DIY ACA mini
My Google-Fu / diyA search skills are lacking. I think (but I can't find it to provide a link nor do I remember the specifics) that someone implemented a DVM readout and some front-panel mounted pots for easier alteration of their H2V2.
I dig it.
I know one good boyz
Reactions: ItsAllInMyHead
Hello all,
I have the ACA Mini board but had to source the parts myself as kits were sold out at the time of my order. I did not see any insulater pads for the transistors. The photo by 6L6 appears to apply only heatsink grease. Is the grease all that is required or should a mica or other pad be used? Thank you.
Hello all,
I used a tiny dab of grease on each FET. The heatsinks seem very effective. It takes about 10-15 minutes for the amp to fully warm up. If in doubt I would use the grease. Most people over apply it. It really only takes a little dab in the center of the FET.
Has anyone bridged a pair of ACA minis? Is it possible? if so how?
I did it and it works well. I used a simple unity gain inverter circuit with a TL071 to feed the negative side. But, you could probably use a resistor to tap the inverted signal from the drain of Q1. It looks like there is a symmetric inverted signal there. But... I have not tried it and I'm not sure what effect that would have on the bias. Considering it would be driving a 100k load plus divider resistor I'm thinking it could work
This is what I did with a TL071 and it works well. Unity gain stable and FET (Hi Z) input were the reasons I chose this part.
Someone smarter than me could probably figure out something better.
Absolutely. I also put a balanced XLR in my amps but I have no balanced source to try it with. Some people say gimmick, some say problem solved. 😎
plenty of ways to ...... paint the Fence
SE/Bal xformer
OP inverter
in this case you can't use same trick as with ACA; feeding one "phase" output to other "phase input" is possible only if "phase" (previously channel of normal stereo amp) is inverting signal (output vs. input)
Reactions: fvzeppelin
SE/Bal xformer
OP inverter
I was naively hoping that there was a simple way to connect the negative input to the sources of the input pair.
you can try it
you'll get either silence ...... or buzz ...... or fireworks
:clown:
in fact , I remember Lampizator Guru did some of his endeavors - connecting Bal signal to common anode triode stage; well, I know I'm dumb and I never understood how's that working
though, every lousy solution lacks just one element to became perfect solution - some amount of perfectly sold mythology ....... and there you have it - High End
:rofl:
(generally, you can feed one phase to gate, second phase to source, and you'll get some sort of balanced amplification, but so bad that it hurts ........ except in case that you're feeding both nodes with 0 Ohms of Rout; but in this case )
ACA mini is ready for action. I went to get a picture frame at the craft store, but ended up with this box for less than $6. Speaker posts and “ice blue” ice cube LED were in the parts box. Today I’ll test it on real speakers. It sounded great on my bench speakers. I may paint or oil the box at some point in the future.
Thanks Nelson for another cool project!!
