50w Single-Ended BAF2015 Schade Enabled
TF-3 are good candidate as input transformer.
For the moment I don't have Cinemag or Jensen to compare but all are high audio quality.
My progress. Should have used PCB boards with traces. P2P is tedious. 🙄
Haha P2P 😀
My was 3 small amp. sub circuits :
1 | CCS
2 | Audio path
3 | Bias voltage
transformer was soldered directly to RCA input
Sometimes is good time on the bench.
Printed schematic on the paper then connection I finished is marked OK before the next one step.
I can visualise more easyly all P2P connections who is ready done 🙂 Have Fun
Even though it's late in the thread Zen Mod suggested I stick my nose in over here. After a brief review I'm intrigued. I believe I might have enough heatsinks for a good start. Hmmmmmm................... 😉
I would definitely go all out with a 1kW three phase 600v version! Then I would sell the fireplace in my basement.
Dan
How is the 10000uF output cap value calculated? Is it the output impedance in parallel w/ the 220R resistor as an RC circuit? If so, that would give a rolloff (-3db) around 14hz on the CCS tap and 24hz on the middle tap, correct? But this measures flat out to 10hz. I guess I'm missing something. Just want to know where it comes from.
*Edit, I guess it would be 220R + 22R in series and then parallel w/ the output impedance. Doesn't affect the numbers though.
