Yes, YBDZ.Ydbz?
input connector and mute sd connector on left side, so looking at it from chipside: +,-,+,- (I think all 3116 boards are like that or should be LOL, 3116chip pin-layout, if your green board is Advance Controls ac1103 tpa3110 eg, tpa3110 is + - - +)
Thank you!
Cannot comment on these, but remember reading an opinion that the Alps sounds a little bright with these amps. I've had excellent results with this (think it is an 'Omeg'):Any opinions on sound performance between Panasonic EVJ-Y10F03A54 Stereo Pot (VS) ALPS 50K, Blue Velvet - STEREO Pot
Dual Potentiometer Logarithmic 47K Variable Resistor | eBay
Also tried the following which is more pricey (for entertainment see what 'hifi collective' charge for this!). Mine had very poor channel matching at lower volumes and my impression was did not sound quite as good as the one above, although still acceptable once you get past the lower volume channel matching problem. (I guess it is possible mine was an ebay fake, but the engraving was exactly like illustrations of real ones and build quality was solid).
1pc Cosmos Tocos Potentiometer RV24YG 24mm A 50K? x2 Log Japan | eBay
50K Tocos Cosmos RV24 Stereo Potentiometer Hifi Collective
By the way, here's some interesting reading on Panasonic OSCONs:
http://industrial.panasonic.com/ww/.../AAB8000_e/AAB8000_e/Technical_Note201305.pdf
It is marketing literature from Panasonic, but it may explain why most who have tried these find them to improve the performance of TPA31xx Class D amps. Nichicon and others also offer conductive polymer-type caps in radial thru-hole and SMD mount versions that are probably worth trying.
I've also been wondering what these Nichicons can do. ESR is rated just 7mΩ. However, they are only rated up to 16V but since some are willing to experiment with 6.3V rated caps maybe some of you would be interested in comparing them to OSCONs?
Way cool!
Personally I would never consider under specing a caps voltage - why would you risk it?
... Advance Controls ac1103 tpa3110 ...
Do you have any more info on this board? Sure and TI eval are the only tpa3110 boards of which I'm aware. If there are others, I'm interested!
Advance Controls makes the board ebayseller audiobah sells and now has been copied by YJ. They also make 3110 amps, a stereo btl and a mono pbtl version, and offer a 2A 15V smps powersupply for them (2A is max 3110 according to datasheet TI, so is enough), with 15V the pbtl boards are more powerfull then 3116 LOL size 50x50mm like hiampmini. and psu 50x100mm. Advance Controls prices for 3116 (audiobah)~ $8, stereo3110 ~$4 mono 3110 ~$3, 15V2A psu ~ $5. 3110 pbtl unmodded sounds a little warmer then "audiobah".
URL plz???
I was going to have a play with the sure tpa3110 board in an active setup,
has anybody bridged the sure tpa3110 board??
If so, is it straightforward getting hold of the pin/traces?
A totally noob question:
I'm starting to assebmle my first amp. It happens to be a TPA3116, the red stereo one.
Questions:
- what sizew ires do I use for signal? I don't have the connector, so I think I could solder through board?
- size of wires for output? My speaker cables are 2x2,5mm2. Must they be the same from amp to terminal or is there somehigher science behind?
Questions:
RHING,
What was the performance outcome if any, in swapping out the CoilCraft 10uH SER2915l-103KL for the smaller 222uH CoilCraft MSS1583-223MEB SMD as noted in the post below.
That makes sense regarding the ceramic caps.
As for the Sure amp vs. the modded YJ blue/black amp, the Sure amp is hands-down a better amp in stock form vs. the YJ amp in stock form. Based on my limited experience using the Panasonic OSCONs in the SMSL and YJ amps, I would expect improvements to the Sure amp as KJA 2013 has reported (and lacro in an indirect way).
Just to throw another wrench into the woodwork, I have four 22uH CoilCraft MSS1583-223MEB SMD inductors on their way to try out. These are a more compact form factor than the CoilCraft 10uH SER2915l-103KL inductors on my modded YJ amp, and since some here insist that 10uH inductors and .668uF caps are the wrong LC filter combination for my 8 ohm nominal impedance Klipsch Forte II speakers, I'll try these.
I'm planning to use my YJ black board to run my bass shakers (attached to the couch). I have four of them and they are 4ohm each, so I understood that by connecting them in 2s2p formation I would end up with a 4ohm solution.
I was planning to run the board in PBTL but I'm not exactly sure how I should do that, which components to remove etc. I understood some of you have done a PBTL mod but a photo of the mod would be great.
Do you think I would benefit from upgrading some of the components, like the DC power caps or output filter coils? Sibilance is probably not an issue in this use but reaching the lowest frequencies and getting enough power to the shakers might be.
I'll be running this off a 19V/5.2A laptop brick.
If I remembered correctly, the typical YJ boards come with 100 uH inductor and are designed for 4 ohm speaker loads. The PBTL version will handle loads as low as 2 ohm. So, if your speakers are 4 ohm nominal, the amp board "as-is" should be fine.
*10uH.
Also note, the PBTL version won't give you much more power than BTL with a 4ohm load. As mentioned though, in PBTL mode you can drive a 2 ohm load and develop more power (thanks to higher current output ability of the chip in PBTL).
DC electrolytics YJblue if Jamicon barely function, you can also add additional caps offboard on DC-input to help PSU, 100W PSU 19V isn't enough for 1 board and yes many other people use 50watt PSU and are very happy. If it doesn't deliver enough energy for the shakers just keep that in mind 😀
OK trying solids once again, Oscons on pcb first, playing now for a day. Anybody noticed they needed longer to settle/burn in? The Panasonic hybrids do not improve I feel, but Oscons???
Wanted to put the board into a lego box earlier, but when I hooked it up to check if the signal connection is soldered okay, I just couldnt unhook it. Still listening to the thing😀
The topping tp20 was not only too weak for chr70's in a fh3 box, but the sound also lacked some "body". This is THE thing. I don't really see why, but I may try some stingy mods. Someday. If I manage to give it enough off time😛
Here's the photo I'm not proud of..😛
So I am preparing for DUGs PBTL boards and I ordered a pair of PSU boards from john broskie at tubecad.com. these are regulated lv supplies and well filtered...dead quiet. I will be ready for "dual mono" when they arrive.
I got a toroid xformer from antek...200va 20v dual secondaries. Since it gets fed raw 28v at 4A after regulation I get exactly 24V after diode/regulator losses. Plus the TPA doesn't draw that much current.
I ran one of the supplies to my hotrodded blue boards and I must say it continues to impress the hell out of me. It thumps like a class ab but sounds like a SE tube amp...TI really worked some magic on this chip.
Very Nice!
- Class D
- TPA3116D2 Amp
