, on axis at 1.5 meters in my room. No attempt to gate or eliminate room reflections. Room response should taper downward slightly as frequency rises. Some speakers measure more perfectly in an anechoic chamber… but these measure very well in real rooms. Not just in one spot but everywhere in the room! This EQ sounds most neutral to my ears.
In this design I optimized the physical design and shape for radiation pattern, and then I corrected the problems this incurred with Digital Signal Processing.
Upgrades Since the 2021 AudioXpress article:
  • I upgraded the aluminum dome in the Radian 5208C to beryllium. The beryllium has very similar frequency response but sounds quite a bit different. Extremely clear and transparent. Sounds “buttery transparent” and not analytical. The tweeter just disappears.
  • I changed the tweeter wiring and several EQ settings in the DSP crossover.
  • I added Bass EQ options. The stock design is flat down to below 30Hz. This is great for small rooms and listeners who are not “bass heads.” However, if you push them super hard with lots of deep bass, the subs will complain. I added a “Rock and Roll” EQ setting that rolls off below 35Hz. With this setting you can play loud music in a large room and the speakers will handle the full dynamic range without effort.
Aluminum vs Beryllium
The standard version with aluminum dome sounds fantastic and I have no criticisms. Though the beryllium diaphragms cost several hundred dollars apiece, they are well worth the dinero. They deliver extreme transparency similar to ribbons and electrostatics, without harshness. The tweeters just disappear and let the music flow through. Finally, they’re not merciless. Many high-def speakers are harsh and unforgiving of ordinary recordings, but the Rolling Stones and AC/DC sound great too.
High SPL Drivers, Amps and DSPs
The Eminence 18 Kappa LF woofers produce 98dB SPL / 1W. The Radian 5208 coax puts out 95dB from the woofer section and ~100dB from the 16-ohm tweeter section.
High efficiency makes them extremely sensitive to electronic hum and noise. Amps with noise and grounding problems, not evident in typical 85-90dB audiophile speakers, are exposed. Furthermore, the MiniDSP 2x4HD has some noise which is not obvious with most speakers, but evident with high efficiency horns.
You can solve this by using an amp with an input control and turning it down a bit (Adcom GFA2535 is a great 4 channel amp and has level controls) or with a padding device like a Harrison Labs 12dB attenuator.
An even better solution is the MiniDSP Flex Eight, which has higher resolution and lower noise floor. I have configuration files for this too, discussed below. I further minimized the noise problem by wiring the rear tweeter (PRV WG175PH) and front tweeter in series, with parallel resistor networks bringing the total impedance down to 11 ohms. This tames the tweeter output to 95dB.
Only the most basic functions are performed by passive components: 200Hz crossover between woofer and midrange; tweeters are wired in series with an L-pad for adjusting level of the rear tweeter; a 20uF capacitor simply protects the tweeters from accidents. All heavy lifting is done by the DSP with 2KHz crossover with FIR phase correction.
Noise sensitivity notwithstanding, the energy, dynamic range and effortless performance you get from efficient pro drivers like Eminence and Radian more than compensate for the noise precautions you have to take. Speakers with vast dynamic range and low distortion sound so effortless and open, you feel compelled to crank the volume up.
Most audiophiles are so conditioned to buckets of intermodulation distortion, they’re stunned when a system doesn’t have it. I call it “Dynamic range to burn.” Once you’ve experienced it, you never go back.
The “Lambda Slab” U-Frame
The triangular sides on the bottom of the cabinet on each side of the 18” woofer pushes the dipole roll off frequency lower. Without them the roll off would start around 100Hz; with them it’s around 60Hz. The wings buy you almost an octave of bass.
It’s easy to get deep bass from an Open Baffle speaker… you just need a Digital Signal Processor and heavy EQ. You pay a price, however, which is that your woofer can easily bottom. Distortion spikes at low frequencies. I have paid close attention to this issue. The bass EQ begins in earnest below 60Hz. This is the curve for the standard “Jazz EQ” DSP file:
Above: EQ reaches 20dB at 29Hz, then rolls off gently below. Yep, 20dB is a ton of EQ, but remember that these have 95-98dB sensitivity, so across 90% of the spectrum they require very little power. Extra power is only demanded by occasional deep bass passages.
I call this the Jazz EQ setting. It’s optimized for lowest group delay and least ringing in the step response. Most speakers have gobs of phase shift at low frequencies which you easily hear on well recorded bass drums. The steeper the filter, the more phase shift. Steep slopes like in actively assisted 6th order reflex designs add many tens of milliseconds of phase delay. This design sidesteps that.
Above: Phase is +/-30 degrees from 40Hz to 20KHz with a max of only 120 degrees around 20-30Hz. Very, very few speakers match this. This cuts group delay and maximizes bass resolution.
Above: Step response. Fast rise time followed by steady descent with no phase reversals. Drivers fire in perfect time with each other. There is little low frequency ringing because the design minimizes phase shift and group delay. Very few speakers match this. This is one reason why clarity and imaging are so precise.
Above: Impulse response. Most speakers shred impulses, which should look like an upside down “T.” The Live Edge Dipoles deliver 80% of their energy in a tight 0.1 millisecond slice. This makes lightning fast transients and exquisite detail.
Bass from most subs, even celebrated designs, sounds more like well-articulated thumps than genuine instruments. Open Baffle speakers bring a welcome exception and sound extremely natural. The Jazz EQ setting achieves flat response to below 30Hz with minimum phase delay. Perfect for listeners with small rooms and / or do not demand the pantleg-flapping bass of car stereo shows and rave clubs.
However if you have a big room and/or want to shake the house with loud rock or electronic music, I added a 2nd EQ configuration file called “Rock & Roll EQ” that adds a dual shelf filter (instead of standard high pass) at 35Hz, with a slight lift between 40-60Hz and above 5KHz:
With this one tweak, the speaker can play 10dB louder than the Jazz setting. So if you like your music loud, even in a large room, this EQ setting will keep your woofers from bottoming or wincing in pain.
Above: Low frequency drive signal from amp. Blue = Jazz EQ. Orange = Rock & Roll EQ. Reduces woofer excursion by 70%, allowing up to 10dB greater output.
This matters in an Open Baffle design. That’s because an acoustic suspension woofer’s max output falls at the rate of 12dB per octave. That is challenging enough if you’re trying to shake the house. But an Open Baffle woofer loses traction at the rate of 18dB per octave (12dB from standard radiation resistance, plus an extra 6 dB due to rear wave cancellation). So every 1/3 octave of bass you ask of an Open Baffle speaker demands +6dB which requires 2X the excursion and 4X the power. One full octave costs you 18dB: 8X excursion and 64X power!
By relieving the 18” woofer of everything below 35Hz, you buy yourself 10dB more dynamic range. The 18” Eminence woofers, bolstered by the U-frame wings and 35Hz roll off on the Rock & Roll EQ, use 14dB of boost at 39Hz and generate high SPLs without effort. You can load both settings into your MiniDSP 2x4 HD and switch between them at will.
Low Distortion
Below:
Distortion measured at mid-band output of 90dB SPL/1M in a real room; SPL climbs to 100dB at 40Hz. This is with the Rock & Roll EQ setting. Distortion is under 2% above 60Hz, under 1% above 150Hz. (Data also includes rattles and buzzes of the room itself.) The darker curve is 2nd order, lighter 3rd order:
(continued in next post)
AEM6000 Based 100W Amp
This is a design I've had in use for rather a long time. It started life as a design exercise to see if I could do a more space-efficient board for my original AEM6000 based amps, as I wanted something that would fit on a 50mm high heatsink. It's a very, very close friend to my 50W version with a couple of extra output transistors and a bit of a compensation tweak. Along the way it changed a little from Tilbrook's original in topology, and rather a lot in component choice. It has better performance than my original design, both through a better tighter layout and also through the use of faster transistors.
I've built a few of these. Nowhere near as many as the 50W flavour.
Lots of component substitution is reasonable. I like to use MELF resistors, but that's mostly just bloody-mindedness. An exception is the feedback divider. No, it won't work with vertical MOSFETs.
I have checked just now, and every single component is currently (December 2020) available.
The design is free for use for non-commercial purposes.
In the design folder I have placed:
PDF file of schematic
PDF file of construction notes
Top and bottom layer stuffing diagrams
PDF file of parts list with supplier info
Gerbers and drill file for board manufacture.
