Acoustic Horn Design – The Easy Way (Ath4)
Kind of unrelated, but I asked chat GPT to write software that output a biradial horn flare curve. [...]
# Calculate the flare rate coefficient
k = math.tan(exit_angle) / throat_radius
# Calculate the corresponding radius values
r = throat_radius * np.sqrt(1 + (k * x)**2)
The quoted formula represents a simple (infinite) OS contour.
I'm not sure about the rest - the mentioned cutoff frequency and radius, I doubt it has any sensible use.
I'm having another minor issue that using the import curves script in fusion 360 is resulting in a horn of 10x the size of the modeled horn. This is easy to fix by just scaling the sketch.
If you used Grid Export include Scale = 0.1 fusion likes to default to cm.
GridExport:f360 = {
ExportProfiles = 0
ExportSlices = 1
Scale = 0.1
Reactions: 1 user
I'm (still) having problems with fields. I've started ABEC3 in windows 8 compatibility mode (on win11 machine), but this still doesn't look right:
Higher SPL on the back...
Anyone any idea what is going on and how to fix that?
Here is the ath file, btw:
Code:
R-OSSE = {
  R = 225 ; increasing nr 2
  a = 30
  r0 = 12.7
  a0 = 15.5
  k = 1.2984
  r = 0.5124
  m = 0.806909
  b = 0.31678
  q = 2.9633
Mesh.LengthSegments = 40
Mesh.AngularSegments = 64
Mesh.SubdomainSlices =
Mesh.ThroatResolution = 4
Mesh.MouthResolution = 8
Mesh.InterfaceResolution = 5
Mesh.RearResolution = 15
Source.Shape = 1
ABEC.SimType = 2
ABEC.MeshFrequency = 1000
ABEC.NumFrequencies = 40
ABEC.Abscissa = 1
ABEC.f1 = 200
ABEC.f2 = 20000
ABEC.Polars:SPL_H = {
  MapAngleRange = 0,180,37
  NormAngle = 0
  Distance = 1.5
ABEC.Polars:SPL_V = {
  NormAngle = 0
  Inclination = 90
  Distance = 1.5
;ABEC.SphericalField:1 = {
;  Radius = 0.5
ABEC.AxialField:1 = {
  Inclination = 60 ; [deg]
  Radius = 0.4 ; [m]
  z0 = 0.0 ; [m]
  z1 = 0.75 ; [m]
  Resolution = 10,20,50,30 ; [mm]
Output.ABECProject = 1
Output.STL = 1
Report = {
  Title = ST260BLD
  PolarData = SPL_H
  ;Width = 1200
  ;Height = 900
Joined 2004
For an axisymmetric horn there's of course no need to do it with a full 3D mesh.
In a CircSim mode (ABEC.SimProfile = 0), to add a field insert something like this into observation.txt:
Code:
Nodes "FNodes"
  Scale=1m
  1  0.0 0.5
  2  0.7 0.5
Field "Field_1"
  RefNodes="FNodes";
  MeshFrequency=8kHz
  AnalysisType=Pressure; BodeType=LeveldB; StepSize=3; Range=48;
  Alpha=0.9
  601  1 2
- BTW, this is the same waveguide solved as a full-3D mesh (~2700 elements) and in CircSym mode:
Reactions: 1 user
Iteration of my shaped cabinet with "WG v.4 - The Rising DI"
Linear DI +4dB 1k to 10k
Charts are wg in cabinet only - no LFSource
1st watt friendly design
Initial look - 10 points with following settings. Running 40 points over night.
Code:
Mesh.AngularSegments = 100
Mesh.LengthSegments = 24
Mesh.CornerSegments = 5
Mesh.ThroatResolution = 2.5 ; [mm]
Mesh.MouthResolution = 7.0 ; [mm]
Mesh.InterfaceResolution = 7.0 ; [mm]
Reactions: 1 user
I see 8 points, linearly spaced between 200-16000 Hz, i.e. with 2257 Hz step between them. This is way too low, as there's almost no data below 5 kHz.
- One feasible option is to reduce the mesh resolution considerably and repeat the calculation for the lower (<5k?) band only, with a higher number of points and with log step.
Reactions: 1 user
