Something like this:
Vintage Hexacon 500 watt Soldering Iron | #435086464
It's a welder, I think ... The laminate would be burnt through.
I improved the soldering at the gnd audio points. Next I did this:
1. I turned on the power supply without load - no difference and 0V between the chassis and the gnd
2. I turned on the power supply with only the left channel. Also 0V
3. I turned on the power supply with only the right channel. 3.4mV between chassis and gnd.
Will it help in the diagnosis?
Edit:
4 I turned on with both channels. No improvement, so 6.8mV on the right and 0.8mV on the left channel.
Edit:
But between the two gnd-points.....20 cm from each other ......they are connected together via the PCB ground plane?
I can only thing about a bad connection.......
What is the voltage between the two gnd-points?
It must be zero......unless there is a very large current flowing between the two points...
What if you measure AC.....or is it AC voltage you measure?
I would try to also re-flow the solder joints for the capacitors. There must be an "unbalance" somewhere. When charging these caps very high current is flowing and if one has a bad connection you will have much more current flowing in one part of the PCB which can maybe cause a difference in voltage between the two gnd-points.....
Yes, and I would say that it can only be caused by an uneven current flow and my guess is it could be a bad solder connection of caps, filter resistors etc.....some kind of "unbalance" between the two channels. Maybe connection to the bridges......
With power on but no load......you measure 0V?
So it seems the voltage difference is caused by a much higer current on side of PCB....is my best guess.
Maybe with load measure voltage over filter resistors on both channels using your scope to see if you can see a difference......also check resistor values and the solder connections.
Ok, but if you have 0 ohm between all the Gnd-points on PCB then regardless of which Gnd-point you measure from to chassis......it should measure the same. At least in theory. All Gnd-points on PCB are connected to each other via the PCB ground plane so you should not have any voltage drop in that ground-plane. Of course the world is not ideal....but here I think it should be "ideal enough".
Maybe try the DiyAudio Store universal PSU PCB next time
I can only confirm. All audio gnd points on both amplifier boards are 0R (cheap meter shows 0.3R) All gnd audio points to the chassis are 10R. Maybe I will ask the designer in his thread.
There is also the question of the difference between the Ishikawa and Mountain View cards. Is it possible that the PSRR of the amplifier changes depending on the type of input card and the power filtering requirements increase?
Yes, the symmetrical input boards will usually have better PSRR and Ishikawa is one of those. Also the opamp based input boards should be good at this. The best opamp board is the new IPS#7 which has additional filtering for the power supply "on-board".
Looking at Mountain view......it does not look symmetrical.....but better the designer of this board tells how good the PSRR is. But according to your own findings there is a difference.
You've dedicated a lot of time to this. Well done.
Excellent - then it's not the power supply in isolation. You've essentially ruled that out. Leave it alone.
Then there is nothing to look at most likely with the left channel in isolation, but you can double check.
Yes, the right channel amp board is possibly 'polluting' your ground(s) with a few mV.
You've done this:
Amp Board L => PSU L => 0V across Audio Ground and Chassis Ground
Amp Board R => PSU R => 3,4mV across Audio Ground and Chassis Ground
Now try this if you'd like:
Amp Board R => PSU L => You should get 3,4mV across Audio Ground and Chassis Ground
Amp Board L => PSU R => You should get 0V across Audio Ground and Chassis Ground
If that's the case, then you now have another data point to steer you toward focusing your attention on the right channel amplifier board to see how it may be 'injecting noise' into your ground(s) and/or if there is some other issue.
You've done this:
- The diyAudio First Watt M2x