Google Drive link to design files
MarkAudio MAOP 11 single driver loudspeaker
http://www.fidelitatem-sound.jp/fidelitatem-NC/n_detail_NC11.html
Login to view embedded media
Product specifications​
  • Model: NC11_MOP_MC /NC11_MOP_MC
  • SP unit: MAOP_11 v2
  • Playback frequency: 35 Hz - 25,000 Hz
  • Maximum input: 35W (cont.)
  • Output sound pressure level: 87dB /1w@1m
  • Rated impedance: 7.2Ω
  • Mms = 7.90 g
  • Xmax(1way) 8.0mm
  • Dimensions: (width x height x depth) 245 x 450 x 295 mm
  • Weight: 11.5 kg x 2
For Sale Babelfish J with Semisouth SJEP 120R100
For sale are 2 Babelfish J boards adjusted to 1,8A bias.
They are tested and ran for aprox 100h in my setup. They sound great!
With XLR inputs and Semisouth outputs.
And before you ask - yes, these are originals, I bought them directly from Semisouth when the company still existed 😉
You can buy it with or without the heatsinks. The heatsinks are thought for 80mm fans.
I would like to have €250 without and €300 with heatsink (without fan!) plus shipping costs.
Reactions: schultzsch
T+A 1220R "no Disc"
Hello,
I have a T+A 1220R that always displays "no disc."
It doesn't even try to spin.
I can see the lens 2-3 times, but I can't see any red light.
I replaced the laser unit with a "new" one, but the error remains the same.
I then measured the LDON signal on the SAA7372, but it stays permanently low. That can't be normal, can it?
Unfortunately, the manufacturer doesn't provide any documentation about the device.
But maybe someone here can help.
Mario
Suitable midrange cone, for bandpass mid in Unity horn
I'm looking for a midrange cone, up to 6.5"dia to fit into a Bandpass enclosure which will fire into an odd unity horn (odd because its being re-shaped to fit into a car, but its using the unity concept).
Basically (I think) I need a midrange driver with a relatively high Fs and low Qt, to work in a 4th order bandpass (sealed rear chamber and ported front) and give me a lower cut off of about 200Hz and upper cut of of 1400Hz (-6db) if I can get more bandwidth all the better.
I'd like to go for a single 6.5" driver or smaller, multiple 2" or 3" drivers would be quite acceptable. I would ideally like something that is available in the UK though, importing from the states is an option but something easily available would be prefered. Someone is having reasonable success with multiple AuraSound NS2 'Whisper' drivers, I'm looking at the Eminence Alpha6 as they are cheap and easily available. any other suggestions please?
Ported Tweeter
Erin Hardison made a video in 2023 of a ported tweeter. He said it was made by someone named "Alex" who was going to file a patent.
I haven't seen anything more on that since then, so I thought I'd take a crack at reverse engineering it.
This is the ported tweeter that Erin reviewed.
Pic is from his FB.
Go subscribe to his channel and buy your merch using his link: Login to view embedded media
Here's Alex's website: www.referenceacoustics.com
Here's a graph from Alex's website, illustrating the difference in SPL.
Here's a graph from Alex's website, illustrating the difference in excursion.
This is a ScanSpeak D3004/6600. For sale at Madisound for $228: https://www.madisoundspeakerstore.c...inator-d3004/6600-aircirc-tweeter-textile-dom
In order to make a Ported Tweeter, I believe Alex simply drilled holes through the faceplate, to allow the radiation from the rear of the diaphragm to "vent" through the faceplate.
Scan Speak hasn't published full Thiele Small for this tweeter: https://www.madisound.com/pdf/scanspeak/D3004_660000.pdf
But I think that's kinda irrelevant. I have an idea of how you could port it:
Basically, you buy a set of drill bits, and then you drill progressively larger ports, until you get the frequency response you're looking for. As with any ported box, you can trade efficiency for bandwidth.
If you don't want to spend $230 on a tweeter, this "trick" should work with any tweeter that you can expose the back side. IE, if the magnet is solid, it won't work. But most of the 1" and 1.125" SB Acoustics Tweeters, they'll work. I used the SB29ADC in my experiments with metamaterial absorbers:
What makes cymbals sound real?
Some time ago, I was walking on a parking lot and heard music coming from the adjacent building 20 meters away. Its doors were open. What struck me, was that I could hear that the cymbals sounded like the real thing, without being able to see what made the sound. It turned out to be a dance organ. In a large, reverberant room.
For those who do not know what a dance organ is, it is awesome:
Now, I am curious why it was clear that a real instrument was playing and not a loudspeaker.
  • Can it be related to an instrument being 'faster' than the same instrument, recorded and played back over a loudspeaker? I do not think this could explain it here, because there only was a mix of reflected sounds to hear.
  • Can it be related to directivity pattern? I doubt it. There is no way to distinguish between different directions. All I knew was that sound was coming from some doors 20 meters away.
  • Can it be the sound pressure level? Real cymbals are loud. But it was not that loud outside.
  • Can it be the dynamics? Real instruments have no compression applied to them. Maybe?
  • Can it be the spectral content of the sound? Being outside of the building, I must have heard the power response. Cymbals are quasi-omnidirectional over their full frequency range, while most loudspeakers beam at high frequencies and have a downward trend in their power response. But would not have it been altered to an unknown amount, by the room acoustics?
Any thoughts are appreciated.
recommend a nice mid-budget over ear with noise cancelling?
Hello friends
as the title says, I am looking for a nice, mid-priced ( < 500.- ) over-ear headphone with noise cancelling, as birthday present for my better half... I am not really into HP, although they sometimes come in veery handy. She's not admitting to be into audio (listening through laptop/handy and other calamities, but let's ignore this for a second)
I personally would go after soundquality first, she OTOH weighs the aesthetics rather high (me too, but second to sound)...
If I'm right, the usual suspects are apple's things, bose and sony? Anything but them?
Thank you
:cheers::
For Sale Pass A40
I remember very well when the A40 was presented in AA/78. Gee, that’s a healthy while ago! Evil tongues might even mention generations.
Ok, the years to follow have been filled with what they have been filled with.
Short story, I never got around to build one, and now it’s time to pass, pun intended, it on.
You get two new boards, NOS (with golden legs) MPSLs, and used, original, Lambda output TO-3s.
2N5248 and the other components you have to supply yourself.
$200 + shipping at cost.
R
Capacitor quality in 3-way crossovers, different size capacitors, externally mounted upgradable crossovers... And other questions (Anthology II build)
Hi! Before I go into the Anthology build, I'm trying to first carefully calculate costs and predict possible ways in which I should go.
To start off, I have some questions:
1. For building the crossovers, I have found out that Jim stated in his plans that the tweeters should have 8.800uF capacitors. I assume he means 8.8uF (European notation is a little different with , and .) but I find no capacitors of such size. Should I therefore buy 2 capacitors and try to find ones that would add to each other to get exactly that measurement? Or should I rather buy 9.0uF or 8.2u F?
2. I tried to find some objective talk on which parts matter in quality and which don't (like super expensive cables which is propagated by a lot of people, so I don't know who to trust with capacitor quality). Could someone guide me on which parts matter? Capacitors, resistors, inductors... I'm trying to be on a budget but since I'm building Anthologies... I can spend a bit more on these electronic parts if it really is worth it. I saw some people claiming they hear differences between high grade capacitors of different lines and some claiming that as long as the quality is good (like ClarityCap PX), it's not worth paying more because there will be no difference. If it makes a difference, which ones are worth upgrading? I see people usually get these 82uF ones cheaper like ClarityCap PX or even Audyn Q4 (that would reduce the cost dramatically). Where does it make a difference? Will it make a difference where the capacitors are wired between signal wire and ground? (Woofers and mids have these 82uF capacitors mounted like that, the 8.8uF and 20uF are directly on the signal line)
3. Can I purchase capacitors of a reputable brand like ClarityCap and assume the capacitance will be correct without having to buy 5x more parts and picking ones closest to each other? Will that also work for Audyn?
4. If the components do matter, would it be possible to make an external upgradable crossover so I could switch these parts to better ones later on? As far as I understand, when I glue the speaker and install drivers, to upgrade the crossovers I would have to remove the drivers? Which are blocked by the front baffle? I don't understand the purpose of dual baffles sadly, could anyone explain how these are mounted? I thought the front baffle would cover the drivers but it seems it doesn't, so what purpose does it serve?
