Here's a picture of my latest kanged power supply.
Great. What is the output configuration of the large board? RCRC? What value?
CRC... 470ux2 -> 5R -> 470u. There is a stepped soft start using the resistors that look like a C in an RCRC filter though. The noise if any is all common mode rejected in the OPTs...
hmm, I think my supply's MosFET has to be replaced. Connected to 6800u -500ohm - 6800u and ripple is close to 300mV/20KHz with Fluke multimeter...
My bad, it was a grounding issue. Now, ripple can't be detected (0.000V) even just with 6800uF cap (no choke, no resistor).
Thank you so much, kodabmx. This converter is awesome.
And no sag. The voltage is as it should be. 18.9V input 220V tap output = 346V with 200mA load, very accurate. This is a great converter with adjustable voltage SMPS (MEANWELL)!
You're welcome, plasnu!
It might not be as pretty to look, but it works well and it's relatively cheaper 🙂
I got the converter yesterday. I haven't had the time to hook it up, but I find some inconsistencies. The spec and title of the listing on Amazon says DC12V/24V to AC 0-220V..... My board has a 16 volt 4700 uF electrolytic across the input. It's not going to like 24 volts.
I forgot to change 16 volt cap and it exploded with 20V input. 😀
The board stopped working now, No blue light. It's not related to capacitor. It was constantly feeding 100mA/350V without FET heatsink, so I guess FET is dead, but it's not clear that this board actually can handle 24V input (440V from 220V tap)...
The controller and MOSFETs can handle the voltage, the transformer might not be happy about it
though.
I've had a few MOSFET failures (DX3205 and YP1906) and I replace them with IRF3205 and all is well again 🙂
though.
Hello,
Did someone tried this?
€ 21,73 | Transformateur de carte d'alimentation de commutateur d'amplificateur de Tube 60W pour l'entrée de AC95V-260V d'ampli de Radio de Tube de préamplificateur Audio H252
Tube Amplifier Switch Power Supply Board Transformer 60W For Audio Amplifier Preamplifier Tube Radio AMP AC95V 260V input H252|Amplifier| - AliExpress
I want to use it for my tube phono preamp.
How far from tubes should i mount it ?
How should be the way of the transformer ?
Please
In coments and feedbacks someone have builded one phono unit,but impossible to ask any question.
Please
Hello,Did you try that 60W power supply?
I didn't try it with my phono preamp because i didn't finish my project.
But voltage are 294v and 6,2v.
Thanks. I'd hoped to hear about it's reliability over time but I certainly understand having projects that get pushed to the back and never finished.
For those of you trying a DC boost module using a SG3525... Pin 8 IS your friend.
Changing 1uF to 22uF will allow most SMPS to start this into a large capacitance.
Hi, a lot of good information here.
I know this is a rather old thread but if possible, could you provide a block diagram of the finished power supply? I think that would sum up the work you’ve done on this project in one place and helpful to people who want to emulate your design. A graphic such as that would likely show up in a Google image search and would draw more readers. I know providing links for each module may be a lot of work, and perhaps too much to ask, so even just a model number or other identifying information would be welcome.
Thanks.
Thanks.
There's not really a finished version - it's just as simple as taking 12V, getting DC-DC boost and kanging them together.
This one works well for preamp/phono/headphone/low power amplifier: DC AC Converter 12V to 110V 200V 220V 280V AC 150W Inverter Boost Board Transformer Power(6.5)|dc-ac converter 12v|dc-ac converterinverter boost board - AliExpress
This one works well for mid/high power ~50W-100W per channel 500W DC12V To AC 18V 0~160V~220V~380V DC To AC Inverter Pre amplifier Boost Converter Module|boost inverter|inverter acac boost converter - AliExpress
There was a 1000W unit, but it's not available now.
- Power Supplies
- Kanged switching power supply for a tube amp
