An accurate statement?
Class A amp power supply
https://www.diyaudio.com/forums/images/diy/store/board-documentation/P-PSU-1V30/P-PSU-1V30-schematic.pdf
Dan
Regulated (constant) voltage, not current.
All of the Nelson Pass class A amplifiers,
around 50W stereo, use a CRC unregulated supply.
Dan
To get the ball rolling on this project, I'm seriously considering a couple of 60V ebay switchers.
I can get one switch mode power supply cheaper than the price of just one capacitor and I was thinking of getting 8 of those capacitors (not cheap).
You're right about the capacitors. Here's what I'm starting with,
4pcs NEW KENDEIL K01 22000UF 75V CAP AUDIO QUAD303 QUAD 405 UPGRADE NAIM!63V REP | eBay
Dan
So.............looks like R1 to R3 and R7 to R9 are 1/2 watt. R4 and R5 are 10watt and the sole survivor R6 is 3 watt.
Dan
P.S. I wouldn't mind finding some CPCC10's. Nice and compact. Speaking of compact. These look nice too. TNP10SAR200JE Ohmite | Mouser Canada
Dan
Dan
Too bad someone didn't do a PCB. With the right components this could be simple, compact, and neat. Everything Father Pass looks for in a design?
Dan
CCS boards can be the similar concept but power stage pcb with Tokin SIT need design modyfications.
Yes, but I am a mere mortal compared to Mr. Rothacher. That's why simple designs have so much appeal.
Dan
I'm going old school all the way! Massive toroids! 5 Farads of capacitance! And in the end an class A amplifier that weighs more than a small car!
5 Farads Too goood
Do You go with Kemet caps brand ?
https://www.mouser.fr/KEMET/Passive...MIlLLmveyb4wIVxRd9Ch1hLQdPEAAYASAAEgJCp_D_BwE
Some heavy duty bridge rectifiers
VBE60-06A IXYS | Discrete Semiconductor Products | DigiKey
Bought a few of these out of curiosity, but sadly, the cheapest Chinese bridges sound better to me.
Amp at 3.2A run HOT weight "" if stereo version make him on small wheels are not one extravagance
I have enough 'parts' to make a monster stereo amp!
Did you put a Quasimodo in front of them?
- 50w Single-Ended BAF2015 Schade Enabled
