DIY Class A/B Amp The "Wolverine" build thread
^ I don't disagree. I admit that I saw the photo with the "series" configuration buttons pressed and your proposed wiring, and I reacted too quickly without noticing your careful addition of "independent" in the text.
If it's better to remove the posts and following conversation after, I'm totally fine with that. I have no issues with admitting / owning an error. Cheers.
And even now you still don't understand why that message of you was so wrong. RTFM you said. Yes let's just do that, practice what you preach. Read The ******* Manual. I give you a pointer to the most relevant part below.
Note that on this unit the master is at RHS as pointed out in the manual page 2 - 4.
Hello OmeEd,
My first comment was "It works in the way expected." In other words, as I described above.
The second part was addressing what I read in the manual (and excerpt you posted), and also applying it to normal bench practice. That is, we do not normally use the earth ground at the power supply. I gave the reasons why this is not normally done as well. Just for completeness.
Your point?
Actually, I was merely asking what your objection was to my post. So I ask again, what was your point. You responded to me.
Frankly, you are aware that moderators simply post as normal members unless we make it clear it is an official post, normally using this symbol: :cop: Which I have not done. To the very best of my knowledge, I am acting accordingly as a normal member who had their post questioned.
Is this Luxman amp class A?
No , AB with a EF2 Sanken output pair.
I studied the Luxman's -
most are a deluxe version of the Hitachi topology (below 1). The input stage is the typical Wolverine fair ,
the VAS is different (differential w/ current mirror) . Compensation is lead - lag + VAS miller (C707,711,717,719).
Close in THD to Wolverine - without the EF3 !
"Typical Luxman" is similar to the "Symasym".
(below 2) is a deluxe LUX .... .1PPM ! Add a Widlar mirror and the Wolverine input stage = lower than the Wolverine ! ZERO distortion.
Almost 15dB more gain margin at 20Khz without oscillation. The only circuit that can beat the Wolverine I know of.
Luxman does not need to be class A with that advanced feedforward 2 pole setup.
OS
What Luxman model is that one?
That's a newer one - the A-007. Just a 50W Sanken TO-3P output stage.
The bulk of better old Luxman designs (LV series - 105/205) use the Wolverine IPS + a Hawksford cascode - w/LED's.
The luxman series is actually a Wolverine "grandparent" design. Many of my designs were inspired
by LUX tech. They have some GOOD engineers !!
(BELOW) ye olde (1973) M2000 amp. LUX Cult following - same as a sonance 260 -20 years later.
I've run this on the Wolverine OPS , People forget ..... the Wolverine can run ANY input stage!
OS
The LUX 505/507-9 looks exactly like a typical Wolverine build - 6000$ perfect amp.
EF3 with 3-4 pair Sanken outputs. Most of these elite units are <.001% THD.
Similar circuit and construction to a Wolverine.
One could fetch $2-5K for a well built Wolverine. I only spent 250$ with spare parts for my
Wolverine to get a 2K$ amp. People underestimate the value of this DIY offering.
Stuart's monoblocks are easily worth 3-4K each !!! Yikes....
Can't forget the HAND WOUND (by a Japanese craftsman) 600VA trafo - (below 2)
Caps are custom (samwah - korea) 10Kuf 71V beauties !
OS
Hi OS,
Marantz and a few others used vapour phase heat sinks. The Lux M-02 is one example. The odd service guy blew products up since "standard service position" was the unit on it's side. Those heat sinks must be level to work properly.
I don't like these heatsinks. In practice, the fin to pipe connection is poor, and the fins are not thick enough to be effective. They were less expensive and lighter than standard heat sinks. These were abandoned later. I think another reason they were used was to make slim case as was the style in the early 1980's.
Also shipping weight for mass production would be a huge cost saving.....
You have alot of knowledge from a service point of view Anatech, I take it you spent quite alot of time on the soldering iron ?
OS
aren't there errors in here? for example, looks like no DC bias applied at Q206 base!