5. Could someone recommend me some inductors and resistors that I could buy in Europe or from China? Madisound wants 250$ for shipping to EU...
Thanks in advance! I hope to find some knowledge here, the entire thing is very confusing to me as of right now... Sorry for the question dump 🙁
CNC made WN300ALO horns (picture heavy thread)
This is the next step from the plastic horn I made as the very first prototype: https://www.diyaudio.com/community/...-neile-alo-horn-by-sphericalhorns-net.390581/
In this thread, I would like to show the workflow. I really enjoy watching other people's work, so I hope you will enjoy this thread as well. First, some overall data. The horn is ca 64 cm wide, 47 cm deep and 29 cm high. Each is made of 16 layers of 18 mm birch plywood and weights around 20 kg (estimate, did not weigh one). One horn needs two 1500 x 1500 mm sheets with a bit of leftovers. In total, the plywood bought was over 120 kg of material.
The workflow need to fit my hobby CNC. First, I cut all the single layers and rough the 3D parts. This was done by a 1/8" milling bit. Then, the layers are glued by two together and machined with the finishing pass with 6 mm bit. Glue up of the dual slices follows, during the project a friend of mine developed a unique press using water pressure to clamp the curved surfaces perfectly together. Then it is sanding, sanding and more sanding, gluing the two halves together, fitting the driver flange and more sanding.
Ready to start round one.
The slices are arranged to minimize waste.
Another layer cut.
Glue the two roughed layers together.
Reactions: stv and docali
Cannot determine cap polarity from this wiring diagram
Hello all, long time listener first time caller. So as a hobbyist I finally decided to get one of those diy kits from China thats loosely based on the marantz 7c. I have made some modifications but my problem is with this wiring diagram. I can read them OK but Ive never seen electrolytic capacitors shown thiis way, just hanging there. Specifically the top 3. What is the polarity? If I was to guess, positive to 1 and 6 (12ax7 triodes), but I hate making things explode so I thought Id ask people smarter than me. I'm sure this is a rookie question, but ive searched a lot and dont see anything like it. Is positive to both sides and that shorthand for nagative to ground?
Hello from Italy
Hello to everyone in this forum, I'm Eduardo, 25 years old from Italy! Nice to meet you. I've been reading this forum and found a lot of interesting arguments and knowledge. I have a strong passion for electronics, and i'm currently trying to repair my grandfather's old Rega system. I'm looking forward to learn new things!
A new thread for lightbulb loaded amplifiers.
Since the de lite thread is archived i decided to start a brand new thread for lighbulb loaded amplifiers.
I'll start and i present you the "De broke" an cost cut version of the delite using a darlington transistor and a car turn signal lightbulb (that was cheaper than a headlight one and has a diffrent glow) and running on 12V making a whopping 1,5W of power at 8 ohms.
Reactions: gijser
Tweeter repair, Shellac vs Damar?
Yesterday I got lucky, scored a pair of roadkill KEF C40s.
Unfortunately, the tweeter coatings are dodgy, almost completely dissapeared on one, highly cracked on the other.
Careful work with Shellite (What us in Aus call Naptha) got the remains off.
So, the next step is to re-coat them, following the ideas in this thread:
https://pinkfishmedia.net/forum/threads/restoring-kef-c40-loudspeaker-system.293967/
But it occurred to me that I could use Damar varnish as an alternative to Shellac (I have both), however neither are ideal; I assume both will set hard, whereas the original coating appears to have been somewhat flexible. Opinions?, comments?, Alternatives?
(if the worst comes to the worst, I have other alternatives I could use behind the original KEF faceplates. Plan is to restore them to original to see how they sound, more to come whn I've got some pics & measurements sorted)
Another diyAudio newbie
I am a new member of diyAudio although I have browsed the site many times over the years. I have 25 years experience as a technician in the consumer electronics field (HiFi, VCR, computer monitors and television). I decided to join after finding a thread here about the YH11068A DC converter which gave me plenty of information. I now wish to contribute to this thread.
Reactions: dantwomey
Xsim4 frequency response graph not simulating
I have recently learned about the DIY audio world, and got immediately hooked. I really want to build a set of powerful speakers this summer, but I cannot seem to get started with it all. There are plenty of kits online and other designs, but I want to make my own and be proud of it. I have found some drivers that I think meet my requirements, but when I try to use software like Xsim4 or VituixCAD, I cannot make a crossover. I understand how the crossover needs to be built, but the frequency response graphs do not update when I make changes to the circuit. This happens in both programs and I cant seem to find any fixes online. Its very odd because the impedance graph will update with components being added and changed but I cant see the frequency response changes. I have tried using different drivers but it has the same result.
I found 2 Dayton audio drivers on Parts Express. I got the frd and zma files from Dayton Audio's website, and I uploaded them into the software. It seems like there is some setting not checked, or the software version is buggy. I don't really know what to say, the issue is because I have tried other drivers with different frd and zma data, and it still doesn't work. I get even more confused because I can see the simulated system frequency response when the drivers are simply connected to the amp, but that graph remains unchanged if I add any crossover components.
What's wrong with the kiss, boy?
What's wrong with the kiss,boy ? ........ or - How I gained a gain ,little before Lee De Forest and little after Papa
lookie : Iron Pre | Zen Mod Blog
I already posted that link in few places here , but as it seems ,few Greedy Boyz are greedy for more info
cheap and clean way of having 6db (or little more ,with different gain device)
it's already everything written in that blog post , but to recapitulate :
-pot , then buffer of your choice , then 600:600 xformer connected as autoformer , voila! -there is 6db gain
if approach was good eons ago , when microfarrads and active gain devices were much more expensive than chunk of copper and iron,if approach is good for numerous mic input stages , if approach is good for F6 and especially M2 (buffer-autoformer-buffer) , it must be god for line stage too.
and yes , with 1+1 autoformer , Rout is four times Rout of buffer itself
xformers : Edcor have few , Jensen , Sowter, Lundahl etc.............
-do not expect that more expensive ones are necessary better sounding,
-do not expect maximum verity from buffer if you not use decent (shunt , my poison) reg.
-you can go wild and make your own autoformer , equipped with 24 taps , so skip pot on input and use autoformer at output, as volume attenuator and gain device ,as one device
-or you can make it this way - buffer -commercial AVC (200$ Slagle?)-output autoformer
-or you can go wild and connect commercial AVC to appropriate tap , as output autoformer and have 6db gain ...... that would be buffer -commercial AVC connected on proper tap
now I'm working on balanced Iron Pre ..... will post that soon too
edit on 11.10.2020. : last files for SE and Bal iteration are in posts #1149 and #1150
Modular active 3 way - work in progress
I've been wanting to try this for a while. I've been building the knowledge (generous help from DIYaudio members) and acquiring the pieces for it over the last year.
I call this a "work in progress" because I'll be changing drivers and configurations until I'm happy with it. A modular design should accomodate this. So no pretty packaging for now.
- V1 : woofer=tc6028, midrange=pc83, tweeter=td20f :
- V2 : woofer=tc6028, midrange=rs52an, tweeter=td20f
- V3 : 2x woofer=tc6028, midrange=rs52an, tweeter=td20f
- V4 : 2x woofer=tc6028, midrange=rs52an, tweeter=td20f
- V5 : 2x woofer=W20RC380, midrange=rs52an,tweeter=dc28f
- V6 : 2x woofer=W20RC380, midrange=rs52an,tweeter=dc28f
- V7 : 4x woofer=tc6028, midrange=rs52an,tweeter=dc28f
- V8 : 4x woofer=tc6028, midrange=prv290 + sh402, tweeter=cd130+h07e
- V9 : 4x woofer=tc6028, midrange=prv290 + phrn1014, tweeter=cd130+ebay slotted
- V10: 4x woofer=DSA175, midrange=RS52an, tweeter=DC28f
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6310628
- V11: 4x woofer=DSA175, midrange=ZXPC-11x17 + D2200Ph, tweeter=Dayton H07E + CD130
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6914493
Misc other tools and equipment
- turn table for polar measurements
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6238989
- circle cutting jig
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6246764
- fan speed control for amplifiers
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6337253
- plain wave tubes (built 1inch and 2inch)
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6544772
- acoustic impedance measurement tube
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6553137
- UMIK1 repair
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6899378
- optical intf DAC
https://www.diyaudio.com/community/threads/modular-active-3-way-work-in-progress.326926/post-6899483
Mo' Power - 100W / 8 ohms From Tokin 2SK182ES SIT? Can't Resist the Siren's Song
I don't need a hundred watt per channel amplifier but I want one. The siren's song is very alluring and I can't resist, so my next project is a Tokin 2SK182ES SIT amp which I hope wiil be able to output 100 watts into 8 ohms.
