50w Single-Ended BAF2015 Schade Enabled
@ Dantwomey
Good price for such large capacity, hope quality are ok as well.
After diode bridge first cap can be small ~ 22000 uF then R ( big power wirewound resistor )
next 120 000 uF and L (choke) and one more 120 000uF and is plenty.
Two rails = 0.524 Farad ! Do You need more ?
My psu be 220 000uF per channel.
Bigger capacitors give bunch of storage energie available.
Too much not mean better sound.
BTW Chassis with heavy heatsinks cost a lot.
Summer climat in France and run of 50 watt´s in Class A is a " Coldcut "
Recommended voltages for C1,C2, and C3?
Dan😱
OK for IXYS amp build this one , is tested Zen Mod version and work like charm with multiturns trimmer 🙂
What consumes most of my time is I'm a classic over builder. All of my builds I hand machine the cases usually out of 6mm aluminum plate. This and the fact that I only have a few hours a week to indulge in my hobby makes for long build times. On a most positive note, this gives me more time to come up with creative solutions for layouts, etc. Right now I'm thinking of building something that will hold my capacitors, inductors, and bridge rectifiers in some sort of compact multi-tier package that will make both electrical and aesthetic sense.
Dan 🙂
So much fun, I think I will join the party too. I can't have too many Class A amps.
I just purchased two large heat sinks from a Canadian ebay merchant. No worries about Canada Customs or brokerage fees.
The heat sinks are 11.75'' x 8.875'' x 5.25'' and weigh 20 pounds each.
I will build them with THF-51S in monoblocks. My Hammond inductor loaded VFET L'Amps sound great. CCS loaded THF-51S with much higher power should be fantastic.
The heatsink will dissipate heat through convection and radiation. Convection may not be the best with the tight spaced fins but the large bulk of fins will radiate quite a bit of heat.
I will find out when I get the amps running. But I am encouraged by Soundhappy's amps with similar heatsinks.
