What makes this better than the MM28?
Cascode in VAS
Thanks!
If it's possible parts ,parts numbers?
Hi Thimios,
Here is a stab at part values. BC560 is the wrong pinout for this layout. I used 2SA992 but maybe something else is better. There are two resistors that are not in the schematic so I gave them a zero ohm. Maybe Mile can say what they are. Please check against schematic in case I have errors. I guessed on the LED circuit and there is one cap on the bottom right that is not in the schematic. Anyway, I hope this helps.
Hi Thimios,
Instead 7k5 and 0R you can use 6k8 and 680R.
Thanks!
OK thanks. Do you know the value of the three caps on the lower edge of the layout? One across the +12V input, one across the ground circuit although it is connected. The other one is on the right and it is not indicated what it connects to.
Thanks, Terry
Wow, even more transistors.
All transistor have lower price than one good OP amp.
Hi Mr. Mile,
BC550C/560C is obsolete now. Could you please suggest alternatives without compromising on the performance.
BC547/557 are available but they are not 'Low Noise' version.
This would even help us in building A40, SR200, P30,etc as well.
Sha
Sha
Phono MC Preamp
please read the forum rules regarding posting in English only.
Try bc546 bc556 I've used them on many amplifiers and get good results and they have good pressure resistance.
试试bc546 bc556 我在很多个放大器上使用过他们,并获得不错的效果,它们有不错的耐压.
Noted. Thank you
- 100W Ultimate Fidelity Amplifier