Not only do I not need a hundred watt amplifier, I really don't need another amplifer, so I am planning to modify my BAF 2015 THF-51S monoblocks. I like these amps and I've got them currently in my bi-amped system. But I overbuilt the cooling system in them and they barely get warm after extended operation, which makes them the perfect platform for the high power dissipation requirements of the new design.
The other plus is that with some juggling around, I can use a lot of the existing pricey parts. I really don't want to spend a lot of money up front on a design that is unproven.
I knew I needed more voltage than the 62V power supply of my BAF2015 amps. Each monoblock is powered an Antek AN-6450 toroidal transformer. That is a 600VA transformer with 2 x 50V secondaries. Currently, they are wired in parallel. If I wired them in series, PSUD Designer predicts about 135 volts. That's the value that I used for the basis of my new design.
I spent many hours with LTspice trying various circuit topologies. I tried mu follower, choke loading, ccs loading, common drain, and common source. The most promising was the mu follower. I really wanted the common source mu follower to work, but I could not get as much power out as with common drain (follower). The common source version would be easier to implement as it has voltage gain.
So although LTspice said that a mu follower follower could produce 100 watts into 8 ohms, I wasn't sure if that was worth anything if I couldn't come up with a voltage amplifier to drive the output stage to full power. A hundred watts at 8 ohms is about 40 volts peak or 80 volts peak-to-peak. And, the 80 volts peak-to-peak should be fairly low distortion.
Luckily, I remembered that I had been exploring the use of the United SiC power JFETs in preamplifier and amplifier duties and that they performed quite well in those tasks (https://www.diyaudio.com/community/...loring-the-uj3n065080k3s.409636/#post-7624728). In fact, I still had a working prototype of a United SiC JFET preamp sitting on my workbench. So naturally, I decided to explore the upper limits of this preamp.
My previous experiments showed that I could get a clean 50 volt peak-to-peak signal out of the preamp when driven by my test oscillator at maximum output. I have an old Acurus preamp that I know to have low distortion so I set up a test with my test oscillator driving the Acurus preamp which fed into the United SiC preamp.
On checking the output with my oscilloscope, I was very pleased to see that the 1 kHz sine was amplified to about 190 volts peak-to-peak before noticeable distortion was visible. The Acurus preamp supplied about 26 volts peak-to-peak to the United SiC preamp. That encouraged me enough to get out my distortion test rig and take some measurements.
To make things simple, I set the preamp chain to output about 100 volts peak-to-peak for the FFT test. I figured that would be enough voltage swing to drive the follower output stage to 100 watts output with some safety margin. The results show a nice distortion profile with 0.029% Total Harmonic Distortion. This is significantly lower than the expected greater than 1% THD from the amp output stage at full power. So, this was good news.
With all this preliminary work done, I think that it will be possible to reach the goal of 100 watt into 8 ohms with this Tokin SIT. However, the SIT and CCS MOSFET will be operating near their limits, so there are unknowns and rough waters ahead.
But the sirens sing so sweetly.
Replacing Standard Low Pass Xovers with Notch & Shelf Filters
The most common crossover problem in the world is taming cone breakup and removing peaks from woofer response.
Many designers use 18dB and 24dB crossovers simply because they have to get rid of a peak and they don't have a better way to do it. But in general I don't like steep filters. All other things being equal (which of course they rarely are) I think shallow filters sound better to my ear.
My philosophy as a designer is "don't use brute force when finesse will do" and "don't use nuclear weapons when you can use a bow and arrow."
One of my favorite ways to get around this is with shelf and notch filters. At the Parts Express Midwest Audiofest in August, I won a pair of Ciare HWG160-4 woofers. These are excellent drivers. Like most woofers they have some peaking at the high end. This is the Ciare spec sheet:
In a bass reflex box in my room, data imported into VituixCad, the response looks like this, below:
A 6dB filter would level the response overall, but you'd still get that peak at 5-6kHz showing up in the response.
Most folks, then, would apply a low-Q 12dB filter. That would work just fine, but a 12dB filter adds to the driver's 12dB rolloff making a 24dB/octave final slope which has 360 degrees of phase shift. I feel that is undesirable. Given that the woofer is already 2cm behind the tweeter physically, it adds group delay and makes the crossover integration even more difficult.
A notch filter is a more gentle approach.
Schematic:
Signal at driver terminals:
Above is the drive signals at the woofer and tweeter terminals. You see a notch filter at 5.5kHz which cancels out the peak without adding even more phase shift at higher frequencies.
You might think that the -35dB depth of the notch is too much, and initially I did too. But when experimenting with real life measurements I found that it minimized interference with the tweeter.
Below is the schematic of the filter. I have a zobel across the woofer terminals, and a 4 ohm resistor in series with a 0.75uF capacitor, and those are in parallel with the 1.2mH inductor:
As you see above, I get a flat response up to 2K and a very nicely behaved downward taper above that point.
The tweeter is a SB Acoustics SB29BNC. The total circuit and modeled response are below:
The actual measured response of the system, at 1M distance in my room (no gating or attempt to reduce reflections) is here:
These speakers sound fantastic. The woofers reach down to 35Hz in an 18 liter reflex box. 86dB SPL. The tweeters have all of the holographic imaging and detail you'd expect from an SB Acoustics beryllium tweeter. They have precise 3D imaging and a "high resolution monitor" sound signature.
I chose off the shelf Iwistao cabinets https://www.iwistao.com/collections...15l-for-tube-amplifier?variant=31964739993715 - Iwistao will custom cut the driver openings for you before they ship, and it took less than 2 weeks from order to delivery. The build quality is not impeccable - you can see a tiny little mark just above the speaker grille socket for example - but the quality is quite good and the speakers are beautiful.
looking for someone to restore Fisher 173
My son inherited a Fisher Model 173 and loves its sound. It is a nice sounding amp from 1973 with a warm tube-like character and works well with his vinyl and FM playback.
It's sounding a little soft and is lacking a bit of detail and punch. I found a guy, Todd of Timerider.net, who performs full restorations of vintage gear, but he broke a finger and can no longer do the work. I'm looking for someone who would be willing to do the restoration. I have the schematic and service manual.
He offered to perform the following work:
• Fully disassembled and clean. Inputs/outputs cleaned.
• All switches cleaned (pulled, if possible) and lubricated internally.
• All capacitors on all boards replaced, including main filter capacitors (Audio-quality and/or stacked film capacitors in tuner, pre-amp, amplifier, protection, power and tone stages (WIMA, Kemet, Nichicon and/or Panasonic capacitors).
• All Zener and Schottky diodes replaced.
• All trouble-prone or hot-running transistors replaced with modern, low noise units.
• Output transistors pulled, cleaned and re-set with new thermal pads and thermal grease.
• Heavy-duty regulator transistors on power supply board.
• New power regulator resistors on power supply board.
• New rectifier diodes x4 on power supply board.
• Adjust amp circuit with new Bourns trim-pots.
• Adjusted Bias to factory spec.
• New lamps.
• New snubber circuit on power switch.
• Circuit boards inspected for any cracking, burning, etc. Any cracked solder joints re-flowed, especially in high-heat areas.
• Bench tested for 12 hours under an 8 ohm load.
Hello from Long Island New York, USA
I have been bitten by the hifi bug again after many years. Mostly interested in vintage gear, I get a lot of satisfaction in saving old but very good quality pieces of equipment from just gathering dust or worse yet a landfill. I have a soft spot for vintage Kenwood gear, recently acquired a KA-2000 amp and added the matching KT-1000 tuner. I am currently resto-modding some Acoustic Research AR8b's. The woofers need to be re-foamed after 40+ years, the tweeters look fine. I am also going to tweak the crossover by adding a low pass and a high pass filter, the original design has only a single 5 microfarad cap in series connected to the tweeter. Cosmetically the enclosures look pretty good for their age, but I plan on replacing the grill cloth the something with a 70's vintage beige tweed. I am putting money into this project but I was given the speakers for free. Hope to chat soon and also get some valuable advice.
