100W Ultimate Fidelity Amplifier
APEX P36
Thanks!:)
If it's possible parts ,parts numbers?
Hi Thimios,
Here is a stab at part values. BC560 is the wrong pinout for this layout. I used 2SA992 but maybe something else is better. There are two resistors that are not in the schematic so I gave them a zero ohm. Maybe Mile can say what they are. Please check against schematic in case I have errors. I guessed on the LED circuit and there is one cap on the bottom right that is not in the schematic. Anyway, I hope this helps.
Hi Thimios,
Instead 7k5 and 0R you can use 6k8 and 680R.
Thanks!:)
OK thanks. Do you know the value of the three caps on the lower edge of the layout? One across the +12V input, one across the ground circuit although it is connected. The other one is on the right and it is not indicated what it connects to.
Thanks, Terry
