I'm a recent convert of the lowest possible impedance of power supply based on my experience of adding caps to my chipamp. So I figure the signal stages can't be harmed by reducing their supply impedance either, particularly at LF.
I note there are a few aftermarket regulators around - I had a look at Paul Hynes and Belleson in the past few days. They're a bit pricey for my tastes, given the cost of the components they're using can't be over single digit $ so I've had a look at "doing it at home, only cheaper".
First off, a simple TL431 is about the best bang for the buck achievable, as the part here is 0.2rmb. But the dynamic impedance is typically 0.2ohms and I was hoping and aiming to go a bit lower than this - perhaps an order of magnitude lower, to around 10mohms. Lower than this and the resistance of the PCB tracks come into play and its also very hard to maintain such a low impedance beyond the audio band as cap ESRs (for the best ones) are of...