UNSET pentode for voltage amplification
Hello everyone!
Has anyone tried a pentode in UNSET topology and loaded with a CCS as voltage amplification stage? I'm getting very low distortion for 160Vpp output voltage, 220K load, gain 36. The gain is controlled by R2/R4 ratio. I want to build it, but first checking whether anyone has played with this. Tried multiple pentodes, even a 6BQ5 gets around 0.08% full swing at 15ma.
Jose
Single supply, three-pole compensated class-B retro amp
I never saw 3P compensated amplifier so I tried to build one. The basic design is come from the local forum's guru, Danhard. I made fine-tuning to adapt it to the real conditions. Three boards were built, the biggest problem was the correct placement of components and routing so as not to cause distortion degradation. The measured 1kHz/4R thd is under 0.0001%, the 10kHz/4R is about 0.0005%.
As you can seen the loopgain slope falls 60db/decadeView attachment 1044059
Hiraga Class A30 w amplifier
I have just completed a pair of these Hiraga amplifiers and was amazed with the sound. Was never an advocate of class A but after completing a regulated power supply and using transistors that i had available i can confirm that this simple amp,designed some 30 years ago, is one of the very best as far as sound quality is concerned .For those who want to give it a try and cannot get the specified original transistors here is what i used and its working fine with no problem in setting the bias current and the DC offset. I do not want to get into a debate about the characteristics of the transistors i used. I can only say that they complement the circuit and they do the job. Just bear in mind that you might have to adjust the 47 k bias resistor to give around 380 mv measured across the 0.33 R resistors at 30 v. I got it right at around 34.3 k.
The use of a regulated power supply is highly recommended as with it,the amp is extremely quiet,no hum etc.
Transistors used for the output is the 2SA 1942 and 2SC5200
Drivers BD237 and BD238
Inputs BC 258 and BC630. (TYPING ERROR CORRECTED SHOULD BE BC 639)
Greetings from West Yorkshire, UK
Greetings!
I've recently entered the vintage HiFi world, after buying 2 pairs of Monitor Audio R352 speakers - yes, 2 pairs! - plus Audiolab 8000A amp.
This community has been really helpful in helping me swap out the tweeters in one of the pairs of speakers - from metal to the original soft domes - but I'd like to learn more about replacing the bass drivers on one of the pairs of speakers, and perhaps upgrading the crossovers.
Looking forward to getting stuck in!
Neal
Reactions: phreepie
PP KT120 ... The last power amplifier
Hi to all members!
My name is Gabriel, I have been a member since 2009 and lurked before that.
So far I have completed many projects to fruition thanks to others input, their encouragement, critics, and (hard) questionings!
I have been able to to gather from outside in literature missing pieces of calculations and theory to draw tube curves, calculate frequency response, cut off points, oscillation, and the hardest, amplifier gain and GNF loops, which I still don't understand, but I can measure it and listen to the difference it makes.
I have completed so far: many pre-amps (tube and SS), a hifi solid state 100 watt amp, a few 3-ways speakers (alnico, OB etc) and a 2-ways with passive radiator based on Usher drivers with XO simulators and real reactance curves measured in-room with my amplifier.
I acquired a true-RMS voltmeters, a variac, built a test station, dummy load, a dual channel THD analyzer and multiple channels SCOPES and gathered data stored in EXCEL charts, (some are lost now)
I built a few tube outputs from dacs, cd-players, but I am not a dac specialist and figuring oscillation and parasitic noise is too hard for me.
I modified 845 SET amplifier, and two solid state amplifiers.
I built a few PP amplifiers: kt77UL , el84 in triode, EL34 UL, Kt88 UL , Kt88 triode, Kt88 zero feedback, Kt88 LTP balanced input zero and with feedback, 6BL7 PPP, and a few more exotic dac tube outputs, and a Kt120 UL!!!
I have experience with a few types of transformers and many Hammond, Edcor, and high end ones.
I am lacking the experience with LTSpice and time!
The goal here is to post/develop an exotic circuit in LTSpice of a Kt120 PP amplifier which I designed and to bring it to perfection.
I set up years ago the OT to be a 5k low insertion loss high power 80W+ and high inductance design which will remain secret, let say it is similar to a Lundhal transformer. I wish other DIY members buy their choice of OTs and experiment and have the best circuit possible with tube respect to build their DIY amplifier. I have seen many designs and many commercial kits and built them, I want to build something unique which summarize the best knowledge in tube amplifier design and sound accuracy, beyond 'claims' and beyond 'exotic parts' and beyond 'this was good enough'
The philosophy here is to attain excellency by design choices which doesn't cost much as a DIY. I want us in the forum to get that extra listening pleasure that higher price amplifiers bring, not only by the choices of OT and feedback, but also by circuit design.
The amplifier would be a PP UL 70W 1% THD , B+ 600V, Bias servo 67.5 mA. GNF 10.5db or so. There is some margin and testing to do there, there should be a +/- 50 V in the B+ margin to build the amplifier, DIY's should be fine with using 40 Watts to 120 W OT , Bias would also be a choice, there should be room for experimenting by members while I build my own design.
The input tube would be by default a 6sn7gt in common cathode from TungSol or NOS of the highest fidelity, possibly using both sections as follower using the cathode part to take the signal out...
The driver tube would be overkill and easy to obtain like a LTP ECC99 and CCS EL822 (which required a tube and separate TX+PS), it could be also an alternative to use a LTP 12BH7 with LM334 CCS, experimenters could also use CCS and Drains with transistors...
Adcom GFA-5800 Amplifier pops fuse when setting bias.
Hello everyone,
I am working on a nice Adcom GFA 5800 amp. The problem I am having is that when setting the bias as per service manual instructions, the left side .5 amp regulator fuse blows hard (bright light/vaporized metal) only after about 30 minutes of running. I have amp multimeters on both regulated rails feeding the amp board also and the current is steady at 50 ma on each until the fuse blows. The fuse seems to blow when the bias current approaches about 700ma. The current on my variac, idle current, and regulated current do not rise abnormal compared to the right side until the fuse blows, then idle current goes down a bit and fan goes off. I have a thermal camera and the amp is not overheating, and the overall channel and individual components are within a couple of degrees of each other on the regulator board and amp boards. Since everything runs fine until the fuse blows I’m not seeing any odd voltages. This is a fet based amp. My question is what parts have this type of failure mode? Any clues would be much appreciated!
Multiple Entry Horn with removable mouth?
I move home often, so can't design speakers for a known room shape or size (and room treatments must usually be modest, too). Headphones and near-field listening have been the answer, but I miss having room-sized speakers. I suspect that horn/waveguide type speakers would have many positives in this situation, and I find MEHs especially interesting for other reasons as well.
I've not gone there because they would need to be large; unfortunately it is the somewhat lower frequencies, say at least down to 500hz or so, that would seem most beneficial for me to direct. Keel's equasion indicates something like an 80cm (32inch) wide horn-mouth for that, depending on what angle is chosen. Though they would probably need to play lower than their directvity, down to around 80-100hz, as I'd want to hand over to subwoofer(s) rather than need an additional bass driver.
However.. it occured to me that a lot of MEHs are quite sensibly sized around the actual drivers, taps and the straighter part of the horn. So, if the seconary flare and any round-overs were easily detachable and dismantlable (for transport, storage and when letting-agents come to inspect), the size might not be such a deal-breaker.
Though I've never built a MEH or even a big waveguide; there seems to be a huge amount to learn and test, especially if I'm on the wrong track.. For those who have experience of such speakers: do my hopes and expectations seem valid and reasonably achievable?
Thanks,
Kev
Specs for the small transformer inside Parasound 2250 amplifier?
I have a Parasound 2250 Two channel amplifier with a transformer i believe is dead.
I can measure 220V AC on primary side but nothing going to the rectifier on secondary side.
So i need specifications for this small transformer on pictures below.
