Wayne's BA 2018 linestage
All right, I see those speakers aren't the most popular 😛 Am always happy to hear suggestions 😉 (I mostly listen to jazz, and was in a jazz band for quite a few years. For that kind of sound, they make me happy, but would not mind trying something new as well! 😀 )
I believe the general consesus in the last posts is that your speakers are good, and that you may want to review either the choice of power amp, preamp, or both 🙂
Haha, wasn't so sure, I personally really like them, but saw a ton of very polarized reviews online, so never really sure what people think about them 😅
Input -> Amp: sounds fantastic (except just one input)
Input -> Preamp -> Amp: sounds fantastic in a different way (except for the hissing)
Input -> Preamp -> Headphones: sounds fantastic and no hissing!
Might just skip the Preamp with the amp, and keep it for headphones.
Thanks everyone!
The guys around here like and recommend speakers like you have. It's just that they typically pair them with simple, elegant, and beautiful sounding amplifiers of ~20 watts or so and ~15 db of gain (very loose ballpark numbers). Some extra gain with a linestage may, or may not be needed. Situation dependent.
I see, thanks!! 🙂 Am definitely enjoying learning about all these things a lot. So, all is good. Will try Zen Mod's suggestion of a unity-gain preamp (or buffered volume as he calls it).
The buffer(s) take care of impedance issues, that you might otherwise encounter with just a volume control between the source and power amp.
also beware that running balanced adds 6db gain. If you use source «that is a hundred times better being run balanced than single ended», according to the manufacturer, simply change the source 🙂
Reactions: aatallah
I've build this board today.
Are the parts marked with red circles in the image below without polarity?
Experimental concept of Wayne linestage with 2SK209 and JFE2140 on one board.
That helped to adapt JFE2140 to ready layout with SK209 and borrow ideas from one part to other.
Too bad I have difficulties to find both locally but have 2SK170 that simualates the best of all.
So I guess I need to start making 2SK170 ver. with J111 on CCS.
So far the best simulation achieved with BD139/BD140 on Q9/Q14 and 2SC4793/2SA1837 on Q8/Q10.
Both is ECB or reversed BCE pinout (except BD139G/BD140G).
