2stageEF high performance class AB power amp / 200W8R / 400W4R
Dear Toni,
400x210mm + black elox (117,65€), ...I'll do the drilling and threading myself.
Modushop heatsinks: 200x210mm 2x (91.74€) + base plate 10mm drilled + thread cutting (50€)
Reactions: astx
SA2021-NCH: case design study. Would be my first tower design if it will ever materialize ... 😉
Side panels and part of top panel are translucent black acryl so it would allow to have a look inside when LED stripes are installed.
EMI is blocked using hexagonal aluminium panels mounted between acryl and inside steel panels.
Have fun, Toni
Reactions: HRDSTL
Finally the cable finished, probably ate up most of my nerves! I'm still going to wind the choke and the first test can begin!
I still don't know how to solve the aesthetic side of the pcb, I can't get to all the pins of the transistors to pinch off them. Obstructing capacitors 🙁
Reactions: astx