Selling Zhou Fang’s remaining stocks including some very rare Toshiba transistors
Selling Zhou Fang's remaining stocks including some very rare Toshiba transistors
Sale: I am getting rid of some old stocks to create spaces for new parts, sale for the following items (PS: N/P not matched). Thx
k2013 matched quad (4X): $23 (28%off)
J313 matched quad (4X): $23 (28%off)
k1530 matched quad (4X): $42 (20% off)
J201 matched quad (4X): $42 (20% off)
K170 cota (8X, Idss<7mA): $22 (30% off)
Notice: For customers who want to use courier service instead of Singpost, pls use this website to estimate shipping cost: Calculate shipping rates
Items available:Pls refer to the follow table or Click here
682876d1527174653-selling-zhou-fang-remaining-stocks-including-rare-toshiba-transistors-price-jpg
Matching Curves:
2SJ74BL-2SK170BL Third Batch
Take note 2SJ74 for this batch are taken out from NOS 2SJ75 (as normal J74 are running very low...), so these is no marking on them. Rest assured that these are 100% genuine 2sj74, and the quality is as good as J74 with markings. Pls refer to the excel file for matching details.
batch3_release (1).xlsx - Google Sheets
2SJ74GR-2SK170GR Matched Quad Sets ($42 per set)
J74GR_K170GR Matched Quads.xlsx - Google Sheets
Take note 2SJ74 for this batch are from mixed sources. Some are normal 2SJ74GR, and some are taken out from NOS 2SJ75 (as normal J74 are running very low...), so these is no marking on them. Rest assured that these are 100% genuine 2sj74, and the quality is as good as J74 with markings.
2SJ74BL-2SK170BL Matched Quad Sets--all sold out
First batch: 2SJ74-2SK170 Matched Quad.xlsx - Google Sheets
2SJ74BL-2SK170BL Second Batch--all sold out J74 Batch_2.xlsx - Google Sheets
2SJ201-Y / 2SK1530-Y matched NNNNPPPP
power MOS matching IV.xlsx - Google Sheets
2SK2013/2SJ313
https://docs.google.com/spreadsheets/d/1Z2iR0_6jUHs4GhxxVcFBy31qbvgDGChd96arg_rm_g4/edit?usp=sharing
J75
https://docs.google.com/spreadsheets/d/1_d_jKIvsxYGP2_4FQO9mLGIBa2si7NjNsNIVM3-0TG4/edit?usp=sharing
Sample IRFP240 / IRFP9240
https://docs.google.com/spreadsheets/d/10J2-KA5yA91wPdIgeehZRQrpQr5iC-scRCto_tTg9wQ/edit?usp=sharing
2SK170 matched octal curves
https://docs.google.com/spreadsheets/d/1fcgMEsK8BPPaGctPudCtVpmgMpIr63OiyZ1MCDYtaWE/edit?usp=sharing
Thermal pad:
http://www.diyaudio.com/forums/vendors-bazaar/291486-selling-zhou-fang-s-remaining-stocks-including-some-very-rare-toshiba-transistors-17.html#post5012672
Shipping & Ordering T&C
Ordering:
pls sent me a PM with the following information:
Forum ID:
Real Name:
Shipping address:
Paypal account email:
The list of items, the quantity, and options (matched, unmatched, or special request)
Declared parcel value for customs/insurance purpose.
Payment:
Exclusively by PayPal. PayPal fee is always inclusive in prices shown.
Price are shown in USD$, but for non US buyers, I may invoice you with the USD equivalent in my local currency SDG (Singapore Dollar). This will help me to save on currency exchange fee. X-rate determined by Yahoo Finance. If any non US buyer wants to pay in USD only, please state it explicitly when placing your order.
Shipping and handling fee:
Shipment by Singapore Post International Registered mail.
Once paypal is received I will ship your package within 5 working days.
If anyone did not receive your package within 18 working days from my shipment notice, please inform me.
Free shipping for all orders >= $80, unless otherwise stated. IRFP240 / IRFP9240 are excluded from this offer.
For order between $50 and $79.9, $2 shipping/packaging fee will be charged.
For order between $20 and $49.9, $5 shipping/packaging fee will be charged.
For order <$20, additional $2 small order fee applies, plus shipping fee, a total of $7 will be added to the price.
For unusual items, shipping fee might be different, in that case, I will state it clearly in the item description.
Important Shipping Policy Change: Effective from 24 March 2017, I will not be responsible or provide refund for any lost of packages through Singpost registered mails, unless the packages are insured. Take note insurance of the parcel is not included in the shipping fees stated in the shipping T&C. Pls contact me for quote of insurance. Pls do consider using more reliable delivery service providers, such as DHL, EMS or FEDEX, if your parcel’s value is above $100. Pls only place order if you accept the condition. Thank you for your kind understanding.
Search Index: 2SK170-BL, 2SK170-GR, 2SK170-BL / 2SJ74-BL, 2SK369-BL, 2SJ103-BL / 2SK246-BL, 2SJ201-Y / 2SK1530-Y, 2SK2013 / 2SJ313, 2SJ75-BL / 2SJ75-GR, 2SJ109-GR, 2SJ109-BL, 2SK79, IRFP240 / IRFP9240, 2SC2911S / 2SA1209S, 2SA1943-O / 2SC5200-O, 2SK117-BL, 2SB737.
XMOS board interface with AD1865
Hi everyone,
Id like to connect the I2SoverUSB interface module to a CS8414->AD1865 board (see picture below)
The "lazy" approach would be connecting the SPDIF output from the I2SoverUSB to the SPDIF input on the DAC board, although my understanding is that I could bypass/remove the CS8414 and drive the AD1865 directly from the I2SoverUSB. Has anyone any experience with it?
Diy speaker for phone
Hi! Im new to audio world. What to i need to make a speaker for phone/ boost audio with a d class amp. Can I use a pam8403 with a rechargeable battery and connect it to my phone using usb c to 3.5mm dac. Or should i buy a cheap pc speaker and connect the speaker part to the amplifier and then into the phone. Does it work like that. Any help is appreciated. Thanks.
QUAD 303 PSU fault
My Quad 303 won't switch on and I'm just checking I'm on the right track, checked dc at main caps and got nothing
Confirmed 230vac to transformer,
Disconnected transformer secondaries from bridge and got
46vac
7.5vac
Connected them back and disconnected vdc from bridge rectifier and got
On the vac 48v and 8.1v
on the vdc outputs on the bridge measures 2.5vdc on both
I'm leaning towards a faulty bridge rectifier?
Does this sound correct?
Speaker Turn On Delay and DC Protector Board Set (V3)
This thread is for discussions about the new Speaker Turn-On Delay and DC Protector boards (V3). This is an updated version of the V2 boards, primarily to make them compatible with the 10x10 grid mounting pattern we've now standardized on so they can be easily mounted to Deluxe chassis baseplate, riser panels, front panels and/or heatsinks. Refer to the V2 discussion thread for additional information.
For more information on this product, please see the product page.
Change History
  • 2.0 First Production Release
  • 2.0.1 Added Board Dimensions
  • 3.0 New Layout
    • Double sided board
    • Added Keystone connectors as option
    • Conforms to 10mm mounting grid
  • For future changes
    • Add polarity markers for electrolytic capacitors
Information
  • Product Page
  • BOM - Attached below (Now updated to V3.0.2b) -- 3-paged BOM
  • Schematic - Coming soon
  • Dimensions - 100mm x 50mm
Best 1" compression drivers & compact 1" horns 2024?
Hi, community.
What would you judge as the best (premium, but still somewhat affordable) 1" exit throat compression drivers of today? Along with a compact horn that would fit in a normal living room compatible speaker - meaning around 8" diameter max.
My first candidate pair would be an 18Sound NSD1095N on an XT120 horn. Probably hard to exceed that actually, according to its excellent Voice Coil test.
Stoneeh
Measurement mics
What's the forum consensus on the best XLR measurement mic thats available out there? For home/outdoor DIY speaker measuring + crossover design.
I've currently got a Dayton EMM, A SoundID reference and 2x UMIKs, and while they all measure similar in the bass to mids, the highs are all over the place with about 6db variance between them (yes, tested in the same stand in the same location with the mfr cal files, at the same time in the same temp). Funny the USB* mic measures the highest treble output, sounds the most neutral to me when used to voice designs, but I need XLR for the proper 2 channel measurements.
Are the cross spectrum calibrated Daytons the go-to?
For Sale Audio Amplifier Components Bundle (South Africa)
Clearing out my stash of amplifier parts. Original manufacturer parts. I am offering a substantial discount for anyone interested in buying the bundle (this is my preferred condition of sale). I am sharing a list of prices off the internet as of 1 week ago. Parts on offer have a new value of over R11000, averaged over 4 suppliers, excluding postage and duties. I am asking R5000.
