AmyAlice: DC filter for SMPS, using 2 feedthru capacitors + SMD assembly. max 3A & max 48V
i did a test at my class D journey and test the over swing at a TPA3255 chinese amp 2018. generally the SMPS should go in hick up mode if the current exceed the start up current. (pip pip...you can hear that).
big caps:
additionally if you use a big cap , e.g. 10mF or 33mF you will have a big overshoot. this is because if you "request a big current by an amplifier" you get about 5V more at voltage on scope. instead of your adjusted voltage. so that means that the regulated internal circuit have problems with this big cap. that can shoot the caps on the amp pcb.
i remember that XRK did a trick if he use a SMPS and use a CRCRC like nelson did at the ACP. if you have too much ripple voltage from your SMPS you can use a CRCRC and use smal lytic caps for that.
kr chris
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_originamp_2x1000uF_scope on a...jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_originamp_7x4700uF_crc_scope ...jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_1300mVrms input burst_originamp_2x1000uF_scope on ...jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_1300mVrms input burst_originamp_7x4700uF_crc_scope...jpg
Reactions: gary s
hick up tests:
I found the info on those dual cap mult. pcb's.
I am still puzzled why the 22,000uF input caps on the cap mult. pcb's have no effect on the LRS SMPS - after all they are sitting directly on the SMPS output. I will take you word they are fine however - will try this for myself.
Can I ask - how does your M2 sound with this PSU setup?
Started practicing my smd soldering for my F5M with smps similar to @birdbox
Blue tape pcb’s will be for the negative rail.
Those pads are nice and big for first time SMD soldering… more to follow.
Eventually I plan to use an AmyAlice for every piece in my system that uses smps… ACP+, DAC, Wim mini and el cheapo phono pre-amp.
Best,
Jose
Hello, I have kind of a newbie question:
I am trying to size an appropriate smps to use in a project. Can the output A of the smps be higher than 3A to the input of the AmyAlice board. I understand the 3A max on the output supply, but was not sure of the input from the smps.
Thanks,
MM
Thanks,
MM
Hello,
The easiest way to avoid any problems is to double the power required.
If you need for example, 12V at 2A, or 24W, use a AC-DC power supply that outputs 50W. It will remain cold, the voltage will not change even in the event of a current spike and the ripple will stay low.
Stef.
The datasheet of the SRR1280A-100M shows a saturation current of 6.3A, well more than 3A.
I presumed the limit was due to either the current capacity of the traces or R1 / R3. For example, for 4A,
Voltage drop 0.1 x 4 = 0.4V
Power 0.4X 4 = 1.6W which is too close to 2W.
Perhaps Mark could let us know.
ray
  • Thank You
Reactions: chermann
I received this question recently, would anyone like to offer their experience, advice, opinion, or suggestions? I think it's best to encourage everyone to participate in the discussion and contribute ideas & thoughts if they wish. That's why the Forums exist, after all.
Can I series connect 2 kits of AmyAlice Vout of kit 1 goes to Vin of kit 2. Any pros and cons of doing it? I tried this scheme to my Aca mini using diyaudio store filter kit and running.
