Wayne's BA 2018 linestage
So finally got around measurint the WLS distortion. Pretty new with this equipment. But if I dis this right (caveat!!), it looks like 0.0045% negative phase 2nd harmonic distortion dominant (if I understand the way to read the 334A at the 0.001 setting). I think I might have misread it too low. Need to rewatch Wayne’s BAF video.
sine is not perfect, but parts aren’t matched so maybe OK?
does this look right, friends?
regards,
Andy
Reactions: Mikerodrig27
I have read up a bit, printed the manual. The copyright on this thing is from 1966! Impressive, old stuff working like a charm.
the manual says that a 0.4 reading on the 1 percent scale, means 0.4 percent distortion. If read correctly (on the correct lines and dots), my WLS shows .35 on the .3 percent scale. That would be 0.105% distortion.
have adjusted the meter, and will redo step by step following the manual 🙂
once I dial this in, I will measure both the ACP+ and J Zen 🙂
Andy
As planned I got to remeasuring today, with a cleaner sine too, following manual.
end result is 0.081% distortion. Very happy with that. Single ended, 7db gain.
reconfirming neg phase 2hd, affirms my suspicions as to why it sounds so good with my Aleph J Zen. The J was measured to redicilously low levels of distortion @ 1 watt output today, approx 0.15 percent. Neg phase that too 🙂 But need to redo those measurements.
btw, preamp noise under 300uV measured at the outputs. Completely independent of shorting input or not. And a noise environment for the probes. Very nice 🙂
thank you, Wayne!
regards,
Andy
Boyz are referring to Focusrite 2i2 as good one for job
I have one, but still (lazy) grinding with my old and trusty EMU1212
Never got confirmation that the Focusrite solution enables visualization of the residual waveform?
don’t own a PC, so this was an easy and cheap solution for me to achieve initial goal: adjusting the BA-3 FE.
anyways, soundcards are for sissies. Real men use Audio Analyzer :rofl:
will check out the Focusrite some more. Maybe sell the 334 on ebay. They can fetch good money.