I will keep the offer up for a while, with the hope that someone will take the bundle. Failing that, I have given prices per item.
To the person who takes the bundle, I will also give a bag of 15 35A bridge rectifiers and my unfinished projects of 4 stereo amplifier boards based on LM4702 driver chips (they are just missing the transistors).
Condition: New (except for 2 used items)
Price: R5000 for all
Shipping: Yes. Pudo locker or door-to-door. Buyer's cost.
ComponentManufNotesQtyDigi-KeyMouserRS CompsFarnellMkt AveMkt Ave TotMy PriceTotal
MJE350STPNP TO-126
10​
12.50​
13.00​
14.00​
13.50​
13.25​
132.50​
10.00​
100.00​
MJE340STNPN TO-126
10​
12.50​
13.00​
14.00​
13.50​
13.25​
132.50​
10.00​
100.00​
MJE15034ON SemiNPN TO-220
22​
25.00​
27.00​
30.00​
28.00​
27.50​
605.00​
20.00​
440.00​
MJE15035ON SemiPNP TO-220
23​
25.00​
27.00​
30.00​
28.00​
27.50​
632.50​
20.00​
460.00​
8TQ100Int RectSchottky Rectifier TO-220
43​
15.00​
16.50​
18.00​
17.00​
16.63​
714.88​
10.00​
430.00​
2SC3281*ToshibaNPN Power Transistor (*used, tested)
5​
60.00​
65.00​
70.00​
68.00​
65.75​
328.75​
40.00​
200.00​
2SA1302*ToshibaPNP Power Transistor (*used, tested)
2​
60.00​
65.00​
70.00​
68.00​
65.75​
131.50​
40.00​
80.00​
2SA1943ToshibaPNP Power Transistor
2​
75.00​
80.00​
85.00​
82.00​
80.50​
161.00​
60.00​
120.00​
MJL4302AON SemiPNP Power Transistor
19​
90.00​
95.00​
100.00​
97.00​
95.50​
1814.50​
70.00​
1330.00​
MJL4281AON SemiNPN Power Transistor
17​
90.00​
95.00​
100.00​
97.00​
95.50​
1623.50​
70.00​
1190.00​
MJL21193ON SemiPNP Power Transistor
8​
118.94​
112.70​
120.00​
114.00​
116.41​
931.28​
90.00​
720.00​
MJL21194ON SemiNPN Power Transistor
8​
118.94​
112.70​
120.00​
114.00​
116.41​
931.28​
90.00​
720.00​
LME49811Nat SemiAudio Driver IC
4​
120.00​
125.00​
130.00​
128.00​
125.75​
503.00​
90.00​
360.00​
L4780TANat SemiDual Audio Power Amp (LM3886 x2)
4​
150.00​
155.00​
160.00​
158.00​
155.75​
623.00​
110.00​
440.00​
LM4702Nat SemiBalanced Audio Driver
1​
130.00​
135.00​
140.00​
138.00​
135.75​
135.75​
100.00​
100.00​
Cap Electro MXR 1000uF 100VRubyconAudio-grade Electrolytic Cap
91​
20.00​
22.00​
24.00​
23.00​
22.25​
2024.75​
15.00​
1365.00​
11425.69
8155.00
melted crossovers
I picked up some more speakers to restore this week.
Interdyn P33 which is a nice unit, when I got there the mid ranges weren’t working and the woofers had been replaced. I nearly walked away but decided the cabinets might be resurrected and/or I could use the tweeters and crossovers as spares, probably too generous but paid $50.
Well….the mids are fine but these have to be the best cooked crossovers I’ve ever seen!
I did what I could to trace the design, I was a bit worried the inductors would be damaged but they both read an identical 0.18mH/0.4 ohm so I might be lucky.
The crossover design looks interesting, first order only with some impedance compensation, nothing at all on the woofer.
Based on the sketch this would be 700Hz/5kHz, can anyone see anything wrong with my assumptions?
SEAS H086 tweeter, 10 F-M midrange and normally a 25F-EWX woofer has been replaced with a Plessey C100.
Reactions: STOXX
Measuring Response: How close is "close enough" to anechoic?
(Edit: Sorry about the extra large photos: I'll re-size if I have the time)
About a month ago I purchased a pair of Elac DBR62 speakers and sent it to Amir at AudioScienceReview so he could measure it with his Klippel Near Field Scanner. Results here:
Elac Debut Reference DBR-62 Speaker Review | Audio Science Review (ASR) Forum
The reason I was interested is because I'm starting back up doing reviews and thought having the NFS 'anechoic' measurements would be a big help in determining my measurement method for reviews. My initial plan was to measure outdoors for far-field mid/high frequency and merge with a ground-plane measurement for low frequency. So, here's the first measurement...
Test # 1) Speaker on platform ~ 8.5 feet off the ground; window to about 13ms with accuracy down to approximately 100hz.
Speaker flush with front of platform (picture was taken before I began tests). Mic at 1m; signal 2.83v. Note: I don't care that the mic stand can cause a reflection for this measurement; this is just a test of a test.
Pros: This method has the benefit of having very high resolution as you go above 200hz.
Cons: being subject to the elements (cold, wind, rain; external noise not really an issue in my area) and having to hoist a speaker up 8.5 feet in the air and risk throwing out my shoulder should I ever test a floorstanding speaker.
Here's a photo of the setup:
index.php
Here's the result compared to Amir's. You can see some decent differences namely above 1khz. Notably the 1-2khz region.
index.php
Now, I wouldn't say that test was 'final'; it was just a "proof of concept" and I suspect that I could probably get better accuracy with an additional test and higher # samples that feed the average. Given the hassle of setting the speaker up high I thought I would try a few other methods out to see how they compare.
Ok. That brings you up to speed to today's testing. Where I tried a number of things. I'll list the method, the pros/cons and provide a picture of the setup as well as my result vs Amir's result. Note: The stand was thrown together from scrap wood; if I were to use this it would change. But I didn't want to waste too much time because storms are setting in this afternoon and I needed to get to work. Also, ignore levels for now. I used a mic calibration file for FR but haven't checked the level with the pistonphone; I only care about the general trends for this process.
Test # 2) Measurement on a 5 foot stand in my garage; gating was about 4 ms.
Same stand used below but inside my garage with a ceiling height of about 10 feet. The speaker was positioned about 5 feet above the ground with the tweeter at about 10" off the platform. Mic at 1m; signal 2.83v.
Pros: Don't have to worry about the elements nor do I have to hoist the speaker 8 feet in the air.
Cons: Poor resolution below 1khz. I don't think I would even bother posting this data. For a single drive unit it's fine. But, speaking from experience, I need good resolution to determine where to merge LF response data of ported loudspeakers.
I didn't take a picture of this setup.
Here's the result compared to Amir's:
index.php
Test # 3) Outdoors on stand. Same stand as before. Window ~ 7ms.
Pro: Better resolution than garage measurement since ceiling reflection isn't there and thus gating is extended an additional 3ms or so. Don't have to hoist the speaker up 8 feet in the air.
Con: Outoors; weather/environment. Still not as reflection-free as the 8.5 foot platform or ground plane measurement (see below).
index.php
index.php
Test # 4) Ground Plane Measurement: Speaker Angled ~ 8 degrees; window out to 40ms before first reflection.
Speaker was angled at about 8 degrees so that the tweeter would be pointing on-axis with the microphone (well, as on-axis as it can be without burying the mic and pointing the mic at the DUT). Mic at 2m; signal 2.83v. Note: Though the response was gated here, if I were to actually use this method I would move to the back yard where I could get the nearest reflection about 40 feet away which should get me down to around 20hz.
Pro: Invulnerability to reflection; I can get ever further out in my backyard. High resolution in to the very low frequency region.
Con: Outdoors. Diffraction effect of speaker changes due to the baffle doubling (via the mirror image effect). HF > 10khz seems to be a pain. From my research that's generally accepted as questionable. Though, I had decent results.
index.php
Phone placed at tweeter on baffle and used in 'selfie' mode to make sure the microphone was at the center of the image (trick I learned on another website).
index.php
index.php
Thoughts:
At face value, each of my methods look pretty reasonable. And all are pretty much "industry standard". You can go to a website or magazine and see any number of reviewers using any of the above methods. But I wanted to do a comparison myself and see if there was any one method that is better than the other. Unfortunately, there isn't. I was hopeful the Ground-Plane method would yield the utmost accuracy (aka: match what Amir has). But it's missing the 600 hz - 1khz bump Amir's data shows and there's a slight difference in the LF region. Potentially diffraction effects; but playing around in EDGE and VirtuixCAD I didn't see the influence. Otherwise, it looks pretty dang good.
