Alpha Nirvana 39w 8ohm Class A Amp
Hi Gill,
The amplifiers that we used in our listening sessions during the last years were:
KT88 IT PP, First One 1.4, Juma Cubie2, First Watt F5, DartZeel clone, Alpha 20, FirstWatt Sony vFet PP, USSA3, LM-608IA 845, Alpha Nirvana
Hi Anand,
Yes, CLC is so much better than CRC, easy to compare in Duncan PSU Designer.
I had read your subjective review and that gave me the encouragement to finish this amplifier before starting another project 🙂
Hi X,
Yes, don't skimp on the power supply, after all, an amplifier is a modulated power supply 🙂
This Alpha Nirvana is a keeper!
Happy New Year!
What chokes are these? Do you have a preferred supplier?
The chokes are from AE Europe, they're located close to me.
The specs are:
10mH 0.07 Ohm
5A DC
WxDxH 80x70x60mm
Another good candidate is the Hammond 196Q2, with the dual coils in parallel you have 10mH 0.12R
single: 20mH 2A 0.24R
parallel: 10mH 4A 0.12R
series: 40mH 2A 0.48R
Grts,
Danny
And thank you Danny for building that AN!
This is very encouraging news....
Perhaps I should accelerate the next AN version!
Happy New Year to, to Bernard, your families and indeed the entire DIY family!
Let us hope 2025 is a good year, or perhaps we avert war...
Hugh
Happy New Year everyone!
Greetings, Hugh. A new Alpha Nirvana variant? Very cool. It already sounds wonderful I am not sure how it can be improved.
And here's the LTspîce sim,
it's all standard except for the feedback resistor I used 1800 instead of 825:
lowers gain and better 4ohm compatibility:
FFT on 1800 with 4ohm load is the same as 825 with 8ohm load
Output transistors are FQA40N25 and FQA36P15
I'm impressed with this Alpha Nirvana amplifier 😯
It's an open 3D window on the recordings, therefor you need good recordings.
Bass is controlled and detailed, even low bass 20-30hz is amazing,
Instruments and voices layered, easy to pick or follow one.
When there's holographic info you'll get it n spades,
Perfect, except for some recordings 🙂
The power supply is a dual mono with Toriody transfos, LT4320 bridges and CLC.
For the Alpha Nirvana I used bulk foil resistors for the critical positions and Isabellenhutte PBH as source resistors, other resistors are cmf60/rn60
Input caps are Clarity cap PUR, the rest Muse ES, Elna Simic and Jupiter Cosmos wet capacitors.
Happy New Year !!!
Please excuse the ignorant question, but what is the purpose of 6 transformers in what appears to be 2 stages ?
TIA
Reactions: otto88
Sadly I cannot identify the differences between the present AN39 and my concept for a 'better' mousetrap.
Certainly it would be great to have a Class A develop more power and reduce dissipation, that would be nice.......
Unfortunately most of my great ideas come to me while standing under the shower in early mornings; but tragically a couple of weeks ago my hot water system collapsed so my bright ideas are on hold..........
Happy New Years to DIYers, I owe you all gratitude for so many of you building my designs. Danny, those inductors very likely make all the difference to the sound. Very well done!
Hugh
