Doug Self Preamp from Linear Audio #5
Hey guys,
I should receive my boards by the end the week.
Does any of you could point me to the right FDP files for front and back panels?
I'm kinda confused about which are the right ones since some people noted that there are some mistakes on some files.
Did any of you use another case than the slimline 1U? I'm not sure my wife would like that case in our living room but I don't really know how to adapt the FDP files so that they fit a galaxy case.
Thank you
The band shows the outer connection of the foil and can be used to shield the internal part of the cap from hum/noise pickup if you connect it suitably.
For example if the cap were across an audio input to ground you would connect the band to the ground end. If it were a feedback cap across an opamp output and input then you would connect the band to the opamp output to make use of the low impedance at that point.
