Alpha Nirvana 39w 8ohm Class A Amp
I am now listening with 0.22R power resistors and the bias being 0.710v with the heat manageable over my heat sinks. The gain and power is very good with my 4 ohm load PAP speakers and for the first time I can actually listen in low volume without loosing any of the details paired with the HPA clone preamp and Aya 5 being the source.
Will it give me any benefit in changing the resistors to 0.15R to increase the bias apart from more heat?
This (bias current) is a very interesting Qu! 👍
I am now listening with 0.22R power resistors and the bias being 0.710v with the heat manageable over my heat sinks. The gain and power is very good with my 4 ohm load PAP speakers and for the first time I can actually listen in low volume without losing any of the details paired with the HPA clone preamp and Aya 5 being the source.
I assume - having 4 ohm spkrs - you built the AN4R?
If so - surely 0.12R is the recommended Source resistor value???
Now, Hugh said this:
I do not believe in increasing quiescent if your amp is NOT clipping.
There is no benefit if your amp is free of clipping during the listening sessions.
HD
This makes a lot of sense; I recently increased the Source resistors in my AN4R from 0.12R to 0.15R - ie. reduced the bias current ... in order to reduce heat output (so I could use the amp for more months of the year).
There does not appear to be any resulting decrease in SQ - and I am still not clipping with my spkrs.
Listening to music at high volume, one would not be able to distinguish the weakness of the amplifier due to low quiescent current, harsh music tone.....?
I guess it depends on:
* how loud is 'high volume', and
* do your spkrs drop below 4 ohms?
Certainly, at my listening levels and with my spkrs (active - so, having no passive XO ... a fairly constant 4R) ... there is no harshness.
Reactions: manniraj
Hi my friend Andy .
how do see this? from clip led? or from test gen and scope with load 4Ω?
I don't have any diagram response chart of these speakers, for this and I went to 2.6A to be sure ....but my ears also heard this at high volumes like listening to mp3 vs flac ....hahaha
Hi my friend Andy .
First, I measured the clipping level with a resistive load from 6 ohms down to 2 ohms (and posted my results). From memory, the red clip LEDs came on before the scope showed a clipped sine wave for 6R, 4R and 3R loads - but at 2R load, the sine wave clipped before the red LED lit up.
Listening with my spkrs, I did see the red LEDs light up briefly, with some tracks.
Then, on Hugh's suggestion, I changed the +ve rail mosfet for a BJT - and, unfortunately, this stopped the clip LEDs from working! 🙁
I don't have any diagram response chart of these speakers, for this and I went to 2.6A to be sure ... but my ears also heard this at high volumes like listening to mp3 vs flac ....hahaha
Mmmm ... you would seem to listen much louder than I do! 😀 Or your spkrs are less efficient than mine. 😵
Hahahaha yes....Proson or JWS Speakers inside i think....
