Heatsink question
Jason:
I guess U got your sinks afterall. It's about time! where did you get them anyway?
I like your idea of air channel. It reminds me the impulse ventilators in underground car parks. I guess it migth work.
Actually I thought of something similar for PC cooling, without massive heatsinks, of course, only noisy fans and pipes.
Take some temperature readings with and without your gadget to see how good it is(use yourgadget versus fans only)
JasonL
I ordered too a a pair of aleph 5 boards just like yours.( I couldn't resist) what kind of heat are we talking about without any fans? I don't like fans in amps very much... could we be under 60º with your heatsinks?
see..
This is how Borberly and Welbourne Labs recommended to mount transistors in desins like that. You have to consider that Mosfet might have 80 deg C or more and it may be too much for PCB.
You don't have to use wires, you can trim the PCB so it doesn't touch devices. OTOH that method must have been check already and nobody seems to complain.
I've seen fets mounted the way JasonL shows. It can be done, wheather it's the best way I dunno (probably not). But I don't see them heating the board up that much. Afterall you're trying to keep them cool, and even though the junction temp between the fet and heatsink will be rather high, they are to-247 devices so the opposite side will be much cooler due to it being insulated.
And this is how I mounted FETs on my A75 boards. The trick is to run the traces in a top layer, so there is no problem to solder mosfets.
Coulomb you wouldn't be interested in those boards?😉 Double sided, custom designed, assembled and tested. Same resistors as seen in Mark Levinson equipment.😉
