ecc99 - 6C19n PP, (6S19P)
I always implement a time delay on my +B which is a very simple little relay driver circuit. My approach is always to make everything as automatic as possible in order to avoid user error. One transistor, two caps and a few resistors is all it takes.
I have family who use my amp and they get annoyed enough with the complexity of my whole system to not be prepared to deal with two on switches. I even have it wired such that my Preamp on switch controls a none fused jumper mains lead to my power amp - that way one press and everything comes to life in a nice safe sequence.
Shoog
hey, a redrawn schematic
just silly, but I thought it looked better this way 😛
ok
I have looked at Edcor trafos, and several others
ok prices, but shipping, custom and taxes eats on any bargains
I decided to better use the exstra expences to get better quality
or at least trafos with optimal specs
I contacted the Dutch trafo company AutomaticElectricEurope
by making it simpler I could get ok prices from them too
that means potted PP C-core OPTs without UL tap, and lowish powerhandling
multi tapped main supply trafo without heater winding
and center tapped 5A heater trafos with both 6.3V and 6V CT
regarding interstage Im in contact with Per Lundahl
I cant get any further until I have all trafos
due to long delivery time this thread may on hold for a while
maybe a month or two
as said, this is a winter project
and hopefully by then I may have forgot how much it costs 😛
see you later 🙂
cheers
btw, am I right presuming that ripple voltage on each coil is about half of total, when series connected, as shown in schematic ?
I suppose that what is said in Lundahl spec sheet
quote
ripple voltage is approx. 0.42 x input voltage
http://www.lundahl.se/pdfs/datash/1685.pdf
though, I still dont know which to choose
I get a bit confused when it says recommended DC current
well, in my book it means the closer the better, or ?
maybe to load it better ?
any ideas which to choose ?
hmm, I need to post this, so I dont forget it
C3g has huge gain in pentode
and only slightly less in UL
ok
I need to deal with that
looks like my IT may be something like 4:2+2
in other words, its a 2:1 step down configuration
and next move, away with cathode decoupling cap
additional info
http://www.diyaudio.com/forums/tubes-valves/174449-understanding-cathode-decoupling.html
http://www.angelfire.com/electronic/funwithtubes/Basics_05_Multigrid.html
http://www.diyaudio.com/forums/tubes-valves/149195-whats-advantage-e-linear.html
Revintage, we/you "found" a way to do the cross referenced BlumleinGarter with interstage
I can see why it was needed, with the relatively small resistor coupling
But if we look at Broskies active BlumleiGarter version
Resistors to ground are much larger
Wouldnt this not be exactly what we need, loading the IT secondary
or what am I missing ?
hey Revintage, nice to see you are still around
my latest version
I dont know, but I have a lot more variations
The last one I did twice, without knowing
but my first thought was hey, drawing the same schematic twice within minutes, without knowing, it could mean thats how it should be
but its probably just stupid, and I dont know for sure, as usual
whatever, trafos are still the same
and I cant do nothing but wait
In the meantime Im looking at the weird tube OPS JohnBroskie is doing right now
And he has promissed more on the subject tube OPS
hey, I just got trafos, and shot a few pictures 🙂
