PCB Kits Shipped
Hello all,
As of this morning all kits ordered in recent weeks have been mailed. Those going to the US should receive them in the next couple of days (some already have them). Those going overseas should arrive as soon as next week.
For those interested, I do have a few kits on hand.
Hello all,
Nice pot knobs, Carl 🙂Good news!
The last parts needed for the 'DSelf Preamp PCB kits' arrive Monday. We will get them packaged up and shipped within a few days. If you are looking to buy a kit,now is the time to do it.
Do you have the part numbers?
"Nice pot knobs, Carl
Do you have the part numbers?"
Those gold knobs are from AliExpress. They sell cheap by the bag full.
Hey guys,
I should receive my boards by the end the week.
Does any of you could point me to the right FDP files for front and back panels?
I'm kinda confused about which are the right ones since some people noted that there are some mistakes on some files.
Did any of you use another case than the slimline 1U? I'm not sure my wife would like that case in our living room but I don't really know how to adapt the FDP files so that they fit a galaxy case.
Thank you
Thank you
Hello all,
Late to the party...if there are extra kits, I'm in for one. Thank you!
"Late to the party...if there are extra kits, I'm in for one."
We have them! Please check your inbox. I sent you a private message.
Hello all,
Received boards today...thanks 😀
Good news!
Quick ?.... What was R48 for? Thought I was going mad
Just curious
Scott
Quick ?.... What was R48 for? Thought I was going mad...It's a 47ohm res. There is no spot on the board for them.
Just curious
Scott
+1
I searched through the threads and the only thing I came up with is it was an older version V1.2 shows it, that got left in the BOM...
Almost done building it, just waiting for a few parts...
Doug Self Preamp from Linear Audio #5
"What type of opamp is used in the power supply?"
Those are NE5534AN opamps. They are described in the power supply schematic
Thanks!
Question about the Polystyrene caps...(1000 and 1800pf)
I've never used these before and the ones I received have a red band around one end. Does this matter which way they are installed? The schematic shows non-polarized.
The band shows the outer connection of the foil and can be used to shield the internal part of the cap from hum/noise pickup if you connect it suitably.
For example if the cap were across an audio input to ground you would connect the band to the ground end. If it were a feedback cap across an opamp output and input then you would connect the band to the opamp output to make use of the low impedance at that point.
- Analog Line Level
- Doug Self Preamp from Linear Audio #5
