Assemblage Power Amp
New beefier layout 🙂
  • Assemblage layout.pdf
How can I implement a CFP VAS ?
Replace Q18 by a complementary-feedback-pair. But think about it? is it needed (in this stage) to complicate things? how is it as it is how? (the last 'how' was added for symmetry, but then it complicated the sentence, you could ask yourself 'was it needed?' and 'how is it as it is how?') 🙂
Hi bimo
Welcome a thank you for your intervention.
Unfortunately I do not have the trannies you used in my library.
Would you care to do the same sim using the stock components in my schematic (post 84)?
Bias current should be around 180mA in each output transistor.
Hi Ricardo,
I would recommend that you use other type of output transistors, (D44h/D45H) have very bad S.O.A (safe operation area) at 35 Volts they can only take 400mA, for example a NJL3281D can take 6A for 1 second at 35 volts and 4A at DC, almost all audio transistors from toshiba, sanken, on, fairchild or magnatec have very good S.O.A. and will be more reliably.
Other thing that I strongly recommend is the use of a small inductance (1uH) in parallel with a 4.7 resistor at the output of the amplifier, not using this inductance is a mistake that I have made myself some year ago, the capacitance from the speakers cables can make the amplifier oscillate, this oscillations are difficult to spot but the sonic degradation is very audible, I only discover that problem because when I where using one type of speaker cables the sound was very good but switching to other cables the sound become more fatiguing and veiled, adding the output inductance on that amplifier resolve the problem and the amplifier sounded much better.
Other thing that I would like to show is this images that represent the gain of the CFP pair and the gain of an emitter follower with a 4R load at various quiescent current values, as one can see the CFP pair have an abrupt change in gain at the crossover region.
As far as i understand a simple EF stage has lower gain change in the crossover region then a CFB stage.
The CFB stage has that gain change in a more narrow region though.
Sergio, in your simulation two resistors are missing that are in Ricardos amp.
I do not know if that makes any difference.
It could be beneficial to put emitter resistors to PSU in the output transistors.
