The Singing Bush Tips 'n' Tricks
and industrial ultrasonic baths
Listen to your Captain :rofl:
One SIT gain board down. I realize I soldered in the 22r gate resistor. I’ll either clip it out or bolt into the board for that nice clean look. 😉
Thanks for the tip on the 22r. It does look nice on the board. 😉
Absolutely will add the heat sink for the IRF510. Thanks ZM. These boards are more form than function at the moment. I’m making sure I can fit everything in my chassis’s in full mock up form.
So I made the mistake of looking at IXYS's sheet on mounting SOT227 devices and they made it sound like the silicone grease I got from MOUSER is not recommended.
They recommend DOW CORNING TC-5022 though every expensive a small amount - Dow Corning TC 5022 Thermally Conductive Compound 3.5g - modDIY.com
THEN the next level is an Indium pad. I know this is most likely overkill - I can see ZM's eye rolling towards the ether ..
Indium Foil Cooling Thermal Pad Alternative to Thermal Paste/Grease fo – Cold & Colder
I doubt we are running these parts at anywhere near the heat level these recommendations are considering but it is always fund to do something ridiculous in DIY audio.
I was planning on using the silicone stuff I recently got from MOUSER before reading these specifications sheet.
Made it sound like using any paste required very careful application.
So is even considering this stuff a flight extreme audio kookery?
What are others using?
I just typically use Thermal Grizzly Kryonaut. It's a high-end paste for use with CPUs and other computer applications. Pricey compared to others, but has always worked well for me.
I finally got around to replacing the under-ventilated top covers for my monoblocks. Another homage to Digital Do Main… lot more holes now, along with some more bling. They’ve definitely helped lower temps.
methinks that you need more work on that ddomain signs
get them to engraver and engrave on symbol lines "Tnx to Papa!"
:devilr:
with that logic, I could badge any of my amps as Motorola!!!!!!! or Tokin!!!!!!!!! or IXYS!!!!!!!! or IR!!!!!!!!!!
ok, at least one I can badge PASS!!!!!!!!!!!!!!!!!!!!
:rofl:
Well, I was looking at more as the ‘SIT’ symbol rather than the Digital Do Main logo. By homage I meant, “look, here’s another SIT symbol on top of an amp!” I’ve seen a few others do it, so making sure I received no credit for originality.
Yes, I DO need to add a TTP (Thanks to Pa) text somewhere 🙂
