What's wrong with the kiss, boy?
it's written , see on on bottom one
regarding CMOQ-4 , see attached
if you did as drawn , without getting close to 1Vin/4Vout , something is fishy with your measurements ......
That makes sense, especially as a utility preamp, you don't want to high of an Rout.
I should have clarified- I am thinking of using this into a hiZ input, such as the Salas 6V6 buffer to get just a little bit of a boost.
most probably adding too much to Rout
think about Rdc of windings ...... even if there isn't simple adding of Rdc in Rout figure , there still is substantial consequeance
I suspect it is not of quality to be on par with rest of concept
however - it's cheap enough , just try it
Could you please tell what parameters to look for selecting a transformer for voltage gain in preamp.. from the iron pre it seems to be a 600ohm:600hom.. ie. 1:1 turn ratio (can we look for a 1:2 turn ratio for gain more than 6db).. what other parameters do we need to look for
it needs to be linear ...... not just on paper , as many of these small and cheap thingies are
connected as autoformer , 1:1 is becoming 1+1 , having 2V/V gain , which is 6db
if you take 1:2 , it is becoming 1+2 , giving 3V/V gain , which is 9.5db
there is waste number of possible xformers ....... if you take 600CT:600CT , that's practically 4 windings of 150R (nominally) ......
you can use that one as 1:1+1+1 , resulting in 1+3 , having gain of 4V/V , which is 12db
and that's where I think you need to stop with gain , because Rout of entire shebang is really going up