There's two possible reasons I'm seeing differences:
1) none of the methods I use are fool-proof
or
2) I shouldn't put all my trust in to the NFS (not saying it's wrong; just saying it may also have a few things that make 97% accurate instead of 100% accurate; keeping in mind that an anechoic chamber has its own issues).
I think the answer may actually be a large heaping of #1 and a small portion of #2. All of that said, once you combine these possibilities with the level of detail I'm viewing this in... really, none of my results are extremely different from the NFS results. They're just different in some areas and alike in others. I mean, I'm usually within 2dB difference. Which, yea, it's not minimal but in the grand scheme of things, I'd say that's not too bad. I want to be closer, though.
Ultimately, this is where I am at at this point:
I still want to re-test on the 8.5 foot platform. Maybe I can do that tomorrow.
Measuring in the garage is convenient. But measuring outdoors provides better resolution, especially in the area where I would need to perform low-frequency response stitching and that is useful in determining how best to align the two sets of measurements.
I would prefer to find a method that yields the best accuracy without the need for additional post-processing. Though, when I started this venture my plan was to use the outdoor farfield measurement for > 200hz response and merge that with a ground-plane measurement for low frequency.
But if I could figure out how to calculate the diffraction impact then I could just remove it from the result. I could also use the near-field technique but if I were to get an oddly shaped port (flared) or something that's harder to easily measure and quantify then that would impact accuracy as well. There's also the "mic in the box" method but it has the issue of being able to fit a mic; some speakers (like this Elac) won't allow my mic inside the slot port.
If you've read this far I assume you have some vested interest in these results. So, I welcome your opinions, as either or both fellow testers and reviewers. Would you say the ground plane measurement is "close enough"? Is there a formula or set of formulas I can incorporate in to my Matlab script (which post-processes the data) to account for diffraction in the ground plane measurement? Would you stick with the original plan, combining "speaker in the sky" (Test #1) for mid/high frequency with ground plane for LF?
Am I off my rocker?
- Erin
CDM-4/36 in a NSM jukebox, TCS0372DP2 on order. Hope I guessed right…
So my CD jukebox is sick. For awhile it has been giving me trouble with some 700MB music CDs. It used to play everything just fine. But lately (2 years) it would only play the first half of some, not all, disks. Eventually it stopped playing any disc, resulting in an error code 61, no disc detected. I read about common issues so I replaced all the aging electrolytic capacitors on the servo and decoder boards and performed the laser current and focus adjustments using my voltmeter. Success! It was working again, but only for a few months. Again it started acting up, presenting similar symptoms. However, this time the current and focus adjustment did not help. The present symptoms are this: only the first 10 seconds of any disc, or any track, will play. After about 10 seconds the audio output gets scratchy and the disc stops. No errors, no faults. Watching from the side as the laser pickup moves, I can see it move to higher (further to the outside) tracks somewhat slowly after making a selection, maybe 1/2 a second to get to say track 15. My assumption is that is very slow. I then decided to disassemble the CD drive unit. I inspected the radial movement and spindle movements, both moved freely with no binding or sticking. I also tickled the radial motor with a small DC of only 0.9 volts and it moved freely back and forth with no issues proving to me the motor is not at fault. At this point I started focusing on the servo/tracking control board. I found no bad BJT transistors, zener diodes, or passive components, which left me to suspect the servo amplifier, L272MB. Actually my drive has a TCS0372DP2, dual power op-amp. So today I wait for my obsolete part to arrive. I hope I guessed right. Your thoughts?
See my youtube video
BTW- In the video I don’t think I was on the correct test point for the eye pattern. But I'll worry about that after I get her running better.
Accidental discovery
Been dealing with headphone amps again. This time an accident caused me to fall onto a discovery. In short, my SPL Phonitor SE died. It was my fault. Ok, so it has been sent off to the repair people who will shock me with a quote. There is that. But then, I knew that I was not going to be happy until I had a headphone amp of decent quality to replace it with for the meantime. I looked plenty and came upon the Whammy. I would have built one but as it turns out 6L6 had one already to go and so I bought it. Case almost closed. Did a little fiddling with the chassis because that is what I do and then listened. Volume wasn't quite right, but resoldering the volume control seemed to remedy that (more on that later). I really liked what I heard, but my Hi-Fi 400SE cans are pretty good but need help in the bass and maybe just a little in the treble. When it was up and running, I placed it next to me Black Ice SS-X soundstage expander or what ever they call it no days. Designed by Jim Fosgate, this unit uses crosstalk, has a sort of bass control and the total effect can be adjusted for anywhere from slim soundstage to wide. That is the selling point to me. No preset buttons, you dial it in. It then dawned on me to hook up the SS-X in front of the Whammy. In short, the sound is some of the very best that I have heard. I forgot to mention that the Fosgate unit also incorporates a tube buffer adding fulness to the 400SE phones that they need (at least some of it).
While messing with the Whammy I think that I may have caused another problem that first seemed to be about the volume control, but I am not so sure right now. One channel is still way behind in volume compared to the other channel, and since I listen pretty loud, the volume of each channel is the same, but less than 1/2 volume one channel really drops off.. I plan to attack this, but I must admit that I am very taken by this great sound and want to listen for a while.
I should add that I am even tempted to buy another Whammy while I get this one just right, but we'll see. The power supply voltages are in good shape and so the problem is beyond that point.
For Sale 100% working Whammy headphone amp PCB
Unfortunately my position is being eliminated from my company in the next month, so I am going to sell off my partially built gear to save up some money.
For sale here is a 100% working and tested Whammy headphone amp board. Opamp is an opa2134 and pot is a 50k alps RK27 blue velvet.
I am asking just $180 for it and I’ll ship for free. If you need more parts to finish it I can throw in a pair of rca jacks, a 1/4 headphone jack, and mogami wire.
SB Acoustics 2-way as gift, bass alignment?
I am working on a gift for my father-in-law. looking for advice on bass alignment.
I have previously built the speakers you can see in this thread https://www.diyaudio.com/community/threads/3-way-w-sb-acoustics-ceramics-woofer-choice.348896/
My design is for an approximate 0.5 ft3 or 15 L box with a SB17 woofer and SB26 tweeter in a 6" elliptic waveguide.
Have the choice narrowed down between 2 passive radiators, or a 2" port.
1. Passive Radiator: SB15SFCR-00
https://www.madisoundspeakerstore.c...b-acoustics-sb15sfcr-00-5x8-passive-radiator/
Very similar to what I see used on commercial speakers with a 6" woofer. The F3 I am seeing is a bit higher than I would like, but my in-laws are by no means bass heads.
F3 51.1 Hz, F6 43.0 Hz, F10 37.2 Hz
2. Passive Radiator: SB20PFCR-00
https://www.madisoundspeakerstore.c...acoustics-sb20pfcr-00-passive-radiator-round/
With this I get a deeper extensions, but the moving mass is quite high. Having not worked with passive radiators before will this lead to "slow" response.
F3 46.9 Hz, F6 40.0 Hz, F10 35.1 Hz
3. Ported: 2" flared port
No surprises here, just an 8" or 20cm flared port.
F3 45.6 Hz, F6 38.9 Hz, F10 33.2 Hz
I have some desire to use a passive over a port as placement will not be ideal and it could be fun to do something different. Perhaps this is all moot if I decide to cross a sub at 80-120 Hz.
Details that will help guide advice. These will be placed on a large TV console. It is low and fairly deep, speakers would be about 12" from the back wall. Console is probably 96" wide. The room has a horrid echo, stone floors and ceiling height stone on the kitchen at the side. My in-laws live in Shanghai, so will be hand delivering the speakers my next visit. Will buy the electronics (integrated amp) when I am there. May also get a reasonable 12" powered sub as the room is quite large (estimate 18 ft by 40 ft).
Picture of design concept:
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,797
Members
7,888,845
Messages
Filter
Forum Statistics
Threads
406,261
Messages
7,888,845
Members
507,797
Latest member
Moza
