So many DACs, which to choose
I know, it's a tough decision to desolder the small 1364, but a few posts earlier you said the rather bright sound signature my be caused by the 1364, and I think, despite nice overall sonics, it's still a bit more on the bright side. That's why I'm thinking about rolling a few other opamps.
In the worst case I think I could order a DIP version of the 1364 to put it back in, if the other opamps are not any better.
Yeah... LT1364 sounds slightly bright. Someones says slightly "hard" which I'm not sure I agree to. First step would be trying 2x LT1028CS8 which would make the mid-treble softer and cleaner, add midrange neutrality, and make bass even quicker.
Thanks, Andrea! I see what you mean about where to situate the cap -- you mean, down over one or both regulators, vs. on top of the op-amp.
Yeah....language 🙁 (but you can always learn and improve, no?)
I have a few LM4562 op-amps on hand. I have trouble seeing the difference between it and the 49720. In fact, I think at one point, the 49710 was described as a single version of the 4562 (when obviously it is also the single version of the 49720).
It's certainly OK to try it... Anyhow, the LM4562 is not the best choice; to me the LME49723 sound(ed) better in the Super Pro, and most probably the LME49725 will, too. Best sounding LME (though I did not try that promising LME49725) was the 49720HA though.
I forget, did you try an AD826? Usually, the worry with the 826 is offset current, but the 1364's is much higher....
Yeah, tried! It was...mediocre; plus, it distorted (@ 12V) on certain vocal peaks. I'd rather use the nice sounding AD8022, provided it still works well in the last Super Pro (used it in the former version). AD8022 and AD826 have around 3 uA of bias current, vs. the 600 nA of the LT1364.
Consider the new OPA1641/OPA1642 too... they look good for a FET opamp.
BTW, if I may... I'm really enjoying the DAC a lot with the Blacksheep Mars interconnect. I'm not that sure that my Audioquest King Cobra is any better overall; I really like the midbass articulation & the discreet midrange warmth, plus the clear unaggressive treble this interconnect provides.
Consider a discrete design. All op-amps sound like an op-amp.
If you have to use an op-amp, go for the good old NE5534/NE5532. This is the one most people will pick in a true "blind test". But since most people choose the op-amp based on the technical specs (And not sonic performance), you often see "racing op-amps" used instead.
It will be wrong to call NE5534/NE5532 good for audio. But it may be the least bad op-amp for audio 😕
Hahah, I'm sure you don't know much apart from the "good old NE5534/NE5532". So much for all opamps sounding like opamps. 😉
sorry to bump in with a offtopic question: I am really intrigued by my AudioGD HDAM. Its SQ changes from time to time. Does it permanently need to be in a burn-in stage ? My CD player in which the HDAM is used loses SQ if i turn off the cd player
Can you please tell us what transformer you have exactly used (type, brand, size), and do you know if the same transformer would be suitable for the CS4398?
Thanks!
Oops!
Sorry for the typo, I have the CS4398 🙂
The transformers are from Cinemag CMOQ-2H
The 'H" indicates the Hi-Nickel version 80% Nickel
Lots of us in the thread here using transformers.
This is what my Cinemags look like
