DIY biamp 6-24 crossover
To avoid confusion: the circuit within the yellow marker is the BIAMP 6-24 Crossoverboard from the diyaudio shop.
you don't need Rsource with upper ones, just with lower ones (CCS)
I added a resistor to CCS
counting that you have cap after each cell, no need of chasing some special DC level (output being on same level as input gate)
edit: I don't know circuit if you don't post schm or link to
I dont understand what you mean, sorry.
Here the original circuit, I want to add a additional front end and when needed modify the shown input.
@zm: I try to clear up our confusion. I am sorry!
The yellow part is the unchanged original circuit, wich is topic from this thread.
The left part is "my new" front end, for volume control and buffered.
Will this work?
@Nelson Pass: can you confirm please? No cap needed between the new frontend and the first buffer stage?
Thanks ZM and Nelson!
if arranged as that, you must keep source resistors in upper portion of buffer
observe, you'll see that buffer is practically biased ( Iq set) with source resistor in lower JFet ( CCS), while role of upper source resistor is to establish so-so same DC levels at buffer input ( upper JFet gate) and its output
yeah - if having matched JFets in range of 9mA, just keep all source resistors of same value
whatever you have in range of 4R7 to 10R
